Mouse that freezes
Hello friends,
I have a problem with USB mice. 30 seconds after starting the session, the mouse pointer stops moving.
I tried with a wired mouse and two bluetooth mice always Logitech for the same result.
I used timeshift but the problem comes back with the updates. I tried to boot on older kernels: same thing. I tried a complete reinstallation and still the same problem.
I have a dual boot with windows and the mice work fine. :frowning:
Dmesg
Dmesg | grep USB
Does not return anything conclusive and
Lsusb returns the good model of the mouse.
The battery is at 50%.
The machine is a Lenovo laptop ideapad 3 S145-15API.
ryzen 7 3700u with radeon Vega on chipset.
Can anyone think of a way to solve the problem please.
Hi @Prisme, and welcome!
While I have absolutely no idea what the problem could be, so will not be able to help you, please see How to provide good information and if applicable [HowTo] post screenshots and links for anyone trying to help you.
Hope you come right!
Hello Mirdarthos,
this is better informations :wink: :
  Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=8461a7b1-24bc-46ef-a2fb-2d081a50ac21 rw btusb.enable_autosuspend=0
  quiet apparmor=1 security=apparmor udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Laptop System: LENOVO product: 81UT v: Lenovo IdeaPad S145-15API
  serial: <filter> Chassis: type: 10 v: Lenovo IdeaPad S145-15API
  serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40709WIN serial: <filter>
  UEFI-[Legacy]: LENOVO v: BUCN22WW date: 10/11/2019
  ID-1: BAT0 charge: 21.7 Wh (85.8%) condition: 25.3/30.6 Wh (82.6%)
  volts: 7.7 min: 7.6 model: CPT-COS L16C2PB2 type: Li-poly serial: <filter>
  status: Discharging cycles: 506
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
  status: Discharging
  RAM: total: 5.57 GiB used: 1.9 GiB (34.1%)
  Info: Quad Core model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx
  bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24)
  stepping: 1 microcode: 8108102 cache: L2: 2 MiB bogomips: 36751
  Speed: 1238 MHz min/max: 1400/2300 MHz boost: enabled Core speeds (MHz):
  1: 1238 2: 1223 3: 1223 4: 1222 5: 1244 6: 1320 7: 1259 8: 1222
  bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
  mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
  npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
  perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
  rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
  smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
  topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
  disabled, RSB filling
  Device-1: AMD Picasso vendor: Lenovo driver: amdgpu v: kernel
  bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300
  Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 3-1:2
  chip-ID: 5986:1135 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
  loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
  display-ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  OpenGL: renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.40.0
  5.10.70-1-MANJARO LLVM 12.0.1)
  v: 4.6 Mesa 21.2.3 direct render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de
  class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: no
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  vendor: Lenovo driver: ath10k_pci v: kernel bus-ID: 02:00.0
  chip-ID: 168c:0042 class-ID: 0280
  Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 3-2:3
  chip-ID: 0cf3:e500 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 1.03 TiB used: 79.31 GiB (7.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ128HBHQ-000L2
  size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: 3L1QFXV7 temp: 13.8 C scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
  type: HDD rpm: 5400 serial: <filter> rev: LFM1 scheme: MBR
  ID-1: / raw-size: 29.29 GiB size: 28.67 GiB (97.86%) used: 8.05 GiB (28.1%)
  fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
  uuid: 8461a7b1-24bc-46ef-a2fb-2d081a50ac21
  ID-2: /home raw-size: 20.51 GiB size: 20.02 GiB (97.61%)
  used: 422.3 MiB (2.1%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
  label: N/A uuid: 046943df-b3ac-4841-b686-18e589071939
  ID-3: /run/timeshift/backup raw-size: 244.14 GiB size: 239.31 GiB (98.02%)
  used: 70.85 GiB (29.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: e68a2822-655d-4144-be59-8ddf2ddc8572
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 50 MiB fs: ntfs
  label: R\xc3\xa9serv\xc3\xa9 au syst\xc3\xa8me uuid: 34206C00206BC806
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 58.59 GiB fs: ntfs label: N/A
  uuid: 54E26E75E26E5B6E
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 522 MiB fs: ntfs label: N/A
  uuid: 5CA68E0FA68DEA3A
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1 KiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-5: /dev/nvme0n1p7 maj-min: 259:7 size: 10.28 GiB fs: swap label: N/A
  uuid: de58c5a7-90d9-4811-8b07-7e3fb19cb47a
  ID-6: /dev/sda1 maj-min: 8:1 size: 488.28 GiB fs: ntfs label: N/A
  uuid: A6B4171AB416ED15
  ID-7: /dev/sda3 maj-min: 8:3 size: 199.09 GiB fs: ext4 label: N/A
  uuid: c459df4e-e334-49a0-9e2f-5d184d28b222
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 1-4:2 info: Logitech Unifying Receiver type: Mouse,HID
  driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 98mA chip-ID: 046d:c52f class-ID: 0300
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Device-1: 3-1:2 info: Acer Integrated Camera type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:1135
  Device-2: 3-2:3 info: Qualcomm Atheros type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e500
  class-ID: e001
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 38.1 C mobo: N/A gpu: amdgpu temp: 38.0 C
  Processes: 241 Uptime: 23m wakeups: 41785 Init: systemd v: 249
  tool: systemctl Compilers: gcc: N/A Packages: pacman: 1135 lib: 314
  flatpak: 0 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.08
we can sniff out a lead with sudo dmesg --level emerg,alert,crit,err,warn
0.208787] TSC synchronization [CPU#0 -> CPU#1]:
[    0.208787] Measured 3356480114 cycles TSC warp between CPUs, turning off TSC clock.
[    0.208929]   #2  #3  #4  #5  #6  #7
[    0.215873] mtrr: your CPUs had inconsistent fixed MTRR settings
[    0.215873] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.381097] pci 0000:00:00.2: can't derive routing for PCI INT A
[    0.381098] pci 0000:00:00.2: PCI INT A: not connected
[    0.523467] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    0.544740] Unstable clock detected, switching default tracing clock to "global"
               If you want to keep using the local clock, then add:
                 "trace_clock=local"
               on the kernel command line
[    1.402770] usb: port power management may be unreliable
[    3.157721] elan_i2c i2c-ELAN0632:00: supply vcc not found, using dummy regulator
[    5.827129] kauditd_printk_skb: 62 callbacks suppressed
[   14.023535] kauditd_printk_skb: 2 callbacks suppressed
[   19.246457] kauditd_printk_skb: 12 callbacks suppressed
[   46.324545] xhci_hcd 0000:03:00.3: WARNING: Host System Error
[  878.240623] kauditd_printk_skb: 1 callbacks suppressed
we can find again ā€˜[ 1.402770] usb: port power management may be unreliable’ with :
journalctl -k | grep usb
Oct 31 22:22:32 prismordix kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=8461a7b1-24bc-46ef-a2fb-2d081a50ac21 rw btusb.enable_autosuspend=0 quiet apparmor=1 security=apparmor udev.log_priority=3
Oct 31 22:22:32 prismordix kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=8461a7b1-24bc-46ef-a2fb-2d081a50ac21 rw btusb.enable_autosuspend=0 quiet apparmor=1 security=apparmor udev.log_priority=3
Oct 31 22:22:32 prismordix kernel: usbcore: registered new interface driver usbfs
Oct 31 22:22:32 prismordix kernel: usbcore: registered new interface driver hub
Oct 31 22:22:32 prismordix kernel: usbcore: registered new device driver usb
Oct 31 22:22:32 prismordix kernel: pci 0000:03:00.3: quirk_usb_early_handoff+0x0/0x720 took 22720 usecs
Oct 31 22:22:32 prismordix kernel: usbcore: registered new interface driver usbserial_generic
Oct 31 22:22:32 prismordix kernel: usbserial: USB Serial support registered for generic
Oct 31 22:22:32 prismordix kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
Oct 31 22:22:32 prismordix kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Oct 31 22:22:32 prismordix kernel: usb usb1: Product: xHCI Host Controller
Oct 31 22:22:32 prismordix kernel: usb usb1: Manufacturer: Linux 5.10.70-1-MANJARO xhci-hcd
Oct 31 22:22:32 prismordix kernel: usb usb1: SerialNumber: 0000:03:00.3
Oct 31 22:22:32 prismordix kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Oct 31 22:22:32 prismordix kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
Oct 31 22:22:32 prismordix kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Oct 31 22:22:32 prismordix kernel: usb usb2: Product: xHCI Host Controller
Oct 31 22:22:32 prismordix kernel: usb usb2: Manufacturer: Linux 5.10.70-1-MANJARO xhci-hcd
Oct 31 22:22:32 prismordix kernel: usb usb2: SerialNumber: 0000:03:00.3
Oct 31 22:22:32 prismordix kernel: usb: port power management may be unreliable
Oct 31 22:22:32 prismordix kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
Oct 31 22:22:32 prismordix kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Oct 31 22:22:32 prismordix kernel: usb usb3: Product: xHCI Host Controller
Oct 31 22:22:32 prismordix kernel: usb usb3: Manufacturer: Linux 5.10.70-1-MANJARO xhci-hcd
Oct 31 22:22:32 prismordix kernel: usb usb3: SerialNumber: 0000:03:00.4
Oct 31 22:22:32 prismordix kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Oct 31 22:22:32 prismordix kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
Oct 31 22:22:32 prismordix kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Oct 31 22:22:32 prismordix kernel: usb usb4: Product: xHCI Host Controller
Oct 31 22:22:32 prismordix kernel: usb usb4: Manufacturer: Linux 5.10.70-1-MANJARO xhci-hcd
Oct 31 22:22:32 prismordix kernel: usb usb4: SerialNumber: 0000:03:00.4
Oct 31 22:22:32 prismordix kernel: usb 1-4: new full-speed USB device number 2 using xhci_hcd
Oct 31 22:22:32 prismordix kernel: usb 3-1: new high-speed USB device number 2 using xhci_hcd
Oct 31 22:22:32 prismordix kernel: usb 3-1: New USB device found, idVendor=5986, idProduct=1135, bcdDevice=54.08
Oct 31 22:22:32 prismordix kernel: usb 3-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
Oct 31 22:22:32 prismordix kernel: usb 3-1: Product: Integrated Camera
Oct 31 22:22:32 prismordix kernel: usb 3-1: Manufacturer: Bison
Oct 31 22:22:32 prismordix kernel: usb 3-1: SerialNumber: 200901010001
Oct 31 22:22:32 prismordix kernel: usb 1-4: New USB device found, idVendor=046d, idProduct=c52f, bcdDevice=30.00
Oct 31 22:22:32 prismordix kernel: usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Oct 31 22:22:32 prismordix kernel: usb 1-4: Product: USB Receiver
Oct 31 22:22:32 prismordix kernel: usb 1-4: Manufacturer: Logitech
Oct 31 22:22:32 prismordix kernel: input: Logitech USB Receiver as /devices/pci0000:00/0000:00:08.1/0000:03:00.3/usb1/1-4/1-4:1.0/0003:046D:C52F.0001/input/input4
Oct 31 22:22:32 prismordix kernel: hid-generic 0003:046D:C52F.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:03:00.3-4/input0
Oct 31 22:22:32 prismordix kernel: input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:03:00.3/usb1/1-4/1-4:1.1/0003:046D:C52F.0002/input/input5
Oct 31 22:22:32 prismordix kernel: hid-generic 0003:046D:C52F.0002: input,hiddev96,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:03:00.3-4/input1
Oct 31 22:22:32 prismordix kernel: usbcore: registered new interface driver usbhid
Oct 31 22:22:32 prismordix kernel: usbhid: USB HID core driver
Oct 31 22:22:32 prismordix kernel: usb 3-2: new full-speed USB device number 3 using xhci_hcd
Oct 31 22:22:32 prismordix kernel: logitech-djreceiver 0003:046D:C52F.0001: hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:03:00.3-4/input0
Oct 31 22:22:32 prismordix kernel: logitech-djreceiver 0003:046D:C52F.0002: hiddev96,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:03:00.3-4/input1
Oct 31 22:22:32 prismordix kernel: usb 3-2: New USB device found, idVendor=0cf3, idProduct=e500, bcdDevice= 0.01
Oct 31 22:22:32 prismordix kernel: usb 3-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Oct 31 22:22:32 prismordix kernel: input: Logitech Wireless Mouse PID:4057 Mouse as /devices/pci0000:00/0000:00:08.1/0000:03:00.3/usb1/1-4/1-4:1.1/0003:046D:C52F.0002/0003:046D:4057.0003/input/input8
Oct 31 22:22:32 prismordix kernel: input: Logitech Wireless Mouse PID:4057 Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:03:00.3/usb1/1-4/1-4:1.1/0003:046D:C52F.0002/0003:046D:4057.0003/input/input9
Oct 31 22:22:32 prismordix kernel: hid-generic 0003:046D:4057.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4057] on usb-0000:03:00.3-4/input1:1
Oct 31 22:22:32 prismordix kernel: input: Logitech B330/M330/M3 as /devices/pci0000:00/0000:00:08.1/0000:03:00.3/usb1/1-4/1-4:1.1/0003:046D:C52F.0002/0003:046D:4057.0003/input/input13
Oct 31 22:22:32 prismordix kernel: logitech-hidpp-device 0003:046D:4057.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech B330/M330/M3] on usb-0000:03:00.3-4/input1:1
Oct 31 22:22:34 prismordix kernel: usbcore: registered new interface driver btusb
Oct 31 22:22:34 prismordix kernel: input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:08.1/0000:03:00.4/usb3/3-1/3-1:1.0/input/input21
Oct 31 22:22:34 prismordix kernel: usbcore: registered new interface driver uvcvideo
Oct 31 22:22:34 prismordix kernel: Bluetooth: hci0: using rampatch file: qca/rampatch_usb_00000302.bin
Oct 31 22:22:34 prismordix kernel: Bluetooth: hci0: using NVM file: qca/nvm_usb_00000302.bin
From this page
I & others had to do:
pamac remove --no-save tlp
That fixed it for me although if I plug in two usb it stops again. So for now I only use one at a time. (not counting the one for the mouse)
Thank you for answer @Hipster,
Yesterday there was a very little upgrade with pacman.
Since I don’t have the problem anymore
cat /var/log/pacman.log  | tail -10
[2021-10-31T23:50:33+0000] [PACMAN] Running 'pacman -Syu'
[2021-10-31T23:50:33+0000] [PACMAN] synchronizing package lists
[2021-10-31T23:50:51+0000] [PACMAN] starting full system upgrade
[2021-10-31T23:52:33+0000] [PACMAN] Running 'pacman -Syu'
[2021-10-31T23:52:33+0000] [PACMAN] synchronizing package lists
[2021-10-31T23:52:37+0000] [PACMAN] starting full system upgrade
[2021-10-31T23:52:41+0000] [ALPM] transaction started
[2021-10-31T23:52:41+0000] [ALPM] upgraded kernel-alive (0.5-1 -> 0.5-2)
[2021-10-31T23:52:41+0000] [ALPM] transaction completed
[2021-10-31T23:52:41+0000] [ALPM] running '30-systemd-update.hook'...
I rebooted several times and the kernel-alive 0.5-2 switch seems to fix the problem.
I am going to wait one week before to close the thread, but I am already so happy not being forced to use my dual boot anymore :dancing_women: :woman_cartwheeling: :man_cartwheeling: :dancer: :dancer:
Hello friends,
:weary:I’m sorry, but my problem came back as suddenly as it had disappeared.:weary:
The mouse cursor freezes after 30 seconds after logging in.
I have already put the system information above.
If you need anything else, please ask me.
Thanks for help.
