MaxP
28 October 2022 11:46
1
Hi
I just installed manjaro on my hybrid grafics laptop and did “sudo pacman -Syu” → reboot.
(Before reboot two monitors where working, i used proprietary drivers at installation)
I think my driver was updated, somehow I cannot get two monitors to work:
First no external monitor was detected, but I found:
“nvidia-xconfig” to create the xorg.conf.
I did this, reboot and now only my external monitor is working, I cannot get the laptop monitor to work and xrandr says:
Screen 0: minimum 8 x 8, current 2560 x 1440, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 697mm x 392mm
2560x1440 120.00*+ 143.93 59.95
3840x2160 59.94 50.00 29.97 25.00 23.98
1920x1080 119.88 60.00 59.94 50.00
1280x720 59.94 50.00
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94
DP-4 disconnected (normal left inverted right x axis y axis)
Which leaves me with no clue.
I have the recommended video-hybrid-intel-nvidia-prime driver via manjaro settings manager installed.
Any idea?
Hi @MaxP ,
MaxP:
Any idea?
Yeah, the forum has many posts regarding this problem and in many the solution is the same. Nevertheless, in order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also provide the output for:
mhwd --list
and
mhwd --listinstalled
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Alternatively , paste the text you wish to format as terminal output, select all pasted text, and click the </> button on the taskbar. This will indent the whole pasted section with one TAB , causing it to render the same way as described above.
Thereby improving legibility and making it much easier for those trying to be of assistance.
MaxP
28 October 2022 12:10
3
Thanks a lot, I´ll try.
mhwd --list:
0000:01:00.0 (0300:10de:1e91) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:3d:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:00:02.0 (0300:8086:9bc4) Display controller Intel Corporation:
mhwd --listinstalled:
> Installed PCI configs:
Manjaro Settings Manager (if useful):
Edit: inxi -v7azy:
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=f6749781-cff4-407e-901e-8a9ef0769b7c rw quiet
resume=UUID=1c21a424-6086-4aaf-be2b-fca62390f27d udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: MEDION product: BEAST X10 v: Standard
serial: <superuser required> Chassis: type: 10 v: Standard
Mobo: MEDION model: GM7Mx v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: N.1.05 date: 07/21/2020
ID-1: BAT0 charge: 86.1 Wh (94.0%) condition: 91.6/91.6 Wh (100.0%)
volts: 12.0 min: 11.6 model: standard type: Li-ion serial: <filter>
status: N/A
RAM: total: 15.46 GiB used: 2.38 GiB (15.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: MEDION AG
ports: active: none off: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU104M [GeForce RTX 2070 SUPER Mobile / Max-Q]
vendor: Tongfang Hongkong driver: nvidia v: 520.56.06
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-10) arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.0 chip-ID: 10de:1e91 class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:6
chip-ID: 04f2:b68b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting failed: nvidia dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 92 s-size: 707x393mm (27.83x15.47")
s-diag: 809mm (31.85")
Monitor-1: eDP-1 mapped: HDMI-0 note: disabled model: LG Display 0x065b
built: 2019 res: 2560x1440 hz: 120 dpi: 93 gamma: 1.2
size: 697x392mm (27.44x15.43") diag: 438mm (17.3") ratio: 16:9
modes: 1920x1080
OpenGL: renderer: llvmpipe (LLVM 14.0.6 256 bits) v: 4.5 Mesa 22.1.7
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: MEDION AG driver: snd_hda_intel
chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU104 HD Audio vendor: Tongfang Hongkong
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f8
class-ID: 0403
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: no
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: Tongfang Hongkong driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3d:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp61s0 state: down mac: <filter>
bus-ID: 1-14:8 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 10.89 GiB (1.1%)
model: MZVLB1T0HBLR-00000 size: 953.87 GiB block-size: physical: 512 B
rev: EXF7201Q temp: 34.9 C scheme: GPT
ID-1: / raw-size: 111.57 GiB size: 109.26 GiB (97.93%) used: 10.87 GiB
(9.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: f6749781-cff4-407e-901e-8a9ef0769b7c
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 27.6 MiB
(9.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: B475-2B94
ID-1: swap-1 type: partition size: 8.01 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 1c21a424-6086-4aaf-be2b-fca62390f27d
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 833.89 GiB fs: ntfs label: Boot
uuid: C07EDCF47EDCE3E6
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-6:2 info: Integrated Express ITE Device(8291)
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:ce00 class-ID: 0300
Hub-2: 1-9:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Device-1: 1-9.2:5 info: Microsoft Xbox360 Controller
type: <vendor specific> driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 045e:028e class-ID: ff00 serial: <filter>
Device-2: 1-9.3:7 info: SiGma Micro XM102K Optical Wheel Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 1c4f:0034 class-ID: 0301
Device-3: 1-9.4:9 info: Microdia USB Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 0c45:760a class-ID: 0301
Device-4: 1-10:4 info: Integrated Express ITE Device(8291)
speed: 12 Mb/s power: 100mA chip-ID: 048d:6005 class-ID: 0300
Device-5: 1-13:6 info: Chicony HD Webcam type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b68b
Device-6: 1-14:8 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Device-1: 2-2:2 info: Realtek Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 0bda:0316 class-ID: 0806 serial: <filter>
Hub-4: 2-5:3 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0813 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.0 C pch: 50.0 C mobo: N/A gpu: nvidia
temp: 43 C
Processes: 276 Uptime: 40m wakeups: 3 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1101 libs: 300 tools: pamac Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
And can you please provide the output for:
lsmod | grep -i nvi
MaxP
28 October 2022 12:19
5
Sure.
lsmod | grep -i nvi:
nvidia_modeset 1187840 3
nvidia 55255040 247 nvidia_modeset
i2c_nvidia_gpu 16384 0
Olli
28 October 2022 12:25
6
llvmpipe
however, this system is screwed up.
install optimus-manager and switch to nvidia
MaxP
28 October 2022 12:49
8
Switching to nvidia with optimus worked, and now I can only see the laptop monitor and no external anymore.
How can you tell there is something very wrong with the system?
Should I reinstall manjaro?
brahma
28 October 2022 12:58
9
try with different kernel…
also add this parameter to your grub:
kate /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT - inside the quotes add this parameter:
ibt=off
dont remove anything from there, just add it to the existing parameters, save the file, update grub with:
sudo update-grub
reboot
You wrote something about nvidia-xconfig.
I think that tool overwrites the Manjaro configuration or at least a while back it was not recommended to use.
Maybe this?
Olli
28 October 2022 13:03
11
you switched to what ? what is the setting of optimus ? nvidia or SGI (internal GPU) ?
MaxP
28 October 2022 13:04
12
I needed to delete the xconfig file in order to switch to nvidia with optimus
edit: optminus-manager --switch nvidia
2nd edit: @brahma ibt=off brought no change so far.
MaxP
28 October 2022 14:05
14
I found the problem I had:
First, I did not edit the sddm.conf file where I have to comment out the DisplayCommand and DisplayStopCommand.
Secondly, I changed the optimus-magager.conf file, where I set the driver explicit to nvidia.
Now everything works as intended, even both monitors at the same time!
Thank you so much. Awesome community!
system
Closed
31 October 2022 04:06
15
