Newb is confused with firejail messages
hello. i tried setup
firejail as wiki says: su pacman -S firejail → firejail firefox
im little bit confused , is there now some error what i need to repair (with that “aa-enforce…”)
or is it all ok?
Mod edit: Text image removed. Check this out: [HowTo] Request support
don’t know what wiki this tells but manjaro uses the “sudo” command instead of “su”.
Did you read Firejail - ArchWiki
Did you follow the instructions in the install message
In order to use the apparmor integration with firejail, install the apparmor package and run as root: 'apparmor_parser -r /etc/apparmor.d/firejail-default'
You will likely also need to enable and start the apparmor.service
sudo systemctl enable --now apparmor.service
Bear in mind that if you configure firejail to the extent described in the Arch Wiki - upon removal of firejail you will need to clear out unwanted files in /usr/local/
Hi @findian, and welcome!
This doesn’t make sense, actually.
And also, we need more information if there seems to be a problem and you wish assistance.
  • Which Wiki?
  • Did you check the Manjaro wiki?
  • Did you check the Arch wiki?
See:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
