For some reason, my computer randomly drops to only 1/10 of it’s performance and I don’t know what is causing it. Do you have any tips how could I solve it? (all of my drivers are up to date).
When I freshly installed Manjaro and tried to run Minecraft 1.8.9, it ran on around 350-400 FPS, but then for some reason (the only things I installed after were Steam and Brave browser), my performance dropped only on 30-40 FPS. Then, two days after, I started Minecraft and everything runned as it should again, but the next day, the game was running again on only 30 FPS and it is still after nearly a week. Does anybody has any tips how could I fix this problem? Thank you so much!
Hi @jozef_papricka, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as formatted text.
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
From my experience, Minecraft is not the best optimized game. That said, a FPS drop like that is very strange.
I suggest:
- Check if your computer is plugged in AC while playing (in case of a laptop);
- Install Optifine or similar, it will improve your fps;
- Check if your system in not under heavy load. For example, if Timeshift is running at the same time;
- Check if your CPU frequency is not being capped (affected by your governor);
- Check if you GPU is being used.
This is a generic advice, for better advice more info is required, as @Mirdarthos said. Hope this helps.
Probably VSYNC/VRR is active? Did you notice any high GPU usage?
