Mount secondary SSD without loosing data?
I put in a seccond ssd on my laptop to use. It’s unfortunately only visible in the grub terminal but not when I’m runing manjaro. Is it possible to make it visible when booted up without loosing data?
Where exactly are you expecting to see it?
Hi @lzy.am,
Please provide the output of:
fdisk -l
…and:
lsblk
:bangbang: Tip: :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
In the operating system
Obviously. Asking for specifics.
Where in the operating system?
for fdisk -l
Disk /dev/sda: 238.47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: HFS256G39TND-N21
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 0C43B4E9-CEC8-2C49-8E58-778145057C2A
Device      Start       End   Sectors   Size Type
/dev/sda1    4096    618495    614400   300M EFI System
/dev/sda2  618496 500103449 499484954 238.2G Linux filesystem
for lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda      8:0    0 238.5G  0 disk
├─sda1   8:1    0   300M  0 part /boot/efi
└─sda2   8:2    0 238.2G  0 part /
There is only 1 Storage Medium attached to the computer. What do you want to mount?
Just checking: what do you call “grub terminal”? The one you get dropped to if it can’t show the menu at boot? The rescue one? Something else?
That’s what I’m trying to fix I have two storage devices but I can only see one
When booting the computer and press esc for some it’s shift and it’s not the bios
That…that hurts my brain, because it doesn’t make sense. Please be more descriptive, not less, when communicating online. There is no other communication going on between you and who-ever’s reading this, no facial expressions, no skin tone, nothing. So you need to be more expressive when compiling your sentences. Please also see,
However, if the drive doesn’t show up in the UEFI/BIOS I’m leaning toward a hardware problem, which is something we cannot help you with, sadly.
