Hello,
I have the same Problem after the last update of ca. 360 packages: The Problem ist that the Lightdm starts and when the X-Server starts it died and then is repeating tried to start of lightdm.
I can login over SSH and then I give as root the command “systemctl stop lightdm”, so the repeating starting of Lightdm is stopping. Now I can login at the text console.
Then I try under my user-account the command “startx”: “The welcome music” plays but the screen ist black. With ctrl-alt-F2 I go to the next text console and see that the grafik system is started with the “ps” command. Bevore the upgrade I have selected over “optimus” the “NVIDIA-Grafik-Card” and it seems the the problem is the XOrg X-Server. I don’t know how I can select the Intel grafik card from the command line to test if I see the Desktop.
Here my inxi output:
[ag@tuxedo ~]$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=38d07028-fb4e-47ff-a22a-31b392cec2fd rw apparmor=1
Desktop: N/A dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: TUXEDO product: TUXEDO v: N/A
serial: <superuser required> Chassis: Notebook type: 10
Mobo: TUXEDO model: PB50_70RF,RD,RC serial: <superuser required>
UEFI: INSYDE v: 1.07.12RTR2 date: 02/01/2019
ID-1: BAT0 charge: 60.0 Wh (100.0%) condition: 60.0/60.0 Wh (100.1%)
volts: 11.0 min: 10.9 model: Notebook BAT type: Li-ion serial: <filter>
status: Full
RAM: total: 31.19 GiB used: 762.9 MiB (2.4%)
RAM Report:
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 900 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
8: 900 9: 900 10: 900 11: 900 12: 900 bogomips: 62431
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: CLEVO/KAPOK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: CLEVO/KAPOK
driver: N/A alternate: nouveau, nvidia_drm, nvidia bus-ID: 01:00.0
chip-ID: 10de:2191 class-ID: 0300
Display: server: X.org 1.21.1.2 driver: loaded: modesetting,nvidia
Device-1: Intel Cannon Lake PCH cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.42 running: no
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus-ID: 72:00.0
IF: enp114s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 74:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp116s0 state: down mac: <filter>
IF-ID-1: bridge0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 1.4 TiB used: 208.17 GiB (14.5%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 970 PRO 512GB
lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7 temp: 26.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 512GB
lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7 temp: 39.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 48.83 GiB size: 47.81 GiB (97.92%) used: 24.25 GiB (50.7%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:3 label: N/A
uuid: 38d07028-fb4e-47ff-a22a-31b392cec2fd
used: 4.1 MiB (1.4%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2 label: N/A
uuid: AC3D-E7D1
ID-3: /home raw-size: 97.66 GiB size: 95.62 GiB (97.92%)
used: 54.21 GiB (56.7%) fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:4
label: N/A uuid: 826a7799-d81d-4be7-86a7-34c5b9cae50b
ID-4: /run/timeshift/backup raw-size: 325.28 GiB size: 319.17 GiB (98.12%)
used: 129.7 GiB (40.6%) fs: ext4 dev: /dev/nvme1n1p5 maj-min: 259:6
label: timeshift uuid: f38e20f8-82ab-4190-a590-c18ec75fa7ac
ID-1: swap-1 type: partition size: 4.88 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p4 maj-min: 259:5 label: N/A
uuid: a71354bd-fc72-41c0-821a-5e4e8a6215e0
ID-1: /dev/nvme0n1p1 maj-min: 259:7 size: 1.46 GiB fs: vfat label: BOOT
uuid: 084E-C362
ID-2: /dev/nvme0n1p2 maj-min: 259:8 size: 1.95 GiB
fs: <superuser required> label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:9 size: 236.76 GiB fs: ntfs
label: Windows 11 uuid: 00864F3A864F2F88
ID-4: /dev/nvme0n1p4 maj-min: 259:10 size: 1.95 GiB fs: ntfs
label: Recovery uuid: 84064F86064F77E6
ID-5: /dev/nvme0n1p5 maj-min: 259:11 size: 4.66 GiB fs: swap label: N/A
uuid: 7e53684c-849b-439f-9a34-04d16bba805c
ID-6: /dev/nvme0n1p6 maj-min: 259:12 size: 111.76 GiB fs: ext4
label: LinuxMint20 uuid: 60eb6941-9001-43e1-afc2-63ff46954c16
ID-7: /dev/nvme0n1p7 maj-min: 259:13 size: 118.39 GiB fs: ext4
label: timeshift_LM20 uuid: dcf343c0-1385-42f2-bfe5-31f8ae02a3ba
ID-8: /dev/sda1 maj-min: 8:1 size: 476.94 GiB fs: ntfs
label: Cygwin_und_yaze-ag uuid: 1362EF9C3D3CA825
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-5:2 info: QinHeng CH340 serial converter
type: <vendor specific> driver: ch341,ch341-uart interfaces: 1 rev: 1.1
speed: 12 Mb/s power: 96mA chip-ID: 1a86:7523 class-ID: ff00
Device-2: 1-7:3 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00c7
class-ID: ff00 serial: <filter>
Device-3: 1-14:4 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-3: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 58.0 C pch: 80.0 C mobo: N/A
Processes: 228 Uptime: 5h 43m wakeups: 1 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1501
lib: 425 flatpak: 0 Shell: Bash v: 5.1.12 running-in: sshd (SSH)
inxi: 3.3.11
[ag@tuxedo ~]$
Here my inxi output as root:
Console: pty pts/0 DM: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: TUXEDO product: TUXEDO v: N/A serial: N/A
Chassis: Notebook type: 10 serial: N/A
Mobo: TUXEDO model: PB50_70RF,RD,RC serial: N/A UEFI: INSYDE
status: Full
RAM: total: 31.19 GiB used: 785.5 MiB (2.5%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 size: 16 GiB speed: 2667 MT/s type: DDR4
detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Samsung
part-no: M471A2K43CB1-CTD serial: <filter>
Device-2: ChannelB-DIMM0 size: 16 GiB speed: 2667 MT/s type: DDR4
Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake family: 6 model-id: 0x9E (158)
Speed (MHz): avg: 899 high: 900 min/max: 800/4500 base/boost: 792/8300
scaling: driver: intel_pstate governor: powersave volts: 0.6 V
ext-clock: 100 MHz cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 899
Type: l1tf
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
Local Storage: total: 1.4 TiB used: 78.47 GiB (5.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 512GB
ID-2: /dev/nvme1n1 maj-min: 259:8 vendor: Samsung model: SSD 970 PRO 512GB
lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7 temp: 42.9 C scheme: GPT
fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p2 maj-min: 259:10 label: N/A
used: 4.1 MiB (1.4%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:9 label: N/A uuid: AC3D-E7D1
used: 54.21 GiB (56.7%) fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p3
maj-min: 259:11 label: N/A uuid: 826a7799-d81d-4be7-86a7-34c5b9cae50b
priority: -2 dev: /dev/nvme1n1p4 maj-min: 259:12 label: N/A
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 1.46 GiB fs: vfat label: BOOT
uuid: 084E-C362
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 1.95 GiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 236.76 GiB fs: ntfs
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1.95 GiB fs: ntfs
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 4.66 GiB fs: swap label: N/A
ID-6: /dev/nvme0n1p6 maj-min: 259:6 size: 111.76 GiB fs: ext4
ID-7: /dev/nvme0n1p7 maj-min: 259:7 size: 118.39 GiB fs: ext4
ID-8: /dev/nvme1n1p5 maj-min: 259:13 size: 325.28 GiB fs: ext4
ID-9: /dev/sda1 maj-min: 8:1 size: 476.94 GiB fs: ntfs
System Temperatures: cpu: 55.0 C pch: 80.0 C mobo: N/A
Processes: 265 Uptime: 2m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1501 lib: 425
flatpak: 0 Shell: Bash (sudo) v: 5.1.12 running-in: sshd (SSH) inxi: 3.3.11
[tuxedo ~]#
Best Regards
Andreas (agl)
Hello,
I have spend a partition for timeshift and I restor the snapshot from 1.2.2022 → now I have again a running machine. The packet manager say: 368 packages for install.
I would wait until there is a fix of the problem with the not running Xorg X-Server.
Best Regards
Andreas (agl)
