Rod
8 February 2022 21:19
1
I Clicked on Manjaro xfce update icon.
Pamac showed 1.6Gb of updates.
I clicked “Apply” to accept and install the updates.
After a few minutes - it finished and stated that I needed to REBOOT to complete the changes.
I clicked to reboot.
After several times trying to reboot, scrolling text on black screen is the only thing I see, as in the attached picture.
Why is this happening??
Do you need to see the log files to help fix this lock up? If so, how do I find them?
Right now, I’m using my computer with a manjaro live USB stick.
Where do I go from here?
Dave
Rod
8 February 2022 22:31
3
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2115 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop Mobo: Micro-Star model: B450 GAMING PLUS MAX (MS-7B86) v: 3.0
serial: <filter> UEFI: American Megatrends LLC. v: H.D3 date: 09/28/2021
RAM: total: 15.55 GiB used: 3.76 GiB (24.1%)
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
bogomips: 81631
Speed: 1376 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
1: 1376 2: 1378 3: 2337 4: 1271 5: 1357 6: 1272 7: 2337 8: 1272 9: 2002
10: 1517 11: 1457 12: 1271
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte
driver: nouveau v: kernel bus-ID: 26:00.0 chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.5x10.9")
s-diag: 523mm (20.6")
Monitor-1: HDMI-1 res: 1680x1050 hz: 60 dpi: 90 size: 473x296mm (18.6x11.7")
diag: 558mm (22")
OpenGL: renderer: NV137 v: 4.3 Mesa 21.2.3 direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 26:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 28:00.3 chip-ID: 1022:1457
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 22:00.0
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.52 TiB used: 518.4 GiB (20.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 043 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500418AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: CC46 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HUA723020ALA641
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A840 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB model: General USB Flash Disk
size: 14.55 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 1100 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSC0 rev: LI00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: /mnt raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 54.17 GiB (23.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 6be889fb-e5cd-4676-8afd-4e7140a6da75
ID-2: /mnt/boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 679A-1508
ID-3: /run/media/manjaro/Ht1 raw-size: 550 GiB size: 540.37 GiB (98.25%)
used: 464.23 GiB (85.9%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: Ht1
uuid: 48d40e11-d416-4079-9abd-c3115f9bdfc3
ID-1: /dev/sdb1 maj-min: 8:17 size: 232.88 GiB fs: ext4 label: DDrive1
uuid: 6e4c97b7-826e-445e-8796-72d0e38f7e36
ID-2: /dev/sdb2 maj-min: 8:18 size: 232.88 GiB fs: ext4 label: DDrive2
uuid: 353601dc-0eb6-45f9-9475-50f8fb8def2c
ID-3: /dev/sdc3 maj-min: 8:35 size: 640 GiB fs: ext4 label: Ht2
uuid: db9f7c41-b09a-462e-a202-e0cd136c5ee7
ID-4: /dev/sdc4 maj-min: 8:36 size: 673.02 GiB fs: ext4 label: Ht3
uuid: dc1ff585-f270-4de5-ae19-45a09aa1bbb7
ID-5: /dev/sdd1 maj-min: 8:49 size: 2.93 GiB fs: iso9660
ID-6: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
uuid: B11D-A078
Device-1: 1-1:2 info: HP Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 03f0:134a class-ID: 0301
Device-2: 1-4:3 info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 090c:1000 class-ID: 0806
serial: <filter>
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nouveau temp: 51.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Processes: 328 Uptime: 5h 58m wakeups: 0 Init: systemd v: 249
tool: systemctl Compilers: gcc: N/A Packages: 1130 pacman: 1123 lib: 307
flatpak: 4 snap: 3 Shell: Bash v: 5.1.8 running-in: xfce4-terminal
inxi: 3.3.06
Rod
8 February 2022 22:32
4
This is the results of manjaro-chroot -a
[manjaro@manjaro ~]$ manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdd1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda2]
→ mount: [/mnt]
→ mount: [/mnt/boot/efi]
[manjaro /]#
Rod
8 February 2022 22:36
5
Thank you for responding - I was so busy - I forgot.
The 5.13 kernel is long EOL, thus the driver headers for it have also been dropped.
Do you have other kernels installed?
mhwd-kernel -li
Rod
9 February 2022 15:16
7
Thank you for responding - the currently running kernel is my Manjaro live usb I’m now using to run the computer.
→ mount: [/mnt]
[manjaro /]# mhwd-kernel -li
Currently running: 5.13.19-2-MANJARO (linux513)
[manjaro /]#
I’ll let you follow the above guide to get logs then.
5.13 is EOL. Can you try booting with 5.10 as that is already installed. Press Esc during boot to get into grub menu > advanced options and boot with 5.10.
Rod
9 February 2022 16:26
10
Thank you - I rebooted using advanced options with 5.10 and there was no error - booted as expected.
so, what does this mean? Do I continue using old kernel 5.10 or upload log files or what?
5.10 is not old by any means. If you want you can switch to the latest LTS kernel which is 5.15. First make sure you are not on 5.13 and then remove it. Then you can boot with 5.15 or 5.10. As you wish.
uname -r #to check kernel version coz you don't want to remove a active kernel
sudo mhwd-kernel -r linux513
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
sudo mhwd-kernel -i linux515
Rod
9 February 2022 16:57
12
This my latest boot
[ultra@ultra-ms7b86 ~]$ mhwd-kernel -li
Currently running: 5.15.19-1-MANJARO (linux515)
linux510
linux515
Thank you maycne.sonahoz and ishaanbhimwal for your responses and help!
Evidently kernel 515 rt must have been the problem, kernel 513 (on the live usb) worked fine, and kernels 510 and 515 works fine on the desktop. Is there anything else I should be aware of at this time?
Update your “rolling-release” distro regularly and check release announcements. That’s it.
system
Closed
12 February 2022 07:05
15
