I am using Canon Pixma Ts7450 series wifi capable scanner+printer device. Skanlite app doesn’t seem to recognize this scanner. Any suggestion how to make it work?
Hi @s8srahme,
Without more information, this is just a shot in the dark. But perhaps your Drivers for that aren’t installed. It sounds like it. There does seem to nee some kind of driver for that device in the AUR:
$ pamac search 7450
cnijfilter-ts7450series 6.10-1 AUR
Canon IJ Printer Driver for Linux for Pixma 7450 series and other based on 6.10 version
So you could try and install it to see if it helps:
pamac build cnijfilter-ts7450series
Followed by a reboot to see if it worked. If not, reply and tell us. Also provide more information:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as preformatted text.
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Just note: If it does work and you continue using it, it’ll have to be rebuilt any- and every time there’s a change/update to your current, or you change to a different kernel.
Installing cnijfilter-ts7450series package helped to make the printing functionalities detected. but I have no luck with scanning capabilities. I tried Skanlite app, which doesn’t detect my scanner though.
It looks like the following should work for the scanner:
https://aur.archlinux.org/packages/scangearmp2-sane-git
pamac build scangearmp2-sane-git
Or:
skanlite is available from the official repositories, though I am not sure that is what is needed here.
pamac install skanlite
Skanlite just looks like basic scanning software like gscan2pdf, vuescan, xsane, etc.
scangearmp2 did the job. Thanks a lot.
