Hi, I recently installed manjaro xfce over my arch build. Everything was working fine on my kde arch build. This is my first time using xfce.
So when I try to play audio from vlc commmand line i get -
[0000642d4545b5a0] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[0000766c68eca8e0] avcodec decoder: Using Intel i965 driver for Intel(R) Kaby Lake - 2.4.1 for hardware decoding
[vp9 @ 0x766c68ed3c00] get_buffer() failed
[vp9 @ 0x766c68ed3c00] thread_get_buffer() failed
[vp9 @ 0x766c68ed5000] get_buffer() failed
[vp9 @ 0x766c68ed5000] thread_get_buffer() failed
If i try to play youtube videos they won’t play unless I mute them.
If i try to play any game my FPS drops to 5 and no audio will play. Have no problems running the games i tested at 120fps usually.
Audio works when using wmplayer.
So here is some info :::
Kernel: 6.9.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=c6ce2870-c819-40e6-adec-52deaae9d2da rw quiet splash
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: ASUSTeK model: PRIME B250M-A v: Rev X.0x
UEFI: American Megatrends v: 0808 date: 06/16/2017
Info: model: Intel Core i7-7700 bits: 64 type: MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF8
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 28808
Device-1: Intel HD Graphics 630 vendor: ASUSTeK H110I-PLUS driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-2 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:5912 class-ID: 0300
Device-2: NVIDIA AD107 [GeForce RTX 4060] vendor: Micro-Star MSI
driver: nvidia v: 550.107.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2882
class-ID: 0300
Display: x11 server: X.org v: 1.21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
dri: iris gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-size: <missing: xdpyinfo>
Monitor-1: DP-1-0 pos: primary,right res: 3840x2160 hz: 60 dpi: 163
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Monitor-2: HDMI-2 pos: left res: 1920x1080 hz: 60 dpi: 40
size: 1209x680mm (47.6x26.77") diag: 1387mm (54.61") modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:5912 memory: 7.56 GiB unified: yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
API: ALSA v: k6.9.12-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: active with: 1: wireplumber
status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl,pavucontrol
Your ALSA information is located at http://alsa-project.org/db/?f=62cd5bce1333cf37bb9107f8b0d550a39549122d
The only available device given to me for output is HDMI Digital Stereo but as you can see i have that on off and audio through wmplayer is still working.
As you can see I have all audio turned down to 0 but wmplayer is still working. Everything else is not.
Sorry for not using the proper tags, there is no preview button so I wasn’t sure if i was using the correct ones.
So I want to use my Intel hdmi cable hooked into my tv to play the audio. The NVIDIA card is connected to a monitor w. no audio.
Thanks in advance for your help.
