MSI Modern 14 with Ryzen 5 4500U touchpad detected but not working
Touchpad not working
I installed manjaro in live os mouse is working but after installation not working
No click working no moving
No touch sensing
Also one important thing
When i updated all kde plasma 5.22 is there first it is changed to 5.26.4
After update process touchpad start working
But after reboot happen again
Lastest not working
I think some packages installed thats why runned and after that packages upgraded after reboot
And touchpad stop working
Pls help me
Hi @Newbienoob, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Also, if your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
  **Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0**
    root=UUID=5437603d-4834-4f0d-b647-c4aa2d74cd01 rw quiet
    udev.log_priority=3
  **Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM**
**    Distro: Manjaro Linux base: Arch Linux**
  Type: Laptop System: Micro-Star product: Modern 14 B4MW v: REV:1.0
  Mobo: Micro-Star model: MS-14DK v: REV:1.0 serial: <superuser required>
    BIOS: American Megatrends v: E14DKAMS.111 date: 11/18/2020
  ID-1: BAT1 charge: 36.6 Wh (86.1%) condition: 42.5/52.4 Wh (81.1%)
    volts: 11.9 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
    status: discharging
  RAM: total: 7.17 GiB used: 1.71 GiB (23.9%)
  **Info: model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP**
**    arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22**
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600104
  Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
    desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1445 high: 1657 min/max: 1400/2375 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
    3: 1657 4: 1397 5: 1397 6: 1430 bogomips: 28462
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    prctl and seccomp
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Renoir vendor: Micro-Star MSI driver: amdgpu v: kernel
    arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 34.0 C
  Device-2: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 3-4:2
    chip-ID: 5986:211c class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x08d7 built: 2019
    res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
    diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6 Mesa 22.2.4 renderer: AMD Radeon Graphics (renoir LLVM
    14.0.6 DRM 3.42 5.15.81-1-MANJARO) direct render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1
    chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Micro-Star MSI
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
    bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.61 running: no
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0
    chip-ID: 10ec:c822 class-ID: 0280
  Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 1-1:2 chip-ID: 13d3:3549 class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 484.21 GiB used: 19.35 GiB (4.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
    lanes: 4 type: SSD serial: <filter> rev: P6MA001 temp: 34.9 C scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Sony model: Storage Media
    size: 7.27 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: 0100 scheme: MBR
  ID-1: / raw-size: 476.93 GiB size: 468.38 GiB (98.21%) used: 14.27 GiB (3.0%)
    fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 5437603d-4834-4f0d-b647-c4aa2d74cd01
  ID-2: /run/media/edith/Ventoy raw-size: 7.23 GiB size: 7.23 GiB (99.99%)
    used: 5.08 GiB (70.2%) fs: exfat dev: /dev/sda1 maj-min: 8:1 label: Ventoy
    uuid: 9529-8526
  ID-1: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
    uuid: C559-2E5D
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 1-1:2 info: IMC Networks Bluetooth Radio type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
  Device-2: 1-3:3 info: Silicon Labs USB OPTICAL MOUSE type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
    power: 100mA chip-ID: 10c4:8108 class-ID: 0301
  Device-3: 1-4:4 info: Realtek RTS5129 Card Reader Controller
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
    class-ID: ff00 serial: <filter>
  Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:3 info: Sony Storage Media type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
    chip-ID: 054c:05ba class-ID: 0806 serial: <filter>
  Device-2: 3-4:2 info: Acer HD Webcam type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:211c
    class-ID: 0e02
  Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 34.8 C mobo: N/A gpu: amdgpu temp: 33.0 C
  Processes: 223 Uptime: 18m wakeups: 1 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
  pkgs: 1112 libs: 307 tools: pamac Shell: Zsh v: 5.9 default: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.24
update i tried all solutions but nothing works i tried synaptic packages base packages als libinput but not worked
Try to switch X11 to Wayland.
  1. Install plasma-wayland-session
  2. reboot
  3. switch X11 to Wayland on the login screen.
  4. Login.
I heard and also experienced that the touchpad works more smoothly in Wayland than Xorg.
@Mirdarthos @Zesko
Your solutions did not work it’s driver issue I think
Touchpad is detected but no touch sensing clicks
I said one thing when I changed to kde 22 to kde 26.4 in the middle of update my touchpad started working
But after reboot it’s gone
