New kernel installed but does not shown in grub
I have installed kernel 5.14.9-1 and after rebooting it does not boot into the latest kernel, Grub Menu only shows 5.13.19-2 and its fallback.
So far I have tried reinstalling the kernel.
➜  ~ uname -r
5.13.19-2-MANJARO
➜  ~ mhwd-kernel -li
Currently running: 5.13.19-2-MANJARO (linux513)
   * linux513
   * linux514
   * linux515
➜  ~ sudo update-grub
[sudo] password for garvit-joshi:
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.14-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.14-x86_64.img
Found initrd fallback image: /boot/initramfs-5.14-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.13-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
The output you posted shows 3 installed kernels and all are detected while generating the grub config file…
Yes, But when I reboot every time 5.13 kernel is used. I GRUB Menu when I go to Advanced option there also 5.13 and fallback is listed.
Can you give output of ls /boot/grub/ -l?
➜  ~ ls /boot/grub/ -l
total 56
drwxr-xr-x 2 root root  4096 Oct  5 20:54 fonts
-rw-r--r-- 1 root root  6468 Oct  5 20:55 grub.cfg
-rw------- 1 root root  8399 Oct  7 02:53 grub.cfg.new
-rw-r--r-- 1 root root  1024 Oct  5 20:55 grubenv
drwxr-xr-x 2 root root  4096 Oct  7 02:48 locale
drwxr-xr-x 3 root root  4096 Oct  5 20:54 themes
drwxr-xr-x 2 root root 20480 Oct  7 02:48 x86_64-efi
Can you post the following files:
/boot/grub/grub.cfg and grub.cfg.new ?
This apparently denotes an issue in your /etc/default/grub config file or one of the scripts used to generate the /boot/grub/grub.conf file
You made a change or installed something that breaks the grub configuration file generation process.
Think of what you did in the past two days as apparently on October 5th you properly generated your grub.conf file.
I was trying to make things work so I did this
sudo grub-install --recheck --no-rs-codes
sudo update-grub
Before that, on October 5 ,I reinstalled manajro from new ISO,and then just changed the GRUB background color from manjaro themes(/usr/share/grub/themes/manjaro/theme.txt), and did update-grub. Nothing More.
grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
set menu_color_normal=light-gray/black
set menu_color_highlight=green/black
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod part_gpt
insmod ext2
search --no-floppy --fs-uuid --set=root 46702065-bed3-4f5e-a152-5c50607902b3
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  set locale_dir=$prefix/locale
  set lang=en_US
  insmod gettext
fi
terminal_input console
terminal_output gfxterm
insmod part_gpt
insmod ext2
insmod gfxmenu
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_24.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_48.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_bold_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_mono_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-18.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b18.pf2
insmod png
set theme=($root)/usr/share/grub/themes/manjaro/theme.txt
export theme
if [ x$feature_timeout_style = xy ] ; then
  set timeout_style=hidden
  set timeout=5
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 5 ; then
  set timeout=0
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Manjaro Linux' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-46702065-bed3-4f5e-a152-5c50607902b3' {
	savedefault
	load_video
	set gfxpayload=keep
	insmod gzio
	insmod part_gpt
	insmod ext2
	linux	/boot/vmlinuz-5.13-x86_64 root=UUID=46702065-bed3-4f5e-a152-5c50607902b3 rw  quiet udev.log_priority=3
	initrd	/boot/amd-ucode.img /boot/initramfs-5.13-x86_64.img
submenu 'Advanced options for Manjaro Linux' $menuentry_id_option 'gnulinux-advanced-46702065-bed3-4f5e-a152-5c50607902b3' {
	menuentry 'Manjaro Linux (Kernel: 5.13.19-2-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.13.19-2-MANJARO x64-advanced-46702065-bed3-4f5e-a152-5c50607902b3' {
	savedefault
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
	menuentry 'Manjaro Linux (Kernel: 5.13.19-2-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.13.19-2-MANJARO x64-fallback-46702065-bed3-4f5e-a152-5c50607902b3' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		initrd	/boot/initramfs-5.13-x86_64-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows Boot Manager (on /dev/nvme0n1p1)' --class windows --class os $menuentry_id_option 'osprober-efi-7405-A3BC' {
	savedefault
	insmod part_gpt
	insmod fat
	search --no-floppy --fs-uuid --set=root 7405-A3BC
	chainloader /EFI/Microsoft/Boot/bootmgfw.efi
set timeout_style=menu
if [ "${timeout}" = 0 ]; then
  set timeout=10
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' {
	fwsetup
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/41_snapshots-btrfs ###
### END /etc/grub.d/41_snapshots-btrfs ###
### BEGIN /etc/grub.d/60_memtest86+ ###
if [ "${grub_platform}" == "pc" ]; then
    menuentry "Memory Tester (memtest86+)" --class memtest86 --class gnu --class tool {
        search --fs-uuid --no-floppy --set=root  46702065-bed3-4f5e-a152-5c50607902b3
        linux16 /boot/memtest86+/memtest.bin
fi
### END /etc/grub.d/60_memtest86+ ###
grub.cfg.new:
insmod part_gpt
insmod part_msdos
  load_env
fi
   set next_entry=
   save_env next_entry
   set boot_once=true
else
fi
else
fi
  set boot_once=true
fi
  fi
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
   font=unicode
else
insmod part_gpt
insmod ext2
fi
  set gfxmode=auto
  load_video
  insmod gfxterm
  set lang=en_IN
  insmod gettext
fi
insmod part_gpt
insmod ext2
insmod gfxmenu
insmod png
export theme
  set timeout=5
# unavailable.
  set timeout=0
fi
        savedefault
        load_video
        set gfxpayload=keep
        insmod gzio
        insmod part_gpt
        insmod ext2
        linux   /boot/vmlinuz-5.15-x86_64 root=UUID=46702065-bed3-4f5e-a152-5c50607902b3 rw  quiet udev.log_priority=3
        initrd  /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
        menuentry 'Manjaro Linux (Kernel: 5.15.rc4.211005.g9e1ff30-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.15.rc4.211005.g9e1ff30-1-MANJARO x64-advanced-46702065-bed3-4f5e-a152-5c50607902b3' {
        savedefault
                load_video
                set gfxpayload=keep
                insmod gzio
                insmod part_gpt
                insmod ext2
        menuentry 'Manjaro Linux (Kernel: 5.15.rc4.211005.g9e1ff30-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.15.rc4.211005.g9e1ff30-1-MANJARO x64-fallback-46702065-bed3-4f5e-a152-5c50607902b3' {
                load_video
                set gfxpayload=keep
                insmod gzio
                insmod part_gpt
                insmod ext2
                initrd  /boot/initramfs-5.15-x86_64-fallback.img
        menuentry 'Manjaro Linux (Kernel: 5.14.9-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.14.9-1-MANJARO x64-advanced-46702065-bed3-4f5e-a152-5c50607902b3' {
        savedefault
                load_video
                set gfxpayload=keep
                insmod gzio
                insmod part_gpt
                insmod ext2
                linux   /boot/vmlinuz-5.14-x86_64 root=UUID=46702065-bed3-4f5e-a152-5c50607902b3 rw  quiet udev.log_priority=3
                initrd  /boot/amd-ucode.img /boot/initramfs-5.14-x86_64.img
        menuentry 'Manjaro Linux (Kernel: 5.14.9-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.14.9-1-MANJARO x64-fallback-46702065-bed3-4f5e-a152-5c50607902b3' {
                load_video
                set gfxpayload=keep
                insmod gzio
                insmod part_gpt
                insmod ext2
                initrd  /boot/initramfs-5.14-x86_64-fallback.img
        savedefault
                load_video
                set gfxpayload=keep
                insmod gzio
                insmod part_gpt
                insmod ext2
                load_video
                set gfxpayload=keep
                insmod gzio
                insmod part_gpt
                insmod ext2
        savedefault
        insmod part_gpt
        insmod fat
  set timeout=10
fi
        fwsetup
fi
Is your installation a btrfs one? Also what did you change exactly in GRUB?
I suppose the issue lies in grub-btrfs as it is where it stops in the grub.cfg.new file
It stops at the start of this script generated output.
Are you on a btrfs installation?
//EDIT: anyway, the fact that your grub.cfg file is not updated and you have a leftover grub.cfg.new file shows that something breaks during the update-grub process apparently. Now the thing is to find what breaks and fix it.
You should move grub.cfg to backup file (e.g. grub.bckup)
and
overwrite grub.cfg with grub.cfg.new.
Then the kernels 5.13, 5.14 and 5.15 should show up.
That will work as the grub.cfg.new file seem to be correct but that will not fix the root of the issue. He should find what is breaking the grub.cfg creation.
Yes … I have not done anything other then the above mentioned steps. For now i will fix the system.
Thanks @omano @Keruskerfuerst .
Hey, I just reinstalled manjaro from ISO 21.1.4 and still the problem exists.
The only commands i have run are these:
sudo pacman-mirrors --api --set-branch unstable
sudo pacman -Syu
pamac build google-chrome
uname -r
exit
sudo pacman -Syu
Still not fixed. Also my PC is in Dual boot with windows 11.
Hello,
grub-btrfs 4.10 break grub-mkconfig
grub-btrfs 4.10.2 solved this.
Sorry for the inconvenience.
Thanks.
@garvitjoshi9 As a temporary measure until this version lands, you can replace /etc/grub.d/41_snapshots-btrfs with the fixed version from: grub-btrfs/41_snapshots-btrfs at a790ff054e76b5997cde294ad9674e448ec12d53 · Antynea/grub-btrfs · GitHub
Thanks This Worked.
Yeah that was my guess. Thanks for the follow up and the fix. At first I was wondering why a new user would reply to me about the issue, then I found out you are the creator of this package :smiley:
:+1:
