Hello, I’m new on linux.
I just installed Manjaro KDE but I can’t find my wi-fi, it says " No available connection ". It worked just fine on windows. Can anyone help me?
( Sorry for my bad english )
Welcome to the Forum!
Please give the system information as the output of
inxi -Fazy
Also, you can see what running nmtui
gives
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=542fabd5-5d9f-48e5-a42f-5af2341fa1b4 rw quiet apparmor=1
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_wayland vt: 2 dm: SDDM
Type: Laptop System: Dell product: Latitude E5270 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 0D6XXP v: A00 serial: <superuser required> UEFI: Dell
v: 1.20.4 date: 05/20/2019
ID-1: BAT0 charge: 4.8 Wh (16.6%) condition: 29.0/47.0 Wh (61.8%)
volts: 11.9 min: 11.4 model: SMP DELL JY8D64C type: Li-poly serial: <filter>
status: Charging
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEC
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 599 high: 600 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 600 2: 598 3: 600 4: 600
bogomips: 20004
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-2:3 chip-ID: 0bda:5686 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
alternate: fbdev,vesa gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70
class-ID: 0403
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Lenovo driver: N/A pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 14e4:4365
class-ID: 0280
IF-ID-1: enp0s20f0u3 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: vivo V2027 type: USB driver: rndis_host v: kernel bus-ID: 1-3:6
chip-ID: 2d95:600a class-ID: 0a00 serial: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 238.47 GiB used: 10.86 GiB (4.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD9TN8W256G1001
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 6101 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 10.86 GiB (4.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 53.0 C pch: 45.5 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 198 Uptime: 5m wakeups: 1 Memory: 7.66 GiB used: 2.15 GiB (28.1%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: pacman: 1205 lib: 332 flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.13
Of course you have to do it for your running kernel version
Or go this way
but for that you will have to install the linux headers
sudo pacman -S $(pacman -Qsq "^linux" | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
You will be able to do this while using phone tethering, so you get internet access …
Thank you so much for your help, it works!
