No iio sensors detected on Framework Laptop
I used to run KDE Neon on my Framework laptop, and I had access to my brightness sensor on the path /sys/bus/iio/devices/iio\:device0/in_illuminance_raw
But on Manjaro (6.12.21-4-MANJARO) the path /sys/bus/iio doesn’t even exist.
According to Arch’s wiki, it should work out of the box (wiki archlinux: /title/Framework_Laptop_13#Ambient_light_sensor)
Is Manjaro doing something different ?
  Kernel: 6.12.21-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=12a8cd7d-0b18-4dad-bb02-63281b426e4c rw i915.enable_psr=0
    resume=UUID=d3e4f66d-3884-4420-9012-f7d47f583a3d "acpi_osi=!Windows 2020"
  Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
    wm: kwin_x11 with: kdocker,krunner vt: 2 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: Framework product: Laptop v: AA
    serial: <superuser required>
  Mobo: Framework model: FRANBMCP0A v: AA serial: <superuser required>
    part-nu: FRANBMCP0A uuid: <superuser required> UEFI: INSYDE v: 03.17
    date: 10/27/2022
  ID-1: BAT1 charge: 31.5 Wh (71.8%) condition: 43.9/55.0 Wh (79.9%)
    volts: 15.5 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
    status: discharging cycles: 21
  Device-1: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 32 GiB available: 31.13 GiB used: 6.64 GiB (21.3%)
  Array-1: capacity: 64 GiB slots: 2 modules: 1 EC: None
  Device-1: Controller0-ChannelA-DIMM0 type: no module installed
  Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 32 GiB speed: 2667 MT/s volts: curr: 1 width (bits): data: 64
    total: 64 manufacturer: Crucial Technology part-no: CT32G4SFD8266.C16FE
    serial: <filter>
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xB8
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 863 min/max: 400/2400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 863 2: 863 3: 863 4: 863 5: 863 6: 863 7: 863
    8: 863 bogomips: 38720
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
    rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
    loop
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Framework
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
    bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2256x1504 s-dpi: 96 s-size: 596x397mm (23.46x15.63")
    s-diag: 716mm (28.19")
  Monitor-1: eDP-1 model: BOE Display 0x095f built: 2019 res:
    mode: 2256x1504 hz: 60 scale: 100% (1) dpi: 201 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
    x: 0.314 y: 0.329 size: 285x190mm (11.22x7.48") diag: 343mm (13.5")
    ratio: 3:2 modes: 2256x1504
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
    GT2) device-ID: 8086:9a49 memory: 15.2 GiB unified: yes
  API: Vulkan v: 1.4.309 layers: N/A device: 0 type: integrated-gpu
    name: Intel Iris Xe Graphics (TGL GT2) driver: mesa intel v: 25.0.3-arch1.1
    device-ID: 8086:9a49 surfaces: xcb,xlib
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Framework
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
  API: ALSA v: k6.12.21-4-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: aa:00.0
    chip-ID: 8086:2725 class-ID: 0280
  IF: wlp170s0 state: up mac: <filter>
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0032
    class-ID: e001
  Local Storage: total: 1.82 TiB used: 830.46 GiB (44.6%)
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
  ID-1: / raw-size: 1.63 TiB size: 1.6 TiB (98.41%) used: 830.42 GiB (50.7%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 12a8cd7d-0b18-4dad-bb02-63281b426e4c
    used: 40.3 MiB (42.0%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: F291-0693
  ID-1: swap-1 type: partition size: 51.53 GiB used: 12 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: swap
    uuid: d3e4f66d-3884-4420-9012-f7d47f583a3d
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 145.86 GiB fs: ntfs label: N/A
    uuid: 04204C76204C712A
  ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 536 MiB fs: ntfs label: N/A
    uuid: 52AAF0F1AAF0D309
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-1:2 info: Lenovo ThinkPad Compact Keyboard with TrackPoint
    type: keyboard,mouse driver: lenovo,usbhid interfaces: 2 rev: 2.0
    chip-ID: 17ef:6047 class-ID: 0301
  Device-2: 3-9:6 info: Shenzhen Goodix Fingerprint USB Device
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 27c6:609c class-ID: ef00 serial: <filter>
  Device-3: 3-10:4 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  System Temperatures: cpu: N/A mobo: N/A
  Fan Speeds (rpm): cpu: 1470
  Packages: pm: pacman pkgs: 1891 libs: 431 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    2: https://manjaro.ynh.ovh/stable/$repo/$arch
    3: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    5: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    7: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    8: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    9: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    10: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    11: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    12: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    13: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    14: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    15: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    16: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    17: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    18: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    19: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    20: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    21: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    22: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    24: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    25: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    26: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    27: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    28: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    29: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    32: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    33: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    34: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    35: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    36: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    37: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    38: https://mirror.23m.com/manjaro/stable/$repo/$arch
    39: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    40: https://mirrors2.manjaro.org/stable/$repo/$arch
    41: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    42: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    43: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    44: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    45: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    46: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    47: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    48: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    49: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    50: http://manjaro.grena.ge/stable/$repo/$arch
    51: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    52: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    53: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    54: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    55: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    56: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    57: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    58: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    59: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    60: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    61: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    62: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    63: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    64: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    65: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    66: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    67: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    68: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    69: https://manjaro.kurdy.org/stable/$repo/$arch
    70: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    71: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    72: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    73: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    74: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    75: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    76: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    77: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    78: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    79: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    80: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    81: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    82: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    83: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    84: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    85: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    86: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    87: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    88: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    89: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    90: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    91: https://linorg.usp.br/manjaro/stable/$repo/$arch
    92: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    93: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    94: https://mirror.init7.net/manjaro/stable/$repo/$arch
    95: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    96: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    97: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    98: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    99: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    100: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    101: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    102: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    103: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    104: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    105: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    106: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    107: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    108: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    109: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
Processes:
  CPU top: 5 of 298
  1: cpu: 4.7% command: firefox pid: 153398 mem: 283.9 MiB (0.8%)
  2: cpu: 2.2% command: firefox pid: 149188 mem: 274.7 MiB (0.8%)
  3: cpu: 1.2% command: bitmagnet pid: 1021 mem: 203.4 MiB (0.6%)
  4: cpu: 1.1% command: firefox pid: 1538 mem: 592.4 MiB (1.8%)
  5: cpu: 0.8% command: postgres: pid: 154937 mem: 255.8 MiB (0.8%)
  Memory top: 5 of 298
  1: mem: 592.4 MiB (1.8%) command: firefox pid: 1538 cpu: 1.1%
  2: mem: 463.4 MiB (1.4%) command: thunderbird pid: 2467 cpu: 0.0%
  3: mem: 424.8 MiB (1.3%) command: plasmashell pid: 1291 cpu: 0.1%
  4: mem: 401.5 MiB (1.2%) command: firefox pid: 2226 cpu: 0.4%
  5: mem: 349.0 MiB (1.0%) command: psst-gui pid: 2374 cpu: 0.0%
  Processes: 298 Power: uptime: 16h 15m states: freeze,mem,disk
    suspend: s2idle avail: deep wakeups: 2 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 12.44 GiB
    services: org_kde_powerdevil,upowerd Init: systemd v: 257
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: yakuake
    inxi: 3.3.38
Hi @juanito, and welcome!
Have you tried a different kernel? Also, You don’t give much info aout the laptop, so please see:
Please also note and heed: Forum Rules - Manjaro
Those with privacy concerns: note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output. :eyes:
Hope you manage!
:bangbang: Tip for legibility: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
Thanks, I’ve updated my initial message with my system info.
I haven’t tried with a different kernel, but I’m going to look into it right now.
first: your bios is from 2022, check the vendor for a bios update and update it if avaiable.
second: enable aur. you’ll find the framework stuff at the aur.
especially these packages:
framework-laptop-kmod-dkms-git
framework-sensors-git
Ok, I updated to latest BIOS 3.20 and installed the 2 packages from the AUR.
After a reboot, I did a rerun of sensors-detect, but nothing new has been added, only coretemp is found.
I also tried to boot on another kernel, 6.12.16_rt9-1 but nothing changed either. Should I try an older kernel ?
If I manually load modprobe cm32181 (cm32181 is supposed to be the name of my ambient light sensor) and run sensors-detect, I see that /sys/bus/iio gets created but it’s only populated with empty files and folders.
is the sensord-daemon active ?
It wasn’t !
There was this error:
/usr/sbin/sensord: error while loading shared libraries: librrd.so.8: cannot open shared object file
After installing rrdtool, sensord starts:
journalctl -xeu sensord.service
avril 29 11:13:24 laptop systemd[1]: Starting Log hardware monitoring data...
░░ Subject: A start job for unit sensord.service has begun execution
░░ Defined-By: systemd
░░ A start job for unit sensord.service has begun execution.
░░ The job identifier is 5695.
avril 29 11:13:24 laptop sensord[23574]: sensord started
avril 29 11:13:24 laptop sensord[23574]: Chip: cros_ec-isa-0000
avril 29 11:13:24 laptop sensord[23574]: Adapter: ISA adapter
avril 29 11:13:24 laptop sensord[23574]:   fan1: 1605 RPM
avril 29 11:13:24 laptop sensord[23574]:   F75303_Local: 42.9 C
avril 29 11:13:24 laptop sensord[23574]:   F75303_CPU: 50.9 C
avril 29 11:13:24 laptop sensord[23574]:   F75303_DDR: 45.9 C
avril 29 11:13:24 laptop systemd[1]: Started Log hardware monitoring data.
░░ Subject: A start job for unit sensord.service has finished successfully
░░ A start job for unit sensord.service has finished successfully.
avril 29 11:13:24 laptop sensord[23574]:   Battery: 31.9 C
avril 29 11:13:24 laptop sensord[23574]:   PECI: 52.9 C
avril 29 11:13:24 laptop sensord[23574]: Chip: framework_laptop-isa-0000
avril 29 11:13:24 laptop sensord[23574]: Chip: BAT1-acpi-0
avril 29 11:13:24 laptop sensord[23574]: Adapter: ACPI interface
avril 29 11:13:24 laptop sensord[23574]:   Voltage: +16.50 V
avril 29 11:13:24 laptop sensord[23574]: Chip: iwlwifi_1-virtual-0
avril 29 11:13:24 laptop sensord[23574]: Adapter: Virtual device
avril 29 11:13:24 laptop sensord[23574]:   WiFi: 49.0 C
avril 29 11:13:24 laptop sensord[23574]: Chip: nvme-pci-0100
avril 29 11:13:24 laptop sensord[23574]: Adapter: PCI adapter
avril 29 11:13:24 laptop sensord[23574]:   Composite: 50.9 C (min = -273.1 C, max = 84.8 C)
avril 29 11:13:24 laptop sensord[23574]:   Sensor 1: 50.9 C (min = -273.1 C, max = 65261.8 C)
avril 29 11:13:24 laptop sensord[23574]:   Sensor 2: 50.9 C (min = -273.1 C, max = 65261.8 C)
avril 29 11:13:24 laptop sensord[23574]: Chip: acpitz-acpi-0
avril 29 11:13:24 laptop sensord[23574]:   F75303_Local: 52.8 C
However, /dev/sbus/iio hasn’t changed. Any further steps ?
have you already checked the section “ambient light sensors” from
https://wiki.archlinux.org/title/Framework_Laptop_16
and the given links in this article ?
there is also the
is this the correct setting ? you set the acpi-configuration to this windows-2020 behaviour. i’m unsure why you have set this. must it be ? keep in mind there is a new bios on your system now.
i would give it a try to delete this setting from the grub-config and update grub afterwards.
Can’t remember why I put that in grub, from a quick research it used to be advised on Arch Wiki, but not anymore. I’ve removed it, updated grub, restarted, but sadly with no effect :frowning:
I did follow the section on ambient light sensors from arch wiki. I’ve installed iio-sensors-proxy which refuses to run:
> sudo iio-sensors-proxy -r -v
** (iio-sensor-proxy:7088): DEBUG: 11:53:54.630: Starting iio-sensor-proxy version 3.6
** (iio-sensor-proxy:7088): WARNING **: 11:53:54.648: Not a switch [/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4/../capabilities/sw]
** (iio-sensor-proxy:7088): WARNING **: 11:53:54.648: Invalid bitmask entry for /sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4/event3
** (iio-sensor-proxy:7088): DEBUG: 11:53:54.649: No sensors or missing kernel drivers for the sensors
I don’t know if this is the chicken or the egg. Is iio-sensors-detect supposed to populate /sys/sbus/iio, or does it refuse to run because it’s empty ?
The other tool mentionned in the wiki is illuminanced. It requires to provide the path to the ambient light sensor and instruct to find it with find /sys/bus -name '*illuminance*'. Of course, there’s nothing returned by this command on my system.
sorry that i can’t give more ideas to this specific-framework laptop. i have no framework laptop. but a very good swiss-knife method would be to boot for testing in a live-iso session from a stick and check if the hardware is detected in the live-iso. that could give a first impression if it is a general problem or just a problem with your installed one.
p.s.: just a simple question ? are you on stable ?
pacman-mirrors -G
in this case it’s worth to switch to unstable. check the manjaro-wiki for switching the branches. there is no problem to switch between the branches and the check if the unstable branch works better solves very often hardware-hickups
Thanks for your help !
I tried a few distributions and all of them had iio correctly populated.
I currently have some weird issue linked to hibernation, so I disabled it and oh miracle ! /sys/bus/iio gets populated at last !
sudo systemctl mask hibernate.target is enough to have iio back.
However, now I don’t have hibernation anymore. Unmasking hibernation kills it.
well as said it’s sometimes really helpful to use live-iso’s to check and bringing up some inspirations that help to get on track.
