Hi,
So my situation is very weird. My fake-ish Xbox 360 controller itself works, but very but when I freshly installed Manjaro it worked perfectly fine but after some time it stopped working and only got recognized. And yes on steam too, it even vibrates when I tested it. Button input doesnt work.
Hi @EskimoGabe,
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as formatted text.
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Please also provide the output for:
…executed while the dev8ice is plugged in.
Hello this is my system:
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=5d329181-1d2d-47b3-948e-91767f49a31e rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
Mobo: HP model: 80CC v: 99.32 serial: <superuser required>
part-nu: P0G72EA#ACB uuid: <superuser required> UEFI-[Legacy]: Insyde v: F.12
date: 07/30/2015
ID-1: BAT1 charge: 28.3 Wh (100.0%) condition: 28.3/28.3 Wh (100.0%)
volts: 17.0 min: 14.8 model: 111-83-72 HS04041 type: Unknown serial: <filter>
status: full
System RAM: total: 6 GiB available: 4.77 GiB used: 3.31 GiB (69.3%)
Array-1: capacity: 8 GiB slots: 2 modules: 2 EC: None
max-module-size: 4 GiB note: est.
Device-1: Bottom type: DDR3 detail: synchronous unbuffered (unregistered)
size: 4 GiB speed: 800 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M471B5173QH0-YK0 serial: <filter>
Device-2: Top type: DDR3 detail: synchronous unbuffered (unregistered)
size: 2 GiB speed: 800 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Hynix part-no: HMT425S6CFR6A-PB serial: <filter>
Info: model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64 type: MCP
arch: Puma level: v2 built: 2014-15 process: GF 28nm family: 0x16 (22)
model-id: 0x30 (48) stepping: 1 microcode: 0x7030105
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 1x2 MiB
Speed (MHz): avg: 1074 high: 1300 min/max: 1000/2200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1000 2: 998
3: 1000 4: 1300 bogomips: 17574
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1 bpext
clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de
decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht
hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe
msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall
wdt xsave xsaveopt
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu arch: GCN-2 code: Sea Islands
process: GF/TSMC 16-28nm built: 2013-17 ports: active: eDP-1
empty: HDMI-A-1,VGA-1 bus-ID: 00:01.0 chip-ID: 1002:9851 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile] vendor: Hewlett-Packard driver: radeon v: kernel
alternate: amdgpu arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380
temp: 49.0 C
Device-3: Realtek HP Truevision HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.1:3 chip-ID: 0bda:57d6
Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6
compositor: kwin_x11 driver: X: loaded: radeon unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: Samsung 0x4e51 built: 2014
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 chroma: red: x: 0.576 y: 0.337
green: x: 0.333 y: 0.576 blue: x: 0.161 y: 0.114 white: x: 0.314 y: 0.329
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1366x768, 1280x720, 1152x768, 1024x768, 800x600, 848x480, 720x480,
640x480
EDID-Warnings: 1: parse_edid: unknown flag 2
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: KABINI (radeonsi LLVM 16.0.6 DRM 2.50
6.6.26-1-MANJARO) device-ID: 1002:9851 memory: 1000 MiB unified: no
Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840
class-ID: 0403
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-3: C-Media 1MORE Spearhead Gaming Headphones
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 0d8c:01e0 class-ID: 0300
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard
driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:4365 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-3: Ralink MT7601U Wireless Adapter driver: mt7601u type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.1.2:8
chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp0s18u1u1u2 state: up mac: <filter>
Info: services: NetworkManager,wpa_supplicant
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.4:4 chip-ID: 0a5c:216d
Local Storage: total: 447.13 GiB used: 37.04 GiB (8.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 66.5 scheme: MBR
Optical-1: /dev/sr0 vendor: hp model: DVDRW SU208GB rev: HH00
dev-links: cdrom
ID-1: / raw-size: 447.13 GiB size: 439.04 GiB (98.19%) used: 37.04 GiB (8.4%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 5d329181-1d2d-47b3-948e-91767f49a31e
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
chip-ID: 0438:7900 class-ID: 0900
Hub-3: 1-1.1:3 info: Huasheng 4-port hub [Maxxter ACT-HUB2-4P HS8836 iSoul
ultra-slim] ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 100mA chip-ID: 214b:7000 class-ID: 0900
Device-1: 1-1.1.2:8 info: Ralink MT7601U Wireless Adapter type: Network
driver: mt7601u interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 160mA chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
Device-2: 1-1.1.3:6 info: GEMBIRD MicroSD Card Reader/Writer
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 150mA
chip-ID: 1908:0226 class-ID: 0806
Device-3: 1-1.1.4:7 info: Microsoft Xbox360 Controller
type: <vendor specific> driver: xpad interfaces: 1 rev: 2.0
chip-ID: 045e:028e class-ID: ff00
Device-4: 1-1.4:4 info: Broadcom BCM43142A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Hub-4: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-5: 2-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
Device-1: 2-1.1:3 info: Realtek HP Truevision HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0bda:57d6 class-ID: 0e02 serial: <filter>
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: [Maxxter] USB GAMING MOUSE type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 18f8:1286 class-ID: 0301
Device-2: 3-2:3 info: C-Media 1MORE Spearhead Gaming Headphones
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA
Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 56.6 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: radeon temp: 50.0 C device: radeon temp: 54.0 C
Packages: 1269 pm: pacman pkgs: 1246 libs: 358 tools: pamac pm: flatpak
pkgs: 23
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
2: https://mirrors2.manjaro.org/stable/$repo/$arch
3: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 231
1: cpu: 300% command: ps pid: 4812 mem: 4.00 MiB (0.0%)
2: cpu: 22.9% command: chrome pid: 4545 mem: 265.4 MiB (5.4%)
3: cpu: 4.5% command: chrome pid: 2795 mem: 477.7 MiB (9.7%)
4: cpu: 4.2% command: chrome pid: 4653 mem: 199.8 MiB (4.0%)
5: cpu: 3.7% command: spotify pid: 3359 mem: 286.2 MiB (5.8%)
Memory top: 5 of 231
1: mem: 477.7 MiB (9.7%) command: chrome pid: 2795 cpu: 4.5%
2: mem: 396.3 MiB (8.1%) command: plasmashell pid: 849 cpu: 1.8%
3: mem: 286.2 MiB (5.8%) command: spotify pid: 3359 cpu: 3.7%
4: mem: 279.3 MiB (5.7%) command: chrome pid: 3574 cpu: 2.1%
5: mem: 272.4 MiB (5.5%) command: spotify pid: 3282 cpu: 1.1%
Processes: 231 Power: uptime: 3h 40m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 1.89 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
if that helps
My humble apologies. I seem to have forgotten the command. The command there should be:
xinput list
~ xinput list ✔
zsh: correct 'xinput' to '_xinput' [nyae]? n
zsh: command not found: xinput
~ xinput list 127 ✘
zsh: correct 'xinput' to '_xinput' [nyae]? y
_arguments:comparguments:327: can only be called from completion function
This is what I got do I have to install Xinput via Aur?
No, it would seem the xorg-xinput package from the extra repository isn’t installed. So install it first:
pamac install xorg-xinput
…and then try the above command again, please.
xinput list ✔
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ SynPS/2 Synaptics TouchPad id=13 [slave pointer (2)]
⎜ ↳ USB GAMING MOUSE Keyboard id=10 [slave pointer (2)]
⎜ ↳ USB GAMING MOUSE id=16 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Video Bus id=8 [slave keyboard (3)]
↳ Power Button id=9 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=12 [slave keyboard (3)]
↳ Wireless hotkeys id=14 [slave keyboard (3)]
↳ HP WMI hotkeys id=15 [slave keyboard (3)]
↳ USB GAMING MOUSE Keyboard id=11 [slave keyboard (3)]
↳ 1MORE Inc. 1MORE Spearhead Gaming Headphones id=17 [slave keyboard (3)]
hmm should unplug everything and make another with and without only the controller?
Yes, please. I was hoping/thinking it might have an obvious name.
Is the device USB? If so, also provide the output of:
lsusb
…please.
lsusb ✔
Bus 001 Device 002: ID 0438:7900 Advanced Micro Devices, Inc. Root Hub
Bus 001 Device 004: ID 0a5c:216d Broadcom Corp. BCM43142A0 Bluetooth 4.0
Bus 001 Device 039: ID 214b:7000 Huasheng Electronics 4-port hub [Maxxter ACT-HUB2-4P, HS8836, iSoul ultra-slim]
Bus 001 Device 040: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
Bus 001 Device 041: ID 1908:0226 GEMBIRD MicroSD Card Reader/Writer
Bus 001 Device 058: ID 045e:028e Microsoft Corp. Xbox360 Controller
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 0438:7900 Advanced Micro Devices, Inc. Root Hub
Bus 002 Device 003: ID 0bda:57d6 Realtek Semiconductor Corp. HP Truevision HD
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 007: ID 18f8:1286 [Maxxter] USB GAMING MOUSE
Bus 003 Device 008: ID 0d8c:01e0 C-Media Electronics, Inc. 1MORE Spearhead Gaming Headphones
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
yep its usb
xinput list ✔
with nothing connected.
xinput list ✔
with controller
I hope it helps
You say it works, but it doesn’t really?
Well, that combined with the fact that I spot no difference in the xinput list outputs, but it seems to be present in the lsusb output:
…yet it’s visible in the inxi output:
…with a driver loaded, makes me think the controller is FUBAR. Terribly sorry.
Well its not FUBAR not at all. On Windows 11, just tested it. Works perfectly fine. Works Perfect. Its only here which stopped working for some reason.
Try a different kernel?
ok ok do I need a flash drive or can I do it inside Linux?
Yes, this might be a valid approach. Well, it won’t do any harm. According to https://linux-hardware.org/?id=usb:045e-028e the driver is in Kernel versions 2.6.26 - 6.3, so another kernel might actually work…
I recommend version 6.1 as it’s LTS and will be maintained for 10 years. So, to install it, just run:
sudo mhwd-kernel --install linux61
You can do it from your current installation.
Reboot into it and test:
All available kernels installed on your system will be presented upon booting up. GNU GRUB is visible with a couple of options. Choose “Advanced Options for Manjaro Linux” by using the arrow keys ↑ ↓ on your keyboard and then ↵ Enter.
On the next screen (as illustrated) are backup copies of each kernel version installed (which will also be automatically removed if or when a kernel version is deleted). To select a kernel, simply use the arrow keys ↑ ↓ to highlight the desired version, and then press ↵ Enter.
It was the kernel omg thank you btw that you helped me and that small tip with the GRUB
Glad I could help!
