Hello everyone, i have an old laptop ASUS N53(DA), which came with Windows 7 and Linux based ASUS OS. BIOS has option to turn on UEFI mode on. When i tried installing Ubuntu flavors all of them stops after GRUB, i installed Plasma and then GRUB opened command line, there was not some files, as it said, i do not remember what exactly. Mostly from live usb screen is black, grub works fine, sometimes system loads and works normally, most time is does not. Then i tried Manjaro, KDE Plasma, same thing it did not loading, then i tried on another laptop and live usb worked fine. After Manjaro KDE Plasma loaded. I turned off and and on and Plasma loaded from USB, Plasma worked a little slow so I tried XFCE, same thing happens, only black screen after GRUB, XFCE does not load. From black screen nothing happens and TTY does not open if i try. It takes less then minute to load system from usb if everything is fine. Now i want to try Manjaro minimal XFCE, and if same happens, then Plasma, It is interesting if Plasma loads.
Can someone help, I do not understand how sometimes loads and sometimes not. On another old laptop, usb always loads, so it is not USB or installer. SHA1 and GPG signature are correct.
I also do not have access to windows 7, i rewrite some linux on it and i also uninstalled stock, asus Linux. So i want to fully delete drive and install Manjaro, but i cannot until i see that it is stable. I will also try windows 10 installer, if it works.
Please help, i do not want windows.
UPDATE: IN UEFI mode from GRUB menu, when it hangs on black screen, GRUB says efi file not detected or similar.
There are some old Personal Computer, with option âUEFIâ.
That does not mean you can install and run OS in UEFI-way, because the BIOS
support is very limited. First trials
I have such an old PC too, and the only way is to install the OS (Ubuntu/Suse/manjaro)
in BIOS-mode. Unless there is a newer firmware/bios - no uefi possibleâŚ
Did you try to stop grub with ESC - key while booting ?
How to boot from USB into live Manjaro (for repair):
How to increase your chances of solving your issue:
Please provide Information:
Thank you for your answer, i will not try with UEFI on this PC more, but this thing also happens in BIOS mode. An hour ago i tried one more time and it booted successfully, then restarted and boot was successful.
I do not understand why this thing happens and i want to be sure that installation will be normal and system will be usable.
I will provide more information as described by next comment.
All info below is from live usb terminal.
When this commands ran, one of the HDDâs partitionâs were deleting with dd command.
when run âmanjaro-chroot -aâ I got this reply:
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> ERROR: No Linux partitions detected!
With the command, journalctl --boot=-1 --priority=3 --catalog | less, i got this reply:
Specifying boot ID or boot offset has no effect, no persistent journal was found.
(END)
I cannot interrupt this command, without closing terminal window.
With the command âjournalctl --boot=-1 --unit=<service_name> | lessâ there is error: bash: syntax error near unexpected token `|â
This command inxi --admin --verbosity=7 --filter --width has output:
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2122 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: N53DA v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: N53DA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: N53DA.207 date: 04/08/2011
ID-1: BAT0 charge: 13.4 Wh (67.3%) condition: 19.9/48.4 Wh (41.1%)
volts: 12.5 min: 11.1 model: ASUSTek M50--24 type: Li-ion serial: N/A
status: Charging
RAM: total: 3.83 GiB used: 2.28 GiB (59.5%)
RAM Report:
Info: model: AMD Phenom II P960 bits: 64 type: MCP arch: K10
family: 0x10 (16) model-id: 5 stepping: 3 microcode: 0x10000C8
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 512 KiB
desc: d-4x64 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB
Speed (MHz): avg: 1300 high: 1800 min/max: 800/1800 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 800 2: 800
3: 1800 4: 1800 bogomips: 14371
Flags: 3dnow 3dnowext 3dnowprefetch abm apic clflush cmov cmp_legacy
constant_tsc cpuid cr8_legacy cx16 cx8 de extapic extd_apicid fpu fxsr
fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext
monitor msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
pdpe1gb pge pni popcnt pse pse36 rdtscp rep_good sep skinit sse sse2 sse4a
svm svm_lock syscall tsc vme vmmcall wdt
Type: spec_store_bypass status: Not affected
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Whistler [Radeon HD 6630M/6650M/6750M/7670M/7690M]
vendor: ASUSTeK driver: radeon v: kernel bus-ID: 01:00.0 chip-ID: 1002:6741
class-ID: 0300
Device-2: IMC Networks UVC VGA Webcam type: USB driver: uvcvideo
bus-ID: 3-3:2 chip-ID: 13d3:5710 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS res: 1366x768 hz: 60
Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aa90 class-ID: 0403
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: no
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: AzureWave AW-NE785 / AW-NE785H 802.11bgn driver: ath9k v: kernel
bus-ID: 04:00.0 chip-ID: 168c:002b class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK
driver: atl1c v: kernel port: d000 bus-ID: 05:00.0 chip-ID: 1969:1083
class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-1: ASUSTek BT-270 Bluetooth Adapter type: USB driver: btusb v: 0.8
bus-ID: 5-4:2 chip-ID: 0b05:1788 class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 624.99 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD6400BPVT-80HXZT1 size: 596.17 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 28.82 GiB block-size: physical: 512 B
logical: 512 B speed: <unknown> type: N/A serial: <filter> scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GT34N rev: AS00
dev-links: cdrom
Message: No partition data found.
ID-1: /dev/sda1 maj-min: 8:1 size: 25 GiB fs: vfat label: RECOVERY
uuid: 9628-2FDD
ID-2: /dev/sda2 maj-min: 8:2 size: 259.17 GiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 1 KiB fs: <superuser required>
ID-4: /dev/sda5 maj-min: 8:5 size: 279.59 GiB fs: ntfs label: Data
uuid: FA922E32922DF3B3
ID-5: /dev/sdb1 maj-min: 8:17 size: 3.43 GiB fs: iso9660
ID-6: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 01C9-8517
Hub-1: 1-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Device-1: 1-3:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s power: 300mA chip-ID: 0951:1666 class-ID: 0806
serial: <filter>
Hub-2: 2-0:1 info: Full speed or root hub ports: 5 rev: 2.0
Hub-3: 3-0:1 info: Full speed or root hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: IMC Networks UVC VGA Webcam type: Video
Hub-4: 4-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-5: 5-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
Device-1: 5-4:2 info: ASUSTek BT-270 Bluetooth Adapter type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0b05:1788
Hub-6: 6-0:1 info: Full speed or root hub ports: 4 rev: 1.1 speed: 12 Mb/s
System Temperatures: cpu: 47.5 C mobo: N/A gpu: radeon temp: 44.0 C
Processes: 211 Uptime: 3h 21m wakeups: 12 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1160
lib: 319 flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.12
sudo dmesg | less
output:
[ 0.000000] Linux version 5.15.16-1-MANJARO (builduser@fv-az82-887) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT
Thu Jan 20 13:58:19 UTC 2022
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2
122 quiet systemd.show_status=1 apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
[ 0.000000] x86/fpu: x87 FPU will use FXSAVE
[ 0.000000] signal: max sigframe size: 1440
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000afcc0fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000afcc1000-0x00000000afd0bfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000afd0c000-0x00000000afd1cfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000afd1d000-0x00000000afd24fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000afd25000-0x00000000afd33fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000afd34000-0x00000000afd34fff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000afd35000-0x00000000afd35fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000afd36000-0x00000000afd36fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000afd37000-0x00000000afd37fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000afd38000-0x00000000afd38fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000afd39000-0x00000000afd3bfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000afd3c000-0x00000000afd49fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000afd4a000-0x00000000afd4ffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000afd50000-0x00000000afd53fff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000afd54000-0x00000000afd64fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000afd65000-0x00000000afd6ffff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000afd70000-0x00000000afd70fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000afd71000-0x00000000afd71fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000afd72000-0x00000000afd82fff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000afd83000-0x00000000afd85fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000afd86000-0x00000000afd8cfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000afd8d000-0x00000000afefffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed61000-0x00000000fed70fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff800000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100001000-0x000000014fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.00 by American Megatrends
[ 0.000000] efi: ACPI 2.0=0xafd3c018 SMBIOS=0xafd84b98 ACPI=0xafd3c018
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: ASUSTeK Computer Inc. N53DA/N53DA, BIOS N53DA.207 04/08/2011
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 1795.592 MHz processor
[ 0.001266] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001272] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001287] last_pfn = 0x150000 max_arch_pfn = 0x400000000
[ 0.001440] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001598] total RAM covered: 2815M
[ 0.001994] Found optimal setting for mtrr clean up
[ 0.001996] gran_size: 64K chunk_size: 2M num_reg: 4 lose cover RAM: 0G
[ 0.002163] e820: update [mem 0xaff00000-0xffffffff] usable ==> reserved
[ 0.002179] last_pfn = 0xaff00 max_arch_pfn = 0x400000000
[ 0.008568] Using GB pages for direct mapping
[ 0.010184] Secure boot disabled
[ 0.010186] RAMDISK: [mem 0x31927000-0x34c8afff]
[ 0.010201] ACPI: Early table checksum verification disabled
[ 0.010206] ACPI: RSDP 0x00000000AFD3C018 000024 (v03 _ASUS_)
[ 0.010213] ACPI: XSDT 0x00000000AFD3C088 00005C (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.010223] ACPI: FACP 0x00000000AFD48FC8 0000F4 (v04 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.010232] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20210730/tbfadt-615)
[ 0.010240] ACPI: DSDT 0x00000000AFD3C170 00CE51 (v02 _ASUS_ Notebook 00000000 INTL 20051117)
[ 0.010246] ACPI: FACS 0x00000000AFD4AF40 000040
[ 0.010251] ACPI: FACS 0x00000000AFD4AF80 000040
[ 0.010256] ACPI: APIC 0x00000000AFD490C0 000072 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.010262] ACPI: ECDT 0x00000000AFD49138 0000C1 (v01 _ASUS_ Notebook 01072009 AMI. 00000003)
[ 0.010268] ACPI: SLIC 0x00000000AFD49200 000176 (v01 _ASUS_ Notebook 01072009 ASUS 00000001)
[ 0.010274] ACPI: MCFG 0x00000000AFD49378 00003C (v01 _ASUS_ Notebook 01072009 MSFT 00000097)
[ 0.010279] ACPI: SSDT 0x00000000AFD493B8 00088C (v01 AMD POWERNOW 00000001 AMD 00000001)
[ 0.010285] ACPI: HPET 0x00000000AFD49C48 000038 (v01 _ASUS_ Notebook 01072009 AMI 00000003)
[ 0.010290] ACPI: Reserving FACP table memory at [mem 0xafd48fc8-0xafd490bb]
[ 0.010293] ACPI: Reserving DSDT table memory at [mem 0xafd3c170-0xafd48fc0]
[ 0.010295] ACPI: Reserving FACS table memory at [mem 0xafd4af40-0xafd4af7f]
[ 0.010298] ACPI: Reserving FACS table memory at [mem 0xafd4af80-0xafd4afbf]
[ 0.010300] ACPI: Reserving APIC table memory at [mem 0xafd490c0-0xafd49131]
[ 0.010303] ACPI: Reserving ECDT table memory at [mem 0xafd49138-0xafd491f8]
[ 0.010305] ACPI: Reserving SLIC table memory at [mem 0xafd49200-0xafd49375]
[ 0.010307] ACPI: Reserving MCFG table memory at [mem 0xafd49378-0xafd493b3]
[ 0.010309] ACPI: Reserving SSDT table memory at [mem 0xafd493b8-0xafd49c43]
[ 0.010312] ACPI: Reserving HPET table memory at [mem 0xafd49c48-0xafd49c7f]
[ 0.010388] Scanning NUMA topology in Northbridge 24
[ 0.010395] No NUMA configuration found
[ 0.010397] Faking a node at [mem 0x0000000000000000-0x000000014fffffff]
[ 0.010403] NODE_DATA(0) allocated [mem 0x14fffa000-0x14fffdfff]
[ 0.010448] Zone ranges:
[ 0.010449] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.010453] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.010456] Normal [mem 0x0000000100000000-0x000000014fffffff]
[ 0.010458] Device empty
[ 0.010460] Movable zone start for each node
[ 0.010462] Early memory node ranges
[ 0.010463] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.010465] node 0: [mem 0x0000000000100000-0x00000000afcc0fff]
[ 0.010468] node 0: [mem 0x00000000afd36000-0x00000000afd36fff]
[ 0.010470] node 0: [mem 0x00000000afd8d000-0x00000000afefffff]
[ 0.010472] node 0: [mem 0x0000000100001000-0x000000014fffffff]
[ 0.010475] Initmem setup node 0 [mem 0x0000000000001000-0x000000014fffffff]
[ 0.010483] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.010541] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.027150] On node 0, zone DMA32: 117 pages in unavailable ranges
[ 0.027166] On node 0, zone DMA32: 86 pages in unavailable ranges
[ 0.034781] On node 0, zone Normal: 257 pages in unavailable ranges
[ 0.034959] ACPI: PM-Timer IO Port: 0x808
[ 0.034971] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.034984] IOAPIC[0]: apic_id 0, version 33, address 0xfec00000, GSI 0-23
[ 0.034989] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.034993] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.034999] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.035001] ACPI: HPET id: 0xffffffff base: 0xfed00000
[ 0.035008] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.035072] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.035077] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.035081] PM: hibernation: Registered nosave memory: [mem 0xafcc1000-0xafd0bfff]
[ 0.035083] PM: hibernation: Registered nosave memory: [mem 0xafd0c000-0xafd1cfff]
[ 0.035085] PM: hibernation: Registered nosave memory: [mem 0xafd1d000-0xafd24fff]
[ 0.035087] PM: hibernation: Registered nosave memory: [mem 0xafd25000-0xafd33fff]
[ 0.035089] PM: hibernation: Registered nosave memory: [mem 0xafd34000-0xafd34fff]
[ 0.035090] PM: hibernation: Registered nosave memory: [mem 0xafd35000-0xafd35fff]
[ 0.035094] PM: hibernation: Registered nosave memory: [mem 0xafd37000-0xafd37fff]
[ 0.035096] PM: hibernation: Registered nosave memory: [mem 0xafd38000-0xafd38fff]
[ 0.035098] PM: hibernation: Registered nosave memory: [mem 0xafd39000-0xafd3bfff]
[ 0.035099] PM: hibernation: Registered nosave memory: [mem 0xafd3c000-0xafd49fff]
[ 0.035101] PM: hibernation: Registered nosave memory: [mem 0xafd4a000-0xafd4ffff]
[ 0.035103] PM: hibernation: Registered nosave memory: [mem 0xafd50000-0xafd53fff]
[ 0.035104] PM: hibernation: Registered nosave memory: [mem 0xafd54000-0xafd64fff]
[ 0.035106] PM: hibernation: Registered nosave memory: [mem 0xafd65000-0xafd6ffff]
[ 0.035108] PM: hibernation: Registered nosave memory: [mem 0xafd70000-0xafd70fff]
[ 0.035110] PM: hibernation: Registered nosave memory: [mem 0xafd71000-0xafd71fff]
[ 0.035111] PM: hibernation: Registered nosave memory: [mem 0xafd72000-0xafd82fff]
[ 0.035113] PM: hibernation: Registered nosave memory: [mem 0xafd83000-0xafd85fff]
[ 0.035115] PM: hibernation: Registered nosave memory: [mem 0xafd86000-0xafd8cfff]
[ 0.035119] PM: hibernation: Registered nosave memory: [mem 0xaff00000-0xfebfffff]
[ 0.035120] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.035122] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.035124] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.035126] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed60fff]
[ 0.035127] PM: hibernation: Registered nosave memory: [mem 0xfed61000-0xfed70fff]
[ 0.035129] PM: hibernation: Registered nosave memory: [mem 0xfed71000-0xfed7ffff]
[ 0.035131] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[ 0.035132] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xff7fffff]
[ 0.035134] PM: hibernation: Registered nosave memory: [mem 0xff800000-0xffffffff]
[ 0.035136] PM: hibernation: Registered nosave memory: [mem 0x100000000-0x100000fff]
[ 0.035139] [mem 0xaff00000-0xfebfffff] available for PCI devices
[ 0.035145] Booting paravirtualized kernel on bare hardware
[ 0.035149] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.043971] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.045026] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u524288
[ 0.045044] pcpu-alloc: s212992 r8192 d28672 u524288 alloc=1*2097152
[ 0.045049] pcpu-alloc: [0] 0 1 2 3
[ 0.045102] Built 1 zonelists, mobility grouping on. Total pages: 1031483
[ 0.045105] Policy zone: Normal
[ 0.045108] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2122 quiet systemd.show_status=1 apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
[ 0.045450] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2122 driver=free", will be passed to user space.
[ 0.046862] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.047601] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.048376] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.124266] Memory: 3937264K/4192076K available (14344K kernel code, 2097K rwdata, 10884K rodata, 1864K init, 3784K bss, 254552K reserved, 0K cma-reserved)
[ 0.124277] random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
[ 0.124641] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.124666] ftrace: allocating 44514 entries in 174 pages
[ 0.143660] ftrace: allocated 174 pages with 5 groups
[ 0.143929] rcu: Preemptible hierarchical RCU implementation.
[ 0.143931] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.143933] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.143935] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.143937] Trampoline variant of Tasks RCU enabled.
[ 0.143938] Rude variant of Tasks RCU enabled.
[ 0.143940] Tracing variant of Tasks RCU enabled.
[ 0.143941] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.143943] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.152722] NR_IRQS: 20736, nr_irqs: 456, preallocated irqs: 16
[ 0.153197] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.153294] Console: colour dummy device 80x25
[ 0.153322] printk: console [tty0] enabled
[ 0.153366] ACPI: Core revision 20210730
[ 0.153587] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.153609] APIC: Switch to symmetric I/O mode setup
[ 0.154079] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.170309] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x19e1e5766c9, max_idle_ns: 440795227913 ns
[ 0.170318] Calibrating delay loop (skipped), value calculated using timer frequency.. 3592.81 BogoMIPS (lpj=5985306)
[ 0.170323] pid_max: default: 32768 minimum: 301
[ 0.173699] LSM: Security Framework initializing
[ 0.173718] landlock: Up and running.
[ 0.173720] Yama: becoming mindful.
[ 0.173767] AppArmor: AppArmor initialized
[ 0.173813] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.173842] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.174331] LVT offset 0 assigned for vector 0xf9
[ 0.174341] process: using AMD E400 aware idle routine
[ 0.174343] Last level iTLB entries: 4KB 512, 2MB 16, 4MB 8
[ 0.174345] Last level dTLB entries: 4KB 512, 2MB 128, 4MB 64, 1GB 0
[ 0.174355] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.174359] Spectre V2 : Mitigation: Full AMD retpoline
[ 0.174361] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.180407] Freeing SMP alternatives memory: 36K
[ 0.183651] process: System has AMD C1E enabled
[ 0.291478] process: Switch to broadcast mode on CPU0
[ 0.291487] smpboot: CPU0: AMD Phenom(tm) II P960 Quad-Core Processor (family: 0x10, model: 0x5, stepping: 0x3)
[ 0.291846] Performance Events: AMD PMU driver.
[ 0.291853] ... version: 0
[ 0.291855] ... bit width: 48
[ 0.291857] ... generic registers: 4
[ 0.291858] ... value mask: 0000ffffffffffff
[ 0.291860] ... max period: 00007fffffffffff
[ 0.291861] ... fixed-purpose events: 0
[ 0.291863] ... event mask: 000000000000000f
[ 0.292023] rcu: Hierarchical SRCU implementation.
[ 0.292881] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.292999] smp: Bringing up secondary CPUs ...
[ 0.293299] x86: Booting SMP configuration:
[ 0.293302] .... node #0, CPUs: #1
[ 0.003890] process: Switch to broadcast mode on CPU1
[ 0.293993] #2
[ 0.003890] process: Switch to broadcast mode on CPU2
[ 0.297320] #3
[ 0.003890] process: Switch to broadcast mode on CPU3
[ 0.299450] smp: Brought up 1 node, 4 CPUs
[ 0.299450] smpboot: Max logical packages: 1
[ 0.299450] smpboot: Total of 4 processors activated (14370.26 BogoMIPS)
[ 0.300942] devtmpfs: initialized
[ 0.300942] x86/mm: Memory block size: 128MB
[ 0.301119] ACPI: PM: Registering ACPI NVS region [mem 0xafcc1000-0xafd0bfff] (307200 bytes)
[ 0.301119] ACPI: PM: Registering ACPI NVS region [mem 0xafd1d000-0xafd24fff] (32768 bytes)
[ 0.301119] ACPI: PM: Registering ACPI NVS region [mem 0xafd38000-0xafd38fff] (4096 bytes)
[ 0.301119] ACPI: PM: Registering ACPI NVS region [mem 0xafd4a000-0xafd4ffff] (24576 bytes)
[ 0.301119] ACPI: PM: Registering ACPI NVS region [mem 0xafd70000-0xafd70fff] (4096 bytes)
[ 0.301119] ACPI: PM: Registering ACPI NVS region [mem 0xafd86000-0xafd8cfff] (28672 bytes)
[ 0.301119] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.301119] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.301119] pinctrl core: initialized pinctrl subsystem
[ 0.301119] PM: RTC time: 21:46:35, date: 2008-01-02
[ 0.301152] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.303780] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.303982] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.304183] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.304212] audit: initializing netlink subsys (disabled)
[ 0.304258] audit: type=2000 audit(1199310395.149:1): state=initialized audit_enabled=0 res=1
[ 0.304258] thermal_sys: Registered thermal governor 'fair_share'
[ 0.304258] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.304258] thermal_sys: Registered thermal governor 'step_wise'
[ 0.304258] thermal_sys: Registered thermal governor 'user_space'
[ 0.304258] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.304258] cpuidle: using governor ladder
[ 0.304258] cpuidle: using governor menu
[ 0.304258] node 0 link 0: io port [d000, ffff]
[ 0.304258] TOM: 00000000b0000000 aka 2816M
[ 0.304258] Fam 10h mmconf [mem 0xe0000000-0xefffffff]
[ 0.304258] node 0 link 0: mmio [a0000, bffff]
[ 0.304258] node 0 link 0: mmio [b0000000, dfffffff]
[ 0.304258] node 0 link 0: mmio [e0000000, efffffff] ==> none
[ 0.304258] node 0 link 0: mmio [f0000000, ff7fffff]
[ 0.304258] TOM2: 0000000150000000 aka 5376M
[ 0.304258] bus: [bus 00-ff] on node 0 link 0
[ 0.304258] bus: 00 [io 0x0000-0xffff]
[ 0.304258] bus: 00 [mem 0x000a0000-0x000bffff]
[ 0.304258] bus: 00 [mem 0xb0000000-0xdfffffff]
[ 0.304258] bus: 00 [mem 0xf0000000-0xffffffff]
[ 0.304258] bus: 00 [mem 0x150000000-0xfcffffffff]
[ 0.304258] bus: [bus 00-06] on node 0 link 0
[ 0.304258] HugeTLB: can free 4094 vmemmap pages for hugepages-1048576kB
[ 0.304258] ACPI: bus type PCI registered
[ 0.304258] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.304258] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.304258] PCI: not using MMCONFIG
[ 0.304258] PCI: Using configuration type 1 for base access
[ 0.304258] PCI: Using configuration type 1 for extended access
[ 0.307829] Kprobes globally optimized
[ 0.307848] HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
[ 0.307848] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.307848] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.317249] ACPI: Added _OSI(Module Device)
[ 0.317253] ACPI: Added _OSI(Processor Device)
[ 0.317255] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.317257] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.317259] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.317261] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.317263] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.338392] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.339530] ACPI: EC: EC started
[ 0.339532] ACPI: EC: interrupt blocked
[ 0.340914] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.340917] ACPI: EC: Boot ECDT EC used to handle transactions
[ 0.341375] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.344464] ACPI: Interpreter enabled
[ 0.344510] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.344512] ACPI: Using IOAPIC for interrupt routing
[ 0.344939] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.345046] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.345079] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.347148] ACPI: Enabled 8 GPEs in block 00 to 1F
[ 0.365830] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.365847] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.366336] acpi PNP0A03:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.366340] acpi PNP0A03:00: _OSC: not requesting control; platform does not support [PCIeCapability]
[ 0.366344] acpi PNP0A03:00: _OSC: OS requested [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.366346] acpi PNP0A03:00: _OSC: platform willing to grant []
[ 0.366349] acpi PNP0A03:00: _OSC: platform retains control of PCIe features (AE_SUPPORT)
[ 0.366928] PCI host bridge to bus 0000:00
[ 0.366932] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.366936] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.366939] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.366942] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000fffff window]
[ 0.366945] pci_bus 0000:00: root bus resource [mem 0xb0000000-0xffffffff window]
[ 0.366948] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.367140] pci 0000:00:00.0: [1022:9601] type 00 class 0x060000
[ 0.367449] pci 0000:00:02.0: [1022:9603] type 01 class 0x060400
[ 0.367471] pci 0000:00:02.0: enabling Extended Tags
[ 0.367504] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[ 0.367768] pci 0000:00:04.0: [1022:9604] type 01 class 0x060400
[ 0.367789] pci 0000:00:04.0: enabling Extended Tags
[ 0.367819] pci 0000:00:04.0: PME# supported from D0 D3hot D3cold
[ 0.368080] pci 0000:00:05.0: [1022:9605] type 01 class 0x060400
[ 0.368101] pci 0000:00:05.0: enabling Extended Tags
[ 0.368130] pci 0000:00:05.0: PME# supported from D0 D3hot D3cold
[ 0.368404] pci 0000:00:11.0: [1002:4390] type 00 class 0x01018f
[ 0.368421] pci 0000:00:11.0: reg 0x10: [io 0xf090-0xf097]
[ 0.368432] pci 0000:00:11.0: reg 0x14: [io 0xf080-0xf083]
[ 0.368442] pci 0000:00:11.0: reg 0x18: [io 0xf070-0xf077]
[ 0.368452] pci 0000:00:11.0: reg 0x1c: [io 0xf060-0xf063]
[ 0.368462] pci 0000:00:11.0: reg 0x20: [io 0xf050-0xf05f]
[ 0.368471] pci 0000:00:11.0: reg 0x24: [mem 0xfeb0a000-0xfeb0a3ff]
[ 0.368496] pci 0000:00:11.0: set SATA to AHCI mode
[ 0.368772] pci 0000:00:12.0: [1002:4397] type 00 class 0x0c0310
[ 0.368789] pci 0000:00:12.0: reg 0x10: [mem 0xfeb09000-0xfeb09fff]
[ 0.369096] pci 0000:00:12.2: [1002:4396] type 00 class 0x0c0320
[ 0.369114] pci 0000:00:12.2: reg 0x10: [mem 0xfeb08000-0xfeb080ff]
[ 0.369192] pci 0000:00:12.2: supports D1 D2
[ 0.369195] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[ 0.369466] pci 0000:00:13.0: [1002:4397] type 00 class 0x0c0310
[ 0.369484] pci 0000:00:13.0: reg 0x10: [mem 0xfeb07000-0xfeb07fff]
[ 0.369796] pci 0000:00:13.2: [1002:4396] type 00 class 0x0c0320
[ 0.369813] pci 0000:00:13.2: reg 0x10: [mem 0xfeb06000-0xfeb060ff]
[ 0.369892] pci 0000:00:13.2: supports D1 D2
[ 0.369894] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[ 0.370154] pci 0000:00:14.0: [1002:4385] type 00 class 0x0c0500
[ 0.370470] pci 0000:00:14.1: [1002:439c] type 00 class 0x01018a
[ 0.370488] pci 0000:00:14.1: reg 0x10: [io 0xf040-0xf047]
[ 0.370498] pci 0000:00:14.1: reg 0x14: [io 0xf030-0xf033]
[ 0.370508] pci 0000:00:14.1: reg 0x18: [io 0xf020-0xf027]
[ 0.370517] pci 0000:00:14.1: reg 0x1c: [io 0xf010-0xf013]
[ 0.370527] pci 0000:00:14.1: reg 0x20: [io 0xf000-0xf00f]
[ 0.370547] pci 0000:00:14.1: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.370550] pci 0000:00:14.1: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.370553] pci 0000:00:14.1: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.370555] pci 0000:00:14.1: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.370802] pci 0000:00:14.2: [1002:4383] type 00 class 0x040300
[ 0.370823] pci 0000:00:14.2: reg 0x10: [mem 0xfeb00000-0xfeb03fff 64bit]
[ 0.370890] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[ 0.371143] pci 0000:00:14.3: [1002:439d] type 00 class 0x060100
[ 0.371452] pci 0000:00:14.4: [1002:4384] type 01 class 0x060401
[ 0.371745] pci 0000:00:16.0: [1002:4397] type 00 class 0x0c0310
[ 0.371762] pci 0000:00:16.0: reg 0x10: [mem 0xfeb05000-0xfeb05fff]
[ 0.372072] pci 0000:00:16.2: [1002:4396] type 00 class 0x0c0320
[ 0.372089] pci 0000:00:16.2: reg 0x10: [mem 0xfeb04000-0xfeb040ff]
[ 0.372168] pci 0000:00:16.2: supports D1 D2
[ 0.372170] pci 0000:00:16.2: PME# supported from D0 D1 D2 D3hot
[ 0.372362] pci 0000:00:18.0: [1022:1200] type 00 class 0x060000
[ 0.372566] pci 0000:00:18.1: [1022:1201] type 00 class 0x060000
[ 0.372766] pci 0000:00:18.2: [1022:1202] type 00 class 0x060000
[ 0.372966] pci 0000:00:18.3: [1022:1203] type 00 class 0x060000
[ 0.373170] pci 0000:00:18.4: [1022:1204] type 00 class 0x060000
[ 0.373401] pci 0000:01:00.0: [1002:6741] type 00 class 0x030000
[ 0.373418] pci 0000:01:00.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.373430] pci 0000:01:00.0: reg 0x18: [mem 0xfdf20000-0xfdf3ffff 64bit]
[ 0.373438] pci 0000:01:00.0: reg 0x20: [io 0xe000-0xe0ff]
[ 0.373452] pci 0000:01:00.0: reg 0x30: [mem 0xfdf00000-0xfdf1ffff pref]
[ 0.373459] pci 0000:01:00.0: enabling Extended Tags
[ 0.373476] pci 0000:01:00.0: BAR 0: assigned to efifb
[ 0.373508] pci 0000:01:00.0: supports D1 D2
[ 0.373533] pci 0000:01:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x8 link at 0000:00:02.0 (capable of 32.000 Gb/s with 2.5 GT/s PCIe x16 link)
[ 0.373676] pci 0000:01:00.1: [1002:aa90] type 00 class 0x040300
[ 0.373693] pci 0000:01:00.1: reg 0x10: [mem 0xfdf40000-0xfdf43fff 64bit]
[ 0.373727] pci 0000:01:00.1: enabling Extended Tags
[ 0.373771] pci 0000:01:00.1: supports D1 D2
[ 0.373902] pci 0000:00:02.0: PCI bridge to [bus 01-03]
[ 0.373908] pci 0000:00:02.0: bridge window [io 0xe000-0xefff]
[ 0.373911] pci 0000:00:02.0: bridge window [mem 0xfdf00000-0xfe8fffff]
[ 0.373916] pci 0000:00:02.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.374027] pci 0000:04:00.0: [168c:002b] type 00 class 0x028000
[ 0.374046] pci 0000:04:00.0: reg 0x10: [mem 0xfea00000-0xfea0ffff 64bit]
[ 0.374143] pci 0000:04:00.0: supports D1
[ 0.374145] pci 0000:04:00.0: PME# supported from D0 D1 D3hot D3cold
[ 0.374309] pci 0000:00:04.0: PCI bridge to [bus 04]
[ 0.374315] pci 0000:00:04.0: bridge window [mem 0xfea00000-0xfeafffff]
[ 0.374413] pci 0000:05:00.0: [1969:1083] type 00 class 0x020000
[ 0.374439] pci 0000:05:00.0: reg 0x10: [mem 0xfe900000-0xfe93ffff 64bit]
[ 0.374452] pci 0000:05:00.0: reg 0x18: [io 0xd000-0xd07f]
[ 0.374509] pci 0000:05:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
[ 0.374566] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.374710] pci 0000:00:05.0: PCI bridge to [bus 05]
[ 0.374715] pci 0000:00:05.0: bridge window [io 0xd000-0xdfff]
[ 0.374719] pci 0000:00:05.0: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.374735] pci_bus 0000:06: extended config space not accessible
[ 0.374797] pci 0000:00:14.4: PCI bridge to [bus 06] (subtractive decode)
[ 0.374807] pci 0000:00:14.4: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.374811] pci 0000:00:14.4: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.374814] pci 0000:00:14.4: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.374817] pci 0000:00:14.4: bridge window [mem 0x000c0000-0x000fffff window] (subtractive decode)
[ 0.374820] pci 0000:00:14.4: bridge window [mem 0xb0000000-0xffffffff window] (subtractive decode)
[ 0.376097] ACPI: PCI: Interrupt link LN24 configured for IRQ 24
[ 0.376195] ACPI: PCI: Interrupt link LN25 configured for IRQ 25
[ 0.376287] ACPI: PCI: Interrupt link LN26 configured for IRQ 26
[ 0.376379] ACPI: PCI: Interrupt link LN27 configured for IRQ 27
[ 0.376471] ACPI: PCI: Interrupt link LN28 configured for IRQ 28
[ 0.376562] ACPI: PCI: Interrupt link LN29 configured for IRQ 29
[ 0.376654] ACPI: PCI: Interrupt link LN30 configured for IRQ 30
[ 0.376746] ACPI: PCI: Interrupt link LN31 configured for IRQ 31
[ 0.376838] ACPI: PCI: Interrupt link LN32 configured for IRQ 32
[ 0.376929] ACPI: PCI: Interrupt link LN33 configured for IRQ 33
[ 0.377046] ACPI: PCI: Interrupt link LN34 configured for IRQ 34
[ 0.377138] ACPI: PCI: Interrupt link LN35 configured for IRQ 35
[ 0.377230] ACPI: PCI: Interrupt link LN36 configured for IRQ 36
[ 0.377322] ACPI: PCI: Interrupt link LN37 configured for IRQ 37
[ 0.377414] ACPI: PCI: Interrupt link LN38 configured for IRQ 38
[ 0.377505] ACPI: PCI: Interrupt link LN39 configured for IRQ 39
[ 0.377597] ACPI: PCI: Interrupt link LN40 configured for IRQ 40
[ 0.377689] ACPI: PCI: Interrupt link LN41 configured for IRQ 41
[ 0.377786] ACPI: PCI: Interrupt link LN42 configured for IRQ 42
[ 0.377878] ACPI: PCI: Interrupt link LN43 configured for IRQ 43
[ 0.377970] ACPI: PCI: Interrupt link LN44 configured for IRQ 44
[ 0.378065] ACPI: PCI: Interrupt link LN45 configured for IRQ 45
[ 0.378158] ACPI: PCI: Interrupt link LN46 configured for IRQ 46
[ 0.378249] ACPI: PCI: Interrupt link LN47 configured for IRQ 47
[ 0.378341] ACPI: PCI: Interrupt link LN48 configured for IRQ 48
[ 0.378433] ACPI: PCI: Interrupt link LN49 configured for IRQ 49
[ 0.378525] ACPI: PCI: Interrupt link LN50 configured for IRQ 50
[ 0.378616] ACPI: PCI: Interrupt link LN51 configured for IRQ 51
[ 0.378708] ACPI: PCI: Interrupt link LN52 configured for IRQ 52
[ 0.378799] ACPI: PCI: Interrupt link LN53 configured for IRQ 53
[ 0.378891] ACPI: PCI: Interrupt link LN54 configured for IRQ 54
[ 0.378982] ACPI: PCI: Interrupt link LN55 configured for IRQ 55
[ 0.379173] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.379333] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.379498] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.379662] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.379797] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.379907] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.380016] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.380122] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.380631] ACPI: EC: interrupt unblocked
[ 0.380634] ACPI: EC: event unblocked
[ 0.380640] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.380642] ACPI: EC: GPE=0x3
[ 0.380645] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot ECDT EC initialization complete
[ 0.380648] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 0.380805] iommu: Default domain type: Translated
[ 0.380807] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.380853] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.380853] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.380853] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.380853] vgaarb: loaded
[ 0.380853] SCSI subsystem initialized
[ 0.380853] libata version 3.00 loaded.
[ 0.380853] ACPI: bus type USB registered
[ 0.380853] usbcore: registered new interface driver usbfs
[ 0.380853] usbcore: registered new interface driver hub
[ 0.380853] usbcore: registered new device driver usb
[ 0.380853] pps_core: LinuxPPS API ver. 1 registered
[ 0.380853] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.380853] PTP clock support registered
[ 0.380853] EDAC MC: Ver: 3.0.0
[ 0.380853] Registered efivars operations
[ 0.380853] NetLabel: Initializing
[ 0.380853] NetLabel: domain hash size = 128
[ 0.380853] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.380853] NetLabel: unlabeled traffic allowed by default
[ 0.380853] PCI: Using ACPI for IRQ routing
[ 0.390679] PCI: pci_cache_line_size set to 64 bytes
[ 0.390746] e820: reserve RAM buffer [mem 0xafcc1000-0xafffffff]
[ 0.390751] e820: reserve RAM buffer [mem 0xafd37000-0xafffffff]
[ 0.390755] e820: reserve RAM buffer [mem 0xaff00000-0xafffffff]
[ 0.390773] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.390773] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.392701] clocksource: Switched to clocksource tsc-early
[ 0.406443] VFS: Disk quotas dquot_6.6.0
[ 0.406473] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.406667] AppArmor: AppArmor Filesystem Enabled
[ 0.406702] pnp: PnP ACPI init
[ 0.406949] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.407780] system 00:02: [io 0x04d0-0x04d1] has been reserved
[ 0.407785] system 00:02: [io 0x040b] has been reserved
[ 0.407788] system 00:02: [io 0x04d6] has been reserved
[ 0.407791] system 00:02: [io 0x0c00-0x0c01] has been reserved
[ 0.407794] system 00:02: [io 0x0c14] has been reserved
[ 0.407797] system 00:02: [io 0x0c50-0x0c51] has been reserved
[ 0.407800] system 00:02: [io 0x0c52] has been reserved
[ 0.407803] system 00:02: [io 0x0c6c] has been reserved
[ 0.407806] system 00:02: [io 0x0c6f] has been reserved
[ 0.407809] system 00:02: [io 0x0cd0-0x0cd1] has been reserved
[ 0.407812] system 00:02: [io 0x0cd2-0x0cd3] has been reserved
[ 0.407816] system 00:02: [io 0x0cd4-0x0cd5] has been reserved
[ 0.407819] system 00:02: [io 0x0cd6-0x0cd7] has been reserved
[ 0.407822] system 00:02: [io 0x0cd8-0x0cdf] has been reserved
[ 0.407825] system 00:02: [io 0x0800-0x089f] has been reserved
[ 0.407828] system 00:02: [io 0x0900-0x090f] has been reserved
[ 0.407831] system 00:02: [io 0x0910-0x091f] has been reserved
[ 0.407835] system 00:02: [io 0xfe00-0xfefe] has been reserved
[ 0.407839] system 00:02: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.407845] system 00:02: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.407849] system 00:02: [mem 0xfed80000-0xfed8ffff] has been reserved
[ 0.407854] system 00:02: [mem 0xfed61000-0xfed70fff] has been reserved
[ 0.407858] system 00:02: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.407862] system 00:02: [mem 0xfed00000-0xfed00fff] could not be reserved
[ 0.407866] system 00:02: [mem 0xff800000-0xffffffff] has been reserved
[ 0.408005] system 00:04: [io 0x04d0-0x04d1] has been reserved
[ 0.408141] system 00:06: [io 0x0240-0x0259] has been reserved
[ 0.409542] pnp: PnP ACPI: found 9 devices
[ 0.416508] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.416622] NET: Registered PF_INET protocol family
[ 0.416818] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.418272] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.418384] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.418639] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.418812] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.419017] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.419074] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.419129] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.419225] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.419234] NET: Registered PF_XDP protocol family
[ 0.419262] pci 0000:00:02.0: PCI bridge to [bus 01-03]
[ 0.419269] pci 0000:00:02.0: bridge window [io 0xe000-0xefff]
[ 0.419275] pci 0000:00:02.0: bridge window [mem 0xfdf00000-0xfe8fffff]
[ 0.419279] pci 0000:00:02.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.419284] pci 0000:00:04.0: PCI bridge to [bus 04]
[ 0.419288] pci 0000:00:04.0: bridge window [mem 0xfea00000-0xfeafffff]
[ 0.419293] pci 0000:00:05.0: PCI bridge to [bus 05]
[ 0.419296] pci 0000:00:05.0: bridge window [io 0xd000-0xdfff]
[ 0.419299] pci 0000:00:05.0: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.419305] pci 0000:00:14.4: PCI bridge to [bus 06]
[ 0.419325] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.419328] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.419331] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.419334] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000fffff window]
[ 0.419337] pci_bus 0000:00: resource 8 [mem 0xb0000000-0xffffffff window]
[ 0.419340] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.419343] pci_bus 0000:01: resource 1 [mem 0xfdf00000-0xfe8fffff]
[ 0.419345] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.419349] pci_bus 0000:04: resource 1 [mem 0xfea00000-0xfeafffff]
[ 0.419352] pci_bus 0000:05: resource 0 [io 0xd000-0xdfff]
[ 0.419354] pci_bus 0000:05: resource 1 [mem 0xfe900000-0xfe9fffff]
[ 0.419358] pci_bus 0000:06: resource 4 [io 0x0000-0x0cf7 window]
[ 0.419361] pci_bus 0000:06: resource 5 [io 0x0d00-0xffff window]
[ 0.419363] pci_bus 0000:06: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.419366] pci_bus 0000:06: resource 7 [mem 0x000c0000-0x000fffff window]
[ 0.419369] pci_bus 0000:06: resource 8 [mem 0xb0000000-0xffffffff window]
[ 0.467646] pci 0000:00:12.0: quirk_usb_early_handoff+0x0/0x750 took 46952 usecs
[ 0.468865] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.468907] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.468966] PCI: CLS 64 bytes, default 64
[ 0.468985] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.468987] software IO TLB: mapped [mem 0x00000000abcc1000-0x00000000afcc1000] (64MB)
[ 0.469099] Trying to unpack rootfs image as initramfs...
[ 0.469130] LVT offset 1 assigned for vector 0x400
[ 0.469136] LVT offset 1 assigned
[ 0.474291] perf: AMD IBS detected (0x0000001f)
[ 0.477664] Initialise system trusted keyrings
[ 0.477682] Key type blacklist registered
[ 0.477932] workingset: timestamp_bits=41 max_order=20 bucket_order=0
[ 0.480099] zbud: loaded
[ 0.499021] Key type asymmetric registered
[ 0.499028] Asymmetric key parser 'x509' registered
[ 0.499093] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.499294] io scheduler mq-deadline registered
[ 0.499300] io scheduler kyber registered
[ 0.499386] io scheduler bfq registered
[ 0.500984] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.501300] ACPI: AC: AC Adapter [AC0] (on-line)
[ 0.501399] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.501430] ACPI: button: Power Button [PWRB]
[ 0.501478] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 0.501507] ACPI: button: Lid Switch [LID]
[ 0.501548] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.504141] ACPI: button: Sleep Button [SLPB]
[ 0.504259] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.510796] ACPI: button: Power Button [PWRF]
[ 0.510896] ACPI: processor limited to max C-state 1
[ 0.514198] ACPI: \_TZ_.THRM: Invalid passive threshold
[ 0.516850] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.516858] ACPI: thermal: Thermal Zone [THRM] (51 C)
[ 0.517263] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.521980] Non-volatile memory driver v1.3
[ 0.521986] Linux agpgart interface v0.103
[ 0.521988] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.523749] ahci 0000:00:11.0: version 3.0
[ 0.524194] ahci 0000:00:11.0: AHCI 0001.0200 32 slots 4 ports 3 Gbps 0xf impl SATA mode
[ 0.524201] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
[ 0.525252] scsi host0: ahci
[ 0.525750] scsi host1: ahci
[ 0.526212] scsi host2: ahci
[ 0.526653] scsi host3: ahci
[ 0.526747] ata1: SATA max UDMA/133 abar m1024@0xfeb0a000 port 0xfeb0a100 irq 27
[ 0.526752] ata2: SATA max UDMA/133 abar m1024@0xfeb0a000 port 0xfeb0a180 irq 27
[ 0.526756] ata3: SATA max UDMA/133 abar m1024@0xfeb0a000 port 0xfeb0a200 irq 27
[ 0.526760] ata4: SATA max UDMA/133 abar m1024@0xfeb0a000 port 0xfeb0a280 irq 27
[ 0.526954] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.526973] ehci-pci: EHCI PCI platform driver
[ 0.527196] QUIRK: Enable AMD PLL fix
[ 0.527283] ehci-pci 0000:00:12.2: EHCI Host Controller
[ 0.527299] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 1
[ 0.527308] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 0.527358] ehci-pci 0000:00:12.2: debug port 1
[ 0.527473] ehci-pci 0000:00:12.2: irq 17, io mem 0xfeb08000
[ 0.540747] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 0.540850] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.540855] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.540859] usb usb1: Product: EHCI Host Controller
[ 0.540861] usb usb1: Manufacturer: Linux 5.15.16-1-MANJARO ehci_hcd
[ 0.540864] usb usb1: SerialNumber: 0000:00:12.2
[ 0.541128] hub 1-0:1.0: USB hub found
[ 0.541140] hub 1-0:1.0: 5 ports detected
[ 0.542986] ehci-pci 0000:00:13.2: EHCI Host Controller
[ 0.542997] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 2
[ 0.543004] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 0.543014] ehci-pci 0000:00:13.2: debug port 1
[ 0.543056] ehci-pci 0000:00:13.2: irq 17, io mem 0xfeb06000
[ 0.554073] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 0.554175] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.554179] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.554182] usb usb2: Product: EHCI Host Controller
[ 0.554185] usb usb2: Manufacturer: Linux 5.15.16-1-MANJARO ehci_hcd
[ 0.554187] usb usb2: SerialNumber: 0000:00:13.2
[ 0.554460] hub 2-0:1.0: USB hub found
[ 0.554472] hub 2-0:1.0: 5 ports detected
[ 0.556539] ehci-pci 0000:00:16.2: EHCI Host Controller
[ 0.556554] ehci-pci 0000:00:16.2: new USB bus registered, assigned bus number 3
[ 0.556562] ehci-pci 0000:00:16.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 0.556572] ehci-pci 0000:00:16.2: debug port 1
[ 0.556619] ehci-pci 0000:00:16.2: irq 17, io mem 0xfeb04000
[ 0.560159] random: fast init done
[ 0.567560] ehci-pci 0000:00:16.2: USB 2.0 started, EHCI 1.00
[ 0.567656] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.567661] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.567664] usb usb3: Product: EHCI Host Controller
[ 0.567666] usb usb3: Manufacturer: Linux 5.15.16-1-MANJARO ehci_hcd
[ 0.567668] usb usb3: SerialNumber: 0000:00:16.2
[ 0.567943] hub 3-0:1.0: USB hub found
[ 0.567957] hub 3-0:1.0: 4 ports detected
[ 0.569359] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.569393] ohci-pci: OHCI PCI platform driver
[ 0.569714] ohci-pci 0000:00:12.0: OHCI PCI host controller
[ 0.569732] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 4
[ 0.569798] ohci-pci 0000:00:12.0: irq 18, io mem 0xfeb09000
[ 0.582741] ACPI: battery: Slot [BAT0] (battery present)
[ 0.628202] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 0.628212] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.628215] usb usb4: Product: OHCI PCI host controller
[ 0.628218] usb usb4: Manufacturer: Linux 5.15.16-1-MANJARO ohci_hcd
[ 0.628220] usb usb4: SerialNumber: 0000:00:12.0
[ 0.628457] hub 4-0:1.0: USB hub found
[ 0.628471] hub 4-0:1.0: 5 ports detected
[ 0.628963] ohci-pci 0000:00:13.0: OHCI PCI host controller
[ 0.628976] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 5
[ 0.629015] ohci-pci 0000:00:13.0: irq 18, io mem 0xfeb07000
[ 0.688221] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 0.688230] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.688233] usb usb5: Product: OHCI PCI host controller
[ 0.688236] usb usb5: Manufacturer: Linux 5.15.16-1-MANJARO ohci_hcd
[ 0.688238] usb usb5: SerialNumber: 0000:00:13.0
[ 0.688475] hub 5-0:1.0: USB hub found
[ 0.688488] hub 5-0:1.0: 5 ports detected
[ 0.688978] ohci-pci 0000:00:16.0: OHCI PCI host controller
[ 0.688991] ohci-pci 0000:00:16.0: new USB bus registered, assigned bus number 6
[ 0.689028] ohci-pci 0000:00:16.0: irq 18, io mem 0xfeb05000
[ 0.748218] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 0.748226] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.748229] usb usb6: Product: OHCI PCI host controller
[ 0.748232] usb usb6: Manufacturer: Linux 5.15.16-1-MANJARO ohci_hcd
[ 0.748234] usb usb6: SerialNumber: 0000:00:16.0
[ 0.748541] hub 6-0:1.0: USB hub found
[ 0.748558] hub 6-0:1.0: 4 ports detected
[ 0.749910] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.750029] usbcore: registered new interface driver usbserial_generic
[ 0.750037] usbserial: USB Serial support registered for generic
[ 0.750349] rtc_cmos 00:03: RTC can wake from S4
[ 0.750732] rtc_cmos 00:03: registered as rtc0
[ 0.750764] rtc_cmos 00:03: setting system clock to 2008-01-02T21:46:36 UTC (1199310396)
[ 0.750791] rtc_cmos 00:03: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.750980] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.751268] efifb: probing for efifb
[ 0.751288] efifb: No BGRT, not showing boot graphics
[ 0.751289] efifb: framebuffer at 0xd0000000, using 3072k, total 3072k
[ 0.751292] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 0.751294] efifb: scrolling: redraw
[ 0.751295] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.751447] fbcon: Deferring console take-over
[ 0.751452] fb0: EFI VGA frame buffer device
[ 0.751487] hid: raw HID events driver (C) Jiri Kosina
[ 0.751667] ashmem: initialized
[ 0.751817] drop_monitor: Initializing network drop monitor service
[ 0.751920] Initializing XFRM netlink socket
[ 0.752075] NET: Registered PF_INET6 protocol family
[ 0.790778] usb 1-3: new high-speed USB device number 2 using ehci-pci
[ 0.817427] usb 3-3: new high-speed USB device number 2 using ehci-pci
[ 0.844124] ata4: SATA link down (SStatus 0 SControl 300)
[ 0.844161] ata3: SATA link down (SStatus 0 SControl 300)
[ 0.947099] usb 1-3: New USB device found, idVendor=0951, idProduct=1666, bcdDevice= 0.01
[ 0.947109] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 0.947112] usb 1-3: Product: DataTraveler 3.0
[ 0.947115] usb 1-3: Manufacturer: Kingston
[ 0.947117] usb 1-3: SerialNumber: 4CEDFB75E65BF2C1886D0460
[ 1.007372] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.007406] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.009965] ata2.00: ATAPI: HL-DT-STDVDRAM GT34N, AS00, max UDMA/100
[ 1.010598] ata1.00: ATA-8: WDC WD6400BPVT-80HXZT1, 01.01A01, max UDMA/133
[ 1.011183] ata1.00: ATA Identify Device Log not supported
[ 1.011193] ata1.00: 1250263728 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.012955] ata2.00: configured for UDMA/100
[ 1.015115] ata1.00: ATA Identify Device Log not supported
[ 1.015129] ata1.00: configured for UDMA/133
[ 1.015361] scsi 0:0:0:0: Direct-Access ATA WDC WD6400BPVT-8 1A01 PQ: 0 ANSI: 5
[ 1.015753] sd 0:0:0:0: [sda] 1250263728 512-byte logical blocks: (640 GB/596 GiB)
[ 1.015769] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.015787] sd 0:0:0:0: [sda] Write Protect is off
[ 1.015792] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.015817] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.018047] scsi 1:0:0:0: CD-ROM HL-DT-ST DVDRAM GT34N AS00 PQ: 0 ANSI: 5
[ 1.026493] usb 3-3: New USB device found, idVendor=13d3, idProduct=5710, bcdDevice=11.29
[ 1.026502] usb 3-3: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1.026506] usb 3-3: Product: USB 2.0 UVC VGA WebCam
[ 1.026508] usb 3-3: Manufacturer: Azurewave
[ 1.026510] usb 3-3: SerialNumber: 0x0001
[ 1.084066] usb 5-4: new full-speed USB device number 2 using ohci-pci
[ 1.275797] usb 5-4: New USB device found, idVendor=0b05, idProduct=1788, bcdDevice= 4.49
[ 1.275806] usb 5-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.275809] usb 5-4: Product: BT-270
[ 1.275812] usb 5-4: Manufacturer: Broadcom Corp
[ 1.275814] usb 5-4: SerialNumber: 74F06DDB642E
[ 1.460436] tsc: Refined TSC clocksource calibration: 1795.503 MHz
[ 1.460455] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x19e19166fc0, max_idle_ns: 440795221227 ns
[ 1.460501] clocksource: Switched to clocksource tsc
[ 3.465516] sda: sda1 sda2 sda3 < sda5 >
[ 3.493897] sd 0:0:0:0: [sda] Attached SCSI disk
[ 8.647677] Freeing initrd memory: 52624K
[ 8.658434] Segment Routing with IPv6
[ 8.658440] RPL Segment Routing with IPv6
[ 8.658465] In-situ OAM (IOAM) with IPv6
[ 8.658510] NET: Registered PF_PACKET protocol family
[ 8.659353] microcode: microcode updated early to new patch_level=0x010000c8
[ 8.659436] microcode: CPU0: patch_level=0x010000c8
[ 8.659455] microcode: CPU1: patch_level=0x010000c8
[ 8.659481] microcode: CPU2: patch_level=0x010000c8
[ 8.659506] microcode: CPU3: patch_level=0x010000c8
[ 8.659519] microcode: Microcode Update Driver: v2.2.
[ 8.659528] IPI shorthand broadcast: enabled
[ 8.659550] sched_clock: Marking stable (8658642961, 556770)->(8733340114, -74140383)
[ 8.659819] registered taskstats version 1
[ 8.660276] Loading compiled-in X.509 certificates
[ 8.667628] Loaded X.509 cert 'Build time autogenerated kernel key: 3f1e03b6c321983a2132e6f20299680ca78c27e6'
[ 8.670853] zswap: loaded using pool zstd/z3fold
[ 8.671708] Key type ._fscrypt registered
[ 8.671714] Key type .fscrypt registered
[ 8.671716] Key type fscrypt-provisioning registered
[ 8.671795] AppArmor: AppArmor sha1 policy hashing enabled
[ 8.672238] PM: Magic number: 8:581:802
[ 8.672732] RAS: Correctable Errors collector initialized.
[ 8.675474] Freeing unused decrypted memory: 2036K
[ 8.676399] Freeing unused kernel image (initmem) memory: 1864K
[ 8.700468] Write protecting the kernel read-only data: 28672k
[ 8.701682] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 8.702425] Freeing unused kernel image (rodata/data gap) memory: 1404K
[ 8.751295] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 8.751302] rodata_test: all tests were successful
[ 8.751315] Run /init as init process
[ 8.751317] with arguments:
[ 8.751319] /init
[ 8.751320] with environment:
[ 8.751322] HOME=/
[ 8.751323] TERM=linux
[ 8.751324] BOOT_IMAGE=/boot/vmlinuz-x86_64
[ 8.751326] lang=en_US
[ 8.751327] keytable=us
[ 8.751329] tz=UTC
[ 8.751330] misobasedir=manjaro
[ 8.751331] misolabel=MANJARO_XFCE_2122
[ 8.751333] driver=free
[ 9.152475] fbcon: Taking over console
[ 9.152740] Console: switching to colour frame buffer device 128x48
[ 9.208987] loop: module loaded
[ 9.223916] device-mapper: uevent: version 1.0.3
[ 9.224076] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 9.393111] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 9.398719] i8042: Detected active multiplexing controller, rev 1.1
[ 9.401476] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 9.401576] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 9.401618] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 9.401655] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 9.401693] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 9.431393] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 9.455407] acpi device:45: registered as cooling_device4
[ 9.456409] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:42/LNXVIDEO:00/input/input4
[ 9.457922] usb-storage 1-3:1.0: USB Mass Storage device detected
[ 9.458132] scsi host4: pata_atiixp
[ 9.458398] scsi host5: usb-storage 1-3:1.0
[ 9.458448] scsi host6: pata_atiixp
[ 9.458540] ata5: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xf000 irq 14
[ 9.458546] ata6: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xf008 irq 15
[ 9.458610] usbcore: registered new interface driver usb-storage
[ 9.474282] usbcore: registered new interface driver uas
[ 9.493333] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 9.493345] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 9.518591] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 9.578395] [drm] radeon kernel modesetting enabled.
[ 9.578540] checking generic (d0000000 300000) vs hw (d0000000 10000000)
[ 9.578550] fb0: switching to radeon from EFI VGA
[ 9.578719] Console: switching to colour dummy device 80x25
[ 9.578746] radeon 0000:01:00.0: vgaarb: deactivate vga console
[ 9.579143] [drm] initializing kernel modesetting (TURKS 0x1002:0x6741 0x1043:0x1CD2 0x00).
[ 9.579271] ATOM BIOS: Asus
[ 9.579377] radeon 0000:01:00.0: VRAM: 1024M 0x0000000000000000 - 0x000000003FFFFFFF (1024M used)
[ 9.579383] radeon 0000:01:00.0: GTT: 1024M 0x0000000040000000 - 0x000000007FFFFFFF
[ 9.579390] [drm] Detected VRAM RAM=1024M, BAR=256M
[ 9.579392] [drm] RAM width 128bits DDR
[ 9.579431] [drm] radeon: 1024M of VRAM memory ready
[ 9.579433] [drm] radeon: 1024M of GTT memory ready.
[ 9.579441] [drm] Loading TURKS Microcode
[ 9.579630] [drm] Internal thermal controller with fan control
[ 9.581321] [drm] radeon: dpm initialized
[ 9.581541] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 9.584304] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
[ 9.598146] [drm] PCIE GART of 1024M enabled (table at 0x0000000000162000).
[ 9.598252] radeon 0000:01:00.0: WB enabled
[ 9.598256] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000040000c00
[ 9.598259] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000040000c0c
[ 9.599049] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000072118
[ 9.599412] radeon 0000:01:00.0: radeon: MSI limited to 32-bit
[ 9.599539] radeon 0000:01:00.0: radeon: using MSI.
[ 9.599571] [drm] radeon: irq initialized.
[ 9.626949] [drm] ring test on 0 succeeded in 1 usecs
[ 9.626961] [drm] ring test on 3 succeeded in 3 usecs
[ 9.644781] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input5
[ 9.825028] [drm] ring test on 5 succeeded in 1 usecs
[ 9.825036] [drm] UVD initialized successfully.
[ 9.825580] [drm] ib test on ring 0 succeeded in 0 usecs
[ 9.825644] [drm] ib test on ring 3 succeeded in 0 usecs
[ 10.474880] scsi 5:0:0:0: Direct-Access Kingston DataTraveler 3.0 PQ: 0 ANSI: 6
[ 10.476730] sd 5:0:0:0: [sdb] 60437492 512-byte logical blocks: (30.9 GB/28.8 GiB)
[ 10.477482] sd 5:0:0:0: [sdb] Write Protect is off
[ 10.477492] sd 5:0:0:0: [sdb] Mode Sense: 4f 00 00 00
[ 10.478237] sd 5:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 10.484106] sdb: sdb1 sdb2
[ 10.488113] sd 5:0:0:0: [sdb] Attached SCSI removable disk
[ 10.500528] [drm] ib test on ring 5 succeeded
[ 10.563816] [drm] radeon atom DIG backlight initialized
[ 10.563825] [drm] Radeon Display Connectors
[ 10.563827] [drm] Connector 0:
[ 10.563829] [drm] LVDS-1
[ 10.563831] [drm] DDC: 0x6560 0x6560 0x6564 0x6564 0x6568 0x6568 0x656c 0x656c
[ 10.563835] [drm] Encoders:
[ 10.563836] [drm] LCD1: INTERNAL_UNIPHY
[ 10.563838] [drm] Connector 1:
[ 10.563839] [drm] HDMI-A-1
[ 10.563840] [drm] HPD1
[ 10.563841] [drm] DDC: 0x6440 0x6440 0x6444 0x6444 0x6448 0x6448 0x644c 0x644c
[ 10.563844] [drm] Encoders:
[ 10.563845] [drm] DFP1: INTERNAL_UNIPHY1
[ 10.563846] [drm] Connector 2:
[ 10.563847] [drm] VGA-1
[ 10.563848] [drm] DDC: 0x64d8 0x64d8 0x64dc 0x64dc 0x64e0 0x64e0 0x64e4 0x64e4
[ 10.563851] [drm] Encoders:
[ 10.563852] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 10.973883] [drm] fb mappable at 0xD0363000
[ 10.973890] [drm] vram apper at 0xD0000000
[ 10.973891] [drm] size 4325376
[ 10.973893] [drm] fb depth is 24
[ 10.973894] [drm] pitch is 5632
[ 10.974005] fbcon: radeondrmfb (fb0) is primary device
[ 11.558766] Console: switching to colour frame buffer device 170x48
[ 11.563599] radeon 0000:01:00.0: [drm] fb0: radeondrmfb frame buffer device
[ 11.580694] [drm] Initialized radeon 2.50.0 20080528 for 0000:01:00.0 on minor 0
[ 11.943819] random: crng init done
[ 12.511308] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 12.512810] ISO 9660 Extensions: RRIP_1991A
[ 12.594042] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 12.595538] ISO 9660 Extensions: RRIP_1991A
[ 12.609000] loop0: detected capacity change from 0 to 144568
[ 12.727476] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 12.749989] loop1: detected capacity change from 0 to 1606224
[ 12.851946] loop2: detected capacity change from 0 to 3667072
[ 12.973767] loop3: detected capacity change from 0 to 1619712
[ 13.106569] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 13.914884] systemd[1]: System time before build time, advancing clock.
[ 14.075589] systemd[1]: systemd 250.2-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 14.075817] systemd[1]: Detected architecture x86-64.
[ 15.410389] systemd[1]: Queued start job for default target Graphical Interface.
[ 15.412513] systemd[1]: Created slice Slice /system/getty.
[ 15.413469] systemd[1]: Created slice Slice /system/modprobe.
[ 15.414232] systemd[1]: Created slice User and Session Slice.
[ 15.414566] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 15.414823] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 15.415306] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 15.415555] systemd[1]: Reached target Local Encrypted Volumes.
[ 15.415707] systemd[1]: Reached target Login Prompts.
[ 15.415847] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 15.416030] systemd[1]: Reached target Remote File Systems.
[ 15.416169] systemd[1]: Reached target Slice Units.
[ 15.416310] systemd[1]: Reached target Swaps.
[ 15.416455] systemd[1]: Reached target Local Verity Protected Volumes.
[ 15.416735] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 15.418654] systemd[1]: Listening on LVM2 poll daemon socket.
[ 15.422138] systemd[1]: Listening on Process Core Dump Socket.
[ 15.422698] systemd[1]: Listening on Journal Audit Socket.
[ 15.423071] systemd[1]: Listening on Journal Socket (/dev/log).
[ 15.423433] systemd[1]: Listening on Journal Socket.
[ 15.425253] systemd[1]: Listening on udev Control Socket.
[ 15.425684] systemd[1]: Listening on udev Kernel Socket.
[ 15.427692] systemd[1]: Mounting Huge Pages File System...
[ 15.429727] systemd[1]: Mounting POSIX Message Queue File System...
[ 15.431909] systemd[1]: Mounting Kernel Debug File System...
[ 15.434085] systemd[1]: Mounting Kernel Trace File System...
[ 15.439548] systemd[1]: Mounting Temporary Directory /tmp...
[ 15.442316] systemd[1]: Starting Load AppArmor profiles...
[ 15.445940] systemd[1]: Starting Create List of Static Device Nodes...
[ 15.448390] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 15.451140] systemd[1]: Starting Load Kernel Module configfs...
[ 15.453528] systemd[1]: Starting Load Kernel Module drm...
[ 15.455973] systemd[1]: Starting Load Kernel Module fuse...
[ 15.501234] systemd[1]: Starting Load Kernel Modules...
[ 15.503393] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 15.518210] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 15.520387] systemd[1]: Starting Coldplug All udev Devices...
[ 15.524876] systemd[1]: Mounted Huge Pages File System.
[ 15.524952] fuse: init (API version 7.34)
[ 15.525391] systemd[1]: Mounted POSIX Message Queue File System.
[ 15.525772] systemd[1]: Mounted Kernel Debug File System.
[ 15.526192] systemd[1]: Mounted Kernel Trace File System.
[ 15.526513] systemd[1]: Mounted Temporary Directory /tmp.
[ 15.527149] systemd[1]: Finished Create List of Static Device Nodes.
[ 15.527984] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 15.528263] systemd[1]: Finished Load Kernel Module configfs.
[ 15.528997] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 15.529363] systemd[1]: Finished Load Kernel Module drm.
[ 15.530115] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 15.530418] systemd[1]: Finished Load Kernel Module fuse.
[ 15.534244] systemd[1]: Mounting FUSE Control File System...
[ 15.538105] systemd[1]: Mounting Kernel Configuration File System...
[ 15.552244] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 15.554859] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 15.557175] systemd[1]: Mounted FUSE Control File System.
[ 15.559400] systemd[1]: Mounted Kernel Configuration File System.
[ 15.561653] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 15.604333] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 15.606519] systemd[1]: Starting Load/Save Random Seed...
[ 15.608881] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 15.610797] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 15.666065] systemd[1]: Finished Load Kernel Modules.
[ 15.669606] systemd[1]: Starting Apply Kernel Variables...
[ 15.679547] systemd[1]: Finished Load/Save Random Seed.
[ 15.681299] systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 15.731217] systemd[1]: Finished Apply Kernel Variables.
[ 15.735768] systemd[1]: Starting CLI Netfilter Manager...
[ 15.759867] systemd[1]: Finished Coldplug All udev Devices.
[ 15.781620] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 15.784333] systemd[1]: Reached target Preparation for Local File Systems.
[ 15.789476] systemd[1]: Mounting Temporary /etc/pacman.d/gnupg directory...
[ 15.794436] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of a failed condition check (ConditionPathExists=/var/lib/machines.raw).
[ 15.794502] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
[ 15.797437] systemd[1]: Starting Journal Service...
[ 15.805032] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 15.809647] systemd[1]: Finished CLI Netfilter Manager.
[ 15.811997] systemd[1]: Mounted Temporary /etc/pacman.d/gnupg directory.
[ 15.814181] systemd[1]: Reached target Local File Systems.
[ 15.816334] systemd[1]: Rebuild Dynamic Linker Cache was skipped because all trigger condition checks failed.
[ 15.817266] systemd[1]: Set Up Additional Binary Formats was skipped because all trigger condition checks failed.
[ 15.817346] systemd[1]: Store a System Token in an EFI Variable was skipped because of a failed condition check (ConditionPathExists=/sys/firmware/efi/efivars/LoaderFeatures-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[ 15.817429] systemd[1]: Commit a transient machine-id on disk was skipped because of a failed condition check (ConditionPathIsMountPoint=/etc/machine-id).
[ 15.918409] audit: type=1400 audit(1641958280.999:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=323 comm="apparmor_parser"
[ 15.995578] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 15.997292] audit: type=1130 audit(1641958281.079:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.002293] systemd[1]: Started Journal Service.
[ 16.007033] audit: type=1130 audit(1641958281.086:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.028101] systemd-journald[332]: Received client request to flush runtime journal.
[ 16.064920] audit: type=1400 audit(1641958281.146:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=324 comm="apparmor_parser"
[ 16.067170] audit: type=1400 audit(1641958281.149:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=324 comm="apparmor_parser"
[ 16.075136] audit: type=1130 audit(1641958281.156:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.192263] audit: type=1130 audit(1641958281.273:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.206578] audit: type=1127 audit(1641958281.286:9): pid=357 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 16.219206] audit: type=1130 audit(1641958281.299:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.250655] audit: type=1400 audit(1641958281.329:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=334 comm="apparmor_parser"
[ 16.492775] acpi_cpufreq: overriding BIOS provided _PSD data
[ 16.717695] asus_laptop: Asus Laptop Support version 0.42
[ 16.717916] asus_laptop: BSTS called, 0xff17 returned
[ 16.717947] asus_laptop: model detected
[ 16.718760] input: Asus Laptop extra buttons as /devices/platform/asus_laptop/input/input10
[ 16.839673] atl1c 0000:05:00.0 enp5s0: renamed from eth0
[ 17.110710] ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\SBSM) (20210730/utaddress-204)
[ 17.110728] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 17.119181] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 17.129128] input: PC Speaker as /devices/platform/pcspkr/input/input11
[ 17.170937] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 17.179056] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 17.213737] sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
[ 17.216018] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 17.451600] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input16
[ 17.590062] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VB: line_outs=1 (0x1b/0x0/0x0/0x0/0x0) type:speaker
[ 17.590079] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 17.590083] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 17.590086] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 17.590089] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x1e/0x0
[ 17.590091] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 17.590093] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x19
[ 17.590096] snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
[ 17.598789] input: HDA ATI SB Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input17
[ 17.598888] input: HDA ATI SB Headphone as /devices/pci0000:00/0000:00:14.2/sound/card0/input18
[ 17.918061] kvm: Nested Virtualization enabled
[ 17.918068] SVM: kvm: Nested Paging enabled
[ 17.950228] ath9k 0000:04:00.0: enabling device (0000 -> 0002)
[ 18.000900] ath: phy0: Enable LNA combining
[ 18.002324] ath: EEPROM regdomain: 0x60
[ 18.002327] ath: EEPROM indicates we should expect a direct regpair map
[ 18.002330] ath: Country alpha2 being used: 00
[ 18.002331] ath: Regpair used: 0x60
[ 18.005082] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 18.005937] ieee80211 phy0: Atheros AR9285 Rev:2 mem=0xffffad5dc1fd0000, irq=16
[ 18.013884] ath9k 0000:04:00.0 wlp4s0: renamed from wlan0
[ 18.045287] psmouse serio4: elantech: assuming hardware version 2 (with firmware version 0x040201)
[ 18.084578] psmouse serio4: elantech: Synaptics capabilities query result 0x78, 0x14, 0x0b.
[ 18.123874] psmouse serio4: elantech: Elan sample query result 1f, 00, 00
[ 18.147502] MCE: In-kernel MCE decoding enabled.
[ 18.293348] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio4/input/input15
[ 18.450633] mousedev: PS/2 mouse device common for all mice
[ 19.457275] loop4: detected capacity change from 0 to 8
[ 20.124058] st: Version 20160209, fixed bufsize 32768, s/g segs 256
[ 20.317477] NET: Registered PF_QIPCRTR protocol family
[ 20.444993] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 20.448452] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 20.448553] sd 5:0:0:0: Attached scsi generic sg2 type 0
[ 21.241596] mc: Linux media interface: v0.10
[ 21.330077] kauditd_printk_skb: 33 callbacks suppressed
[ 21.330083] audit: type=1400 audit(1641958286.399:39): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=665 comm="apparmor_parser"
[ 21.344271] audit: type=1300 audit(1641958286.399:39): arch=c000003e syscall=1 success=yes exit=69825 a0=6 a1=55fda206b7b0 a2=110c1 a3=0 items=0 ppid=664 pid=665 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj==unconfined key=(null)
[ 21.344288] audit: type=1327 audit(1641958286.399:39): proctitle=61707061726D6F725F706172736572002D2D7265706C616365002D2D77726974652D6361636865002D4F006E6F2D657870722D73696D706C696679002D2D63616368652D6C6F633D2F7661722F63616368652F61707061726D6F72002D2D736B69702D726561642D6361636865002D2D7175696574002F6574632F6170706172
[ 21.344298] audit: type=1400 audit(1641958286.423:40): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=665 comm="apparmor_parser"
[ 21.344305] audit: type=1300 audit(1641958286.423:40): arch=c000003e syscall=1 success=yes exit=16065 a0=6 a1=55fda1c7a120 a2=3ec1 a3=0 items=0 ppid=664 pid=665 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj==unconfined key=(null)
[ 21.344310] audit: type=1327 audit(1641958286.423:40): proctitle=61707061726D6F725F706172736572002D2D7265706C616365002D2D77726974652D6361636865002D4F006E6F2D657870722D73696D706C696679002D2D63616368652D6C6F633D2F7661722F63616368652F61707061726D6F72002D2D736B69702D726561642D6361636865002D2D7175696574002F6574632F6170706172
[ 21.356462] videodev: Linux video capture interface: v2.00
[ 21.377425] audit: type=1130 audit(1641958286.456:41): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.429674] audit: type=1334 audit(1641958286.509:42): prog-id=15 op=LOAD
[ 21.429905] audit: type=1334 audit(1641958286.509:43): prog-id=16 op=LOAD
[ 21.429981] audit: type=1334 audit(1641958286.509:44): prog-id=17 op=LOAD
[ 21.716116] Bluetooth: Core ver 2.22
[ 21.716184] NET: Registered PF_BLUETOOTH protocol family
[ 21.716186] Bluetooth: HCI device and connection manager initialized
[ 21.716193] Bluetooth: HCI socket layer initialized
[ 21.716196] Bluetooth: L2CAP socket layer initialized
[ 21.716202] Bluetooth: SCO socket layer initialized
[ 21.934671] usb 3-3: Found UVC 1.00 device USB 2.0 UVC VGA WebCam (13d3:5710)
[ 22.013599] input: USB 2.0 UVC VGA WebCam: USB2.0 as /devices/pci0000:00/0000:00:16.2/usb3/3-3/3-3:1.0/input/input19
[ 22.013799] usbcore: registered new interface driver uvcvideo
[ 22.036770] usbcore: registered new interface driver btusb
[ 22.263812] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 22.263821] Bluetooth: BNEP filters: protocol multicast
[ 22.263830] Bluetooth: BNEP socket layer initialized
[ 30.290289] kauditd_printk_skb: 4 callbacks suppressed
[ 30.290300] audit: type=1131 audit(1641958295.369:49): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 33.724105] audit: type=1130 audit(1641958298.806:50): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mhwd-li:
[ 33.724257] audit: type=1131 audit(1641958298.806:51): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mhwd-live comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 34.364585] audit: type=1116 audit(1641958299.446:52): pid=954 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 34.366856] audit: type=1114 audit(1641958299.446:53): pid=954 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user id=1000 exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 34.366877] audit: type=1114 audit(1641958299.446:54): pid=954 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 34.367083] audit: type=1114 audit(1641958299.446:55): pid=954 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 34.367113] audit: type=1114 audit(1641958299.449:56): pid=954 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 34.367213] audit: type=1114 audit(1641958299.449:57): pid=954 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 34.367252] audit: type=1114 audit(1641958299.449:58): pid=954 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[ 37.567908] kauditd_printk_skb: 16 callbacks suppressed
[ 37.567916] audit: type=1100 audit(1641958302.649:75): pid=1195 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="manjaro" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 37.570989] audit: type=1101 audit(1641958302.653:76): pid=1195 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 37.591269] audit: type=1103 audit(1641958302.673:77): pid=1195 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="manjaro" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 37.591410] audit: type=1006 audit(1641958302.673:78): pid=1195 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[ 37.591426] audit: type=1300 audit(1641958302.673:78): arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7ffec208f9c0 a2=4 a3=3e8 items=0 ppid=1063 pid=1195 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="lightdm" exe="/usr/bin/lightdm" subj==unconfined key=(null)
[ 37.591433] audit: type=1327 audit(1641958302.673:78): proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003132003135
[ 37.637866] audit: type=1130 audit(1641958302.719:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 37.653364] audit: type=1101 audit(1641958302.733:80): pid=1207 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 37.653424] audit: type=1103 audit(1641958302.733:81): pid=1207 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="manjaro" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 37.653579] audit: type=1006 audit(1641958302.733:82): pid=1207 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 42.298453] Bluetooth: RFCOMM TTY layer initialized
[ 42.298472] Bluetooth: RFCOMM socket layer initialized
[ 42.298479] Bluetooth: RFCOMM ver 1.11
[ 43.532094] kauditd_printk_skb: 11 callbacks suppressed
[ 43.532100] audit: type=1101 audit(1641958308.613:90): pid=1511 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 43.536938] audit: type=1110 audit(1641958308.616:91): pid=1511 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 43.546058] audit: type=1105 audit(1641958308.626:92): pid=1511 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 43.559712] audit: type=1106 audit(1641958308.639:93): pid=1511 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 43.559993] audit: type=1104 audit(1641958308.639:94): pid=1511 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 43.634882] audit: type=1101 audit(1641958308.716:95): pid=1526 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 43.638366] audit: type=1110 audit(1641958308.719:96): pid=1526 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 43.680438] audit: type=1105 audit(1641958308.763:97): pid=1526 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 43.707711] audit: type=1106 audit(1641958308.789:98): pid=1526 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 43.707987] audit: type=1104 audit(1641958308.789:99): pid=1526 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 51.597516] kauditd_printk_skb: 7 callbacks suppressed
[ 51.597528] audit: type=1131 audit(1641958316.679:107): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 51.620856] audit: type=1334 audit(1641958316.703:108): prog-id=0 op=UNLOAD
[ 51.620874] audit: type=1334 audit(1641958316.703:109): prog-id=0 op=UNLOAD
[ 51.620891] audit: type=1334 audit(1641958316.703:110): prog-id=0 op=UNLOAD
[ 52.304120] audit: type=1131 audit(1641958317.386:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 52.407338] audit: type=1334 audit(1641958317.489:112): prog-id=0 op=UNLOAD
[ 52.407358] audit: type=1334 audit(1641958317.489:113): prog-id=0 op=UNLOAD
[ 52.407368] audit: type=1334 audit(1641958317.489:114): prog-id=0 op=UNLOAD
[ 56.391452] audit: type=1131 audit(1641958321.473:115): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 78.076176] audit: type=1131 audit(1641958343.156:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 88.656249] audit: type=1105 audit(1641958353.736:117): pid=1945 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 101.233715] audit: type=1111 audit(1641958366.316:118): pid=427 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-add-activate uuid=55caaad8-5723-4d01-9a00-29d1f9c038c4 name=6D7A6961206D7A6961 pid=1525 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 101.948353] audit: type=1334 audit(1641958367.029:119): prog-id=21 op=LOAD
[ 101.948838] audit: type=1334 audit(1641958367.029:120): prog-id=22 op=LOAD
[ 101.949056] audit: type=1334 audit(1641958367.029:121): prog-id=23 op=LOAD
[ 102.069745] audit: type=1130 audit(1641958367.149:122): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 105.100119] SGI XFS with ACLs, security attributes, realtime, scrub, repair, quota, no debug enabled
[ 105.147466] JFS: nTxBlock = 8192, nTxLock = 65536
[ 105.454682] raid6: skip pq benchmark and using algorithm sse2x4
[ 105.454695] raid6: using intx1 recovery algorithm
[ 105.471811] xor: measuring software checksum speed
[ 105.473046] prefetch64-sse : 8078 MB/sec
[ 105.474485] generic_sse : 7599 MB/sec
[ 105.474488] xor: using function: prefetch64-sse (8078 MB/sec)
[ 105.713526] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[ 112.537693] wlp4s0: authenticate with 56:48:e6:ac:5b:c9
[ 112.553277] wlp4s0: send auth to 56:48:e6:ac:5b:c9 (try 1/3)
[ 112.591045] wlp4s0: authenticated
[ 112.594030] wlp4s0: associate with 56:48:e6:ac:5b:c9 (try 1/3)
[ 112.637120] wlp4s0: RX AssocResp from 56:48:e6:ac:5b:c9 (capab=0xc11 status=0 aid=2)
[ 112.637279] wlp4s0: associated
[ 112.637412] ath: EEPROM regdomain: 0x8324
[ 112.637414] ath: EEPROM indicates we should expect a country code
[ 112.637416] ath: doing EEPROM country->regdmn map search
[ 112.637418] ath: country maps to regdmn code: 0x3e
[ 112.637420] ath: Country alpha2 being used: UA
[ 112.637421] ath: Regpair used: 0x3e
[ 112.637423] ath: regdomain 0x8324 dynamically updated by country element
[ 112.857499] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
[ 113.276850] audit: type=1130 audit(1641958378.356:123): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 123.289678] audit: type=1131 audit(1641958388.369:124): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 124.345636] audit: type=1334 audit(1641958389.426:125): prog-id=24 op=LOAD
[ 124.346135] audit: type=1334 audit(1641958389.426:126): prog-id=25 op=LOAD
[ 124.346235] audit: type=1334 audit(1641958389.426:127): prog-id=26 op=LOAD
[ 124.475613] audit: type=1130 audit(1641958389.556:128): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 132.143882] audit: type=1131 audit(1641958397.226:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 132.257791] audit: type=1334 audit(1641958397.339:130): prog-id=0 op=UNLOAD
[ 132.257811] audit: type=1334 audit(1641958397.339:131): prog-id=0 op=UNLOAD
[ 132.257820] audit: type=1334 audit(1641958397.339:132): prog-id=0 op=UNLOAD
[ 156.813893] audit: type=1130 audit(1641958421.896:133): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pacman-init comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 167.599763] audit: type=1131 audit(1641958432.679:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 167.627470] audit: type=1334 audit(1641958432.709:135): prog-id=0 op=UNLOAD
[ 167.627484] audit: type=1334 audit(1641958432.709:136): prog-id=0 op=UNLOAD
[ 167.627490] audit: type=1334 audit(1641958432.709:137): prog-id=0 op=UNLOAD
[ 320.498222] audit: type=1105 audit(1641958585.579:138): pid=3141 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 321.511786] audit: type=1334 audit(1641958586.593:139): prog-id=27 op=LOAD
[ 321.511813] audit: type=1334 audit(1641958586.593:140): prog-id=0 op=UNLOAD
[ 321.512206] audit: type=1334 audit(1641958586.593:141): prog-id=28 op=LOAD
[ 321.512228] audit: type=1334 audit(1641958586.593:142): prog-id=29 op=LOAD
[ 321.512237] audit: type=1334 audit(1641958586.593:143): prog-id=0 op=UNLOAD
[ 321.512246] audit: type=1334 audit(1641958586.593:144): prog-id=0 op=UNLOAD
[ 321.514114] audit: type=1334 audit(1641958586.596:145): prog-id=30 op=LOAD
[ 321.514151] audit: type=1334 audit(1641958586.596:146): prog-id=0 op=UNLOAD
[ 321.514514] audit: type=1334 audit(1641958586.596:147): prog-id=31 op=LOAD
[ 322.085069] NILFS version 2 loaded
[ 393.822620] kauditd_printk_skb: 13 callbacks suppressed
[ 393.822632] audit: type=1334 audit(1641958658.903:161): prog-id=38 op=LOAD
[ 393.822649] audit: type=1334 audit(1641958658.903:162): prog-id=0 op=UNLOAD
[ 393.822765] audit: type=1334 audit(1641958658.903:163): prog-id=39 op=LOAD
[ 393.822821] audit: type=1334 audit(1641958658.903:164): prog-id=40 op=LOAD
[ 393.822850] audit: type=1334 audit(1641958658.903:165): prog-id=0 op=UNLOAD
[ 393.822860] audit: type=1334 audit(1641958658.903:166): prog-id=0 op=UNLOAD
[ 393.826333] audit: type=1334 audit(1641958658.906:167): prog-id=41 op=LOAD
[ 393.826368] audit: type=1334 audit(1641958658.906:168): prog-id=42 op=LOAD
[ 393.826727] audit: type=1334 audit(1641958658.906:169): prog-id=0 op=UNLOAD
[ 393.826739] audit: type=1334 audit(1641958658.906:170): prog-id=0 op=UNLOAD
[ 461.490088] kauditd_printk_skb: 12 callbacks suppressed
[ 461.490100] audit: type=1101 audit(1641958726.569:183): pid=3294 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 461.492514] audit: type=1110 audit(1641958726.573:184): pid=3294 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 461.499279] audit: type=1105 audit(1641958726.579:185): pid=3294 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 464.282741] audit: type=1106 audit(1641958729.363:186): pid=3294 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 464.282961] audit: type=1104 audit(1641958729.363:187): pid=3294 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 544.349092] audit: type=1105 audit(1641958809.429:188): pid=3314 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 545.349805] audit: type=1334 audit(1641958810.429:189): prog-id=49 op=LOAD
[ 545.349829] audit: type=1334 audit(1641958810.429:190): prog-id=0 op=UNLOAD
[ 545.350266] audit: type=1334 audit(1641958810.429:191): prog-id=50 op=LOAD
[ 545.350280] audit: type=1334 audit(1641958810.429:192): prog-id=51 op=LOAD
[ 545.350289] audit: type=1334 audit(1641958810.429:193): prog-id=0 op=UNLOAD
[ 545.350296] audit: type=1334 audit(1641958810.429:194): prog-id=0 op=UNLOAD
[ 545.353522] audit: type=1334 audit(1641958810.433:195): prog-id=52 op=LOAD
[ 545.353634] audit: type=1334 audit(1641958810.436:196): prog-id=53 op=LOAD
[ 545.353665] audit: type=1334 audit(1641958810.436:197): prog-id=0 op=UNLOAD
[ 581.378863] sda: sda1 sda2 sda3 < sda5 >
[ 703.695931] kauditd_printk_skb: 13 callbacks suppressed
[ 703.695940] audit: type=1105 audit(1641958968.776:211): pid=3453 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 893.155010] audit: type=1101 audit(1641959158.236:212): pid=3520 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 893.157169] audit: type=1110 audit(1641959158.239:213): pid=3520 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 893.163469] audit: type=1105 audit(1641959158.243:214): pid=3520 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 902.831601] audit: type=1130 audit(1641959167.913:215): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 902.831631] audit: type=1131 audit(1641959167.913:216): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1025.643842] audit: type=1334 audit(1641959290.726:217): prog-id=60 op=LOAD
[ 1025.644650] audit: type=1334 audit(1641959290.726:218): prog-id=61 op=LOAD
[ 1025.644801] audit: type=1334 audit(1641959290.726:219): prog-id=62 op=LOAD
[ 1025.953426] audit: type=1130 audit(1641959291.033:220): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1055.995749] audit: type=1131 audit(1641959321.076:221): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1056.052006] audit: type=1334 audit(1641959321.133:222): prog-id=0 op=UNLOAD
[ 1056.052025] audit: type=1334 audit(1641959321.133:223): prog-id=0 op=UNLOAD
[ 1056.052030] audit: type=1334 audit(1641959321.133:224): prog-id=0 op=UNLOAD
[ 1092.901363] audit: type=1334 audit(1641959357.983:225): prog-id=63 op=LOAD
[ 1092.901654] audit: type=1334 audit(1641959357.983:226): prog-id=64 op=LOAD
[ 1092.902012] audit: type=1334 audit(1641959357.983:227): prog-id=65 op=LOAD
[ 1093.066714] audit: type=1130 audit(1641959358.146:228): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1123.109657] audit: type=1131 audit(1641959388.189:229): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1123.153761] audit: type=1334 audit(1641959388.236:230): prog-id=0 op=UNLOAD
[ 1123.153783] audit: type=1334 audit(1641959388.236:231): prog-id=0 op=UNLOAD
[ 1123.153791] audit: type=1334 audit(1641959388.236:232): prog-id=0 op=UNLOAD
[ 1161.081089] audit: type=1105 audit(1641959426.163:233): pid=3616 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 1161.224368] audit: type=1105 audit(1641959426.306:234): pid=3621 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 1161.362518] audit: type=1105 audit(1641959426.443:235): pid=3625 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 1161.499533] audit: type=1105 audit(1641959426.579:236): pid=3629 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 1163.229736] audit: type=1105 audit(1641959428.309:237): pid=3634 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 1163.392880] audit: type=1105 audit(1641959428.473:238): pid=3638 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 1164.064754] audit: type=1105 audit(1641959429.146:239): pid=3648 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 1915.449878] audit: type=1334 audit(1641960180.529:240): prog-id=66 op=LOAD
[ 1915.450405] audit: type=1334 audit(1641960180.533:241): prog-id=67 op=LOAD
[ 1915.450526] audit: type=1334 audit(1641960180.533:242): prog-id=68 op=LOAD
[ 1915.584500] audit: type=1130 audit(1641960180.666:243): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1962.131557] audit: type=1334 audit(1641960227.213:244): prog-id=69 op=LOAD
[ 1962.131587] audit: type=1334 audit(1641960227.213:245): prog-id=0 op=UNLOAD
[ 1962.131724] audit: type=1334 audit(1641960227.213:246): prog-id=70 op=LOAD
[ 1962.131796] audit: type=1334 audit(1641960227.213:247): prog-id=71 op=LOAD
[ 1962.131824] audit: type=1334 audit(1641960227.213:248): prog-id=0 op=UNLOAD
[ 1962.131841] audit: type=1334 audit(1641960227.213:249): prog-id=0 op=UNLOAD
[ 1962.135165] audit: type=1334 audit(1641960227.216:250): prog-id=72 op=LOAD
[ 1962.135181] audit: type=1334 audit(1641960227.216:251): prog-id=0 op=UNLOAD
[ 1962.135434] audit: type=1334 audit(1641960227.216:252): prog-id=73 op=LOAD
[ 1962.135517] audit: type=1334 audit(1641960227.216:253): prog-id=74 op=LOAD
[ 1991.135260] kauditd_printk_skb: 30 callbacks suppressed
[ 1991.135270] audit: type=1130 audit(1643900234.743:284): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pkgfile-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1991.135281] audit: type=1131 audit(1643900234.743:285): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pkgfile-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1992.554486] audit: type=1131 audit(1643900236.163:286): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1992.570329] audit: type=1334 audit(1643900236.180:287): prog-id=0 op=UNLOAD
[ 1992.570347] audit: type=1334 audit(1643900236.180:288): prog-id=0 op=UNLOAD
[ 1992.570352] audit: type=1334 audit(1643900236.180:289): prog-id=0 op=UNLOAD
[ 2133.114735] audit: type=1334 audit(1643900376.722:290): prog-id=0 op=UNLOAD
[ 2861.477116] audit: type=1130 audit(1643901105.069:291): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2861.477137] audit: type=1131 audit(1643901105.069:292): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2866.057471] audit: type=1105 audit(1643901109.649:293): pid=85095 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 3021.293873] audit: type=1334 audit(1643901264.882:294): prog-id=86 op=LOAD
[ 3021.294232] audit: type=1334 audit(1643901264.886:295): prog-id=0 op=UNLOAD
[ 3021.294495] audit: type=1334 audit(1643901264.886:296): prog-id=87 op=LOAD
[ 3021.294677] audit: type=1334 audit(1643901264.886:297): prog-id=88 op=LOAD
[ 3021.294695] audit: type=1334 audit(1643901264.886:298): prog-id=0 op=UNLOAD
[ 3021.294701] audit: type=1334 audit(1643901264.886:299): prog-id=0 op=UNLOAD
[ 3021.298551] audit: type=1334 audit(1643901264.889:300): prog-id=89 op=LOAD
[ 3021.298635] audit: type=1334 audit(1643901264.889:301): prog-id=90 op=LOAD
[ 3021.298667] audit: type=1334 audit(1643901264.889:302): prog-id=0 op=UNLOAD
[ 3021.298690] audit: type=1334 audit(1643901264.889:303): prog-id=0 op=UNLOAD
[ 4081.745449] kauditd_printk_skb: 14 callbacks suppressed
[ 4081.745463] audit: type=1105 audit(1643902325.318:318): pid=85292 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 4082.932459] audit: type=1334 audit(1643902326.504:319): prog-id=98 op=LOAD
[ 4082.932528] audit: type=1334 audit(1643902326.504:320): prog-id=0 op=UNLOAD
[ 4082.932708] audit: type=1334 audit(1643902326.504:321): prog-id=99 op=LOAD
[ 4082.932795] audit: type=1334 audit(1643902326.504:322): prog-id=100 op=LOAD
[ 4082.932875] audit: type=1334 audit(1643902326.504:323): prog-id=0 op=UNLOAD
[ 4082.932891] audit: type=1334 audit(1643902326.504:324): prog-id=0 op=UNLOAD
[ 4082.936366] audit: type=1334 audit(1643902326.508:325): prog-id=101 op=LOAD
[ 4082.936474] audit: type=1334 audit(1643902326.508:326): prog-id=102 op=LOAD
[ 4082.936531] audit: type=1334 audit(1643902326.508:327): prog-id=0 op=UNLOAD
[ 4105.234504] kauditd_printk_skb: 15 callbacks suppressed
[ 4105.234513] audit: type=1334 audit(1643902348.804:343): prog-id=110 op=LOAD
[ 4105.234521] audit: type=1334 audit(1643902348.804:344): prog-id=0 op=UNLOAD
[ 4105.234678] audit: type=1334 audit(1643902348.804:345): prog-id=111 op=LOAD
[ 4105.234725] audit: type=1334 audit(1643902348.804:346): prog-id=112 op=LOAD
[ 4105.234755] audit: type=1334 audit(1643902348.804:347): prog-id=0 op=UNLOAD
[ 4105.234773] audit: type=1334 audit(1643902348.804:348): prog-id=0 op=UNLOAD
[ 4105.238320] audit: type=1334 audit(1643902348.807:349): prog-id=113 op=LOAD
[ 4105.238414] audit: type=1334 audit(1643902348.807:350): prog-id=114 op=LOAD
[ 4105.238473] audit: type=1334 audit(1643902348.807:351): prog-id=0 op=UNLOAD
[ 4105.238505] audit: type=1334 audit(1643902348.807:352): prog-id=0 op=UNLOAD
[ 4111.692315] kauditd_printk_skb: 14 callbacks suppressed
[ 4111.692322] audit: type=1130 audit(1643902355.260:367): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4182.373323] audit: type=1105 audit(1643902425.939:368): pid=85775 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 4183.450526] audit: type=1105 audit(1643902427.015:369): pid=85782 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 4183.873676] audit: type=1105 audit(1643902427.439:370): pid=85787 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 4184.354261] audit: type=1105 audit(1643902427.922:371): pid=85792 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 4184.565916] audit: type=1105 audit(1643902428.132:372): pid=85797 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 4570.649360] audit: type=1103 audit(1643902814.211:373): pid=85847 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[ 4570.705960] audit: type=1130 audit(1643902814.267:374): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4570.750938] audit: type=1101 audit(1643902814.311:375): pid=85851 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4570.751090] audit: type=1103 audit(1643902814.311:376): pid=85851 uid=0 auid=4294967295 ses=42949672
Output of sudo dmesg --level emerg,alert,crit,err,warn:
[ 0.010232] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20210730/tbfadt-615)
[ 0.293993] #2
[ 0.297320] #3
[ 0.374509] pci 0000:05:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
[ 4579.833315] kauditd_printk_skb: 4 callbacks suppressed
[ 7679.975099] kauditd_printk_skb: 15 callbacks suppressed
[ 8995.620265] kauditd_printk_skb: 14 callbacks suppressed
[ 9004.136762] kauditd_printk_skb: 4 callbacks suppressed
[11701.630949] CE: hpet increased min_delta_ns to 20115 nsec
[13788.431135] CE: hpet increased min_delta_ns to 30172 nsec
journalctl --follow
Output:
Feb 03 22:28:56 manjaro kernel: audit: type=1110 audit(1643912936.650:502): pid=91322 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Feb 03 22:28:56 manjaro sudo[91322]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
Feb 03 22:28:56 manjaro audit[91322]: USER_START pid=91322 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Feb 03 22:28:56 manjaro kernel: audit: type=1105 audit(1643912936.654:503): pid=91322 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Feb 03 22:28:56 manjaro sudo[91322]: pam_unix(sudo:session): session closed for user root
Feb 03 22:28:56 manjaro audit[91322]: USER_END pid=91322 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Feb 03 22:28:56 manjaro audit[91322]: CRED_DISP pid=91322 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Feb 03 22:28:56 manjaro kernel: audit: type=1106 audit(1643912936.687:504): pid=91322 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Feb 03 22:28:56 manjaro kernel: audit: type=1104 audit(1643912936.687:505): pid=91322 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Feb 03 22:29:01 manjaro wpa_supplicant[677]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-80 noise=-95 txrate=65000
Feb 03 22:32:03 manjaro wpa_supplicant[677]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-69 noise=-95 txrate=1000
Feb 03 22:32:03 manjaro wpa_supplicant[677]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-79 noise=-95 txrate=1000
Feb 03 22:32:15 manjaro wpa_supplicant[677]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-68 noise=-95 txrate=65000
Feb 03 22:32:17 manjaro wpa_supplicant[677]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-75 noise=-95 txrate=65000
Feb 03 22:32:22 manjaro wpa_supplicant[677]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-69 noise=-95 txrate=1000
Feb 03 22:32:25 manjaro wpa_supplicant[677]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-75 noise=-95 txrate=1000
Continue:
[manjaro@manjaro ~]$ cat /var/log/Xorg.0.log
[ 34.942]
X.Org X Server 1.21.1.3
[ 34.942] Current Operating System: Linux manjaro 5.15.16-1-MANJARO #1 SMP PREEMPT Thu Jan 20 13:58:19 UTC 2022 x86_64
[ 34.942] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2122 quiet systemd.show_status=1 apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
[ 34.942]
[ 34.942] Current version of pixman: 0.40.0
[ 34.942] Before reporting problems, check http://wiki.x.org
[ 34.942] Markers: (--) probed, (**) from config file, (==) default setting,
[ 34.942] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jan 12 03:31:40 2022
[ 34.944] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 34.944] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 34.950] (==) No Layout section. Using the first Screen section.
[ 34.950] (==) No screen section available. Using defaults.
[ 34.950] (**) |-->Screen "Default Screen Section" (0)
[ 34.950] (**) | |-->Monitor "<default monitor>"
[ 34.950] (==) No monitor specified for screen "Default Screen Section".
[ 34.950] (==) Automatically adding devices
[ 34.950] (==) Automatically enabling devices
[ 34.950] (==) Automatically adding GPU devices
[ 34.950] (==) Automatically binding GPU devices
[ 34.950] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 34.955] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 34.955] Entry deleted from font path.
[ 34.955] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 34.955] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 34.955] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 34.955] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 34.955] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 34.955] (II) The server relies on udev to provide the list of input devices.
[ 34.955] (II) Module ABI versions:
[ 34.955] X.Org ANSI C Emulation: 0.4
[ 34.955] X.Org Video Driver: 25.2
[ 34.955] X.Org XInput driver : 24.4
[ 34.955] X.Org Server Extension : 10.0
[ 34.957] (++) using VT number 7
[ 34.957] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 34.958] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 34.958] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/0000:01:00.0/drm/card0
[ 34.967] (--) PCI:*(1@0:0:0) 1002:6741:1043:1cd2 rev 0, Mem @ 0xd0000000/268435456, 0xfdf20000/131072, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[ 34.967] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 34.967] (II) LoadModule: "glx"
[ 34.969] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 34.984] (II) Module glx: vendor="X.Org Foundation"
[ 34.984] compiled for 1.21.1.3, module version = 1.0.0
[ 34.984] ABI class: X.Org Server Extension, version 10.0
[ 34.984] (II) Applying OutputClass "Radeon" to /dev/dri/card0
[ 34.984] loading driver: radeon
[ 34.984] (==) Matched radeon as autoconfigured driver 0
[ 34.984] (==) Matched ati as autoconfigured driver 1
[ 34.984] (==) Matched modesetting as autoconfigured driver 2
[ 34.984] (==) Matched fbdev as autoconfigured driver 3
[ 34.984] (==) Matched vesa as autoconfigured driver 4
[ 34.984] (==) Assigned the driver to the xf86ConfigLayout
[ 34.984] (II) LoadModule: "radeon"
[ 34.984] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 34.992] (II) Module radeon: vendor="X.Org Foundation"
[ 34.992] compiled for 1.21.1.1, module version = 19.1.0
[ 34.992] Module class: X.Org Video Driver
[ 34.992] ABI class: X.Org Video Driver, version 25.2
[ 34.992] (II) LoadModule: "ati"
[ 34.992] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 34.992] (II) Module ati: vendor="X.Org Foundation"
[ 34.995] (II) LoadModule: "modesetting"
[ 34.995] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 34.998] (II) Module modesetting: vendor="X.Org Foundation"
[ 34.998] compiled for 1.21.1.3, module version = 1.21.1
[ 34.998] Module class: X.Org Video Driver
[ 34.998] ABI class: X.Org Video Driver, version 25.2
[ 34.998] (II) LoadModule: "fbdev"
[ 34.998] (WW) Warning, couldn't open module fbdev
[ 34.998] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 34.998] (II) LoadModule: "vesa"
[ 34.999] (WW) Warning, couldn't open module vesa
[ 34.999] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 34.999] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
ATI Radeon 9800PRO, ATI Radeon 9800XT,
ATI Radeon Mobility 9600/9700 (M10/M11),
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
ATI FireGL V3350, ATI Mobility Radeon X1450,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
ATI FireGL V3400, ATI Mobility FireGL V5250,
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
MULLINS, KAVERI, HAWAII
[ 35.001] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 35.007] (II) [KMS] Kernel modesetting enabled.
[ 35.007] (WW) Falling back to old probe method for modesetting
[ 35.009] (II) RADEON(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 35.009] (==) RADEON(0): Depth 24, (--) framebuffer bpp 32
[ 35.009] (II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 35.009] (==) RADEON(0): Default visual is TrueColor
[ 35.009] (==) RADEON(0): RGB weight 888
[ 35.009] (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
[ 35.009] (--) RADEON(0): Chipset: "TURKS" (ChipID = 0x6741)
[ 35.009] (II) Loading sub module "fb"
[ 35.009] (II) LoadModule: "fb"
[ 35.009] (II) Module "fb" already built-in
[ 35.009] (II) Loading sub module "dri2"
[ 35.009] (II) LoadModule: "dri2"
[ 35.009] (II) Module "dri2" already built-in
[ 36.587] (II) Loading sub module "glamoregl"
[ 36.587] (II) LoadModule: "glamoregl"
[ 36.588] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 36.602] (II) Module glamoregl: vendor="X.Org Foundation"
[ 36.602] compiled for 1.21.1.3, module version = 1.0.1
[ 36.602] ABI class: X.Org ANSI C Emulation, version 0.4
[ 36.646] (II) RADEON(0): glamor X acceleration enabled on AMD TURKS (DRM 2.50.0 / 5.15.16-1-MANJARO, LLVM 13.0.0)
[ 36.646] (II) RADEON(0): glamor detected, initialising EGL layer.
[ 36.646] (II) RADEON(0): KMS Color Tiling: enabled
[ 36.646] (II) RADEON(0): KMS Color Tiling 2D: enabled
[ 36.646] (==) RADEON(0): TearFree property default: auto
[ 36.646] (II) RADEON(0): KMS Pageflipping: enabled
[ 36.649] (II) RADEON(0): Output LVDS has no monitor section
[ 36.650] (II) RADEON(0): Output HDMI-0 has no monitor section
[ 36.663] (II) RADEON(0): Output VGA-0 has no monitor section
[ 36.669] (II) RADEON(0): EDID for output LVDS
[ 36.669] (II) RADEON(0): Printing probed modes for output LVDS
[ 36.669] (II) RADEON(0): Modeline "1366x768"x60.0 78.05 1366 1414 1446 1646 768 770 775 790 -vsync (47.4 kHz eP)
[ 36.669] (II) RADEON(0): Modeline "1280x720"x60.0 74.65 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.9 kHz)
[ 36.669] (II) RADEON(0): Modeline "1152x768"x59.9 71.95 1152 1216 1328 1504 768 771 781 798 -hsync +vsync (47.8 kHz)
[ 36.669] (II) RADEON(0): Modeline "1024x768"x59.9 63.53 1024 1072 1176 1328 768 771 775 798 -hsync +vsync (47.8 kHz)
[ 36.669] (II) RADEON(0): Modeline "800x600"x60.0 38.31 800 832 912 1024 600 603 607 624 -hsync +vsync (37.4 kHz)
[ 36.669] (II) RADEON(0): Modeline "848x480"x59.9 31.65 848 872 952 1056 480 483 493 500 -hsync +vsync (30.0 kHz)
[ 36.669] (II) RADEON(0): Modeline "720x480"x59.9 26.85 720 744 808 896 480 483 493 500 -hsync +vsync (30.0 kHz)
[ 36.669] (II) RADEON(0): Modeline "640x480"x59.9 23.98 640 664 720 800 480 483 487 500 -hsync +vsync (30.0 kHz)
[ 36.670] (II) RADEON(0): EDID for output HDMI-0
[ 36.683] (II) RADEON(0): EDID for output VGA-0
[ 36.683] (II) RADEON(0): Output LVDS connected
[ 36.683] (II) RADEON(0): Output HDMI-0 disconnected
[ 36.683] (II) RADEON(0): Output VGA-0 disconnected
[ 36.683] (II) RADEON(0): Using exact sizes for initial modes
[ 36.683] (II) RADEON(0): Output LVDS using initial mode 1366x768 +0+0
[ 36.683] (II) RADEON(0): mem size init: gart size :3fdde000 vram size: s:40000000 visible:f87d000
[ 36.683] (==) RADEON(0): DPI set to (96, 96)
[ 36.683] (==) RADEON(0): Using gamma correction (1.0, 1.0, 1.0)
[ 36.683] (II) Loading sub module "ramdac"
[ 36.683] (II) LoadModule: "ramdac"
[ 36.683] (II) Module "ramdac" already built-in
[ 36.683] (II) UnloadModule: "modesetting"
[ 36.683] (II) Unloading modesetting
[ 36.684] (II) RADEON(0): [DRI2] Setup complete
[ 36.684] (II) RADEON(0): [DRI2] DRI driver: r600
[ 36.684] (II) RADEON(0): [DRI2] VDPAU driver: r600
[ 36.684] (II) RADEON(0): Front buffer size: 4224K
[ 36.684] (II) RADEON(0): VRAM usage limit set to 225118K
[ 36.687] (II) RADEON(0): SYNC extension fences enabled
[ 36.687] (II) RADEON(0): Present extension enabled
[ 36.688] (==) RADEON(0): DRI3 enabled
[ 36.688] (==) RADEON(0): Backing store enabled
[ 36.688] (II) RADEON(0): Direct rendering enabled
[ 36.810] (II) RADEON(0): Use GLAMOR acceleration.
[ 36.810] (II) RADEON(0): Acceleration enabled
[ 36.810] (==) RADEON(0): DPMS enabled
[ 36.810] (==) RADEON(0): Silken mouse enabled
[ 36.810] (II) RADEON(0): Set up textured video (glamor)
[ 36.810] (II) RADEON(0): [XvMC] Associated with GLAMOR Textured Video.
[ 36.810] (II) RADEON(0): [XvMC] Extension initialized.
[ 36.830] (II) Initializing extension Generic Event Extension
[ 36.830] (II) Initializing extension SHAPE
[ 36.830] (II) Initializing extension MIT-SHM
[ 36.830] (II) Initializing extension XInputExtension
[ 36.831] (II) Initializing extension XTEST
[ 36.831] (II) Initializing extension BIG-REQUESTS
[ 36.831] (II) Initializing extension SYNC
[ 36.832] (II) Initializing extension XKEYBOARD
[ 36.832] (II) Initializing extension XC-MISC
[ 36.832] (II) Initializing extension SECURITY
[ 36.832] (II) Initializing extension XFIXES
[ 36.833] (II) Initializing extension RENDER
[ 36.833] (II) Initializing extension RANDR
[ 36.833] (II) Initializing extension COMPOSITE
[ 36.834] (II) Initializing extension DAMAGE
[ 36.834] (II) Initializing extension MIT-SCREEN-SAVER
[ 36.834] (II) Initializing extension DOUBLE-BUFFER
[ 36.834] (II) Initializing extension RECORD
[ 36.835] (II) Initializing extension DPMS
[ 36.835] (II) Initializing extension Present
[ 36.835] (II) Initializing extension DRI3
[ 36.835] (II) Initializing extension X-Resource
[ 36.836] (II) Initializing extension XVideo
[ 36.836] (II) Initializing extension XVideo-MotionCompensation
[ 36.836] (II) Initializing extension GLX
[ 36.850] (II) AIGLX: Loaded and initialized r600
[ 36.850] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 36.850] (II) Initializing extension XFree86-VidModeExtension
[ 36.850] (II) Initializing extension XFree86-DGA
[ 36.850] (II) Initializing extension XFree86-DRI
[ 36.850] (II) Initializing extension DRI2
[ 36.851] (II) RADEON(0): Setting screen physical size to 361 x 203
[ 37.048] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 37.048] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 37.048] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 37.048] (**) Power Button: Applying InputClass "system-keyboard"
[ 37.048] (II) LoadModule: "libinput"
[ 37.049] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 37.058] (II) Module libinput: vendor="X.Org Foundation"
[ 37.058] compiled for 1.21.1, module version = 1.2.0
[ 37.058] Module class: X.Org XInput Driver
[ 37.058] ABI class: X.Org XInput driver, version 24.4
[ 37.058] (II) Using input driver 'libinput' for 'Power Button'
[ 37.058] (**) Power Button: always reports core events
[ 37.058] (**) Option "Device" "/dev/input/event3"
[ 37.059] (**) Option "_source" "server/udev"
[ 37.078] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 37.078] (II) event3 - Power Button: device is a keyboard
[ 37.079] (II) event3 - Power Button: device removed
[ 37.090] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 37.090] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 37.090] (**) Option "xkb_model" "pc105+inet"
[ 37.090] (**) Option "xkb_layout" "us"
[ 37.090] (WW) Option "xkb_variant" requires a string value
[ 37.090] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.149] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 37.150] (II) event3 - Power Button: device is a keyboard
[ 37.151] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[ 37.151] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 37.151] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 37.151] (**) Video Bus: Applying InputClass "system-keyboard"
[ 37.151] (II) Using input driver 'libinput' for 'Video Bus'
[ 37.151] (**) Video Bus: always reports core events
[ 37.151] (**) Option "Device" "/dev/input/event4"
[ 37.151] (**) Option "_source" "server/udev"
[ 37.153] (II) event4 - Video Bus: is tagged by udev as: Keyboard
[ 37.153] (II) event4 - Video Bus: device is a keyboard
[ 37.154] (II) event4 - Video Bus: device removed
[ 37.197] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:42/LNXVIDEO:00/input/input4/event4"
[ 37.197] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 37.197] (**) Option "xkb_model" "pc105+inet"
[ 37.197] (**) Option "xkb_layout" "us"
[ 37.198] (WW) Option "xkb_variant" requires a string value
[ 37.198] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.202] (II) event4 - Video Bus: is tagged by udev as: Keyboard
[ 37.202] (II) event4 - Video Bus: device is a keyboard
[ 37.205] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 37.205] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 37.205] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 37.205] (**) Power Button: Applying InputClass "system-keyboard"
[ 37.205] (II) Using input driver 'libinput' for 'Power Button'
[ 37.205] (**) Power Button: always reports core events
[ 37.205] (**) Option "Device" "/dev/input/event0"
[ 37.205] (**) Option "_source" "server/udev"
[ 37.208] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 37.208] (II) event0 - Power Button: device is a keyboard
[ 37.209] (II) event0 - Power Button: device removed
[ 37.226] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 37.226] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 37.226] (**) Option "xkb_model" "pc105+inet"
[ 37.226] (**) Option "xkb_layout" "us"
[ 37.226] (WW) Option "xkb_variant" requires a string value
[ 37.226] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.230] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 37.231] (II) event0 - Power Button: device is a keyboard
[ 37.233] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 37.233] (II) No input driver specified, ignoring this device.
[ 37.233] (II) This device may have been added with another device file.
[ 37.235] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 37.235] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 37.235] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 37.235] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 37.235] (II) Using input driver 'libinput' for 'Sleep Button'
[ 37.235] (**) Sleep Button: always reports core events
[ 37.235] (**) Option "Device" "/dev/input/event2"
[ 37.235] (**) Option "_source" "server/udev"
[ 37.238] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 37.238] (II) event2 - Sleep Button: device is a keyboard
[ 37.239] (II) event2 - Sleep Button: device removed
[ 37.253] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[ 37.253] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 37.253] (**) Option "xkb_model" "pc105+inet"
[ 37.253] (**) Option "xkb_layout" "us"
[ 37.253] (WW) Option "xkb_variant" requires a string value
[ 37.253] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.257] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 37.257] (II) event2 - Sleep Button: device is a keyboard
[ 37.261] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event8)
[ 37.261] (II) No input driver specified, ignoring this device.
[ 37.261] (II) This device may have been added with another device file.
[ 37.262] (II) config/udev: Adding input device HDA ATI SB Mic (/dev/input/event9)
[ 37.262] (II) No input driver specified, ignoring this device.
[ 37.262] (II) This device may have been added with another device file.
[ 37.263] (II) config/udev: Adding input device HDA ATI SB Headphone (/dev/input/event10)
[ 37.263] (II) No input driver specified, ignoring this device.
[ 37.264] (II) This device may have been added with another device file.
[ 37.266] (II) config/udev: Adding input device USB 2.0 UVC VGA WebCam: USB2.0 (/dev/input/event12)
[ 37.266] (**) USB 2.0 UVC VGA WebCam: USB2.0 : Applying InputClass "evdev keyboard catchall"
[ 37.266] (**) USB 2.0 UVC VGA WebCam: USB2.0 : Applying InputClass "libinput keyboard catchall"
[ 37.266] (**) USB 2.0 UVC VGA WebCam: USB2.0 : Applying InputClass "system-keyboard"
[ 37.266] (II) Using input driver 'libinput' for 'USB 2.0 UVC VGA WebCam: USB2.0 '
[ 37.266] (**) USB 2.0 UVC VGA WebCam: USB2.0 : always reports core events
[ 37.266] (**) Option "Device" "/dev/input/event12"
[ 37.266] (**) Option "_source" "server/udev"
[ 37.270] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : is tagged by udev as: Keyboard
[ 37.271] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : device is a keyboard
[ 37.271] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : device removed
[ 37.306] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:16.2/usb3/3-3/3-3:1.0/input/input19/event12"
[ 37.306] (II) XINPUT: Adding extended input device "USB 2.0 UVC VGA WebCam: USB2.0 " (type: KEYBOARD, id 10)
[ 37.306] (**) Option "xkb_model" "pc105+inet"
[ 37.306] (**) Option "xkb_layout" "us"
[ 37.306] (WW) Option "xkb_variant" requires a string value
[ 37.306] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.311] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : is tagged by udev as: Keyboard
[ 37.312] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : device is a keyboard
[ 37.314] (II) config/udev: Adding input device Asus Laptop extra buttons (/dev/input/event6)
[ 37.314] (**) Asus Laptop extra buttons: Applying InputClass "evdev keyboard catchall"
[ 37.314] (**) Asus Laptop extra buttons: Applying InputClass "libinput keyboard catchall"
[ 37.314] (**) Asus Laptop extra buttons: Applying InputClass "system-keyboard"
[ 37.314] (II) Using input driver 'libinput' for 'Asus Laptop extra buttons'
[ 37.314] (**) Asus Laptop extra buttons: always reports core events
[ 37.314] (**) Option "Device" "/dev/input/event6"
[ 37.314] (**) Option "_source" "server/udev"
[ 37.317] (II) event6 - Asus Laptop extra buttons: is tagged by udev as: Keyboard
[ 37.317] (II) event6 - Asus Laptop extra buttons: device is a keyboard
[ 37.318] (II) event6 - Asus Laptop extra buttons: device removed
[ 37.340] (**) Option "config_info" "udev:/sys/devices/platform/asus_laptop/input/input10/event6"
[ 37.340] (II) XINPUT: Adding extended input device "Asus Laptop extra buttons" (type: KEYBOARD, id 11)
[ 37.340] (**) Option "xkb_model" "pc105+inet"
[ 37.340] (**) Option "xkb_layout" "us"
[ 37.340] (WW) Option "xkb_variant" requires a string value
[ 37.340] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.343] (II) event6 - Asus Laptop extra buttons: is tagged by udev as: Keyboard
[ 37.343] (II) event6 - Asus Laptop extra buttons: device is a keyboard
[ 37.346] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event5)
[ 37.346] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 37.346] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 37.346] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 37.346] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 37.346] (**) AT Translated Set 2 keyboard: always reports core events
[ 37.346] (**) Option "Device" "/dev/input/event5"
[ 37.346] (**) Option "_source" "server/udev"
[ 37.349] (II) event5 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 37.350] (II) event5 - AT Translated Set 2 keyboard: device is a keyboard
[ 37.353] (II) event5 - AT Translated Set 2 keyboard: device removed
[ 37.370] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input5/event5"
[ 37.370] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[ 37.370] (**) Option "xkb_model" "pc105+inet"
[ 37.370] (**) Option "xkb_layout" "us"
[ 37.370] (WW) Option "xkb_variant" requires a string value
[ 37.370] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.374] (II) event5 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 37.374] (II) event5 - AT Translated Set 2 keyboard: device is a keyboard
[ 37.379] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event11)
[ 37.379] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[ 37.379] (**) ETPS/2 Elantech Touchpad: Applying InputClass "libinput touchpad catchall"
[ 37.380] (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
[ 37.380] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 37.380] (**) Option "Device" "/dev/input/event11"
[ 37.380] (**) Option "_source" "server/udev"
[ 37.383] (II) event11 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 37.388] (II) event11 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 37.388] (II) event11 - ETPS/2 Elantech Touchpad: device removed
[ 37.448] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio4/input/input15/event11"
[ 37.448] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 13)
[ 37.451] (**) Option "AccelerationScheme" "none"
[ 37.451] (**) ETPS/2 Elantech Touchpad: (accel) selected scheme none/0
[ 37.451] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[ 37.451] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[ 37.454] (II) event11 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 37.459] (II) event11 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 37.462] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse0)
[ 37.462] (II) No input driver specified, ignoring this device.
[ 37.462] (II) This device may have been added with another device file.
[ 37.463] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 37.463] (II) No input driver specified, ignoring this device.
[ 37.463] (II) This device may have been added with another device file.
[ 4569.124] (II) event3 - Power Button: device removed
[ 4569.156] (II) event4 - Video Bus: device removed
[ 4569.190] (II) event0 - Power Button: device removed
[ 4569.214] (II) event2 - Sleep Button: device removed
[ 4569.230] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : device removed
[ 4569.270] (II) event6 - Asus Laptop extra buttons: device removed
[ 4569.284] (II) event5 - AT Translated Set 2 keyboard: device removed
[ 4569.297] (II) event11 - ETPS/2 Elantech Touchpad: device removed
[ 4569.330] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 4585.952] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 4586.010] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 4586.011] (II) event3 - Power Button: device is a keyboard
[ 4586.014] (II) event4 - Video Bus: is tagged by udev as: Keyboard
[ 4586.015] (II) event4 - Video Bus: device is a keyboard
[ 4586.020] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 4586.020] (II) event0 - Power Button: device is a keyboard
[ 4586.024] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 4586.024] (II) event2 - Sleep Button: device is a keyboard
[ 4586.029] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : is tagged by udev as: Keyboard
[ 4586.029] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : device is a keyboard
[ 4586.033] (II) event6 - Asus Laptop extra buttons: is tagged by udev as: Keyboard
[ 4586.033] (II) event6 - Asus Laptop extra buttons: device is a keyboard
[ 4586.037] (II) event5 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 4586.038] (II) event5 - AT Translated Set 2 keyboard: device is a keyboard
[ 4586.044] (II) event11 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 4586.047] (II) event11 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 8993.531] (II) event3 - Power Button: device removed
[ 8993.566] (II) event4 - Video Bus: device removed
[ 8993.613] (II) event0 - Power Button: device removed
[ 8993.626] (II) event2 - Sleep Button: device removed
[ 8993.646] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : device removed
[ 8993.703] (II) event6 - Asus Laptop extra buttons: device removed
[ 8993.730] (II) event5 - AT Translated Set 2 keyboard: device removed
[ 8993.751] (II) event11 - ETPS/2 Elantech Touchpad: device removed
[ 8993.810] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 9015.515] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 9015.574] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 9015.574] (II) event3 - Power Button: device is a keyboard
[ 9015.577] (II) event4 - Video Bus: is tagged by udev as: Keyboard
[ 9015.577] (II) event4 - Video Bus: device is a keyboard
[ 9015.580] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 9015.580] (II) event0 - Power Button: device is a keyboard
[ 9015.584] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 9015.584] (II) event2 - Sleep Button: device is a keyboard
[ 9015.588] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : is tagged by udev as: Keyboard
[ 9015.589] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : device is a keyboard
[ 9015.592] (II) event6 - Asus Laptop extra buttons: is tagged by udev as: Keyboard
[ 9015.592] (II) event6 - Asus Laptop extra buttons: device is a keyboard
[ 9015.596] (II) event5 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 9015.596] (II) event5 - AT Translated Set 2 keyboard: device is a keyboard
[ 9015.600] (II) event11 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 9015.603] (II) event11 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 10359.190] (II) event3 - Power Button: device removed
[ 10359.206] (II) event4 - Video Bus: device removed
[ 10359.242] (II) event0 - Power Button: device removed
[ 10359.260] (II) event2 - Sleep Button: device removed
[ 10359.270] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : device removed
[ 10359.317] (II) event6 - Asus Laptop extra buttons: device removed
[ 10359.334] (II) event5 - AT Translated Set 2 keyboard: device removed
[ 10359.357] (II) event11 - ETPS/2 Elantech Touchpad: device removed
[ 10359.406] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 10414.965] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 10415.034] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 10415.034] (II) event3 - Power Button: device is a keyboard
[ 10415.037] (II) event4 - Video Bus: is tagged by udev as: Keyboard
[ 10415.038] (II) event4 - Video Bus: device is a keyboard
[ 10415.041] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 10415.041] (II) event0 - Power Button: device is a keyboard
[ 10415.044] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 10415.044] (II) event2 - Sleep Button: device is a keyboard
[ 10415.048] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : is tagged by udev as: Keyboard
[ 10415.048] (II) event12 - USB 2.0 UVC VGA WebCam: USB2.0 : device is a keyboard
[ 10415.051] (II) event6 - Asus Laptop extra buttons: is tagged by udev as: Keyboard
[ 10415.051] (II) event6 - Asus Laptop extra buttons: device is a keyboard
[ 10415.054] (II) event5 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 10415.055] (II) event5 - AT Translated Set 2 keyboard: device is a keyboard
[ 10415.059] (II) event11 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 10415.062] (II) event11 - ETPS/2 Elantech Touchpad: device is a touchpad
I am new on linux and this is really big headache for me.
I have a hard time following. Is this about the liveUSB (as suggested by the title) or the installed Manjaro?
Yes it is about live usb. If you find solution, Please let me know.
And if live usb boots into system installation is possible but then installed system does not boot up. Only grub prompt opens. When i searched there was not some grub files installed elsewhere.
It may not be possible to find error logs for previous boot failures since the liveUSB doesnât have persistence by default: [root tip] [How To] Multi ISO USB with storage partition
Have you tried using a Minimal LTS ISO (available from the same download page) ? I believe it ships with the 5.10 LTS kernel.
Do you launch the liveUSB with the free or non-free GPU driver?
FYI, those commands are for diagnosing issues on an installed Manjaro, which is then not the present case.
I am going to try it
I used both, same thing happens
As i see if somehow live usb loads, then restart is not problem. But after cold start there is a chance that, problem happens again.
When was the last time you dusted your laptop?
Assuming that dusted means cleaning. Laptop was using actively by family. Then power jack damaged and repair service changed it. After power jack died and i changed second times.
That doesnât tell whenâŚ
I didnât clean it when i opened it, but when Ubuntu canât load, windows worked fine. Even stock linux based asus system worked fine.
Off-topic but i was wondering what you meant by this, so i searched a bit.
Is it Asus Express Gate (actually a rebranded Splashtop OS) ?
Yes, i didnât remember exact name. Yes it is Asus Express Gate
update: I removed the quiet from boot option menu and nothing happens. Only black screen appeares. I think even Manjaro rom does not start loading.
Can someone provide information, where can i find what grub options do. I canât find reliable source. Everywhere is only one or two basic commands.
Please look into the arch wiki to grub
Thank you. No i donât touch anything on black screen, grub menu apppears automatically, so i donât need to click esc key.
And i tested with acpi=off and it loaded system, but mouse and keyboard does not work. So if this works and i install it on hdd now. Does internal keyboard and mouse also not work?
acpi=off
This parameter is too restrictiveâŚ
In a similar case i had sucess with:
acpi=noirq
or
noapic
or
noapic acpi_enforce_resources=lax
BIOS checked: secure boot disabled?
