I also have some ACPI errors here.
inxi -Fazy:
Kernel: 5.10.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=345b76c0-f339-4ca7-8582-440f229512a1 ro quiet
acpi_enforce_resources=lax acpi_osi=! "acpi_osi=Windows 2012" loglevel=3
resume=UUID=a9353f2a-2cf9-4d4e-ada9-f72d8602045e vga=off
nvidia-drm.modeset=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: Foxconn model: H67M-S/H67M-V/H67M serial: <filter>
BIOS: American Megatrends v: C29F1P03 date: 03/15/2013
Info: Dual Core model: Intel Core i3-2105 bits: 64 type: MT MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 24753
Speed: 2803 MHz min/max: 1600/3100 MHz Core speeds (MHz): 1: 2803 2: 1596
3: 1597 4: 1596
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: NVIDIA GF116 [GeForce GTX 550 Ti] vendor: Gigabyte driver: nvidia
v: 390.141 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1244
Display: x11 server: X.Org 1.20.10 compositor: picom v: git-dac85 driver:
loaded: nvidia display ID: :0.0 screens: 1
Screen-1: 0 s-res: 3600x1080 s-dpi: 96 s-size: 953x286mm (37.5x11.3")
s-diag: 995mm (39.2")
Monitor-1: DVI-I-2 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: DVI-I-3 res: 1680x1050 hz: 60 dpi: 90
size: 474x296mm (18.7x11.7") diag: 559mm (22")
OpenGL: renderer: GeForce GTX 550 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 390.141
direct render: Yes
vendor: Foxconn driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1c20
Device-2: NVIDIA GF116 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0bee
Device-3: Creative Live! Cam Chat HD [VF0700] type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus ID: 1-1.3:5
chip ID: 041e:4097 serial: <filter>
Sound Server: ALSA v: k5.10.7-1-MANJARO
vendor: Foxconn driver: r8169 v: kernel port: d000 bus ID: 03:00.0
chip ID: 10ec:8168
Device-2: AVM Fritz!Card PCI v2.0 ISDN driver: N/A modules: avmfritz
port: c000 bus ID: 05:01.0 chip ID: 1244:0e00
Local Storage: total: 1.35 TiB used: 362.1 GiB (26.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intenso model: SSD SATAIII
size: 447.13 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 4A0
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST31000333AS
size: 931.51 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: CC3H
ID-1: / raw size: 438.54 GiB size: 430.65 GiB (98.20%)
used: 107.38 GiB (24.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw size: 915 GiB size: 899.64 GiB (98.32%)
used: 254.72 GiB (28.3%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: partition size: 16.51 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 41.0 C mobo: 27.8 C gpu: nvidia temp: 57 C
Fan Speeds (RPM): cpu: 0 fan-1: 2064 fan-3: 0 gpu: nvidia fan: 61%
Power: 12v: N/A 5v: N/A 3.3v: N/A vbat: 3.10
Processes: 225 Uptime: 1h 17m wakeups: 0 Memory: 7.74 GiB
used: 2.58 GiB (33.4%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.1 Packages: pacman: 1321 lib: 395 Shell: Bash v: 5.1.0
running in: xfce4-terminal inxi: 3.2.02
lspci -vv
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
Subsystem: Foxconn International, Inc. Device 0dcc
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 0
Capabilities: <access denied>
Kernel driver in use: snb_uncore
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 24
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: f4000000-f60fffff [size=33M]
Prefetchable memory behind bridge: 00000000e0000000-00000000ebffffff [size=192M]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA+ VGA16+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel driver in use: pcieport
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 36
Region 0: Memory at f630b000 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05) (prog-if 20 [EHCI])
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 16
Region 0: Memory at f6308000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
Interrupt: pin A routed to IRQ 38
Region 0: Memory at f6300000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 25
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: [disabled]
Prefetchable memory behind bridge: [disabled]
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16+ MAbort- >Reset- FastB2B-
00:1c.1 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 (rev b5) (prog-if 00 [Normal decode])
Interrupt: pin B routed to IRQ 26
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000d000-0000dfff [size=4K]
Prefetchable memory behind bridge: 00000000ec100000-00000000ec1fffff [size=1M]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
00:1c.2 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 3 (rev b5) (prog-if 00 [Normal decode])
Interrupt: pin C routed to IRQ 27
Bus: primary=00, secondary=04, subordinate=05, sec-latency=0
I/O behind bridge: 0000c000-0000cfff [size=4K]
Memory behind bridge: f6200000-f62fffff [size=1M]
00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b5) (prog-if 00 [Normal decode])
Interrupt: pin D routed to IRQ 28
Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
Memory behind bridge: f6100000-f61fffff [size=1M]
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05) (prog-if 20 [EHCI])
Latency: 0
Interrupt: pin A routed to IRQ 23
Region 0: Memory at f6307000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge: Intel Corporation H67 Express Chipset LPC Controller (rev 05)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port Desktop SATA AHCI Controller (rev 05) (prog-if 01 [AHCI 1.0])
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin B routed to IRQ 29
Region 0: I/O ports at f070 [size=8]
Region 1: I/O ports at f060 [size=4]
Region 2: I/O ports at f050 [size=8]
Region 3: I/O ports at f040 [size=4]
Region 4: I/O ports at f020 [size=32]
Region 5: Memory at f6306000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin C routed to IRQ 18
Region 0: Memory at f6305000 (64-bit, non-prefetchable) [size=256]
Region 4: I/O ports at f000 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 VGA compatible controller: NVIDIA Corporation GF116 [GeForce GTX 550 Ti] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Gigabyte Technology Co., Ltd Device 351a
Latency: 0
Interrupt: pin A routed to IRQ 30
Region 0: Memory at f4000000 (32-bit, non-prefetchable) [size=32M]
Region 1: Memory at e0000000 (64-bit, prefetchable) [size=128M]
Region 3: Memory at e8000000 (64-bit, prefetchable) [size=64M]
Region 5: I/O ports at e000 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation GF116 High Definition Audio Controller (rev a1)
Interrupt: pin B routed to IRQ 17
Region 0: Memory at f6080000 (32-bit, non-prefetchable) [size=16K]
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 17
Region 0: I/O ports at d000 [size=256]
Region 2: Memory at ec104000 (64-bit, prefetchable) [size=4K]
Region 4: Memory at ec100000 (64-bit, prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
04:00.0 PCI bridge: Integrated Technology Express, Inc. IT8893E PCIe to PCI Bridge (rev 10) (prog-if 01 [Subtractive decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Latency: 0, Cache Line Size: 32 bytes
Bus: primary=04, secondary=05, subordinate=05, sec-latency=64
Secondary status: 66MHz+ FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
PriDiscTmr- SecDiscTmr+ DiscTmrStat- DiscTmrSERREn-
05:01.0 Network controller: AVM GmbH Fritz!Card PCI v2.0 ISDN (rev 01)
Subsystem: AVM GmbH Fritz!Card PCI v2.0 ISDN
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 5
Region 0: Memory at f6200000 (32-bit, non-prefetchable) [size=32]
Region 1: I/O ports at c000 [size=32]
Kernel modules: avmfritz
06:00.0 USB controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 03) (prog-if 30 [XHCI])
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 19
Region 0: Memory at f6100000 (64-bit, non-prefetchable) [size=8K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
sudo lspci -v:
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
Flags: bus master, fast devsel, latency 0, IRQ 24
Capabilities: [88] Subsystem: Foxconn International, Inc. Device 0dcc
Capabilities: [80] Power Management version 3
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [a0] Express Root Port (Slot+), MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [140] Root Complex Link
Flags: bus master, fast devsel, latency 0, IRQ 36
Capabilities: [50] Power Management version 3
Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
Flags: bus master, medium devsel, latency 0, IRQ 16
Capabilities: [50] Power Management version 2
Capabilities: [58] Debug port: BAR=1 offset=00a0
Capabilities: [98] PCI Advanced Features
Flags: bus master, fast devsel, latency 0, IRQ 38
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [130] Root Complex Link
Flags: bus master, fast devsel, latency 0, IRQ 25
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: Foxconn International, Inc. Device 0dcc
Capabilities: [a0] Power Management version 2
Flags: bus master, fast devsel, latency 0, IRQ 26
Flags: bus master, fast devsel, latency 0, IRQ 27
Flags: bus master, fast devsel, latency 0, IRQ 28
Flags: bus master, medium devsel, latency 0, IRQ 23
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 29
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Capabilities: [b0] PCI Advanced Features
Flags: medium devsel, IRQ 18
Flags: bus master, fast devsel, latency 0, IRQ 30
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Flags: bus master, fast devsel, latency 0, IRQ 17
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [b0] MSI-X: Enable+ Count=4 Masked-
Capabilities: [d0] Vital Product Data
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number 1d-00-00-00-68-4c-e0-00
Capabilities: [90] Power Management version 2
Capabilities: [a0] Subsystem: Foxconn International, Inc. Device 0dcc
Flags: medium devsel, IRQ 5
Capabilities: [40] Power Management version 2
Flags: bus master, fast devsel, latency 0, IRQ 19
Capabilities: [70] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [90] MSI-X: Enable+ Count=8 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [140] Device Serial Number ff-ff-ff-ff-ff-ff-ff-ff
Capabilities: [150] Latency Tolerance Reporting
sudo dmesg | grep “not found”:
[ 1.807302] PM: Image not found (code -22)
[ 3.655914] at24 3-0050: supply vcc not found, using dummy regulator
[ 3.679514] at24 3-0051: supply vcc not found, using dummy regulator
[ 3.680327] at24 3-0052: supply vcc not found, using dummy regulator
[ 3.681422] at24 3-0053: supply vcc not found, using dummy regulator
sudo dmesg -l emerg,alert,crit,err,warn
[ 0.127027] x86/cpu: VMX (outside TXT) disabled by BIOS
[ 0.139133] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.139133] #3
[ 0.144049] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 1.179903] nvidia: loading out-of-tree module taints kernel.
[ 1.179915] nvidia: module license 'NVIDIA' taints kernel.
[ 1.179916] Disabling lock debugging due to kernel taint
[ 1.216675] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 390.141 Mon Dec 28 16:21:32 UTC 2020 (using threaded interrupts)
[ 1.309967] resource sanity check: requesting [mem 0x000e0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000e0000-0x000e3fff window]
[ 1.310194] caller _nv027867rm+0x58/0x90 [nvidia] mapping multiple BARs
[ 1.403562] resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000d3fff window]
[ 1.403733] caller _nv001015rm+0x1bf/0x1f0 [nvidia] mapping multiple BARs
[ 3.269072] ACPI Warning: SystemIO range 0x0000000000000A35-0x0000000000000A36 conflicts with OpRegion 0x0000000000000A35-0x0000000000000A36 (\IP) (20200925/utaddress-204)
[ 3.354058] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200925/utaddress-204)
[ 3.354074] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
[ 3.354081] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
[ 3.354087] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
[ 5.274715] kauditd_printk_skb: 94 callbacks suppressed
[ 14.013308] kauditd_printk_skb: 10 callbacks suppressed
journalctl -xb -p 3:
Jan 14 16:39:38 manjaro kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Jan 14 16:39:41 gerd-desktop smbd[330]: [2021/01/14 16:39:41.063903, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
Jan 14 16:39:41 gerd-desktop smbd[330]: daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
Jan 14 16:39:45 gerd-desktop pulseaudio[553]: module-rescue-stream is obsolete and should no longer be loaded. Please remove it from your configuration.
Jan 14 16:39:45 gerd-desktop pulseaudio[553]: Doing resync
Jan 14 16:39:45 gerd-desktop pulseaudio[553]: Playback too far ahead (92339), drop source 23632
Jan 14 16:39:45 gerd-desktop pulseaudio[553]: Sink echoCancel_sinkt does not exist.
Jan 14 16:39:45 gerd-desktop pulseaudio[553]: GetManagedObjects() failed: org.freedesktop.systemd1.UnitMasked: Unit dbus-org.bluez.service is masked.
