I have the exact same problem. I’m on Intel machine: both CPU and GPU. I don’t use NVIDIA dGPU.
5.10 is very uncomfortable to use.
The problem is not specific to UI oraz GPU. Even saving a file in LibreOffice Writer takes much more time. Desktop starts slower and I see the drive lighting up like crazy. I have a very good SSD, but sometimes it almost feels like it’s an old HDD. Even displaying a web page (gmail or YouTube) takes more time. The entire system is sluggish.
All the below logs are from 5.10.2-2.
inxi -Fazy:
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.10-x86_64
root=UUID=8d5274e2-a298-4bc3-894c-c2e5249a7c83 ro scsi_mod.use_blk_mq=1
intel_pstate=disable mitigations=off udev.log_priority=3
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: GDM 3.38.2.1 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: N56JR v: 1.0 serial: <filter>
Mobo: ASUSTeK model: N56JR v: 1.0 serial: <filter> BIOS: American Megatrends
v: N56JR.204 date: 10/31/2013
ID-1: BAT0 charge: 48.0 Wh condition: 49.1/48.8 Wh (100%) volts: 11.1/11.1
model: ASUSTeK N56--52 type: Li-ion serial: N/A status: Charging
Info: Quad Core model: Intel Core i7-4700HQ bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28
L2 cache: 6 MiB
bogomips: 38322
Speed: 798 MHz min/max: 800/2401 MHz boost: enabled Core speeds (MHz):
1: 798 2: 799 3: 800 4: 798 5: 799 6: 799 7: 799 8: 798
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Type: srbds status: Vulnerable
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0416
Device-2: NVIDIA GK106M [GeForce GTX 760M] vendor: ASUSTeK driver: N/A
alternate: nouveau bus ID: 01:00.0 chip ID: 10de:11e3
Device-3: Sunplus Innovation Asus Webcam type: USB driver: uvcvideo
bus ID: 3-7:5 chip ID: 1bcf:2883
Display: x11 server: X.org 1.20.10 driver: modesetting unloaded: nvidia
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 20.3.1 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
Device-3: GYROCOM C&C Audiotrak ProDigy CUBE type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-2:2 chip ID: 1852:7921
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel port: e000
bus ID: 03:00.0 chip ID: 8086:08b1
vendor: ASUSTeK driver: N/A modules: r8169 port: d000 bus ID: 04:00.0
chip ID: 10ec:8168
IF-ID-1: virbr0 state: down mac: <filter>
IF-ID-2: virbr0-nic state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 231.39 GiB (49.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1B6Q
ID-1: / raw size: 60 GiB size: 58.81 GiB (98.01%) used: 35.01 GiB (59.5%)
fs: ext4 block size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-2: /boot raw size: 520 MiB size: 495.8 MiB (95.35%)
used: 103.6 MiB (20.9%) fs: ext4 block size: 4096 B dev: /dev/sda1
maj-min: 8:1
ID-3: /home raw size: 90.01 GiB size: 88.09 GiB (97.87%)
used: 71.94 GiB (81.7%) fs: ext4 block size: 4096 B dev: /dev/sda3
maj-min: 8:3
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
Processes: 271 Uptime: 1m wakeups: 1 Memory: 15.34 GiB
used: 2.31 GiB (15.1%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: pacman: 1788 lib: 473 Shell: Bash v: 5.1.0
running in: xfce4-terminal inxi: 3.2.01
lspci -vv:
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller (rev 06)
Subsystem: ASUSTeK Computer Inc. Device 14ad
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 0
Capabilities: <access denied>
Kernel modules: ie31200_edac
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 26
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: f6000000-f70fffff [size=17M]
Prefetchable memory behind bridge: 00000000e0000000-00000000f1ffffff [size=288M]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06) (prog-if 00 [VGA controller])
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 36
Region 0: Memory at f7400000 (64-bit, non-prefetchable) [size=4M]
Region 2: Memory at d0000000 (64-bit, prefetchable) [size=256M]
Region 4: I/O ports at f000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
Subsystem: Intel Corporation Device 2010
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 38
Region 0: Memory at f7b14000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05) (prog-if 30 [XHCI])
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 32
Region 0: Memory at f7b00000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
Latency: 0
Interrupt: pin A routed to IRQ 34
Region 0: Memory at f7b1e000 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 05) (prog-if 20 [EHCI])
Latency: 0
Interrupt: pin A routed to IRQ 16
Region 0: Memory at f7b1c000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
Interrupt: pin A routed to IRQ 37
Region 0: Memory at f7b10000 (64-bit, non-prefetchable) [size=16K]
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 27
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: [disabled]
Prefetchable memory behind bridge: [disabled]
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5) (prog-if 00 [Normal decode])
Interrupt: pin C routed to IRQ 28
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: f7a00000-f7afffff [size=1M]
00:1c.3 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 (rev d5) (prog-if 00 [Normal decode])
Interrupt: pin D routed to IRQ 29
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 0000d000-0000dfff [size=4K]
Memory behind bridge: f7900000-f79fffff [size=1M]
Prefetchable memory behind bridge: 00000000f2100000-00000000f21fffff [size=1M]
00:1c.4 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #5 (rev d5) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 30
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
Memory behind bridge: f7800000-f78fffff [size=1M]
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 05) (prog-if 20 [EHCI])
Latency: 0
Interrupt: pin A routed to IRQ 23
Region 0: Memory at f7b1b000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge: Intel Corporation HM86 Express LPC Controller (rev 05)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05) (prog-if 01 [AHCI 1.0])
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin B routed to IRQ 31
Region 0: I/O ports at f0b0 [size=8]
Region 1: I/O ports at f0a0 [size=4]
Region 2: I/O ports at f090 [size=8]
Region 3: I/O ports at f080 [size=4]
Region 4: I/O ports at f060 [size=32]
Region 5: Memory at f7b1a000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin C routed to IRQ 18
Region 0: Memory at f7b19000 (64-bit, non-prefetchable) [size=256]
Region 4: I/O ports at f040 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 3D controller: NVIDIA Corporation GK106M [GeForce GTX 760M] (rev a1)
Interrupt: pin A routed to IRQ 11
Region 0: Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at e0000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at f0000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at e000 [size=128]
Expansion ROM at f7000000 [disabled] [size=512K]
Kernel modules: nouveau
03:00.0 Network controller: Intel Corporation Wireless 7260 (rev 73)
Subsystem: Intel Corporation Dual Band Wireless-N 7260
Interrupt: pin A routed to IRQ 35
Region 0: Memory at f7a00000 (64-bit, non-prefetchable) [size=8K]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
Subsystem: ASUSTeK Computer Inc. Device 200f
Interrupt: pin A routed to IRQ 10
Region 0: I/O ports at d000 [size=256]
Region 2: Memory at f7900000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at f2100000 (64-bit, prefetchable) [size=16K]
Kernel modules: r8169
05:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5227 PCI Express Card Reader (rev 01)
Subsystem: Realtek Semiconductor Co., Ltd. RTS5227 PCI Express Card Reader
Interrupt: pin A routed to IRQ 33
Region 0: Memory at f7800000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
sudo lspci -v:
Controller (rev 06)
Subsystem: ASUSTeK Computer Inc. Device 14ad Flags: bus master, fast
devsel, latency 0 Capabilities: [e0] Vendor Specific Information: Len=0c
<?> Kernel modules: ie31200_edac
Flags: bus master, fast devsel, latency 0, IRQ 26 Bus: primary=00,
secondary=01, subordinate=01, sec-latency=0 I/O behind bridge:
0000e000-0000efff [size=4K] Memory behind bridge: f6000000-f70fffff
[size=17M] Prefetchable memory behind bridge:
00000000e0000000-00000000f1ffffff [size=288M] Capabilities: [88]
Subsystem: ASUSTeK Computer Inc. Device 14ad Capabilities: [80] Power
Management version 3 Capabilities: [90] MSI: Enable+ Count=1/1 Maskable-
64bit- Capabilities: [a0] Express Root Port (Slot+), MSI 00 Capabilities:
[100] Virtual Channel Capabilities: [140] Root Complex Link Capabilities:
[d94] Secondary PCI Express Kernel driver in use: pcieport
devsel, latency 0, IRQ 36 Memory at f7400000 (64-bit, non-prefetchable)
[size=4M] Memory at d0000000 (64-bit, prefetchable) [size=256M] I/O ports
at f000 [size=64] Expansion ROM at 000c0000 [virtual] [disabled]
[size=128K] Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2 Capabilities: [a4] PCI
Advanced Features Kernel driver in use: i915 Kernel modules: i915
Subsystem: Intel Corporation Device 2010 Flags: bus master, fast devsel,
latency 0, IRQ 38 Memory at f7b14000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2 Capabilities: [60] MSI:
Enable+ Count=1/1 Maskable- 64bit- Capabilities: [70] Express Root Complex
Integrated Endpoint, MSI 00 Kernel driver in use: snd_hda_intel Kernel
Subsystem: ASUSTeK Computer Inc. Device 14ad Flags: bus master, medium
devsel, latency 0, IRQ 32 Memory at f7b00000 (64-bit, non-prefetchable)
[size=64K] Capabilities: [70] Power Management version 2 Capabilities:
[80] MSI: Enable+ Count=1/8 Maskable- 64bit+ Kernel driver in use:
xhci_hcd Kernel modules: xhci_pci
devsel, latency 0, IRQ 34 Memory at f7b1e000 (64-bit, non-prefetchable)
[size=16] Capabilities: [50] Power Management version 3 Capabilities: [8c]
MSI: Enable+ Count=1/1 Maskable- 64bit+ Kernel driver in use: mei_me
devsel, latency 0, IRQ 16 Memory at f7b1c000 (32-bit, non-prefetchable)
[size=1K] Capabilities: [50] Power Management version 2 Capabilities: [58]
Debug port: BAR=1 offset=00a0 Capabilities: [98] PCI Advanced Features
devsel, latency 0, IRQ 37 Memory at f7b10000 (64-bit, non-prefetchable)
[size=16K] Capabilities: [50] Power Management version 2 Capabilities:
[60] MSI: Enable+ Count=1/1 Maskable- 64bit+ Capabilities: [70] Express
Root Complex Integrated Endpoint, MSI 00 Capabilities: [100] Virtual
Channel Kernel driver in use: snd_hda_intel Kernel modules: snd_hda_intel
Flags: bus master, fast devsel, latency 0, IRQ 27 Bus: primary=00,
secondary=02, subordinate=02, sec-latency=0 I/O behind bridge: [disabled]
Memory behind bridge: [disabled] Prefetchable memory behind bridge:
[disabled] Capabilities: [40] Express Root Port (Slot-), MSI 00
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit- Capabilities:
[90] Subsystem: ASUSTeK Computer Inc. Device 14ad Capabilities: [a0] Power
Management version 3 Kernel driver in use: pcieport
Flags: bus master, fast devsel, latency 0, IRQ 28 Bus: primary=00,
secondary=03, subordinate=03, sec-latency=0 I/O behind bridge: [disabled]
Memory behind bridge: f7a00000-f7afffff [size=1M] Prefetchable memory
behind bridge: [disabled] Capabilities: [40] Express Root Port (Slot+),
MSI 00 Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: ASUSTeK Computer Inc. Device 14ad
Capabilities: [a0] Power Management version 3 Kernel driver in use:
pcieport
Flags: bus master, fast devsel, latency 0, IRQ 29 Bus: primary=00,
secondary=04, subordinate=04, sec-latency=0 I/O behind bridge:
0000d000-0000dfff [size=4K] Memory behind bridge: f7900000-f79fffff
[size=1M] Prefetchable memory behind bridge:
00000000f2100000-00000000f21fffff [size=1M] Capabilities: [40] Express
Root Port (Slot+), MSI 00 Capabilities: [80] MSI: Enable+ Count=1/1
Maskable- 64bit- Capabilities: [90] Subsystem: ASUSTeK Computer Inc.
Device 14ad Capabilities: [a0] Power Management version 3 Kernel driver in
use: pcieport
Flags: bus master, fast devsel, latency 0, IRQ 30 Bus: primary=00,
secondary=05, subordinate=05, sec-latency=0 I/O behind bridge: [disabled]
Memory behind bridge: f7800000-f78fffff [size=1M] Prefetchable memory
pcieport
devsel, latency 0, IRQ 23 Memory at f7b1b000 (32-bit, non-prefetchable)
<?> Kernel driver in use: lpc_ich Kernel modules: lpc_ich
Subsystem: ASUSTeK Computer Inc. Device 14ad Flags: bus master, 66MHz,
medium devsel, latency 0, IRQ 31 I/O ports at f0b0 [size=8] I/O ports at
f0a0 [size=4] I/O ports at f090 [size=8] I/O ports at f080 [size=4] I/O
ports at f060 [size=32] Memory at f7b1a000 (32-bit, non-prefetchable)
[size=2K] Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [70] Power Management version 3 Capabilities: [a8] SATA HBA
v1.0 Kernel driver in use: ahci
Controller (rev 05)
Subsystem: ASUSTeK Computer Inc. Device 14ad Flags: medium devsel, IRQ 18
Memory at f7b19000 (64-bit, non-prefetchable) [size=256] I/O ports at f040
[size=32] Kernel driver in use: i801_smbus Kernel modules: i2c_i801
devsel, latency 0, IRQ 11 Memory at f6000000 (32-bit, non-prefetchable)
[size=16M] Memory at e0000000 (64-bit, prefetchable) [size=256M] Memory at
f0000000 (64-bit, prefetchable) [size=32M] I/O ports at e000 [size=128]
Expansion ROM at f7000000 [disabled] [size=512K] Capabilities: [60] Power
Management version 3 Capabilities: [68] MSI: Enable- Count=1/1 Maskable-
64bit+ Capabilities: [78] Express Endpoint, MSI 00 Capabilities: [b4]
Vendor Specific Information: Len=14 <?> Capabilities: [100] Virtual
Channel Capabilities: [128] Power Budgeting <?> Capabilities: [600] Vendor
Specific Information: ID=0001 Rev=1 Len=024 <?> Capabilities: [900]
Secondary PCI Express Kernel modules: nouveau
03:00.0 Network controller: Intel Corporation Wireless 7260 (rev 73) Subsystem:
Intel Corporation Dual Band Wireless-N 7260 Flags: bus master, fast
devsel, latency 0, IRQ 35 Memory at f7a00000 (64-bit, non-prefetchable)
[size=8K] Capabilities: [c8] Power Management version 3 Capabilities: [d0]
MSI: Enable+ Count=1/1 Maskable- 64bit+ Capabilities: [40] Express
Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number 0c-8b-fd-ff-ff-78-66-c1
Capabilities: [14c] Latency Tolerance Reporting Capabilities: [154] Vendor
Specific Information: ID=cafe Rev=1 Len=014 <?> Kernel driver in use:
iwlwifi Kernel modules: iwlwifi
Subsystem: ASUSTeK Computer Inc. Device 200f Flags: bus master, fast
devsel, latency 0, IRQ 10 I/O ports at d000 [size=256] Memory at f7900000
(64-bit, non-prefetchable) [size=4K] Memory at f2100000 (64-bit,
prefetchable) [size=16K] Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+ Capabilities:
[70] Express Endpoint, MSI 01 Capabilities: [b0] MSI-X: Enable- Count=4
Masked- Capabilities: [d0] Vital Product Data Capabilities: [100] Advanced
Error Reporting Capabilities: [140] Virtual Channel Capabilities: [160]
Device Serial Number 24-20-18-44-68-4c-e0-00 Capabilities: [170] Latency
Tolerance Reporting Kernel modules: r8169
Flags: bus master, fast devsel, latency 0, IRQ 33 Memory at f7800000
(32-bit, non-prefetchable) [size=4K] Capabilities: [40] Power Management
version 3 Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 00 Capabilities: [100] Advanced
Error Reporting Capabilities: [140] Device Serial Number
00-00-00-01-00-4c-e0-00 Capabilities: [150] Latency Tolerance Reporting
Capabilities: [158] L1 PM Substates Kernel driver in use: rtsx_pci Kernel
modules: rtsx_pci
sudo dmesg | grep “not found”:
[ 2.466502] at24 0-0050: supply vcc not found, using dummy regulator
[ 2.468041] at24 0-0052: supply vcc not found, using dummy regulator
sudo dmesg -l emerg,alert,crit,err,warn:
[ 0.155737] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.751165] ata5.00: supports DRM functions and may not be fully accessible
[ 0.755738] ata5.00: supports DRM functions and may not be fully accessible
[ 1.884423] acpi_call: loading out-of-tree module taints kernel.
[ 2.260475] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000184F (\GPIS) (20200925/utaddress-204)
[ 2.260481] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20200925/utaddress-204)
[ 2.260490] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C5F (\_SB.PCI0.PEG0.PEGP.GPR) (20200925/utaddress-204)
[ 2.260494] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C7F (\GPIO) (20200925/utaddress-204)
[ 2.260497] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C63 (\GP01) (20200925/utaddress-204)
[ 2.260502] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C5F (\_SB.PCI0.PEG0.PEGP.GPR) (20200925/utaddress-204)
[ 2.260505] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C7F (\GPIO) (20200925/utaddress-204)
[ 2.260508] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C63 (\GP01) (20200925/utaddress-204)
[ 2.260512] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20200925/utaddress-204)
[ 2.260516] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C5F (\_SB.PCI0.PEG0.PEGP.GPR) (20200925/utaddress-204)
[ 2.260519] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C7F (\GPIO) (20200925/utaddress-204)
[ 2.260522] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C63 (\GP01) (20200925/utaddress-204)
[ 2.260525] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20200925/utaddress-204)
[ 2.260529] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 2.771365] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 3.223889] hid-generic 0003:1852:7921.0001: No inputs registered, leaving
[ 5.028823] Bluetooth: hci0: unexpected event for opcode 0xfc2f
[ 5.175081] kauditd_printk_skb: 75 callbacks suppressed
[ 12.941497] kauditd_printk_skb: 41 callbacks suppressed
[ 24.976039] kauditd_printk_skb: 4 callbacks suppressed
[ 68.017019] kauditd_printk_skb: 1 callbacks suppressed
journalctl -xb -p 3:
-- Journal begins at Fri 2020-06-19 19:39:45 CEST, ends at Fri 2021-01-01 22:16:51 CET. --
sty 01 22:05:31 station kernel: hid-generic 0003:1852:7921.0001: No inputs registered, leaving
sty 01 22:05:33 station kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
sty 01 22:05:40 station gdm-password][1325]: gkr-pam: unable to locate daemon control file
For now, I’m on 5.9.
