I’m running a Thinkpad X13 without issues. In less than the past week, 2 external MyPassport external HDDs have stopped any sort of response when I plug them in. The LED on them doesn’t come on. dmesg shows no log lines, journalctl -f shows nothing. Not sure if there’s somewhere else I should look.
It doesn’t seem like a cable or device issue because the LED comes on when I plug them into a Mac (though they can’t be read because they’re ext fs).
Has anyone else run into issues after some recent update?
Is it possible that the USB port is faulty? Because it sounds like your Thinkpad’s USB isn’t providing power.
I meant to mention that I tried 2 ports in the Thinkpad with the same result.
Some system information would be useful. Post the output from inxi -zv8
Did you try these ports with other USB devices? Just to eliminate it’s not the USB ports issue?
No problems with my external Seagate HDD’s here, which i connected last week.
Edit:
Blow inside your USB Connector, maybe there is some Dust?
Also try another USB Connector.
Optionally, you could try another Linux Kernel, we have several LTS Kernels available.
Pille
1 April 2026 03:21
8
Did you try a different cable or did you try to “squeeze” the connector a bit?
I had a similar issue with a different USB device which stopped working as the connector seem to have some fitting issues.
To get an idea of what is going on, unplug the devices, open a terminal and run
sudo udevadm monitor
Then plug the device and watch the output
Sample of what to expect when attaching a storage device
$ sudo udevadm monitor
[sudo] password for fh:
monitor will print the received events for:
UDEV - the event which udev sends out after rule processing
KERNEL - the kernel uevent
KERNEL[3487.475562] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1 (usb)
KERNEL[3487.475712] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0 (usb)
KERNEL[3487.475820] add /devices/virtual/workqueue/scsi_tmf_20 (workqueue)
KERNEL[3487.475929] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20 (scsi)
KERNEL[3487.476077] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/scsi_host/host20 (scsi_host)
KERNEL[3487.476188] bind /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0 (usb)
KERNEL[3487.476291] bind /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1 (usb)
UDEV [3487.482193] add /devices/virtual/workqueue/scsi_tmf_20 (workqueue)
UDEV [3487.487072] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1 (usb)
UDEV [3487.489910] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0 (usb)
UDEV [3487.491422] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20 (scsi)
UDEV [3487.492961] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/scsi_host/host20 (scsi_host)
UDEV [3487.494403] bind /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0 (usb)
UDEV [3487.498910] bind /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1 (usb)
KERNEL[3488.481693] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0 (scsi)
KERNEL[3488.481785] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0 (scsi)
KERNEL[3488.481912] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0/scsi_device/20:0:0:0 (scsi_device)
KERNEL[3488.482018] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0/scsi_disk/20:0:0:0 (scsi_disk)
KERNEL[3488.482152] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0/bsg/20:0:0:0 (bsg)
UDEV [3488.483946] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0 (scsi)
UDEV [3488.485743] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0 (scsi)
UDEV [3488.487826] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0/scsi_device/20:0:0:0 (scsi_device)
UDEV [3488.488518] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0/scsi_disk/20:0:0:0 (scsi_disk)
UDEV [3488.489110] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0/bsg/20:0:0:0 (bsg)
KERNEL[3488.499165] add /devices/virtual/bdi/8:128 (bdi)
UDEV [3488.501576] add /devices/virtual/bdi/8:128 (bdi)
KERNEL[3488.516201] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0/block/sdi (block)
KERNEL[3488.516316] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0/block/sdi/sdi1 (block)
KERNEL[3488.516383] bind /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0 (scsi)
UDEV [3488.537727] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0/block/sdi (block)
UDEV [3488.560572] add /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0/block/sdi/sdi1 (block)
UDEV [3488.562277] bind /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0 (scsi)
KERNEL[3488.594675] change /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0/block/sdi/sdi1 (block)
UDEV [3488.614790] change /devices/pci0000:20/0000:20:08.1/0000:23:00.3/usb2/2-1/2-1:1.0/host20/target20:0:0/20:0:0:0/block/sdi/sdi1 (block)
$ inxi -zv8
Kernel: 6.12.77-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=bf245b45-a479-4f20-a603-00226b94fdd1 rw quiet
cryptdevice=UUID=0fef95f5-6b2b-4e7b-a332-a4cdee9cc3e5:luks-0fef95f5-6b2b-4e7b-a332-a4cdee9cc3e5
root=/dev/mapper/luks-0fef95f5-6b2b-4e7b-a332-a4cdee9cc3e5 splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.5.6 tk: Qt v: N/A info: frameworks v: 6.24.0
Type: Laptop System: LENOVO product: 20UF0014US v: ThinkPad X13 Gen 1
Mobo: LENOVO model: 20UF0014US v: SDK0J40697 WIN
serial: <superuser required> part-nu: LENOVO_MT_20UF_BU_Think_FM_ThinkPad
X13 Gen 1 uuid: <superuser required> Firmware: UEFI vendor: LENOVO
v: R1CET75W(1.44 ) date: 06/13/2023
ID-1: BAT0 charge: 35.6 Wh (99.7%) condition: 35.8/48 Wh (74.5%)
power: 9.7 W volts: 12.19 min: 11.46 model: SMP 5B10W139 type: Li-poly
serial: <filter> charging: status: discharging control: start: 95%
end: 100% cycles: 2289
System RAM: total: 16 GiB available: 14.85 GiB used: 5.67 GiB (38.2%)
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A1G44AB0-CWE serial: N/A
Info: model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x860010D
desc: 8x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/1700 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 54321
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xtopology
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 06:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 29.0 C
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 6-2:2 chip-ID: 13d3:5406
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: CTO eDP-1-0x0606 built: 2019 res: mode: 1920x1080
hz: 60 scale: 125% (1.25) to: 1536x864 dpi: 168 gamma: 1.2 chroma: red:
x: 0.639 y: 0.325 green: x: 0.302 y: 0.612 blue: x: 0.153 y: 0.055 white:
x: 0.314 y: 0.329 size: 309x174mm (12.17x6.85") diag: 336mm (13.2")
ratio: 15:9, 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900,
1280x800, 1280x720, 1024x768, 800x600, 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.2-arch1.1
renoir ACO DRM 3.61 6.12.77-1-MANJARO) device-ID: 1002:1636
memory: 500 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.341 layers: 2 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 26.0.2-arch1.1
device-ID: 1002:1636 surfaces: N/A
Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.77-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.2 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-4: PulseAudio v: 17.0-98-gb096 status: active with: pulseaudio-alsa
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2400 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-4:3 chip-ID: 8087:0029
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 11 state: up address: see --recommends
Device-1: luks-0fef95f5-6b2b-4e7b-a332-a4cdee9cc3e5 maj-min: 254:0
type: LUKS dm: dm-0 size: 464.34 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 464.34 GiB
Local Storage: total: 953.87 GiB used: 283.22 GiB (29.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-1T00-1001 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 11170101 temp: 24.9 C scheme: GPT
ID-1: / raw-size: 464.34 GiB size: 455.98 GiB (98.20%)
used: 283.17 GiB (62.1%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-0fef95f5-6b2b-4e7b-a332-a4cdee9cc3e5 label: N/A
uuid: bf245b45-a479-4f20-a603-00226b94fdd1
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 52.3 MiB (20.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: D69D-5BF9
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
label: WinRE_DRV uuid: 78B2A077B2A03B8E
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 488.28 GiB fs: ext4 label: N/A
uuid: 8e981ab2-e4f0-4607-b2c4-587a6db04c7d
Hub-2: 2-0:1 info: full speed or root hub ports: 1 rev: 2.0
Hub-3: 3-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-4: 4-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 4-3:4 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-2: 4-4:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-5: 5-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 6-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 6-2:2 info: IMC Networks Integrated Camera type: video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:5406 class-ID: fe01
serial: <filter>
Hub-7: 7-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 31.0 C mobo: N/A gpu: amdgpu temp: 29.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Packages: 2063 pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr
pkgs: 28 libs: 5 pm: pacman pkgs: 2030 libs: 486 tools: pamac pm: flatpak
pkgs: 5
1: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
2: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
6: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
7: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
9: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
10: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
11: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
12: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
13: https://mirror.fcix.net/manjaro/stable/$repo/$arch
14: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
15: https://muug.ca/mirror/manjaro/stable/$repo/$arch
16: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
17: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
18: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
19: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
20: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
22: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
Active nix channels for user: akkartik
1: nixpkgs https://nixos.org/channels/nixpkgs-unstable
Processes:
CPU top: 5 of 439
1: cpu: 14.2% command: konsole pid: 51852 mem: 265.9 MiB (1.7%)
2: cpu: 2.7% command: zsh pid: 51874 mem: 7.90 MiB (0.0%)
3: cpu: 0.8% command: waterfox pid: 51645 mem: 115.7 MiB (0.7%)
4: cpu: 0.8% command: waterfox pid: 51649 mem: 116.0 MiB (0.7%)
5: cpu: 0.7% command: waterfox pid: 40801 mem: 775.2 MiB (5.0%)
Memory top: 5 of 439
1: mem: 775.2 MiB (5.0%) command: waterfox pid: 40801 cpu: 0.7%
2: mem: 624.1 MiB (4.1%) command: plasmashell pid: 1270 cpu: 0.0%
3: mem: 559.0 MiB (3.6%) command: waterfox pid: 41160 cpu: 0.1%
4: mem: 530.2 MiB (3.4%) command: seamonkey pid: 43128 cpu: 0.0%
5: mem: 509.0 MiB (3.3%) command: waterfox pid: 41197 cpu: 0.0%
Processes: 439 Power: uptime: 4d 21h 34m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 9 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 5.9 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
tool: systemctl
Compilers: clang: 22.1.1 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.40
nitja
2 April 2026 00:14
11
While I don’t think I’ve “solved” the issue, reading how it disappeared on my laptop (Data storage devices @ usb ports stopped working on one machine after today's bundled update … - #2 by nitja ) might “solve” it for you as well.
akkartik:
uptime: 4d 21h 34m
Well, reboot after upgrading the kernel.
Erim
3 April 2026 07:37
13
Were the USB ports on the same side of the laptop?
If yes, try the other side.
USB ports on the same side/close to each other are often connected to the same controller and thereby fail together.
Besides that a restart as @megavolt suggested might work miracles.
I did an autoupdate (but not a kernel upgrade), shut it down overnight (albeit before the reboot), tried another device and also ran sudo udevadm monitor while plugging in the drive. And it works now! Not sure which suggestion fixed it Thanks everyone.
