USB ports broken for 2 months
I’m having a repeat of my issue from March: I’m on a Thinkpad X13 running KDE Plasma. All my USB devices have stopped working on any of my USB ports. The lights on the devices don’t come on. My devices work when plugged into other machines. sudo udevadm monitor shows no output when I plug in a device. No pending updates. Here is the output of inxi:
$ inxi -zv8
  Kernel: 6.18.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    root=UUID=bf245b45-a479-4f20-a603-00226b94fdd1 rw quiet
    cryptdevice=UUID=0fef95f5-6b2b-4e7b-a332-a4cdee9cc3e5:luks-0fef95f5-6b2b-4e7b-a332-a4cdee9cc3e5
    root=/dev/mapper/luks-0fef95f5-6b2b-4e7b-a332-a4cdee9cc3e5 splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.29.0
  Type: Laptop System: LENOVO product: 20UF0014US v: ThinkPad X13 Gen 1
  Mobo: LENOVO model: 20UF0014US v: SDK0J40697 WIN
    serial: <superuser required> part-nu: LENOVO_MT_20UF_BU_Think_FM_ThinkPad
    X13 Gen 1 uuid: <superuser required> Firmware: UEFI vendor: LENOVO
    v: R1CET75W(1.44 ) date: 06/13/2023
  ID-1: BAT0 charge: 22 Wh (61%) condition: 36/48 Wh (75%) power: 5.7 W
    volts: 11.34 min: 11.46 model: SMP 5B10W139 type: Li-poly serial: <filter>
    charging: status: discharging control: start: 95% end: 100% cycles: 2507
  System RAM: total: 16 GiB available: 14.85 GiB used: 1.24 GiB (8.4%)
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A1G44AB0-CWE serial: N/A
  Info: model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x860010D
    desc: 8x512 KiB L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 1397 min/max: 1400/1700 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397 3: 1397
    4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1397
    13: 1397 14: 1397 15: 1397 16: 1397 bogomips: 54296
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
    ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
    smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
    syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
    Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 06:00.0
    chip-ID: 1002:1636 class-ID: 0300 temp: 40.0 C
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 6-2:2 chip-ID: 13d3:5406
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: Lenovo 0x4098 built: 2019 res: mode: 1920x1080
    hz: 60 scale: 125% (1.25) to: 1536x864 dpi: 168 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.325 green: x: 0.302 y: 0.612 blue: x: 0.153 y: 0.055 white:
    x: 0.314 y: 0.329 size: 309x174mm (12.17x6.85") diag: 336mm (13.2")
    ratio: 15:9, 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900,
    1280x800, 1280x720, 1024x768, 800x600, 640x480
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir ACO DRM
    3.64 6.18.49-1-MANJARO) device-ID: 1002:1636 memory: 500 MiB unified: yes
    display-ID: :1.0
  API: Vulkan v: 1.4.357 layers: 2 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 26.2.2-arch1.1
    device-ID: 1002:1636 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
    bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.18.49-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-4: PulseAudio v: 17.0-98-gb096 status: active with: pulseaudio-alsa
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2400 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0f0 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-4:3 chip-ID: 8087:0029
    class-ID: e001
  Device-1: luks-0fef95f5-6b2b-4e7b-a332-a4cdee9cc3e5 maj-min: 253:0
    type: LUKS dm: dm-0 size: 464.34 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 464.34 GiB
  Local Storage: total: 953.87 GiB used: 337.75 GiB (35.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
    SDBQNTY-1T00-1001 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 11170101 temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 464.34 GiB size: 455.98 GiB (98.20%)
    used: 337.7 GiB (74.1%) fs: ext4 dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-0fef95f5-6b2b-4e7b-a332-a4cdee9cc3e5 label: N/A
    uuid: bf245b45-a479-4f20-a603-00226b94fdd1
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 52.3 MiB (20.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SYSTEM uuid: D69D-5BF9
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
    label: WinRE_DRV uuid: 78B2A077B2A03B8E
  ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 488.28 GiB fs: ext4 label: N/A
    uuid: 8e981ab2-e4f0-4607-b2c4-587a6db04c7d
  Hub-2: 2-0:1 info: full speed or root hub ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-4: 4-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 4-3:2 info: Synaptics Prometheus MIS Touch Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
  Device-2: 4-4:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-5: 5-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 6-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 6-2:2 info: IMC Networks Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:5406 class-ID: fe01
    serial: <filter>
  Hub-7: 7-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
  Fan Speeds (rpm): fan-1: 3400 fan-2: 3400
  Packages: 2123 pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr
    pkgs: 28 libs: 5 pm: pacman pkgs: 2090 libs: 495 tools: pamac pm: flatpak
    pkgs: 5
    1: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    2: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    3: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    9: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    10: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    11: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    13: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    15: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    16: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    17: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    18: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    20: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    22: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
  Active nix channels for user: akkartik
    1: nixpkgs https://nixos.org/channels/nixpkgs-unstable
Processes:
  CPU top: 5 of 386
  1: cpu: 100% command: ps pid: 1827 mem: 3.80 MiB (0.0%)
  2: cpu: 5.3% command: plasmashell pid: 1132 mem: 345.4 MiB (2.2%)
  3: cpu: 2.9% command: kwin_wayland pid: 986 mem: 199.8 MiB (1.3%)
  4: cpu: 1.6% command: init pid: 1 mem: 14.4 MiB (0.0%)
  5: cpu: 1.5% command: konsole pid: 1557 mem: 103.9 MiB (0.6%)
  Memory top: 5 of 386
  1: mem: 345.4 MiB (2.2%) command: plasmashell pid: 1132 cpu: 5.3%
  2: mem: 199.8 MiB (1.3%) command: kwin_wayland pid: 986 cpu: 2.9%
  3: mem: 103.9 MiB (0.6%) command: konsole pid: 1557 cpu: 1.5%
  4: mem: 96.5 MiB (0.6%) command: msm_kde_notifier pid: 1394 cpu: 0.4%
  5: mem: 90.9 MiB (0.5%) command: kded6 pid: 1118 cpu: 0.6%
  Processes: 386 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.9 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.8 gcc: 16.2.1 Shell: vim default: Zsh v: 5.9.2
    running-in: konsole inxi: 3.3.41
you should update your UEFI laptop
Have you tried a live ISO boot? If this happens, too then you either have a firmware or hardware issue.
Thank you both! Upgrading firmware fixed it. I’d forgotten firmware exists.
