Even my keyboard doesn’t work
so boot into manjaro usb and see if it works
also you could switch back to the 5.15 kernel in grub menu and see if that works
I have successfully managed to boot my computer normally now. It boots normally like before. There is no freezing yet, but if it freezes in the future, what should i do?
did you booted with the 5.15 kernel or the 5.4?
install these kernels: 4.19 and 5.10, and when freeze happens switch to the 4.19 in the grub menu
I have booted with 5.4 kernel. And in the advanced options I can see 2 versions of the same kernels. What does that mean?
boot with the normal one not the fallback one…
and install the 5.10 and the 4.19 kernel also
I always select the first option of kernel
I can install these 5.10 and 4.19 kernel from Manjaro settings manger right?
Please install 2 kernels (one of them LTS)
How to boot from USB into live Manjaro (for repair):
Gentle shut down a suddenly hanged PC to minimize a chance of getting a broken filesystem and data loss:
yes from there…
Thank you
i am not able to install kernel from settings manger. it gives a error
error: failed retrieving file ‘linux419-4.19.254-2-x86_64.pkg.tar.zst’ from manjaro.mirror.garr.it : The requested URL returned error: 404
warning: failed to retrieve some files
error: failed to commit transaction (failed to retrieve some files)
Update your mirrors.
what is that ? and how?
sudo pacman-mirrors --fasttrack && sudo pacman -Syyu
Thank you let me try
Should I install any other low end old linux operating system
Did you solve the actual problem?
