My Lenovo ThinkBook touchpad is not working
I am a new user who installed MANY distro’s of linux (i liked this one the best) but in all of the linux distro’s (including this one) my touchpad dosent seem to work.
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=dcd73ffd-b62c-41e5-bdb4-26e48a5992fb rw quiet splash apparmor=1
  Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 20RW v: Lenovo ThinkBook 15-IML
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    part-nu: LENOVO_MT_20RW_BU_idea_FM_Lenovo ThinkBook 15-IML
    uuid: <superuser required> UEFI: LENOVO v: CJCN41WW date: 03/13/2023
  ID-1: BAT1 charge: 39.7 Wh (100.0%) condition: 39.7/45.0 Wh (88.3%)
    volts: 12.3 min: 11.1 model: Celxpert L19C3PF9 type: Li-poly serial: <filter>
    status: full cycles: 388
  System RAM: total: 8 GiB available: 7.27 GiB used: 3.05 GiB (42.0%)
  Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2667 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: SK Hynix part-no: HMAA1GS6CMR6N-VK serial: N/A
  Device-2: ChannelB-DIMM0 type: no module installed
  Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0xFC
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 400 min/max: 400/4900 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 36812
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
    rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:9b41 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Topaz XT [Radeon R7 M260/M265 /
    M340/M360 M440/M445 530/535 620/625 Mobile] vendor: Lenovo driver: amdgpu
    v: kernel arch: GCN-3 code: Volcanic Islands process: TSMC 28nm
    built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
    speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:6900 class-ID: 0380
    temp: 42.0 C
  Device-3: Lite-On Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 04ca:7070
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x0812 built: 2018 res: 1920x1080
    dpi: 142 gamma: 1.2 chroma: red: x: 0.584 y: 0.361 green: x: 0.353 y: 0.569
    blue: x: 0.161 y: 0.129 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080
  API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
    drv: iris device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: iris
    surfaceless: drv: iris wayland: drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9b41 memory: 3.55 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
    chip-ID: 8086:02c8 class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
  Local Storage: total: 1.82 TiB used: 9.41 GiB (0.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR313 temp: 37.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0E scheme: MBR
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 9.41 GiB (1.0%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: dcd73ffd-b62c-41e5-bdb4-26e48a5992fb
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: F6FC-4F21
  ID-1: /dev/sda1 maj-min: 8:1 size: 931.48 GiB fs: exfat label: UUI
    uuid: 4E21-0000
  ID-2: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
    uuid: 223C-F3F8
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-4:5 info: ASUSTek ROG OMNI RECEIVER type: keyboard,mouse,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 0b05:1ace class-ID: 0300
    serial: <filter>
  Device-2: 1-5:2 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 04f3:0c4b class-ID: 0000
  Device-3: 1-6:3 info: Lite-On Integrated Camera type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 04ca:7070 class-ID: 0e02
  Device-4: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  System Temperatures: cpu: 70.0 C pch: 47.0 C mobo: N/A gpu: amdgpu
    temp: 42.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1172 libs: 344 tools: gnome-software,pamac
    pm: flatpak pkgs: 0
    1: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 288
  1: cpu: 15.9% command: firefox pid: 2237 mem: 467.5 MiB (6.2%)
  2: cpu: 8.3% command: gnome-shell pid: 1512 mem: 257.6 MiB (3.4%)
  3: cpu: 7.3% command: firefox pid: 2429 mem: 255.5 MiB (3.4%)
  4: cpu: 7.1% command: firefox pid: 2511 mem: 266.8 MiB (3.5%)
  5: cpu: 2.6% command: firefox pid: 2613 mem: 445.0 MiB (5.9%)
  Memory top: 5 of 288
  1: mem: 467.5 MiB (6.2%) command: firefox pid: 2237 cpu: 15.9%
  2: mem: 445.0 MiB (5.9%) command: firefox pid: 2613 cpu: 2.6%
  3: mem: 266.8 MiB (3.5%) command: firefox pid: 2511 cpu: 7.1%
  4: mem: 257.6 MiB (3.4%) command: gnome-shell pid: 1512 cpu: 8.3%
  5: mem: 255.5 MiB (3.4%) command: firefox pid: 2429 cpu: 7.3%
  Processes: 288 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.88 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Bash v: 5.2.37 running-in: gnome-terminal
    inxi: 3.3.37
WARNING: running xinput against an Xwayland server. See the xinput man page for details.
⎡ Virtual core pointer                    	id=2	[master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              	id=4	[slave  pointer  (2)]
⎜   ↳ xwayland-pointer:15                     	id=7	[slave  pointer  (2)]
⎜   ↳ xwayland-relative-pointer:15            	id=8	[slave  pointer  (2)]
⎜   ↳ xwayland-pointer-gestures:15            	id=9	[slave  pointer  (2)]
⎣ Virtual core keyboard                   	id=3	[master keyboard (2)]
    ↳ Virtual core XTEST keyboard             	id=5	[slave  keyboard (3)]
    ↳ xwayland-keyboard:15
Hi @The1TruePerson, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip for legibility: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
If all distributions has issues with the touchpad device, there is obviously a lack of driver support with the upstream kernel.
It is possible you can build a driver - but that is not possible to know from the available info.
You could try using hw-probe/README.md at master · linuxhw/hw-probe · GitHub
Perhaps you have a hardware button to toggle the touchpad - something like disable while typing.
Have you tried 6.13?
whats that?
The Latest Stable Kernel…
… be aware it has only 6 months support.
You can install it with
sudo mhwd-kernel -i linux613
I don’t even see the touchpad in the inxi output, so it’s likely:
  1. a Hardware problem; or
  2. disabled in the UEFI/BIOS.
A stab in the dark here, as I don’t know if your touchpad is related to mine:
sudo modprobe -r psmouse && sudo modprobe -a psmouse
… This might get it working, shouldn’t do any harm otherwise.
If it does work, you will probably need to re-issue it after the first sleep cycle following a clean boot. Someone wrote a script for this recently; I’ll have to look for it; especially if it might also be helpful for you.
It is, of course, possible that there is a hardware fault, as Mirdarthos already mentioned. I guess a mouse works OK?
A mouse does work but the touchpad dosent and command dosent do anything. Do please get me the script.
If the command given fails to bring any joy, then it’s likely that any script mentioned as using the same command(s) will also be pointless.
@Mirdarthos has already suggested it may be a hardware issue, or the touchpad may not be enabled in BIOS.
You seem to have ignored this entirely. :eyes:
Did you check that the touchpad is actually enabled in your computer’s BIOS? We need to know this, at least to rule it out as the cause.
If the touchpad is enabled in BIOS; and considering you noted the failure in “MANY distro’s of Linux”; all that remains in a hardware issue. It is broken. That being the case, there is nothing that Members of the Manjaro forum can likely suggest; apart from taking the machine to a licensed Lenovo repair shop.
The script in question does indeed use the same command. :wink:
This reddit post presents 2 solutions:
It may be necessary to do both changes so I’d first install xf86-input-synaptics and try if that works by itself; if not add pci=nocrs to grub and try again.
The underlying issue seems to be that the synaptic touchpad is incorrectly addressed as an Elan device.
i tried but idk how to
You could follow the information now given by @6x12 to see if that brings any joy.
From this point, with respect offering you help, I’m afraid that:
I’ll simply wish you luck.
