Data storage devices @ usb ports stopped working on one machine after today's bundled update …
I’m running manjaro on 2 computers, a laptop and a desktop.
Due to a severe accident on last Christmas Eve (which smashed my pelvis: 2 months hospital and finally a 3 weeks rehab) I used my laptop exclusively in these last 3 weeks and all usb ports, external sticks, and disks worked perfectly.
When I returned home today both machines (the long unused desktop and the laptop) showed the pending update (300+ packages).
After the update the desktop works pretty well, but the laptop doesn’t see any external storage device anymore. (Tested all 3 usb ports, 2 sticks, and 1 2-TB-SSD - all working yesterday - and still at the desktop’s usb ports.)
26·04·01 inxi output @desktop
[tn@23ed538 ~]$ inxi -zv8
  Kernel: 6.6.128-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=d25d1a9b-c6a7-48d7-a710-98f6ca1bb234 rw quiet splash
    udev.log_priority=3
  Desktop: GNOME v: 49.5 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: FUJITSU product: ESPRIMO D538 v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: FUJITSU model: D3600-A1 v: S26361-D3600-A1
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: FUJITSU // American Megatrends v: 5.0.0.13 R1.21.0 for D3600-A1x
    date: 07/04/2019
  System RAM: total: 32 GiB available: 30.2 GiB used: 19.25 GiB (63.7%)
  Device-1: DIMM CHA1 type: DDR4 detail: synchronous size: 16 GiB speed:
    spec: 3200 MT/s actual: 2400 MT/s volts: curr: 1 width (bits): data: 64
    total: 64 manufacturer: Crucial part-no: CP16G4DFRA32A.C8FF
    serial: <filter>
  Device-2: DIMM CHB2 type: DDR4 detail: synchronous size: 16 GiB speed:
    spec: 3200 MT/s actual: 2400 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Crucial
    part-no: CP16G4DFRA32A.C8FF serial: <filter>
  Info: model: Intel Pentium Gold G5600 bits: 64 type: MT MCP
    arch: Coffee Lake level: v2 built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xF6
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1470 min/max: 800/3900 scaling: driver: intel_pstate
    governor: powersave cores: 1: 1470 2: 1470 3: 1470 4: 1470 bogomips: 31211
  Flags: 3dnowprefetch abm acpi aes aperfmperf apic arat arch_capabilities
    arch_perfmon art bts clflush clflushopt cmov constant_tsc cpuid
    flexpriority flush_l1d fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
    hwp_notify ibpb ibpb_exit_to_user ibrs intel_pt invpcid lahf_lm lm mca
    mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
    rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
    xsaves xtopology xtpr
    vulnerable
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630]
    vendor: Fujitsu Solutions driver: i915 v: kernel arch: Gen-9.5
    process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1,HDMI-A-2
    empty: DP-1, DP-2, DP-3, HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:3e91
    class-ID: 0300
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-1 model: Samsung S27D390 serial: <filter> built: 2015
    res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.647 y: 0.337 green:
    x: 0.329 y: 0.616 blue: x: 0.145 y: 0.055 white: x: 0.314 y: 0.329
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
  Monitor-2: HDMI-A-2 model: HS156PC built: 2021 res: 1920x1080 dpi: 163
    gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue:
    x: 0.149 y: 0.059 white: x: 0.314 y: 0.329 size: 345x194mm (13.58x7.64")
    diag: 397mm (15.6") ratio: 5:4 modes: 1920x1080, 1600x900, 1280x1024,
    1152x864, 1280x720, 1024x768, 800x600, 640x480
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) device-ID: 8086:3e91 memory: 29.5 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xdpyinfo,xprop
  Device-1: Intel Cannon Lake PCH cAVS vendor: Fujitsu Solutions
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  API: ALSA v: k6.6.128-1-MANJARO status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
    vendor: Fujitsu Solutions driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter
    driver: rtl8xxxu type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-8:5 chip-ID: 0bda:f179 class-ID: 0000 serial: <filter>
  IF: wlp0s20f0u8 state: down mac: <filter>
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3
    chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 2.79 TiB used: 426.8 GiB (15.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 25.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 0A82 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Ultra Fit
    size: 57.84 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 93.13 GiB size: 91.11 GiB (97.83%) used: 29.93 GiB (32.8%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: cme1t.manjaro_g
    uuid: d25d1a9b-c6a7-48d7-a710-98f6ca1bb234
  ID-2: /boot/efi raw-size: 954 MiB size: 952.1 MiB (99.80%)
    used: 5.5 MiB (0.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: CME1T_EFI uuid: 4A16-8340
  ID-3: /home raw-size: 93.13 GiB size: 91.11 GiB (97.83%)
    used: 1.75 GiB (1.9%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    label: cme1t.mg_home uuid: 98bd367d-22a4-4028-906e-2f5ae44f1f17
  ID-4: /mnt/bkp raw-size: 931.32 GiB size: 915.64 GiB (98.32%)
    used: 226.76 GiB (24.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
    label: wd2t.bkp uuid: 46399e9f-c924-418b-b49e-fd610ab96b4f
  ID-5: /mnt/data raw-size: 372.72 GiB size: 365.81 GiB (98.15%)
    used: 168.28 GiB (46.0%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    label: cme1t.data uuid: 75b32bf9-4850-4499-94d6-cb737cc173d9
  ID-1: swap-1 type: partition size: 36.32 GiB used: 71.8 MiB (0.2%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 8a3d6405-5b6b-4989-9631-0d94e08239f5
  ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 93.13 GiB fs: ext4
    label: cme1t.manjaro_k uuid: d82e7bbf-2581-4d11-91fa-5cf19f5efb6d
  ID-2: /dev/nvme0n1p6 maj-min: 259:6 size: 93.13 GiB fs: ext4
    label: cme1t.mk_home uuid: f66763f4-5866-4c31-9e2a-793571ac5adb
  ID-3: /dev/nvme0n1p8 maj-min: 259:8 size: 18.63 GiB fs: ext4
    label: cme1t.mg_test uuid: db10dd45-b09e-4aa9-8e5a-c9169aad751d
  ID-4: /dev/nvme0n1p9 maj-min: 259:9 size: 18.63 GiB fs: ext4
    label: cme1t.mgt_home uuid: 3f28027a-6fc9-4a3e-9e23-38c4bbdae08c
  ID-5: /dev/sda2 maj-min: 8:2 size: 372.9 GiB fs: ext4 label: wd2t.backup
    uuid: d13f645b-d2ee-4af6-9ae7-ed84a4355e2e
  ID-6: /dev/sda3 maj-min: 8:3 size: 1024 KiB fs: ext4 label: wd2t.dummy
    uuid: 1d8df0e9-6028-42e1-8c69-da2e78aba055
  ID-7: /dev/sda5 maj-min: 8:5 size: 558.79 GiB fs: ext4 label: wd2t.bkp.old
    uuid: 0ccc4358-5553-49be-a2d5-62fcce9e24d9
  ID-8: /dev/sdb1 maj-min: 8:17 size: 57.84 GiB fs: ext4 label: Transporter
    uuid: 6b52de8e-1520-4301-baa8-263317452d48
  Device-1: 1-5:2 info: SHARKOON GmbH [Mediatrack Edge Mini Keyboard]
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 1ea7:0066 class-ID: 0301
  Device-2: 1-6:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-7.1:6 info: YICHIP Wireless Device type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:1001 class-ID: 0301
  Device-2: 1-8:5 info: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN
    Adapter type: Network driver: rtl8xxxu interfaces: 1 rev: 2.0
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Device-1: 2-4:4 info: SanDisk Ultra Fit type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5583 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 34.0 C pch: 46.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1702 libs: 428
    tools: gnome-software,pamac,yay
    1: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    4: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    5: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    6: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    7: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    8: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 298
  1: cpu: 18.7% command: firefox pid: 27789 mem: 3083.1 MiB (9.9%)
  2: cpu: 18.0% command: gnome-shell pid: 1763 mem: 485.5 MiB (1.5%)
  3: cpu: 5.9% command: firefox pid: 28151 mem: 726.7 MiB (2.3%)
  4: cpu: 2.5% command: Data4tn started-by: nemo pid: 71596
    mem: 162.5 MiB (0.5%)
  5: cpu: 1.9% command: firefox pid: 29384 mem: 1281.4 MiB (4.1%)
  Memory top: 5 of 298
  1: mem: 3083.1 MiB (9.9%) command: firefox pid: 27789 cpu: 18.7%
  2: mem: 1281.4 MiB (4.1%) command: firefox pid: 29384 cpu: 1.9%
  3: mem: 1259.6 MiB (4.0%) command: thunderbird pid: 3568 cpu: 0.9%
  4: mem: 982.7 MiB (3.1%) command: firefox pid: 55030 cpu: 1.6%
  5: mem: 953.0 MiB (3.0%) command: firefox pid: 54848 cpu: 0.5%
  Processes: 298 Power: uptime: 4h 37m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.07 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.1 gcc: 15.2.1 Shell: Bash v: 5.3.9
    running-in: gnome-terminal inxi: 3.3.40
[tn@23ed538 ~]$
26·04·01 inxi output @laptop
    ~  inxi -zv8         ✔
  Kernel: 6.18.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=ab46277f-9387-4ba4-a78d-c5d85119857d rw quiet splash apparmor=1
    security=apparmor udev.log_priority=3 sysrq_always_enabled=1
    base: Arch Linux
  Type: Laptop System: FUJITSU product: CELSIUS H780 v: N/A
  Mobo: FUJITSU model: FJNBB5D v: 757383-01R9500225
    serial: <superuser required> part-nu: SK00 uuid: <superuser required>
    Firmware: UEFI vendor: FUJITSU // Insyde v: Version 1.22 date: 11/16/2023
  ID-1: BAT1 charge: 78.8 Wh (93.3%) condition: 84.5/96.5 Wh (87.5%)
    volts: 16.39 min: 14.4 model: PAC CP722160-01 type: Li-ion serial: <filter>
    charging: status: not charging cycles: 20
  System RAM: total: 32 GiB available: 30.99 GiB used: 2.3 GiB (7.4%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    speed: 2400 MT/s volts: curr: 1 min: 1.35 max: 1.35 width (bits): data: 64
    total: 64 manufacturer: SK Hynix part-no: HMA82GS6AFR8N-UH
    serial: <filter>
  Device-2: ChannelA-DIMM1 type: no module installed
  Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    serial: <filter>
  Device-4: ChannelB-DIMM1 type: no module installed
  Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 52799
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Fujitsu
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
    class-ID: 0300
  Device-2: NVIDIA GP107GLM [Quadro P600 Mobile] vendor: Fujitsu driver: N/A
    non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
    arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1cbc class-ID: 0300
  Device-3: Chicony FJ Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 04f2:b3b4
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
    display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x0630 built: 2016 res: 1920x1080
    dpi: 142 gamma: 1.2 chroma: red: x: 0.584 y: 0.365 green: x: 0.349 y: 0.580
    blue: x: 0.161 y: 0.141 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080
    GT2) device-ID: 8086:3e9b memory: 30.27 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xdpyinfo,xprop
  Device-1: Intel Cannon Lake PCH cAVS vendor: Fujitsu driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio vendor: Fujitsu
    bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  API: ALSA v: k6.18.12-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  Device-2: Intel Ethernet I219-LM vendor: Fujitsu driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  IF-ID-1: wwp0s20f0u4i12 state: down mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
  Local Storage: total: 476.94 GiB used: 177.85 GiB (37.3%)
    model: MZVLB512HAJQ-00007 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: EXA7302Q temp: 27.9 C scheme: GPT
  ID-1: / raw-size: 46.57 GiB size: 45.53 GiB (97.78%) used: 30 GiB (65.9%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: sme_5.ManjaroGNM
    uuid: ab46277f-9387-4ba4-a78d-c5d85119857d
  ID-2: /boot/efi raw-size: 477 MiB size: 476 MiB (99.80%)
    used: 440 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SME_5_EFI uuid: 407C-EF8F
  ID-3: /home raw-size: 9.31 GiB size: 9.07 GiB (97.38%)
    used: 6.59 GiB (72.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    label: sme_5.MG_home uuid: 81135bcb-ea8f-40df-a191-f9f889f914e7
  ID-4: /mnt/bkp raw-size: 176.59 GiB size: 172.76 GiB (97.83%)
    used: 116.96 GiB (67.7%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    label: sme_5.MG_backup uuid: c36ae656-eb75-4218-8828-26090d9b1dec
  ID-5: /mnt/data raw-size: 149.01 GiB size: 145.61 GiB (97.72%)
    used: 24.3 GiB (16.7%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    label: sme_5.data uuid: fae9353f-dda4-4b69-9f6e-5179fa11200c
  ID-1: swap-1 type: partition size: 39.12 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p8 maj-min: 259:8 label: sme_5.swap
    uuid: 136dda25-3200-4c4d-8cd7-dce0de17bdd8
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 46.57 GiB fs: ext4
    label: sme_5.ManjaroKDE uuid: 25f5f5ad-49fe-495c-861f-513c2bb77042
  ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 9.31 GiB fs: ext4
    label: sme_5.MK_home uuid: 2f771f65-7d0a-4dc7-9b37-decd655d959f
  Device-1: 1-2:6 info: Areson Corp Elecom MR-K013 Multicard Reader
    chip-ID: 25a7:fa61 class-ID: 0301
  Device-2: 1-4:3 info: Sierra Wireless EM7455 type: communication,CDC-data
    driver: cdc_mbim interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 1199:9075 class-ID: 0a00
    serial: <filter>
  Device-3: 1-7:4 info: Chicony FJ Camera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b3b4 class-ID: 0e02 serial: <filter>
  Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
  Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
  System Temperatures: cpu: 40.0 C pch: 48.0 C mobo: N/A
  Packages: pm: pacman pkgs: 1564 libs: 411 tools: gnome-software,pamac,yay
    pm: flatpak pkgs: 0
    1: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    3: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    4: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    5: https://mirror.23m.com/manjaro/stable/$repo/$arch
    6: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    7: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    8: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    9: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    10: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    11: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    12: https://manjaro.ynh.ovh/stable/$repo/$arch
Processes:
  CPU top: 5 of 328
  1: cpu: 50.0% command: localsearch-extractor-3 pid: 104886
    mem: 49.5 MiB (0.1%)
  2: cpu: 10.2% command: gnome-shell pid: 2335 mem: 468.6 MiB (1.4%)
  3: cpu: 1.0% command: zsh pid: 104708 mem: 10.5 MiB (0.0%)
  4: cpu: 0.6% command: gjs pid: 4486 mem: 92.0 MiB (0.2%)
  5: cpu: 0.4% command: tzclock pid: 2505 mem: 54.6 MiB (0.1%)
  Memory top: 5 of 328
  1: mem: 468.6 MiB (1.4%) command: gnome-shell pid: 2335 cpu: 10.2%
  2: mem: 294.5 MiB (0.9%) command: /newerversion started-by: dropbox
    pid: 4455 cpu: 0.3%
  3: mem: 130.6 MiB (0.4%) command: ??.tn started-by: nemo pid: 73349
    cpu: 0.2%
  4: mem: 129.4 MiB (0.4%) command: gjs pid: 4345 cpu: 0.0%
  5: mem: 120.0 MiB (0.3%) command: gedit pid: 48790 cpu: 0.2%
  Processes: 328 Power: uptime: 5h 0m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.34 GiB services: gsd-power,
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: gnome-terminal
    inxi: 3.3.40
    ~          ✔  4s 
On account of @linux-aarhus’ advice in Multiple external HDDs not responding in the past week - #9 by linux-aarhus I tried the udevadm monitor:
26·04·01 udevadm monitor output @desktop
[tn@23ed538 ~]$ sudo udevadm monitor
[sudo] Passwort für tn:
monitor will print the received events for:
UDEV - the event which udev sends out after rule processing
KERNEL - the kernel uevent
KERNEL[15106.872834] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/bsg/4:0:0:0 (bsg)
KERNEL[15106.873173] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/scsi_device/4:0:0:0 (scsi_device)
KERNEL[15106.873516] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/scsi_disk/4:0:0:0 (scsi_disk)
KERNEL[15106.873875] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/block/sdb/sdb1 (block)
KERNEL[15106.874064] remove   /devices/virtual/bdi/8:16 (bdi)
KERNEL[15106.874616] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV  [15106.899958] remove   /devices/virtual/bdi/8:16 (bdi)
KERNEL[15106.901296] unbind   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0 (scsi)
KERNEL[15106.901520] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0 (scsi)
UDEV  [15106.901726] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/scsi_device/4:0:0:0 (scsi_device)
KERNEL[15106.901931] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0 (scsi)
KERNEL[15106.902114] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/scsi_host/host4 (scsi_host)
KERNEL[15106.902297] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4 (scsi)
UDEV  [15106.903540] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/scsi_disk/4:0:0:0 (scsi_disk)
UDEV  [15106.905873] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/bsg/4:0:0:0 (bsg)
UDEV  [15106.907003] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/scsi_host/host4 (scsi_host)
UDEV  [15106.909118] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/block/sdb/sdb1 (block)
UDEV  [15106.915907] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[15106.918837] remove   /devices/virtual/workqueue/scsi_tmf_4 (workqueue)
KERNEL[15106.919058] unbind   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0 (usb)
KERNEL[15106.920094] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0 (usb)
KERNEL[15106.921075] unbind   /devices/pci0000:00/0000:00:14.0/usb2/2-4 (usb)
KERNEL[15106.921285] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4 (usb)
UDEV  [15106.923594] remove   /devices/virtual/workqueue/scsi_tmf_4 (workqueue)
UDEV  [15106.924493] unbind   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0 (scsi)
UDEV  [15106.926572] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0 (scsi)
UDEV  [15106.929417] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0 (scsi)
UDEV  [15106.931908] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4 (scsi)
UDEV  [15106.936773] unbind   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0 (usb)
UDEV  [15106.938362] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0 (usb)
UDEV  [15106.943131] unbind   /devices/pci0000:00/0000:00:14.0/usb2/2-4 (usb)
UDEV  [15106.946833] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-4 (usb)
KERNEL[15131.120505] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4 (usb)
KERNEL[15131.122975] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0 (usb)
KERNEL[15131.123647] add      /devices/virtual/workqueue/scsi_tmf_4 (workqueue)
KERNEL[15131.124003] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4 (scsi)
KERNEL[15131.124369] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/scsi_host/host4 (scsi_host)
KERNEL[15131.124770] bind     /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0 (usb)
KERNEL[15131.125207] bind     /devices/pci0000:00/0000:00:14.0/usb2/2-4 (usb)
UDEV  [15131.143648] add      /devices/virtual/workqueue/scsi_tmf_4 (workqueue)
UDEV  [15131.152921] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4 (usb)
UDEV  [15131.159570] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0 (usb)
UDEV  [15131.163883] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4 (scsi)
UDEV  [15131.168112] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/scsi_host/host4 (scsi_host)
UDEV  [15131.173904] bind     /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0 (usb)
UDEV  [15131.184759] bind     /devices/pci0000:00/0000:00:14.0/usb2/2-4 (usb)
KERNEL[15132.133951] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0 (scsi)
KERNEL[15132.134410] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0 (scsi)
KERNEL[15132.134740] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/scsi_device/4:0:0:0 (scsi_device)
KERNEL[15132.135087] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/bsg/4:0:0:0 (bsg)
KERNEL[15132.135448] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/scsi_disk/4:0:0:0 (scsi_disk)
UDEV  [15132.141345] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0 (scsi)
KERNEL[15132.143884] add      /devices/virtual/bdi/8:16 (bdi)
UDEV  [15132.150962] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0 (scsi)
UDEV  [15132.151669] add      /devices/virtual/bdi/8:16 (bdi)
UDEV  [15132.158901] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/scsi_device/4:0:0:0 (scsi_device)
UDEV  [15132.159986] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/bsg/4:0:0:0 (bsg)
UDEV  [15132.161063] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/scsi_disk/4:0:0:0 (scsi_disk)
KERNEL[15132.163139] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[15132.163571] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/block/sdb/sdb1 (block)
KERNEL[15132.163897] bind     /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0 (scsi)
UDEV  [15132.229624] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV  [15132.295902] add      /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0/block/sdb/sdb1 (block)
UDEV  [15132.298182] bind     /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host4/target4:0:0/4:0:0:0 (scsi)
Same device (stick) at 2 different ports (both work for other devices - tried e.g. a non-bluetooth-mouse’s adapter):
26·04·01 udevadm monitor output @laptop
    ~  sudo udevadm monitor                                                  ✔
KERNEL[16387.883463] add      /devices/pci0000:00/0000:00:14.0/usb2/2-2 (usb)
KERNEL[16387.887071] add      /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0 (usb)
KERNEL[16387.887504] bind     /devices/pci0000:00/0000:00:14.0/usb2/2-2 (usb)
UDEV  [16387.934872] add      /devices/pci0000:00/0000:00:14.0/usb2/2-2 (usb)
UDEV  [16387.943541] add      /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0 (usb)
UDEV  [16387.960660] bind     /devices/pci0000:00/0000:00:14.0/usb2/2-2 (usb)
UDEV  [16555.729717] remove   /devices/pci0000:00/0000:00:14.0/usb2/2-2 (usb)
KERNEL[16577.474944] add      /devices/pci0000:00/0000:00:14.0/usb2/2-1 (usb)
KERNEL[16577.476968] add      /devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.0 (usb)
KERNEL[16577.477644] bind     /devices/pci0000:00/0000:00:14.0/usb2/2-1 (usb)
UDEV  [16577.524116] add      /devices/pci0000:00/0000:00:14.0/usb2/2-1 (usb)
UDEV  [16577.535766] add      /devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.0 (usb)
UDEV  [16577.555379] bind     /devices/pci0000:00/0000:00:14.0/usb2/2-1 (usb)
Any idea how let a file manager see external storage on the laptop again?
Shutting the laptop down and switching it on again after 5 minutes, the issue “magically” disappeared.
While I still wonder about the reason for its appearance (so I didn’t mark this as a “solution”) there’s no more urgency in this topic.
Edit: perhaps it’s been just an April fool hoax?
Bro, a kernel upgrade requires a reboot. After updating, your system was still running the old kernel in RAM while the matching kernel modules on the hard drive had already been replaced by the new ones. When you plugged in a USB storage device, the kernel detected the hardware, but was unable to load the required module, resulting in a kernel module version mismatch.
I’m pretty sure that I did reboot the machine immediately after the update and that only powering it off & on did the trick.
Not magic - one idea is that you have forgotten to restart the system after the system update - especially filesystems are very picky about this.
Oh well :face_with_open_eyes_and_hand_over_mouth: … on account of @megavolt’s last post in Multiple external HDDs not responding in the past week I remembered how to check seriously whether I really rebooted the machine (uptime in inxi, above post 1) and see that I indeed had forgotten that one when I updated both machines at the same time.
So I’ll mark @megavolt as the solver.
