the slow response is not isolated. everything responses slow.
i like the distro but i need to figure out how to get it working properly.
My laptop is slow, but my newer desktop is fast. My point? Read how to ask for help, Effectively using the forum to get support
you might want to read how to response and point to where that help is.
your response is useless and only shows negativity.
it is clear you do nothing to help.
Without specific information from you, such as actual error messages and related logs, for example, there is not much to be offered.
Please take some time to familiarize yourself with Forum requirements; in particular, the many ways to use the forum effectively.
The following links will help you achieve that.
And last, but not least, the Stable Update Announcements, which you should check frequently for important update related information.
I hope this helps. Cheers.
thank you!
Here are a few more that will likely be useful as you acquaint yourself with Manjaro (quickly cherry-picked):
Cheers.
Thanks your posts have helped a lot!
is the gui safe from these dangers?
An ambiguous question.
As with most things, it’s only as safe as you make it.
Pacman (No, not the game) is worth time spent. It’s the more traditional package manager for Arch-based distributions, and the one we all turn to when Pamac (gui) fails to deliver.
Think of it in terms of ‘where would I be if I didn’t learn rpm?’
You link maintenance guides and ask whether the GUI is safe from those dangers?
I am not sure what that means.
But … we are on post number 10 and there still fails to be any meaningful system information.
You might want to add that in order to get decent help.
Usually a good starting point is
inxi -Fazy
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
