Hello,
I installed Manjaro Cinnamon on a Dell XPS 17 laptop and am experiencing an issue with sound. I can’t get sound to play through the speakers.The only sound output device I see is “Dummy Output.” The builtin webcam microphone is also not detected, though the webcam itself seems to be fully functional. I’ve come across a few similar posts and have tried some solutions but I haven’t been able to fix anything. I’m not really sure where to start with debugging this. Is there any information that would be helpful?
Thanks
Hello,
According to this Dell XPS 17 (9700) - ArchWiki you need sof-firmware
package installed.
And according to this Dell XPS 17 (9710) - ArchWiki you should get it working with 5.15 kernel installed via MHWD.
But depends what exact model you have. Here is [HowTo] Provide System Information - so post it here.
Thank you for the reply! I should have mentioned that I already checked to see if sof-firmware was installed. Even with that package I have no audio. I have the 9710, but the audio does not work on kernel version 5.15, 5.16, or 5.17. Here is my system info:
Kernel: 5.17.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: Cinnamon 5.2.7 tk: GTK 3.24.33 vt: 7 dm: LightDM 1.30.0
Type: Laptop System: Dell product: XPS 17 9710 v: N/A
Mobo: Dell model: 012MMP v: A01 serial: <superuser required> UEFI: Dell
v: 1.6.0 date: 12/10/2021
ID-1: BAT0 charge: 73.5 Wh (86.7%) condition: 84.8/95.1 Wh (89.2%)
volts: 11.9 min: 11.4 model: BYD DELL F8CPG17 type: Li-poly
serial: <filter> status: Discharging
RAM: total: 62.54 GiB used: 3.24 GiB (5.2%)
RAM Report:
Info: 8-core model: 11th Gen Intel Core i9-11980HK bits: 64 type: MT MCP
smt: enabled arch: Tiger Lake rev: 1 cache: L1: 640 KiB L2: 10 MiB
L3: 24 MiB
Speed (MHz): avg: 858 high: 1048 min/max: 800/4900:5000 cores: 1: 959
2: 800 3: 799 4: 801 5: 791 6: 907 7: 801 8: 1048 9: 1009 10: 960 11: 801
12: 801 13: 801 14: 791 15: 801 16: 863 bogomips: 105712
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 510.54 pcie: speed: 16 GT/s lanes: 8 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-11:3 chip-ID: 0c45:672e class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2400 s-dpi: 48 s-size: 2032x1270mm (80.0x50.0")
s-diag: 2396mm (94.3")
Monitor-1: eDP-1 model: Sharp res: 3840x2400 hz: 60 dpi: 266
size: 366x229mm (14.4x9.0") diag: 432mm (17") modes: 3840x2400
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel pcie:
speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Sound Server-1: ALSA v: k5.17.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: no
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
Device-1: luks-85fc897b-4f37-47af-9fbc-2d6f2ff97789 type: LUKS dm: dm-0
Components: p-1: nvme0n1p7
Local Storage: total: 3.73 TiB used: 182.46 GiB (4.8%)
ID-1: /dev/nvme0n1 vendor: KIOXIA model: KXG70PN84T09 NVMe 4096GB
size: 3.73 TiB speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 10904105 temp: 22.9 C scheme: GPT
ID-1: / size: 1.78 TiB used: 182.37 GiB (10.0%) fs: ext4 dev: /dev/dm-0
mapped: luks-85fc897b-4f37-47af-9fbc-2d6f2ff97789 label: N/A
uuid: 051d882f-dbb6-465f-bcc8-4839f401a44f
ID-2: /boot/efi size: 146 MiB used: 89.2 MiB (61.1%) fs: vfat
dev: /dev/nvme0n1p1 label: ESP uuid: 7019-72CC
ID-1: /dev/nvme0n1p2 size: 128 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 size: 1.9 TiB fs: bitlocker label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 size: 990 MiB fs: ntfs label: WINRETOOLS
uuid: AC4C9FD14C9F94A4
ID-4: /dev/nvme0n1p5 size: 16.39 GiB fs: ntfs label: Image
uuid: A6569FFC569FCB85
ID-5: /dev/nvme0n1p6 size: 1.37 GiB fs: ntfs label: DELLSUPPORT
uuid: 7486356B86352F4C
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 3-10:2 info: Shenzhen Goodix USB2.0 MISC
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
Device-2: 3-11:3 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 3-14:4 info: Intel AX201 Bluetooth type: Bluetooth
Hub-4: 4-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 20 Gb/s
System Temperatures: cpu: 30.0 C mobo: N/A
Processes: 444 Uptime: 10h 38m wakeups: 1462 Init: systemd v: 250
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1466 Shell: Zsh
v: 5.8.1 running-in: gnome-terminal inxi: 3.3.13
You might have to do this
Found the solution here:
https://forum.manjaro.org/t/sound-not-working-after-update-to-manjaro-21-1/73773/2
Quoting Goose:
I found a workaround on the Ubuntu forum. Scroll down to the bottom and someone responded with a solution for Arch. Basically, follow these steps:
Edit grub config
sudo nano /etc/default/grub
Add the following within the quotation after GRUB_CMDLINE_LINUX_DEFAULT
snd_intel_dspcfg.dsp_driver=1
Update grub
sudo update-grub
Reboot
This forces the legacy dr…
Thanks for the link. I followed the link to the solution and tried all combinations of the snd_intel_dspcfg.dsp_driver=1
and snd_hda_intel.dmic_detect=0
fixes but nothing seems to change. I still have no audio and the “dummy output.”
Good idea. I just tried it but am still seeing no changes. I tried all the different GRUB options again too. Thank you for trying to help. I’m trying to avoid reinstalling, but I am considering it as an option at this point. I’ve done a lot of googling about this issue and it seems like everybody else has already had the issue resolved.
Olli
March 8, 2022, 10:55am
8
did you try to boot from a live-iso and check if this works ? that’s more easy
I’m glad you suggested this. I just tried booting into the live install image with both open-source and proprietary drivers but still didn’t see anything different.
Bumping this in case anybody else has an idea, if that’s OK. I still haven’t found a solution.
