Hi, i’ve been distro hopping for the past days and I’m noticing that ALL of arch-based distros that I have tried get stuck on 60hz even though my laptop monitor is up to 165hz. Changing it with xrandr or the settings doesn’t change nothing. In other distros, I do “sudo pacman -S nvidia-lts” and solves it, but there is no nvidia-lts in manjaro. I tried to go to the hardware config section and auto-install proprietary driver, but I reboot and the system wouldn’t boot. It looked like it was about to boot but then the screen froze. Idk why this happens to every arch-based distros and I can’t even boot the archcraft iso from my boot pendrive so yeah. If you guys need any info I would be happy to share
Can you post inxi -Fza on console and the log file /var/log/Xorg.0.log ?
Hi @joya, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as preformatted text.
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
inxi -Fza
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=a023c3b2-c0a1-4866-b473-539b41afd05e rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Dell G15 5511 v: N/A
Mobo: Dell model: 0836K6 v: A00 serial: <superuser required> UEFI: Dell
v: 1.19.2 date: 10/27/2022
ID-1: BAT0 charge: 57.3 Wh (94.4%) condition: 60.7/84.3 Wh (72.0%)
volts: 12.4 min: 11.4 model: BYD DELL M59JH16 type: Li-poly serial: <filter>
status: N/A
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x42
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 858 high: 1091 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 994 2: 767 3: 800 4: 801
5: 791 6: 800 7: 801 8: 787 9: 900 10: 799 11: 1030 12: 800 13: 1091
14: 793 15: 888 16: 889 bogomips: 73744
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: none empty: DP-3,DP-4 bus-ID: 00:02.0 chip-ID: 8086:9a60
class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nouveau v: kernel non-free: 525.xx+ status: current (as of 2022-12)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 ports:
active: HDMI-A-1,eDP-2 empty: DP-1,DP-2 bus-ID: 01:00.0 chip-ID: 10de:2560
class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-5:5 chip-ID: 0c45:6720 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: nouveau
display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1080 s-dpi: 96 s-size: 1185x285mm (46.65x11.22")
s-diag: 1219mm (47.98")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right
model: LG (GoldStar) HDR WFHD serial: <filter> built: 2021 res: 2560x1080
hz: 60 dpi: 81 gamma: 1.2 size: 798x334mm (31.42x13.15")
diag: 869mm (34.2") modes: max: 2560x1080 min: 640x480
Monitor-2: eDP-2 pos: primary,left model: AU Optronics 0xb49b built: 2021
res: 1920x1080 hz: 165 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 800x600
API: OpenGL v: 4.5 Mesa 22.3.1 renderer: llvmpipe (LLVM 14.0.6 256 bits)
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
Device-2: Realtek vendor: Rivet Networks driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 2d:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF: enp45s0 state: down mac: <filter>
bus-ID: 3-14:7 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 924.07 GiB used: 9.98 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data
model: IM2P33F3A NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 92209301 temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: JMicron Tech model: Generic
size: 447.13 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0204 scheme: GPT
ID-1: / raw-size: 446.83 GiB size: 438.75 GiB (98.19%) used: 9.98 GiB (2.3%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 339 Uptime: 2m wakeups: 1 Memory: 15.38 GiB
used: 1.93 GiB (12.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1130 libs: 320 tools: pamac,yay pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
/var/log/Xorg.0.log
[ 13.928] (--) Log file renamed from "/var/log/Xorg.pid-706.log" to "/var/log/Xorg.0.log"
[ 13.934]
X.Org X Server 1.21.1.6
[ 13.934] Current Operating System: Linux manjarobtw 5.15.85-1-MANJARO #1 SMP PREEMPT Wed Dec 21 21:15:06 UTC 2022 x86_64
[ 13.934] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=a023c3b2-c0a1-4866-b473-539b41afd05e rw quiet splash udev.log_priority=3
[ 13.934]
[ 13.934] Current version of pixman: 0.42.2
[ 13.934] Before reporting problems, check http://wiki.x.org
[ 13.934] Markers: (--) probed, (**) from config file, (==) default setting,
[ 13.934] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jan 6 09:18:19 2023
[ 13.942] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 13.942] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 13.948] (==) No Layout section. Using the first Screen section.
[ 13.948] (==) No screen section available. Using defaults.
[ 13.948] (**) |-->Screen "Default Screen Section" (0)
[ 13.948] (**) | |-->Monitor "<default monitor>"
[ 13.952] (==) No monitor specified for screen "Default Screen Section".
[ 13.952] (==) Automatically adding devices
[ 13.952] (==) Automatically enabling devices
[ 13.952] (==) Automatically adding GPU devices
[ 13.952] (==) Automatically binding GPU devices
[ 13.952] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 13.963] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 13.963] Entry deleted from font path.
[ 13.963] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 13.963] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 13.963] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 13.963] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 13.963] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 13.963] (II) The server relies on udev to provide the list of input devices.
[ 13.963] (II) Module ABI versions:
[ 13.963] X.Org ANSI C Emulation: 0.4
[ 13.963] X.Org Video Driver: 25.2
[ 13.963] X.Org XInput driver : 24.4
[ 13.963] X.Org Server Extension : 10.0
[ 13.964] (++) using VT number 1
[ 13.964] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 13.964] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 13.964] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
[ 13.965] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 13.965] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 13.966] (--) PCI: (0@0:2:0) 8086:9a60:1028:0a70 rev 1, Mem @ 0x622c000000/16777216, 0x4000000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 13.966] (--) PCI:*(1@0:0:0) 10de:2560:1028:0a70 rev 161, Mem @ 0x83000000/16777216, 0x6000000000/8589934592, 0x6200000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[ 13.966] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 13.966] (II) LoadModule: "glx"
[ 13.977] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 14.026] (II) Module glx: vendor="X.Org Foundation"
[ 14.026] compiled for 1.21.1.6, module version = 1.0.0
[ 14.026] ABI class: X.Org Server Extension, version 10.0
[ 14.027] (==) Matched modesetting as autoconfigured driver 0
[ 14.027] (==) Matched fbdev as autoconfigured driver 1
[ 14.027] (==) Matched vesa as autoconfigured driver 2
[ 14.027] (==) Assigned the driver to the xf86ConfigLayout
[ 14.027] (II) LoadModule: "modesetting"
[ 14.027] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 14.048] (II) Module modesetting: vendor="X.Org Foundation"
[ 14.048] compiled for 1.21.1.6, module version = 1.21.1
[ 14.048] Module class: X.Org Video Driver
[ 14.048] ABI class: X.Org Video Driver, version 25.2
[ 14.048] (II) LoadModule: "fbdev"
[ 14.048] (WW) Warning, couldn't open module fbdev
[ 14.048] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 14.048] (II) LoadModule: "vesa"
[ 14.049] (WW) Warning, couldn't open module vesa
[ 14.049] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 14.049] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 14.049] (II) modeset(0): using drv /dev/dri/card1
[ 14.049] (II) modeset(G0): using drv /dev/dri/card0
[ 14.049] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 14.049] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 14.049] (==) modeset(0): RGB weight 888
[ 14.049] (==) modeset(0): Default visual is TrueColor
[ 14.049] (II) Loading sub module "glamoregl"
[ 14.049] (II) LoadModule: "glamoregl"
[ 14.049] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 14.071] (II) Module glamoregl: vendor="X.Org Foundation"
[ 14.071] compiled for 1.21.1.6, module version = 1.0.1
[ 14.071] ABI class: X.Org ANSI C Emulation, version 0.4
[ 15.902] (II) modeset(0): Refusing to try glamor on llvmpipe
[ 15.903] (II) modeset(0): glamor initialization failed
[ 15.908] (II) modeset(0): ShadowFB: preferred YES, enabled YES
[ 15.908] (II) modeset(0): Double-buffered shadow updates: off
[ 15.915] (II) modeset(0): Output eDP-2 has no monitor section
[ 15.986] (II) modeset(0): Output DP-1 has no monitor section
[ 16.056] (II) modeset(0): Output DP-2 has no monitor section
[ 16.121] (II) modeset(0): Output HDMI-1 has no monitor section
[ 16.128] (II) modeset(0): EDID for output eDP-2
[ 16.128] (II) modeset(0): Manufacturer: AUO Model: b49b Serial#: 0
[ 16.128] (II) modeset(0): Year: 2021 Week: 16
[ 16.128] (II) modeset(0): EDID Version: 1.4
[ 16.128] (II) modeset(0): Digital Display Input
[ 16.128] (II) modeset(0): 8 bits per channel
[ 16.128] (II) modeset(0): Digital interface is DisplayPort
[ 16.128] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 16.128] (II) modeset(0): Gamma: 2.20
[ 16.128] (II) modeset(0): No DPMS capabilities specified
[ 16.128] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 16.128] (II) modeset(0): First detailed timing is preferred mode
[ 16.128] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 16.128] (II) modeset(0): Display is continuous-frequency
[ 16.128] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 16.128] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 16.128] (II) modeset(0): Manufacturer's mask: 0
[ 16.128] (II) modeset(0): Supported detailed timing:
[ 16.128] (II) modeset(0): clock: 405.0 MHz Image Size: 344 x 193 mm
[ 16.128] (II) modeset(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 16.128] (II) modeset(0): v_active: 1080 v_sync: 1090 v_sync_end 1095 v_blanking: 3240 v_border: 0
[ 16.128] (II) modeset(0): Ranges: V min: 60 V max: 165 Hz, H min: 195 H max: 195 kHz, PixClock max 415 MHz
[ 16.128] (II) modeset(0): MW2V2�B156HAN
[ 16.128] (II) modeset(0): Unknown vendor-specific block 0
[ 16.128] (II) modeset(0): Number of EDID sections to follow: 1
[ 16.128] (II) modeset(0): EDID (in hex):
[ 16.128] (II) modeset(0): 00ffffffffffff0006af9bb400000000
[ 16.128] (II) modeset(0): 101f0104a522137803ee95a3544c9926
[ 16.128] (II) modeset(0): 0f505400000001010101010101010101
[ 16.128] (II) modeset(0): 010101010101349e80a0703870483020
[ 16.128] (II) modeset(0): a50058c11000001a000000fd003ca5c3
[ 16.128] (II) modeset(0): c329010a202020202020000000fe004d
[ 16.128] (II) modeset(0): 57325632814231353648414e00000000
[ 16.128] (II) modeset(0): 0002410f9e001100000f410a20200121
[ 16.128] (II) modeset(0): 7013790000030114349e00847f079f00
[ 16.128] (II) modeset(0): 2f001f00370463000900040000000000
[ 16.128] (II) modeset(0): 00000000000000000000000000000000
[ 16.128] (II) modeset(0): 0000000000000000000000000000e890
[ 16.128] (II) modeset(0): Printing probed modes for output eDP-2
[ 16.128] (II) modeset(0): Modeline "1920x1080"x165.0 405.01 1920 1968 2000 2080 1080 1090 1095 1180 -hsync -vsync (194.7 kHz eP)
[ 16.128] (II) modeset(0): Modeline "1920x1080"x60.1 405.00 1920 1968 2000 2080 1080 1090 1095 3240 +hsync -vsync (194.7 kHz eP)
[ 16.129] (II) modeset(0): Modeline "1920x1080"x60.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 16.129] (II) modeset(0): Modeline "1920x1080"x60.0 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 16.129] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 16.129] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 16.129] (II) modeset(0): Modeline "1680x1050"x60.0 146.36 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz)
[ 16.129] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "1400x1050"x60.0 121.79 1400 1488 1632 1864 1050 1053 1057 1089 -hsync +vsync (65.3 kHz)
[ 16.129] (II) modeset(0): Modeline "1600x900"x60.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 16.129] (II) modeset(0): Modeline "1600x900"x59.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 16.129] (II) modeset(0): Modeline "1280x1024"x85.0 157.50 1280 1344 1504 1728 1024 1025 1028 1072 +hsync +vsync (91.1 kHz d)
[ 16.129] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "1280x1024"x59.9 109.10 1280 1368 1496 1712 1024 1027 1034 1063 -hsync +vsync (63.7 kHz)
[ 16.129] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 16.129] (II) modeset(0): Modeline "1280x960"x85.0 148.50 1280 1344 1504 1728 960 961 964 1011 +hsync +vsync (85.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "1280x960"x60.0 101.34 1280 1360 1488 1696 960 963 967 996 -hsync +vsync (59.8 kHz)
[ 16.129] (II) modeset(0): Modeline "1440x810"x60.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 16.129] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "1152x864"x60.0 81.77 1152 1216 1336 1520 864 867 871 897 -hsync +vsync (53.8 kHz)
[ 16.129] (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 16.129] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 16.129] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "1024x768"x85.0 194.02 1024 1108 1220 1416 768 768 770 806 doublescan -hsync +vsync (137.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "1024x768"x75.0 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[ 16.129] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 16.129] (II) modeset(0): Modeline "1024x768"x59.9 63.53 1024 1072 1176 1328 768 771 775 798 -hsync +vsync (47.8 kHz)
[ 16.129] (II) modeset(0): Modeline "1024x768i"x87.0 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "960x720"x85.0 170.68 960 1036 1144 1328 720 720 722 756 doublescan -hsync +vsync (128.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "960x720"x75.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "928x696"x75.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 16.129] (II) modeset(0): Modeline "896x672"x75.0 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 16.129] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 16.129] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 16.129] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 16.129] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "800x600"x85.0 114.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (106.2 kHz d)
[ 16.129] (II) modeset(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 16.129] (II) modeset(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 16.129] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz d)
[ 16.129] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "800x600"x60.0 38.31 800 832 912 1024 600 603 607 624 -hsync +vsync (37.4 kHz)
[ 16.129] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 16.129] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 16.129] (II) modeset(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x512"x85.0 78.75 640 672 752 864 512 512 514 536 doublescan +hsync +vsync (91.1 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x480"x85.1 74.25 640 672 752 864 480 480 482 505 doublescan +hsync +vsync (85.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 16.129] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 16.129] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 16.129] (II) modeset(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "512x384"x85.0 47.25 512 536 584 688 384 384 386 404 doublescan +hsync +vsync (68.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 16.129] (II) modeset(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 16.129] (II) modeset(0): Modeline "512x384i"x87.1 22.45 512 516 604 632 384 384 388 408 interlace doublescan +hsync +vsync (35.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "400x300"x85.3 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync (53.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 16.129] (II) modeset(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 16.129] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 16.129] (II) modeset(0): Modeline "320x240"x85.2 18.00 320 348 376 416 240 240 242 254 doublescan -hsync -vsync (43.3 kHz d)
[ 16.129] (II) modeset(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 16.129] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 16.129] (II) modeset(0): Modeline "360x200"x85.0 17.75 360 378 414 468 200 200 202 223 doublescan -hsync +vsync (37.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "320x200"x85.3 15.75 320 336 368 416 200 200 202 222 doublescan -hsync +vsync (37.9 kHz d)
[ 16.129] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 16.129] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 16.129] (II) modeset(0): Modeline "320x175"x85.3 15.75 320 336 368 416 175 191 192 222 doublescan +hsync -vsync (37.9 kHz d)
[ 16.199] (II) modeset(0): EDID for output DP-1
[ 16.269] (II) modeset(0): EDID for output DP-2
[ 16.335] (II) modeset(0): EDID for output HDMI-1
[ 16.335] (II) modeset(0): Manufacturer: GSM Model: 7714 Serial#: 4236
[ 16.335] (II) modeset(0): Year: 2021 Week: 4
[ 16.335] (II) modeset(0): EDID Version: 1.3
[ 16.335] (II) modeset(0): Digital Display Input
[ 16.335] (II) modeset(0): Max Image Size [cm]: horiz.: 80 vert.: 34
[ 16.335] (II) modeset(0): Gamma: 2.20
[ 16.335] (II) modeset(0): DPMS capabilities: StandBy Suspend Off
[ 16.335] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 16.335] (II) modeset(0): First detailed timing is preferred mode
[ 16.335] (II) modeset(0): redX: 0.651 redY: 0.332 greenX: 0.307 greenY: 0.631
[ 16.335] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 16.335] (II) modeset(0): Supported established timings:
[ 16.335] (II) modeset(0): 640x480@60Hz
[ 16.335] (II) modeset(0): 640x480@75Hz
[ 16.335] (II) modeset(0): 800x600@60Hz
[ 16.335] (II) modeset(0): 800x600@75Hz
[ 16.335] (II) modeset(0): 832x624@75Hz
[ 16.335] (II) modeset(0): 1024x768@60Hz
[ 16.335] (II) modeset(0): 1024x768@75Hz
[ 16.335] (II) modeset(0): 1280x1024@75Hz
[ 16.335] (II) modeset(0): 1152x864@75Hz
[ 16.335] (II) modeset(0): Manufacturer's mask: 0
[ 16.335] (II) modeset(0): Supported standard timings:
[ 16.335] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 60 vid: 16497
[ 16.335] (II) modeset(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 16.335] (II) modeset(0): #2: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 16.335] (II) modeset(0): #3: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 16.335] (II) modeset(0): #4: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 16.335] (II) modeset(0): #5: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 16.335] (II) modeset(0): #6: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 16.335] (II) modeset(0): #7: hsize: 1920 vsize 1080 refresh: 75 vid: 53201
[ 16.335] (II) modeset(0): Supported detailed timing:
[ 16.335] (II) modeset(0): clock: 181.2 MHz Image Size: 798 x 334 mm
[ 16.335] (II) modeset(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 16.335] (II) modeset(0): v_active: 1080 v_sync: 1083 v_sync_end 1093 v_blanking: 1111 v_border: 0
[ 16.335] (II) modeset(0): clock: 148.5 MHz Image Size: 798 x 334 mm
[ 16.335] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 16.335] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 16.335] (II) modeset(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 90 kHz, PixClock max 255 MHz
[ 16.335] (II) modeset(0): Monitor name: LG HDR WFHD
[ 16.335] (II) modeset(0): clock: 228.2 MHz Image Size: 798 x 334 mm
[ 16.335] (II) modeset(0): v_active: 1080 v_sync: 1083 v_sync_end 1093 v_blanking: 1119 v_border: 0
[ 16.335] (II) modeset(0): clock: 241.5 MHz Image Size: 798 x 334 mm
[ 16.335] (II) modeset(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0
[ 16.335] (II) modeset(0): Serial No: 104SPQJ04236
[ 16.335] (II) modeset(0): Number of EDID sections to follow: 1
[ 16.335] (II) modeset(0): EDID (in hex):
[ 16.335] (II) modeset(0): 00ffffffffffff001e6d14778c100000
[ 16.335] (II) modeset(0): 041f010380502278eaca95a6554ea126
[ 16.335] (II) modeset(0): 0f5054256b807140818081c0a9c0b300
[ 16.335] (II) modeset(0): d1c08100d1cfcd4600a0a0381f403020
[ 16.335] (II) modeset(0): 3a001e4e3100001a023a801871382d40
[ 16.335] (II) modeset(0): 582c45001e4e3100001e000000fd0038
[ 16.335] (II) modeset(0): 4b1e5a19000a202020202020000000fc
[ 16.335] (II) modeset(0): 004c472048445220574648440a200171
[ 16.335] (II) modeset(0): 020337f1230907074c100403011f1359
[ 16.335] (II) modeset(0): da125d5e5f830100006d030c002000b8
[ 16.335] (II) modeset(0): 3c20006001020367d85dc4013c8000e3
[ 16.335] (II) modeset(0): 05c000e3060501295900a0a038274030
[ 16.335] (II) modeset(0): 203a001e4e3100001a565e00a0a0a029
[ 16.335] (II) modeset(0): 50302035001e4e3100001a000000ff00
[ 16.335] (II) modeset(0): 3130345350514a30343233360a000000
[ 16.335] (II) modeset(0): 00000000000000000000000000000090
[ 16.335] (--) modeset(0): HDMI max TMDS frequency 300000KHz
[ 16.335] (II) modeset(0): Not using default mode "2048x1536" (bad mode clock/interlace/doublescan)
[ 16.335] (II) modeset(0): Not using default mode "2560x1440" (bad mode clock/interlace/doublescan)
[ 16.335] (II) modeset(0): Not using default mode "2880x1620" (bad mode clock/interlace/doublescan)
[ 16.335] (II) modeset(0): Not using default mode "3200x1800" (bad mode clock/interlace/doublescan)
[ 16.335] (II) modeset(0): Not using default mode "3840x2160" (bad mode clock/interlace/doublescan)
[ 16.335] (II) modeset(0): Not using default mode "1920x1080" (bad mode clock/interlace/doublescan)
[ 16.335] (II) modeset(0): Not using default mode "2048x1152" (bad mode clock/interlace/doublescan)
[ 16.335] (II) modeset(0): Printing probed modes for output HDMI-1
[ 16.335] (II) modeset(0): Modeline "2560x1080"x60.0 181.25 2560 2608 2640 2720 1080 1083 1093 1111 +hsync -vsync (66.6 kHz eP)
[ 16.335] (II) modeset(0): Modeline "3840x2160"x30.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[ 16.335] (II) modeset(0): Modeline "3840x2160"x25.0 297.00 3840 4896 4984 5280 2160 2168 2178 2250 +hsync +vsync (56.2 kHz e)
[ 16.335] (II) modeset(0): Modeline "3840x2160"x24.0 297.00 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[ 16.335] (II) modeset(0): Modeline "3840x2160"x30.0 296.70 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[ 16.335] (II) modeset(0): Modeline "3840x2160"x24.0 296.70 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[ 16.335] (II) modeset(0): Modeline "2560x1600"x60.0 268.50 2560 2608 2640 2720 1600 1603 1609 1646 +hsync -vsync (98.7 kHz d)
[ 16.335] (II) modeset(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[ 16.335] (II) modeset(0): Modeline "2048x1536"x60.0 266.95 2048 2200 2424 2800 1536 1537 1540 1589 -hsync +vsync (95.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "1920x1440"x75.0 297.00 1920 2064 2288 2640 1440 1441 1444 1500 -hsync +vsync (112.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "1920x1440"x60.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "2560x1080"x75.0 228.25 2560 2608 2640 2720 1080 1083 1093 1119 +hsync -vsync (83.9 kHz e)
[ 16.335] (II) modeset(0): Modeline "2560x1080"x50.0 185.62 2560 3108 3152 3300 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 16.335] (II) modeset(0): Modeline "1856x1392"x75.0 288.00 1856 1984 2208 2560 1392 1393 1396 1500 -hsync +vsync (112.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "1856x1392"x60.0 218.30 1856 1952 2176 2528 1392 1393 1396 1439 -hsync +vsync (86.4 kHz d)
[ 16.335] (II) modeset(0): Modeline "1792x1344"x75.0 261.00 1792 1888 2104 2456 1344 1345 1348 1417 -hsync +vsync (106.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "1792x1344"x60.0 204.80 1792 1920 2120 2448 1344 1345 1348 1394 -hsync +vsync (83.7 kHz d)
[ 16.335] (II) modeset(0): Modeline "2048x1152"x60.0 302.50 2048 2072 2088 2128 1152 1153 1156 1185 doublescan +hsync -vsync (142.2 kHz d)
[ 16.335] (II) modeset(0): Modeline "2048x1152"x59.9 197.00 2048 2184 2400 2752 1152 1155 1160 1195 -hsync +vsync (71.6 kHz d)
[ 16.335] (II) modeset(0): Modeline "2048x1152"x59.9 156.75 2048 2096 2128 2208 1152 1155 1160 1185 +hsync -vsync (71.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "1920x1200"x59.9 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz d)
[ 16.335] (II) modeset(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "1920x1080"x60.0 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 16.335] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 16.335] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 16.335] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 16.335] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 16.335] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 16.335] (II) modeset(0): Modeline "1600x1200"x75.0 202.50 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (93.8 kHz d)
[ 16.335] (II) modeset(0): Modeline "1600x1200"x70.0 189.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (87.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "1600x1200"x65.0 175.50 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (81.2 kHz d)
[ 16.335] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 16.335] (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 16.335] (II) modeset(0): Modeline "1600x900"x60.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 16.335] (II) modeset(0): Modeline "1600x900"x59.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 16.335] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 16.335] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 16.335] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 16.335] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 16.335] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "1440x810"x60.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 16.335] (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 16.335] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 16.335] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 16.335] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 16.335] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 16.335] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 16.335] (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 16.335] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 16.335] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 16.335] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 16.335] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 16.335] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "1024x768"x75.0 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[ 16.335] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 16.335] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 16.335] (II) modeset(0): Modeline "960x720"x75.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "928x696"x75.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 16.335] (II) modeset(0): Modeline "896x672"x75.0 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 16.335] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 16.335] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 16.335] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 16.335] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 16.335] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 16.335] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 16.335] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 16.335] (II) modeset(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 16.335] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz d)
[ 16.335] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 16.335] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 16.335] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 16.335] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 16.335] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 16.335] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 16.335] (II) modeset(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 16.335] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 16.335] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 16.335] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 16.335] (II) modeset(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 16.335] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 16.335] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz d)
[ 16.335] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 16.335] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 16.335] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 16.335] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 16.335] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 16.335] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 16.335] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 16.335] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 16.335] (II) modeset(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 16.335] (II) modeset(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 16.335] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 16.335] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 16.335] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 16.335] (II) modeset(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 16.335] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 16.335] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 16.335] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 16.335] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 16.335] (II) modeset(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 16.335] (II) modeset(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 16.335] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 16.335] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 16.335] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 16.335] (II) modeset(0): Output eDP-2 connected
[ 16.335] (II) modeset(0): Output DP-1 disconnected
[ 16.335] (II) modeset(0): Output DP-2 disconnected
[ 16.335] (II) modeset(0): Output HDMI-1 connected
[ 16.335] (II) modeset(0): Using spanning desktop for initial modes
[ 16.335] (II) modeset(0): Output eDP-2 using initial mode 1920x1080 +0+0
[ 16.335] (II) modeset(0): Output HDMI-1 using initial mode 2560x1080 +1920+0
[ 16.335] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 16.335] (==) modeset(0): DPI set to (96, 96)
[ 16.335] (II) Loading sub module "fb"
[ 16.335] (II) LoadModule: "fb"
[ 16.335] (II) Module "fb" already built-in
[ 16.335] (II) Loading sub module "shadow"
[ 16.335] (II) LoadModule: "shadow"
[ 16.335] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 16.348] (II) Module shadow: vendor="X.Org Foundation"
[ 16.348] compiled for 1.21.1.6, module version = 1.1.0
[ 16.348] ABI class: X.Org ANSI C Emulation, version 0.4
[ 16.348] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 16.348] (==) modeset(G0): RGB weight 888
[ 16.348] (==) modeset(G0): Default visual is TrueColor
[ 16.348] (II) Loading sub module "glamoregl"
[ 16.348] (II) LoadModule: "glamoregl"
[ 16.348] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 16.348] (II) Module glamoregl: vendor="X.Org Foundation"
[ 16.348] compiled for 1.21.1.6, module version = 1.0.1
[ 16.436] (II) modeset(G0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics (TGL GT1)
[ 16.436] (II) modeset(G0): glamor initialized
[ 16.437] (II) modeset(G0): Output DP-1-3 has no monitor section
[ 16.437] (II) modeset(G0): Output DP-1-4 has no monitor section
[ 16.437] (II) modeset(G0): EDID for output DP-1-3
[ 16.437] (II) modeset(G0): EDID for output DP-1-4
[ 16.437] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 16.437] (==) modeset(G0): DPI set to (96, 96)
[ 16.437] (II) Loading sub module "fb"
[ 16.437] (II) LoadModule: "fb"
[ 16.437] (II) Module "fb" already built-in
[ 16.454] (==) modeset(0): Backing store enabled
[ 16.454] (==) modeset(0): Silken mouse enabled
[ 16.481] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 16.481] (==) modeset(0): DPMS enabled
[ 16.572] (==) modeset(G0): Backing store enabled
[ 16.572] (==) modeset(G0): Silken mouse enabled
[ 16.572] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 16.572] (==) modeset(G0): DPMS enabled
[ 16.572] (II) modeset(G0): [DRI2] Setup complete
[ 16.572] (II) modeset(G0): [DRI2] DRI driver: iris
[ 16.572] (II) modeset(G0): [DRI2] VDPAU driver: va_gl
[ 16.572] (II) modeset(G0): Disable reverse prime offload mode for i915.
[ 16.572] (II) Initializing extension Generic Event Extension
[ 16.572] (II) Initializing extension SHAPE
[ 16.572] (II) Initializing extension MIT-SHM
[ 16.572] (II) Initializing extension XInputExtension
[ 16.572] (II) Initializing extension XTEST
[ 16.573] (II) Initializing extension BIG-REQUESTS
[ 16.573] (II) Initializing extension SYNC
[ 16.573] (II) Initializing extension XKEYBOARD
[ 16.573] (II) Initializing extension XC-MISC
[ 16.573] (II) Initializing extension SECURITY
[ 16.573] (II) Initializing extension XFIXES
[ 16.573] (II) Initializing extension RENDER
[ 16.573] (II) Initializing extension RANDR
[ 16.573] (II) Initializing extension COMPOSITE
[ 16.573] (II) Initializing extension DAMAGE
[ 16.573] (II) Initializing extension MIT-SCREEN-SAVER
[ 16.573] (II) Initializing extension DOUBLE-BUFFER
[ 16.573] (II) Initializing extension RECORD
[ 16.573] (II) Initializing extension DPMS
[ 16.573] (II) Initializing extension Present
[ 16.573] (II) Initializing extension DRI3
[ 16.573] (II) Initializing extension X-Resource
[ 16.573] (II) Initializing extension XVideo
[ 16.573] (II) Initializing extension XVideo-MotionCompensation
[ 16.573] (II) Initializing extension GLX
[ 16.573] (II) AIGLX: Screen 0 is not DRI2 capable
[ 16.575] (II) IGLX: Loaded and initialized swrast
[ 16.575] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 16.575] (II) Initializing extension XFree86-VidModeExtension
[ 16.575] (II) Initializing extension XFree86-DGA
[ 16.575] (II) Initializing extension XFree86-DRI
[ 16.575] (II) Initializing extension DRI2
[ 16.588] (II) modeset(G0): Damage tracking initialized
[ 16.589] (II) modeset(0): Damage tracking initialized
[ 16.589] (II) modeset(0): Setting screen physical size to 1185 x 285
[ 16.807] (II) config/udev: Adding input device Video Bus (/dev/input/event22)
[ 16.807] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 16.807] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 16.807] (**) Video Bus: Applying InputClass "system-keyboard"
[ 16.807] (II) LoadModule: "libinput"
[ 16.807] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 16.850] (II) Module libinput: vendor="X.Org Foundation"
[ 16.850] compiled for 1.21.1.3, module version = 1.2.1
[ 16.850] Module class: X.Org XInput Driver
[ 16.850] ABI class: X.Org XInput driver, version 24.4
[ 16.850] (II) Using input driver 'libinput' for 'Video Bus'
[ 16.850] (**) Video Bus: always reports core events
[ 16.851] (**) Option "Device" "/dev/input/event22"
[ 16.899] (II) event22 - Video Bus: is tagged by udev as: Keyboard
[ 16.899] (II) event22 - Video Bus: device is a keyboard
[ 16.899] (II) event22 - Video Bus: device removed
[ 16.956] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input29/event22"
[ 16.956] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[ 16.956] (**) Option "xkb_layout" "br"
[ 17.002] (II) event22 - Video Bus: is tagged by udev as: Keyboard
[ 17.002] (II) event22 - Video Bus: device is a keyboard
[ 17.003] (II) config/udev: Adding input device Video Bus (/dev/input/event21)
[ 17.003] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 17.003] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 17.003] (**) Video Bus: Applying InputClass "system-keyboard"
[ 17.003] (II) Using input driver 'libinput' for 'Video Bus'
[ 17.003] (**) Video Bus: always reports core events
[ 17.003] (**) Option "Device" "/dev/input/event21"
[ 17.004] (II) event21 - Video Bus: is tagged by udev as: Keyboard
[ 17.004] (II) event21 - Video Bus: device is a keyboard
[ 17.005] (II) event21 - Video Bus: device removed
[ 17.076] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/LNXVIDEO:00/input/input28/event21"
[ 17.076] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 17.076] (**) Option "xkb_layout" "br"
[ 17.078] (II) event21 - Video Bus: is tagged by udev as: Keyboard
[ 17.078] (II) event21 - Video Bus: device is a keyboard
[ 17.079] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 17.079] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 17.079] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 17.079] (**) Power Button: Applying InputClass "system-keyboard"
[ 17.079] (II) Using input driver 'libinput' for 'Power Button'
[ 17.079] (**) Power Button: always reports core events
[ 17.079] (**) Option "Device" "/dev/input/event1"
[ 17.080] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 17.080] (II) event1 - Power Button: device is a keyboard
[ 17.080] (II) event1 - Power Button: device removed
[ 17.130] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 17.130] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 17.130] (**) Option "xkb_layout" "br"
[ 17.131] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 17.131] (II) event1 - Power Button: device is a keyboard
[ 17.132] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 17.132] (II) No input driver specified, ignoring this device.
[ 17.132] (II) This device may have been added with another device file.
[ 17.133] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
[ 17.133] (II) No input driver specified, ignoring this device.
[ 17.133] (II) This device may have been added with another device file.
[ 17.133] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event10)
[ 17.134] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event15)
[ 17.134] (II) No input driver specified, ignoring this device.
[ 17.134] (II) This device may have been added with another device file.
[ 17.134] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event16)
[ 17.134] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event17)
[ 17.134] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event18)
[ 17.135] (II) config/udev: Adding input device Logitech G300s Optical Gaming Mouse (/dev/input/event3)
[ 17.135] (**) Logitech G300s Optical Gaming Mouse: Applying InputClass "evdev pointer catchall"
[ 17.135] (**) Logitech G300s Optical Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 17.135] (II) Using input driver 'libinput' for 'Logitech G300s Optical Gaming Mouse'
[ 17.135] (**) Logitech G300s Optical Gaming Mouse: always reports core events
[ 17.135] (**) Option "Device" "/dev/input/event3"
[ 17.191] (II) event3 - Logitech G300s Optical Gaming Mouse: is tagged by udev as: Mouse
[ 17.191] (II) event3 - Logitech G300s Optical Gaming Mouse: device is a pointer
[ 17.191] (II) event3 - Logitech G300s Optical Gaming Mouse: device removed
[ 17.250] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/0003:046D:C246.0001/input/input4/event3"
[ 17.250] (II) XINPUT: Adding extended input device "Logitech G300s Optical Gaming Mouse" (type: MOUSE, id 9)
[ 17.250] (**) Option "AccelerationScheme" "none"
[ 17.250] (**) Logitech G300s Optical Gaming Mouse: (accel) selected scheme none/0
[ 17.250] (**) Logitech G300s Optical Gaming Mouse: (accel) acceleration factor: 2.000
[ 17.250] (**) Logitech G300s Optical Gaming Mouse: (accel) acceleration threshold: 4
[ 17.308] (II) event3 - Logitech G300s Optical Gaming Mouse: is tagged by udev as: Mouse
[ 17.308] (II) event3 - Logitech G300s Optical Gaming Mouse: device is a pointer
[ 17.309] (II) config/udev: Adding input device Logitech G300s Optical Gaming Mouse (/dev/input/mouse0)
[ 17.309] (II) No input driver specified, ignoring this device.
[ 17.309] (II) This device may have been added with another device file.
[ 17.310] (II) config/udev: Adding input device Logitech G512 RGB MECHANICAL GAMING KEYBOARD (/dev/input/event4)
[ 17.310] (**) Logitech G512 RGB MECHANICAL GAMING KEYBOARD: Applying InputClass "evdev keyboard catchall"
[ 17.310] (**) Logitech G512 RGB MECHANICAL GAMING KEYBOARD: Applying InputClass "libinput keyboard catchall"
[ 17.310] (**) Logitech G512 RGB MECHANICAL GAMING KEYBOARD: Applying InputClass "system-keyboard"
[ 17.310] (II) Using input driver 'libinput' for 'Logitech G512 RGB MECHANICAL GAMING KEYBOARD'
[ 17.310] (**) Logitech G512 RGB MECHANICAL GAMING KEYBOARD: always reports core events
[ 17.310] (**) Option "Device" "/dev/input/event4"
[ 17.311] (II) event4 - Logitech G512 RGB MECHANICAL GAMING KEYBOARD: is tagged by udev as: Keyboard
[ 17.311] (II) event4 - Logitech G512 RGB MECHANICAL GAMING KEYBOARD: device is a keyboard
[ 17.311] (II) event4 - Logitech G512 RGB MECHANICAL GAMING KEYBOARD: device removed
[ 17.356] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/0003:046D:C33C.0002/input/input5/event4"
[ 17.356] (II) XINPUT: Adding extended input device "Logitech G512 RGB MECHANICAL GAMING KEYBOARD" (type: KEYBOARD, id 10)
[ 17.356] (**) Option "xkb_layout" "br"
[ 17.358] (II) event4 - Logitech G512 RGB MECHANICAL GAMING KEYBOARD: is tagged by udev as: Keyboard
[ 17.358] (II) event4 - Logitech G512 RGB MECHANICAL GAMING KEYBOARD: device is a keyboard
[ 17.360] (II) config/udev: Adding input device Logitech G512 RGB MECHANICAL GAMING KEYBOARD Keyboard (/dev/input/event5)
[ 17.360] (**) Logitech G512 RGB MECHANICAL GAMING KEYBOARD Keyboard: Applying InputClass "evdev keyboard catchall"
[ 17.360] (**) Logitech G512 RGB MECHANICAL GAMING KEYBOARD Keyboard: Applying InputClass "libinput keyboard catchall"
[ 17.360] (**) Logitech G512 RGB MECHANICAL GAMING KEYBOARD Keyboard: Applying InputClass "system-keyboard"
[ 17.360] (II) Using input driver 'libinput' for 'Logitech G512 RGB MECHANICAL GAMING KEYBOARD Keyboard'
[ 17.360] (**) Logitech G512 RGB MECHANICAL GAMING KEYBOARD Keyboard: always reports core events
[ 17.360] (**) Option "Device" "/dev/input/event5"
[ 17.361] (II) event5 - Logitech G512 RGB MECHANICAL GAMING KEYBOARD Keyboard: is tagged by udev as: Keyboard
[ 17.361] (II) event5 - Logitech G512 RGB MECHANICAL GAMING KEYBOARD Keyboard: device is a keyboard
[ 17.361] (II) event5 - Logitech G512 RGB MECHANICAL GAMING KEYBOARD Keyboard: device removed
[ 17.410] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.1/0003:046D:C33C.0003/input/input6/event5"
[ 17.410] (II) XINPUT: Adding extended input device "Logitech G512 RGB MECHANICAL GAMING KEYBOARD Keyboard" (type: KEYBOARD, id 11)
[ 17.410] (**) Option "xkb_layout" "br"
[ 17.411] (II) event5 - Logitech G512 RGB MECHANICAL GAMING KEYBOARD Keyboard: is tagged by udev as: Keyboard
[ 17.412] (II) event5 - Logitech G512 RGB MECHANICAL GAMING KEYBOARD Keyboard: device is a keyboard
[ 17.413] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event12)
[ 17.413] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[ 17.413] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[ 17.413] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[ 17.413] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[ 17.413] (**) Integrated_Webcam_HD: Integrate: always reports core events
[ 17.413] (**) Option "Device" "/dev/input/event12"
[ 17.414] (II) event12 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 17.414] (II) event12 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 17.414] (II) event12 - Integrated_Webcam_HD: Integrate: device removed
[ 17.476] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5:1.0/input/input16/event12"
[ 17.476] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 12)
[ 17.476] (**) Option "xkb_layout" "br"
[ 17.478] (II) event12 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 17.478] (II) event12 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 17.479] (II) config/udev: Adding input device DELL0A70:00 04F3:317E Mouse (/dev/input/event19)
[ 17.479] (**) DELL0A70:00 04F3:317E Mouse: Applying InputClass "evdev pointer catchall"
[ 17.479] (**) DELL0A70:00 04F3:317E Mouse: Applying InputClass "libinput pointer catchall"
[ 17.479] (II) Using input driver 'libinput' for 'DELL0A70:00 04F3:317E Mouse'
[ 17.479] (**) DELL0A70:00 04F3:317E Mouse: always reports core events
[ 17.479] (**) Option "Device" "/dev/input/event19"
[ 17.480] (II) event19 - DELL0A70:00 04F3:317E Mouse: is tagged by udev as: Mouse Pointingstick
[ 17.480] (II) event19 - DELL0A70:00 04F3:317E Mouse: device is a pointer
[ 17.481] (II) event19 - DELL0A70:00 04F3:317E Mouse: device removed
[ 17.556] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL0A70:00/0018:04F3:317E.0005/input/input25/event19"
[ 17.556] (II) XINPUT: Adding extended input device "DELL0A70:00 04F3:317E Mouse" (type: MOUSE, id 13)
[ 17.557] (**) Option "AccelerationScheme" "none"
[ 17.557] (**) DELL0A70:00 04F3:317E Mouse: (accel) selected scheme none/0
[ 17.557] (**) DELL0A70:00 04F3:317E Mouse: (accel) acceleration factor: 2.000
[ 17.557] (**) DELL0A70:00 04F3:317E Mouse: (accel) acceleration threshold: 4
[ 17.558] (II) event19 - DELL0A70:00 04F3:317E Mouse: is tagged by udev as: Mouse Pointingstick
[ 17.558] (II) event19 - DELL0A70:00 04F3:317E Mouse: device is a pointer
[ 17.559] (II) config/udev: Adding input device DELL0A70:00 04F3:317E Mouse (/dev/input/mouse1)
[ 17.559] (II) No input driver specified, ignoring this device.
[ 17.559] (II) This device may have been added with another device file.
[ 17.559] (II) config/udev: Adding input device DELL0A70:00 04F3:317E Touchpad (/dev/input/event20)
[ 17.559] (**) DELL0A70:00 04F3:317E Touchpad: Applying InputClass "evdev touchpad catchall"
[ 17.559] (**) DELL0A70:00 04F3:317E Touchpad: Applying InputClass "libinput touchpad catchall"
[ 17.559] (**) DELL0A70:00 04F3:317E Touchpad: Applying InputClass "touchpad"
[ 17.559] (II) Using input driver 'libinput' for 'DELL0A70:00 04F3:317E Touchpad'
[ 17.559] (**) DELL0A70:00 04F3:317E Touchpad: always reports core events
[ 17.559] (**) Option "Device" "/dev/input/event20"
[ 17.560] (II) event20 - DELL0A70:00 04F3:317E Touchpad: is tagged by udev as: Touchpad
[ 17.560] (II) event20 - DELL0A70:00 04F3:317E Touchpad: device is a touchpad
[ 17.560] (II) event20 - DELL0A70:00 04F3:317E Touchpad: device removed
[ 17.650] (**) Option "Tapping" "on"
[ 17.650] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL0A70:00/0018:04F3:317E.0005/input/input26/event20"
[ 17.650] (II) XINPUT: Adding extended input device "DELL0A70:00 04F3:317E Touchpad" (type: TOUCHPAD, id 14)
[ 17.652] (**) Option "AccelerationScheme" "none"
[ 17.652] (**) DELL0A70:00 04F3:317E Touchpad: (accel) selected scheme none/0
[ 17.652] (**) DELL0A70:00 04F3:317E Touchpad: (accel) acceleration factor: 2.000
[ 17.652] (**) DELL0A70:00 04F3:317E Touchpad: (accel) acceleration threshold: 4
[ 17.653] (II) event20 - DELL0A70:00 04F3:317E Touchpad: is tagged by udev as: Touchpad
[ 17.654] (II) event20 - DELL0A70:00 04F3:317E Touchpad: device is a touchpad
[ 17.655] (II) config/udev: Adding input device DELL0A70:00 04F3:317E Touchpad (/dev/input/mouse2)
[ 17.655] (**) DELL0A70:00 04F3:317E Touchpad: Applying InputClass "touchpad"
[ 17.655] (II) Using input driver 'libinput' for 'DELL0A70:00 04F3:317E Touchpad'
[ 17.655] (**) DELL0A70:00 04F3:317E Touchpad: always reports core events
[ 17.655] (**) Option "Device" "/dev/input/mouse2"
[ 17.716] (II) mouse2 - not using input device '/dev/input/mouse2'.
[ 17.716] (EE) libinput: DELL0A70:00 04F3:317E Touchpad: Failed to create a device for /dev/input/mouse2
[ 17.716] (EE) PreInit returned 2 for "DELL0A70:00 04F3:317E Touchpad"
[ 17.716] (II) UnloadModule: "libinput"
[ 17.717] (II) config/udev: Adding input device sof-hda-dsp Headphone Mic (/dev/input/event23)
[ 17.717] (II) No input driver specified, ignoring this device.
[ 17.717] (II) This device may have been added with another device file.
[ 17.717] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=3 (/dev/input/event24)
[ 17.718] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=4 (/dev/input/event25)
[ 17.718] (II) No input driver specified, ignoring this device.
[ 17.718] (II) This device may have been added with another device file.
[ 17.718] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=5 (/dev/input/event26)
[ 17.718] (II) config/udev: Adding input device Intel HID events (/dev/input/event7)
[ 17.718] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[ 17.718] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[ 17.718] (**) Intel HID events: Applying InputClass "system-keyboard"
[ 17.718] (II) Using input driver 'libinput' for 'Intel HID events'
[ 17.718] (**) Intel HID events: always reports core events
[ 17.719] (**) Option "Device" "/dev/input/event7"
[ 17.719] (II) event7 - Intel HID events: is tagged by udev as: Keyboard
[ 17.719] (II) event7 - Intel HID events: device is a keyboard
[ 17.719] (II) event7 - Intel HID events: device removed
[ 17.756] (**) Option "config_info" "udev:/sys/devices/platform/INTC1051:00/input/input10/event7"
[ 17.756] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 15)
[ 17.756] (**) Option "xkb_layout" "br"
[ 17.757] (II) event7 - Intel HID events: is tagged by udev as: Keyboard
[ 17.758] (II) event7 - Intel HID events: device is a keyboard
[ 17.758] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event8)
[ 17.758] (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
[ 17.758] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[ 17.758] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[ 17.758] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[ 17.758] (**) Intel HID 5 button array: always reports core events
[ 17.758] (**) Option "Device" "/dev/input/event8"
[ 17.759] (II) event8 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 17.759] (II) event8 - Intel HID 5 button array: device is a keyboard
[ 17.759] (II) event8 - Intel HID 5 button array: device removed
[ 17.783] (**) Option "config_info" "udev:/sys/devices/platform/INTC1051:00/input/input11/event8"
[ 17.783] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 16)
[ 17.783] (**) Option "xkb_layout" "br"
[ 17.784] (II) event8 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 17.784] (II) event8 - Intel HID 5 button array: device is a keyboard
[ 17.785] (II) config/udev: Adding input device Dell Privacy Driver (/dev/input/event13)
[ 17.785] (**) Dell Privacy Driver: Applying InputClass "evdev keyboard catchall"
[ 17.785] (**) Dell Privacy Driver: Applying InputClass "libinput keyboard catchall"
[ 17.785] (**) Dell Privacy Driver: Applying InputClass "system-keyboard"
[ 17.785] (II) Using input driver 'libinput' for 'Dell Privacy Driver'
[ 17.785] (**) Dell Privacy Driver: always reports core events
[ 17.785] (**) Option "Device" "/dev/input/event13"
[ 17.786] (II) event13 - Dell Privacy Driver: is tagged by udev as: Keyboard Switch
[ 17.786] (II) event13 - Dell Privacy Driver: device is a keyboard
[ 17.787] (II) event13 - Dell Privacy Driver: device removed
[ 17.850] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:03/wmi_bus/wmi_bus-PNP0C14:03/PNP0C14:03-6932965F-1671-4CEB-B988-D3AB0A901919/input/input17/event13"
[ 17.850] (II) XINPUT: Adding extended input device "Dell Privacy Driver" (type: KEYBOARD, id 17)
[ 17.850] (**) Option "xkb_layout" "br"
[ 17.851] (II) event13 - Dell Privacy Driver: is tagged by udev as: Keyboard Switch
[ 17.851] (II) event13 - Dell Privacy Driver: device is a keyboard
[ 17.852] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event14)
[ 17.852] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 17.852] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 17.852] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 17.852] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 17.852] (**) Dell WMI hotkeys: always reports core events
[ 17.852] (**) Option "Device" "/dev/input/event14"
[ 17.853] (II) event14 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 17.854] (II) event14 - Dell WMI hotkeys: device is a keyboard
[ 17.854] (II) event14 - Dell WMI hotkeys: device removed
[ 17.930] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:03/wmi_bus/wmi_bus-PNP0C14:03/PNP0C14:03-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input18/event14"
[ 17.930] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 18)
[ 17.930] (**) Option "xkb_layout" "br"
[ 17.931] (II) event14 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 17.931] (II) event14 - Dell WMI hotkeys: device is a keyboard
[ 17.932] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 17.932] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 17.932] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 17.932] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 17.932] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 17.932] (**) AT Translated Set 2 keyboard: always reports core events
[ 17.932] (**) Option "Device" "/dev/input/event2"
[ 17.933] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 17.933] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 17.935] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 17.996] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[ 17.996] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 19)
[ 17.996] (**) Option "xkb_layout" "br"
[ 17.998] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 17.998] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 18.000] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/event11)
[ 18.000] (**) PS/2 Generic Mouse: Applying InputClass "evdev pointer catchall"
[ 18.000] (**) PS/2 Generic Mouse: Applying InputClass "libinput pointer catchall"
[ 18.000] (II) Using input driver 'libinput' for 'PS/2 Generic Mouse'
[ 18.000] (**) PS/2 Generic Mouse: always reports core events
[ 18.000] (**) Option "Device" "/dev/input/event11"
[ 18.000] (II) event11 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[ 18.000] (II) event11 - PS/2 Generic Mouse: device is a pointer
[ 18.001] (II) event11 - PS/2 Generic Mouse: device removed
[ 18.063] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input12/event11"
[ 18.063] (II) XINPUT: Adding extended input device "PS/2 Generic Mouse" (type: MOUSE, id 20)
[ 18.063] (**) Option "AccelerationScheme" "none"
[ 18.063] (**) PS/2 Generic Mouse: (accel) selected scheme none/0
[ 18.063] (**) PS/2 Generic Mouse: (accel) acceleration factor: 2.000
[ 18.063] (**) PS/2 Generic Mouse: (accel) acceleration threshold: 4
[ 18.064] (II) event11 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[ 18.064] (II) event11 - PS/2 Generic Mouse: device is a pointer
[ 18.065] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/mouse3)
[ 18.065] (II) No input driver specified, ignoring this device.
[ 18.065] (II) This device may have been added with another device file.
[ 18.065] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 46.809] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 66.368] (II) modeset(0): EDID vendor "AUO", prod id 46235
[ 66.368] (II) modeset(0): Using EDID range info for horizontal sync
[ 66.368] (II) modeset(0): Using EDID range info for vertical refresh
[ 66.368] (II) modeset(0): Printing DDC gathered Modelines:
[ 66.368] (II) modeset(0): Modeline "1920x1080"x0.0 405.00 1920 1968 2000 2080 1080 1090 1095 3240 +hsync -vsync (194.7 kHz eP)
[ 66.575] (--) modeset(0): HDMI max TMDS frequency 300000KHz
[ 68.363] (II) modeset(0): EDID vendor "AUO", prod id 46235
[ 68.363] (II) modeset(0): Using hsync ranges from config file
[ 68.363] (II) modeset(0): Using vrefresh ranges from config file
[ 68.363] (II) modeset(0): Printing DDC gathered Modelines:
[ 68.363] (II) modeset(0): Modeline "1920x1080"x0.0 405.00 1920 1968 2000 2080 1080 1090 1095 3240 +hsync -vsync (194.7 kHz eP)
[ 68.568] (--) modeset(0): HDMI max TMDS frequency 300000KHz
[ 168.173] (II) modeset(0): EDID vendor "AUO", prod id 46235
[ 168.173] (II) modeset(0): Using hsync ranges from config file
[ 168.173] (II) modeset(0): Using vrefresh ranges from config file
[ 168.173] (II) modeset(0): Printing DDC gathered Modelines:
[ 168.173] (II) modeset(0): Modeline "1920x1080"x0.0 405.00 1920 1968 2000 2080 1080 1090 1095 3240 +hsync -vsync (194.7 kHz eP)
[ 168.378] (--) modeset(0): HDMI max TMDS frequency 300000KHz
Your laptop is definitely recognizing the eDP display as having a 165hz setting at 1080p.
I am not familiar with KDE, but you should have a displays section in the settings where you can change the resolution and refresh rate. Can you change it there to 165hz?
First, before anything else, it looks like nvidia-lts is indeed in the extra repo. Try refreshing the repositories with this command:
‘sudo pacman -Sy nvidia-lts’
If this solves your problem as you mentioned, no need to proceed any further. If this is still unavailable, it may be one of the dependencies which is solving your issue so try installing those.
sudo pacman -Sy libglvnd nvidia-utils nvidia-dkms
There is also linux-lts and linux-lts-headers, but you are not currently on an LTS kernel. (This may be why it is unavailable?)
Now try change your resolution in the system settings or with nvidia-settings if you can.
If it still doesn’t work
Update your driver with the following command and try changing resolutions.
sudo mhwd -a pci nonfree 0300
Here is someone using xrandr to view supported displays and refresh rates that may be helpful in troubleshooting further:
There is also the Arch NVIDIA wiki page that can be of help.
It is of note that there can be issues when having multiple monitors at different refresh rates. Try disconnecting the second monitor you have attached to the hdmi port and try changing refresh rates.
If you are still stuck, post the output from xrandr
Thanks I’ll try that later! But yeah I can’t change into the settings neither xrandr. Only solution I found was installing nvidia-lts (it kinda bugs the audio but that’s another problem).
