Manjaro fails to boot and forces me into uefi
Hello there,
I have once again come to ask for some help as a relative manjaro newbie (getting better) I am having a boot issue where suddenly after I launched Minecraft through the lunar client it became suddenly very low fps and the curser was delayed severely. I hard restarted as none of my clicks worked. When I rebooted nothing loaded until 5 minutes later an American Megalegends thing (I can’t remember the name) said that I need to go into UEFI. I tried just loading nothing happened so I then decided to boot into my windows partition on my hard drive it works and so I came here after looking at some solutions but none worked because I had no terminal available. So here I am any info or things, pictures,etc any needs I will happily provide.
Thanks again,
Vexed
Are you even able to see the Grub boot menu entries?
How are you booting into your Windows system? By selecting “Windows” in the Grub menu, or bypassing Grub entirely and using your BIOS’s built-in boot override?
Here are a few guides to help you providing us with information.
I don’t have a grub menu to load from because I was going to set it up today so I bypassed it and used the UEFI bios directly.
I unfortunately couldn’t access the terminal or anything but somehow I accidentally left my pc running while I went out and the issue resolved itself with an error about invalid sector size after a long boot time. I will send the logs from my pc now.
Here are the kernel ring buffer logs and if you need any others please let me know.
Thanks!
Logs
[ 0.005318] node 0: [mem 0x000000000a20c000-0x00000000d8cfbfff]
[ 0.005319] node 0: [mem 0x00000000da553000-0x00000000dcffffff]
[ 0.005320] node 0: [mem 0x0000000100000000-0x000000041f37ffff]
[ 0.005322] Initmem setup node 0 [mem 0x0000000000001000-0x000000041f37ffff]
[ 0.005325] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.005326] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.005343] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.005495] On node 0, zone DMA32: 766 pages in unavailable ranges
[ 0.011217] On node 0, zone DMA32: 12 pages in unavailable ranges
[ 0.011366] On node 0, zone DMA32: 6231 pages in unavailable ranges
[ 0.036967] On node 0, zone Normal: 12288 pages in unavailable ranges
[ 0.037004] On node 0, zone Normal: 3200 pages in unavailable ranges
[ 0.037672] ACPI: PM-Timer IO Port: 0x808
[ 0.037679] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.037693] IOAPIC[0]: apic_id 7, version 33, address 0xfec00000, GSI 0-23
[ 0.037699] IOAPIC[1]: apic_id 8, version 33, address 0xfec01000, GSI 24-55
[ 0.037700] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.037702] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.037705] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.037706] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.037714] e820: update [mem 0xd458c000-0xd467ffff] usable ==> reserved
[ 0.037723] smpboot: Allowing 32 CPUs, 26 hotplug CPUs
[ 0.037743] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.037745] PM: hibernation: Registered nosave memory: [mem 0x00090000-0x00090fff]
[ 0.037746] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.037748] PM: hibernation: Registered nosave memory: [mem 0x09d02000-0x09ffffff]
[ 0.037749] PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a20bfff]
[ 0.037751] PM: hibernation: Registered nosave memory: [mem 0xd458c000-0xd467ffff]
[ 0.037752] PM: hibernation: Registered nosave memory: [mem 0xd7735000-0xd7735fff]
[ 0.037753] PM: hibernation: Registered nosave memory: [mem 0xd8cfc000-0xd8e45fff]
[ 0.037754] PM: hibernation: Registered nosave memory: [mem 0xd8e46000-0xd8fcefff]
[ 0.037754] PM: hibernation: Registered nosave memory: [mem 0xd8fcf000-0xd90fbfff]
[ 0.037755] PM: hibernation: Registered nosave memory: [mem 0xd90fc000-0xda4b7fff]
[ 0.037756] PM: hibernation: Registered nosave memory: [mem 0xda4b8000-0xda552fff]
[ 0.037757] PM: hibernation: Registered nosave memory: [mem 0xdd000000-0xdfffffff]
[ 0.037758] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xf7ffffff]
[ 0.037758] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.037759] PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfcffffff]
[ 0.037759] PM: hibernation: Registered nosave memory: [mem 0xfd000000-0xffffffff]
[ 0.037760] [mem 0xe0000000-0xf7ffffff] available for PCI devices
[ 0.037762] Booting paravirtualized kernel on bare hardware
[ 0.037764] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.041623] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:32 nr_node_ids:1
[ 0.042921] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u262144
[ 0.042928] pcpu-alloc: s212992 r8192 d28672 u262144 alloc=1*2097152
[ 0.042929] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.042936] pcpu-alloc: [0] 16 17 18 19 20 21 22 23 [0] 24 25 26 27 28 29 30 31
[ 0.042962] Built 1 zonelists, mobility grouping on. Total pages: 4106366
[ 0.042964] Policy zone: Normal
[ 0.042964] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=6b787817-dc22-4902-9fb2-746e1a2ab639 rw quiet cryptdevice=UUID=17195cdd-c5d7-4fef-a9c5-bfc24fa07c02:luks-17195cdd-c5d7-4fef-a9c5-bfc24fa07c02 root=/dev/mapper/luks-17195cdd-c5d7-4fef-a9c5-bfc24fa07c02 apparmor=1 security=apparmor udev.log_priority=3
[ 0.043035] Unknown kernel command line parameters “BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 cryptdevice=UUID=17195cdd-c5d7-4fef-a9c5-bfc24fa07c02:luks-17195cdd-c5d7-4fef-a9c5-bfc24fa07c02”, will be passed to user space.
[ 0.043036] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.043037] printk: log_buf_len total cpu_extra contributions: 126976 bytes
[ 0.043038] printk: log_buf_len min size: 131072 bytes
[ 0.043216] printk: log_buf_len: 262144 bytes
[ 0.043217] printk: early log buf free: 118488(90%)
[ 0.045140] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.046176] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.046526] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.097445] Memory: 16139904K/16686836K available (14344K kernel code, 2091K rwdata, 10892K rodata, 1864K init, 3844K bss, 546672K reserved, 0K cma-reserved)
[ 0.097453] random: get_random_u64 called from __kmem_cache_create+0x2a/0x500 with crng_init=0
[ 0.097592] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[ 0.097605] ftrace: allocating 44423 entries in 174 pages
[ 0.108614] ftrace: allocated 174 pages with 5 groups
[ 0.108751] rcu: Preemptible hierarchical RCU implementation.
[ 0.108751] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.108752] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=32.
[ 0.108753] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.108753] Trampoline variant of Tasks RCU enabled.
[ 0.108754] Rude variant of Tasks RCU enabled.
[ 0.108754] Tracing variant of Tasks RCU enabled.
[ 0.108755] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.108755] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[ 0.111455] NR_IRQS: 20736, nr_irqs: 1224, preallocated irqs: 16
[ 0.111697] kfence: initialized - using 2097152 bytes for 255 objects at 0x(ptrval)-0x(ptrval)
[ 0.111823] Console: colour dummy device 80x25
[ 0.111833] printk: console [tty0] enabled
[ 0.111856] ACPI: Core revision 20210730
[ 0.111971] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.111990] APIC: Switch to symmetric I/O mode setup
[ 0.113014] Switched APIC routing to physical flat.
[ 0.113748] …TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.128658] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x71de2dc26fc, max_idle_ns: 881590488289 ns
[ 0.128662] Calibrating delay loop (skipped), value calculated using timer frequency… 7902.73 BogoMIPS (lpj=13165973)
[ 0.128664] pid_max: default: 32768 minimum: 301
[ 0.131345] LSM: Security Framework initializing
[ 0.131350] landlock: Up and running.
[ 0.131351] Yama: becoming mindful.
[ 0.131364] AppArmor: AppArmor initialized
[ 0.131402] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.131425] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.131623] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.131675] LVT offset 1 assigned for vector 0xf9
[ 0.131787] LVT offset 2 assigned for vector 0xf4
[ 0.131818] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
[ 0.131819] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[ 0.131822] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.131824] Spectre V2 : Mitigation: Retpolines
[ 0.131824] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.131826] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.131827] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.133882] Freeing SMP alternatives memory: 36K
[ 0.243785] smpboot: CPU0: AMD Ryzen 5 3500X 6-Core Processor (family: 0x17, model: 0x71, stepping: 0x0)
[ 0.243896] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.243899] … version: 0
[ 0.243900] … bit width: 48
[ 0.243900] … generic registers: 6
[ 0.243901] … value mask: 0000ffffffffffff
[ 0.243902] … max period: 00007fffffffffff
[ 0.243902] … fixed-purpose events: 0
[ 0.243902] … event mask: 000000000000003f
[ 0.243945] rcu: Hierarchical SRCU implementation.
[ 0.244266] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.244449] smp: Bringing up secondary CPUs …
[ 0.244526] x86: Booting SMP configuration:
[ 0.244527] … node #0, CPUs: #1 #2 #3 #4 #5
[ 0.254206] smp: Brought up 1 node, 6 CPUs
[ 0.254206] smpboot: Max logical packages: 6
[ 0.254206] smpboot: Total of 6 processors activated (47416.39 BogoMIPS)
[ 0.255531] devtmpfs: initialized
[ 0.255531] x86/mm: Memory block size: 128MB
[ 0.255945] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20bfff] (49152 bytes)
[ 0.255945] ACPI: PM: Registering ACPI NVS region [mem 0xd8fcf000-0xd90fbfff] (1232896 bytes)
[ 0.255945] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.255945] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.255945] pinctrl core: initialized pinctrl subsystem
[ 0.255945] PM: RTC time: 20:53:28, date: 2022-06-11
[ 0.255945] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.255945] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.256047] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.256193] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.256199] audit: initializing netlink subsys (disabled)
[ 0.256203] audit: type=2000 audit(1654980808.143:1): state=initialized audit_enabled=0 res=1
[ 0.256203] thermal_sys: Registered thermal governor ‘fair_share’
[ 0.256203] thermal_sys: Registered thermal governor ‘bang_bang’
[ 0.256203] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.256203] thermal_sys: Registered thermal governor ‘user_space’
[ 0.256203] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.256203] cpuidle: using governor ladder
[ 0.256203] cpuidle: using governor menu
[ 0.256203] Detected 1 PCC Subspaces
[ 0.256203] Registering PCC driver as Mailbox controller
[ 0.256203] HugeTLB: can free 4094 vmemmap pages for hugepages-1048576kB
[ 0.256203] ACPI: bus type PCI registered
[ 0.256203] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.256203] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.256203] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.256203] PCI: Using configuration type 1 for base access
[ 0.256332] Kprobes globally optimized
[ 0.256335] HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
[ 0.256335] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.256335] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.258721] ACPI: Added _OSI(Module Device)
[ 0.258722] ACPI: Added _OSI(Processor Device)
[ 0.258722] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.258723] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.258725] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.258725] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.258726] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.269866] ACPI: 7 ACPI AML tables successfully acquired and loaded
[ 0.270975] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.273607] ACPI: Interpreter enabled
[ 0.273619] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.273620] ACPI: Using IOAPIC for interrupt routing
[ 0.273886] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
[ 0.274118] ACPI: Enabled 2 GPEs in block 00 to 1F
[ 0.280675] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.280680] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.280836] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME LTR DPC]
[ 0.280984] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[ 0.280992] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.281285] PCI host bridge to bus 0000:00
[ 0.281286] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.281287] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.281288] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.281289] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.281290] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.281291] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.281292] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfec02fff window]
[ 0.281293] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[ 0.281294] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.281352] pci 0000:00:00.0: [1022:1480] type 00 class 0x060000
[ 0.281476] pci 0000:00:00.2: [1022:1481] type 00 class 0x080600
[ 0.281579] pci 0000:00:01.0: [1022:1482] type 00 class 0x060000
[ 0.281706] pci 0000:00:01.1: [1022:1483] type 01 class 0x060400
[ 0.281732] pci 0000:00:01.1: enabling Extended Tags
[ 0.281777] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 0.281970] pci 0000:00:01.2: [1022:1483] type 01 class 0x060400
[ 0.281998] pci 0000:00:01.2: enabling Extended Tags
[ 0.282043] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.282151] pci 0000:00:02.0: [1022:1482] type 00 class 0x060000
[ 0.282251] pci 0000:00:03.0: [1022:1482] type 00 class 0x060000
[ 0.282375] pci 0000:00:03.1: [1022:1483] type 01 class 0x060400
[ 0.282454] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[ 0.282620] pci 0000:00:04.0: [1022:1482] type 00 class 0x060000
[ 0.282720] pci 0000:00:05.0: [1022:1482] type 00 class 0x060000
[ 0.282819] pci 0000:00:07.0: [1022:1482] type 00 class 0x060000
[ 0.282942] pci 0000:00:07.1: [1022:1484] type 01 class 0x060400
[ 0.282966] pci 0000:00:07.1: enabling Extended Tags
[ 0.283005] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[ 0.283108] pci 0000:00:08.0: [1022:1482] type 00 class 0x060000
[ 0.283231] pci 0000:00:08.1: [1022:1484] type 01 class 0x060400
[ 0.283256] pci 0000:00:08.1: enabling Extended Tags
[ 0.283299] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.283427] pci 0000:00:08.2: [1022:1484] type 01 class 0x060400
[ 0.283453] pci 0000:00:08.2: enabling Extended Tags
[ 0.283495] pci 0000:00:08.2: PME# supported from D0 D3hot D3cold
[ 0.283625] pci 0000:00:08.3: [1022:1484] type 01 class 0x060400
[ 0.283650] pci 0000:00:08.3: enabling Extended Tags
[ 0.283693] pci 0000:00:08.3: PME# supported from D0 D3hot D3cold
[ 0.283831] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.283979] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.284111] pci 0000:00:18.0: [1022:1440] type 00 class 0x060000
[ 0.284184] pci 0000:00:18.1: [1022:1441] type 00 class 0x060000
[ 0.284255] pci 0000:00:18.2: [1022:1442] type 00 class 0x060000
[ 0.284326] pci 0000:00:18.3: [1022:1443] type 00 class 0x060000
[ 0.284397] pci 0000:00:18.4: [1022:1444] type 00 class 0x060000
[ 0.284469] pci 0000:00:18.5: [1022:1445] type 00 class 0x060000
[ 0.284539] pci 0000:00:18.6: [1022:1446] type 00 class 0x060000
[ 0.284610] pci 0000:00:18.7: [1022:1447] type 00 class 0x060000
[ 0.284711] pci 0000:01:00.0: [126f:2262] type 00 class 0x010802
[ 0.284729] pci 0000:01:00.0: reg 0x10: [mem 0xf7c00000-0xf7c03fff 64bit]
[ 0.284906] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.284910] pci 0000:00:01.1: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.284969] pci 0000:02:00.0: [1022:57ad] type 01 class 0x060400
[ 0.285025] pci 0000:02:00.0: enabling Extended Tags
[ 0.285108] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.285207] pci 0000:02:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 126.024 Gb/s with 16.0 GT/s PCIe x8 link)
[ 0.285263] pci 0000:00:01.2: PCI bridge to [bus 02-07]
[ 0.285266] pci 0000:00:01.2: bridge window [io 0xf000-0xffff]
[ 0.285269] pci 0000:00:01.2: bridge window [mem 0xf7200000-0xf76fffff]
[ 0.285589] pci 0000:03:05.0: [1022:57a3] type 01 class 0x060400
[ 0.285667] pci 0000:03:05.0: enabling Extended Tags
[ 0.285853] pci 0000:03:05.0: PME# supported from D0 D3hot D3cold
[ 0.286125] pci 0000:03:08.0: [1022:57a4] type 01 class 0x060400
[ 0.286195] pci 0000:03:08.0: enabling Extended Tags
[ 0.286354] pci 0000:03:08.0: PME# supported from D0 D3hot D3cold
[ 0.286576] pci 0000:03:09.0: [1022:57a4] type 01 class 0x060400
[ 0.286646] pci 0000:03:09.0: enabling Extended Tags
[ 0.286805] pci 0000:03:09.0: PME# supported from D0 D3hot D3cold
[ 0.287000] pci 0000:03:0a.0: [1022:57a4] type 01 class 0x060400
[ 0.287071] pci 0000:03:0a.0: enabling Extended Tags
[ 0.287229] pci 0000:03:0a.0: PME# supported from D0 D3hot D3cold
[ 0.287419] pci 0000:02:00.0: PCI bridge to [bus 03-07]
[ 0.287425] pci 0000:02:00.0: bridge window [io 0xf000-0xffff]
[ 0.287429] pci 0000:02:00.0: bridge window [mem 0xf7200000-0xf76fffff]
[ 0.287563] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000
[ 0.287591] pci 0000:04:00.0: reg 0x10: [io 0xf000-0xf0ff]
[ 0.287628] pci 0000:04:00.0: reg 0x18: [mem 0xf7604000-0xf7604fff 64bit]
[ 0.287651] pci 0000:04:00.0: reg 0x20: [mem 0xf7600000-0xf7603fff 64bit]
[ 0.287799] pci 0000:04:00.0: supports D1 D2
[ 0.287800] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.287979] pci 0000:03:05.0: PCI bridge to [bus 04]
[ 0.287985] pci 0000:03:05.0: bridge window [io 0xf000-0xffff]
[ 0.287989] pci 0000:03:05.0: bridge window [mem 0xf7600000-0xf76fffff]
[ 0.288117] pci 0000:05:00.0: [1022:1485] type 00 class 0x130000
[ 0.288184] pci 0000:05:00.0: enabling Extended Tags
[ 0.288345] pci 0000:05:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.288566] pci 0000:05:00.1: [1022:149c] type 00 class 0x0c0330
[ 0.288866] pci 0000:05:00.1: reg 0x10: [mem 0xf7300000-0xf73fffff 64bit]
[ 0.289703] pci 0000:05:00.1: enabling Extended Tags
[ 0.290202] pci 0000:05:00.1: PME# supported from D0 D3hot D3cold
[ 0.290629] pci 0000:05:00.3: [1022:149c] type 00 class 0x0c0330
[ 0.290654] pci 0000:05:00.3: reg 0x10: [mem 0xf7200000-0xf72fffff 64bit]
[ 0.290714] pci 0000:05:00.3: enabling Extended Tags
[ 0.290788] pci 0000:05:00.3: PME# supported from D0 D3hot D3cold
[ 0.290913] pci 0000:03:08.0: PCI bridge to [bus 05]
[ 0.290922] pci 0000:03:08.0: bridge window [mem 0xf7200000-0xf73fffff]
[ 0.291027] pci 0000:06:00.0: [1022:7901] type 00 class 0x010601
[ 0.291097] pci 0000:06:00.0: reg 0x24: [mem 0xf7500000-0xf75007ff]
[ 0.291117] pci 0000:06:00.0: enabling Extended Tags
[ 0.291215] pci 0000:06:00.0: PME# supported from D3hot D3cold
[ 0.291295] pci 0000:06:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.291341] pci 0000:03:09.0: PCI bridge to [bus 06]
[ 0.291350] pci 0000:03:09.0: bridge window [mem 0xf7500000-0xf75fffff]
[ 0.291454] pci 0000:07:00.0: [1022:7901] type 00 class 0x010601
[ 0.291524] pci 0000:07:00.0: reg 0x24: [mem 0xf7400000-0xf74007ff]
[ 0.291543] pci 0000:07:00.0: enabling Extended Tags
[ 0.291641] pci 0000:07:00.0: PME# supported from D3hot D3cold
[ 0.291722] pci 0000:07:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.291768] pci 0000:03:0a.0: PCI bridge to [bus 07]
[ 0.291776] pci 0000:03:0a.0: bridge window [mem 0xf7400000-0xf74fffff]
[ 0.291868] pci 0000:08:00.0: [10de:2188] type 00 class 0x030000
[ 0.291882] pci 0000:08:00.0: reg 0x10: [mem 0xf6000000-0xf6ffffff]
[ 0.291894] pci 0000:08:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.291907] pci 0000:08:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.291915] pci 0000:08:00.0: reg 0x24: [io 0xe000-0xe07f]
[ 0.291923] pci 0000:08:00.0: reg 0x30: [mem 0xf7000000-0xf707ffff pref]
[ 0.291942] pci 0000:08:00.0: BAR 1: assigned to efifb
[ 0.292001] pci 0000:08:00.0: PME# supported from D0 D3hot D3cold
[ 0.292081] pci 0000:08:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:03.1 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.292130] pci 0000:08:00.1: [10de:1aeb] type 00 class 0x040300
[ 0.292143] pci 0000:08:00.1: reg 0x10: [mem 0xf7080000-0xf7083fff]
[ 0.292271] pci 0000:08:00.2: [10de:1aec] type 00 class 0x0c0330
[ 0.292289] pci 0000:08:00.2: reg 0x10: [mem 0xf2000000-0xf203ffff 64bit pref]
[ 0.292309] pci 0000:08:00.2: reg 0x1c: [mem 0xf2040000-0xf204ffff 64bit pref]
[ 0.292370] pci 0000:08:00.2: PME# supported from D0 D3hot D3cold
[ 0.292425] pci 0000:08:00.3: [10de:1aed] type 00 class 0x0c8000
[ 0.292437] pci 0000:08:00.3: reg 0x10: [mem 0xf7084000-0xf7084fff]
[ 0.292515] pci 0000:08:00.3: PME# supported from D0 D3hot D3cold
[ 0.292594] pci 0000:00:03.1: PCI bridge to [bus 08]
[ 0.292597] pci 0000:00:03.1: bridge window [io 0xe000-0xefff]
[ 0.292599] pci 0000:00:03.1: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.292603] pci 0000:00:03.1: bridge window [mem 0xe0000000-0xf20fffff 64bit pref]
[ 0.292644] pci 0000:09:00.0: [1022:148a] type 00 class 0x130000
[ 0.292673] pci 0000:09:00.0: enabling Extended Tags
[ 0.292783] pci 0000:00:07.1: PCI bridge to [bus 09]
[ 0.292842] pci 0000:0a:00.0: [1022:1485] type 00 class 0x130000
[ 0.292876] pci 0000:0a:00.0: enabling Extended Tags
[ 0.292996] pci 0000:0a:00.1: [1022:1486] type 00 class 0x108000
[ 0.293012] pci 0000:0a:00.1: reg 0x18: [mem 0xf7800000-0xf78fffff]
[ 0.293024] pci 0000:0a:00.1: reg 0x24: [mem 0xf7908000-0xf7909fff]
[ 0.293032] pci 0000:0a:00.1: enabling Extended Tags
[ 0.293142] pci 0000:0a:00.3: [1022:149c] type 00 class 0x0c0330
[ 0.293155] pci 0000:0a:00.3: reg 0x10: [mem 0xf7700000-0xf77fffff 64bit]
[ 0.293185] pci 0000:0a:00.3: enabling Extended Tags
[ 0.293231] pci 0000:0a:00.3: PME# supported from D0 D3hot D3cold
[ 0.293309] pci 0000:0a:00.4: [1022:1487] type 00 class 0x040300
[ 0.293317] pci 0000:0a:00.4: reg 0x10: [mem 0xf7900000-0xf7907fff]
[ 0.293344] pci 0000:0a:00.4: enabling Extended Tags
[ 0.293387] pci 0000:0a:00.4: PME# supported from D0 D3hot D3cold
[ 0.293464] pci 0000:00:08.1: PCI bridge to [bus 0a]
[ 0.293469] pci 0000:00:08.1: bridge window [mem 0xf7700000-0xf79fffff]
[ 0.293516] pci 0000:0b:00.0: [1022:7901] type 00 class 0x010601
[ 0.293551] pci 0000:0b:00.0: reg 0x24: [mem 0xf7b00000-0xf7b007ff]
[ 0.293561] pci 0000:0b:00.0: enabling Extended Tags
[ 0.293619] pci 0000:0b:00.0: PME# supported from D3hot D3cold
[ 0.293703] pci 0000:00:08.2: PCI bridge to [bus 0b]
[ 0.293707] pci 0000:00:08.2: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.293754] pci 0000:0c:00.0: [1022:7901] type 00 class 0x010601
[ 0.293789] pci 0000:0c:00.0: reg 0x24: [mem 0xf7a00000-0xf7a007ff]
[ 0.293800] pci 0000:0c:00.0: enabling Extended Tags
[ 0.293857] pci 0000:0c:00.0: PME# supported from D3hot D3cold
[ 0.293942] pci 0000:00:08.3: PCI bridge to [bus 0c]
[ 0.293946] pci 0000:00:08.3: bridge window [mem 0xf7a00000-0xf7afffff]
[ 0.294300] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.294344] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.294381] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.294427] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.294468] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.294503] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.294537] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.294571] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.294960] iommu: Default domain type: Translated
[ 0.294961] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.294968] pci 0000:08:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.294968] pci 0000:08:00.0: vgaarb: bridge control possible
[ 0.294968] pci 0000:08:00.0: vgaarb: setting as boot device
[ 0.294968] vgaarb: loaded
[ 0.294968] SCSI subsystem initialized
[ 0.294968] libata version 3.00 loaded.
[ 0.294968] ACPI: bus type USB registered
[ 0.294968] usbcore: registered new interface driver usbfs
[ 0.294968] usbcore: registered new interface driver hub
[ 0.294968] usbcore: registered new device driver usb
[ 0.294968] pps_core: LinuxPPS API ver. 1 registered
[ 0.294968] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.294968] PTP clock support registered
[ 0.294968] EDAC MC: Ver: 3.0.0
[ 0.294968] Registered efivars operations
[ 0.295427] NetLabel: Initializing
[ 0.295428] NetLabel: domain hash size = 128
[ 0.295428] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.295438] NetLabel: unlabeled traffic allowed by default
[ 0.295440] PCI: Using ACPI for IRQ routing
[ 0.297138] PCI: pci_cache_line_size set to 64 bytes
[ 0.297243] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 0.297244] e820: reserve RAM buffer [mem 0x09d02000-0x0bffffff]
[ 0.297245] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[ 0.297246] e820: reserve RAM buffer [mem 0xd458c000-0xd7ffffff]
[ 0.297247] e820: reserve RAM buffer [mem 0xd7735000-0xd7ffffff]
[ 0.297248] e820: reserve RAM buffer [mem 0xd8cfc000-0xdbffffff]
[ 0.297249] e820: reserve RAM buffer [mem 0xdd000000-0xdfffffff]
[ 0.297249] e820: reserve RAM buffer [mem 0x41f380000-0x41fffffff]
[ 0.297252] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.297252] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.298702] clocksource: Switched to clocksource tsc-early
[ 0.304585] VFS: Disk quotas dquot_6.6.0
[ 0.304599] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.304678] AppArmor: AppArmor Filesystem Enabled
[ 0.304695] pnp: PnP ACPI init
[ 0.304762] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.304829] system 00:01: [mem 0xfd000000-0xfd0fffff] has been reserved
[ 0.304971] system 00:03: [io 0x0290-0x029f] has been reserved
[ 0.304972] system 00:03: [io 0x0200-0x021f] has been reserved
[ 0.305177] pnp 00:04: [dma 0 disabled]
[ 0.305408] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.305409] system 00:05: [io 0x040b] has been reserved
[ 0.305410] system 00:05: [io 0x04d6] has been reserved
[ 0.305411] system 00:05: [io 0x0c00-0x0c01] has been reserved
[ 0.305412] system 00:05: [io 0x0c14] has been reserved
[ 0.305413] system 00:05: [io 0x0c50-0x0c51] has been reserved
[ 0.305414] system 00:05: [io 0x0c52] has been reserved
[ 0.305415] system 00:05: [io 0x0c6c] has been reserved
[ 0.305416] system 00:05: [io 0x0c6f] has been reserved
[ 0.305417] system 00:05: [io 0x0cd0-0x0cd1] has been reserved
[ 0.305418] system 00:05: [io 0x0cd2-0x0cd3] has been reserved
[ 0.305419] system 00:05: [io 0x0cd4-0x0cd5] has been reserved
[ 0.305420] system 00:05: [io 0x0cd6-0x0cd7] has been reserved
[ 0.305421] system 00:05: [io 0x0cd8-0x0cdf] has been reserved
[ 0.305422] system 00:05: [io 0x0800-0x089f] has been reserved
[ 0.305423] system 00:05: [io 0x0b00-0x0b0f] has been reserved
[ 0.305424] system 00:05: [io 0x0b20-0x0b3f] has been reserved
[ 0.305424] system 00:05: [io 0x0900-0x090f] has been reserved
[ 0.305425] system 00:05: [io 0x0910-0x091f] has been reserved
[ 0.305427] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.305428] system 00:05: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.305430] system 00:05: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.305431] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.305432] system 00:05: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 0.305433] system 00:05: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.305435] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[ 0.305769] pnp: PnP ACPI: found 6 devices
[ 0.311215] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.311258] NET: Registered PF_INET protocol family
[ 0.311487] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.312589] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.312744] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.312942] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.313010] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.313111] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.313159] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.313201] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.313255] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.313259] NET: Registered PF_XDP protocol family
[ 0.313269] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.313273] pci 0000:00:01.1: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.313278] pci 0000:03:05.0: PCI bridge to [bus 04]
[ 0.313281] pci 0000:03:05.0: bridge window [io 0xf000-0xffff]
[ 0.313286] pci 0000:03:05.0: bridge window [mem 0xf7600000-0xf76fffff]
[ 0.313296] pci 0000:03:08.0: PCI bridge to [bus 05]
[ 0.313301] pci 0000:03:08.0: bridge window [mem 0xf7200000-0xf73fffff]
[ 0.313310] pci 0000:03:09.0: PCI bridge to [bus 06]
[ 0.313314] pci 0000:03:09.0: bridge window [mem 0xf7500000-0xf75fffff]
[ 0.313323] pci 0000:03:0a.0: PCI bridge to [bus 07]
[ 0.313328] pci 0000:03:0a.0: bridge window [mem 0xf7400000-0xf74fffff]
[ 0.313337] pci 0000:02:00.0: PCI bridge to [bus 03-07]
[ 0.313339] pci 0000:02:00.0: bridge window [io 0xf000-0xffff]
[ 0.313344] pci 0000:02:00.0: bridge window [mem 0xf7200000-0xf76fffff]
[ 0.313353] pci 0000:00:01.2: PCI bridge to [bus 02-07]
[ 0.313354] pci 0000:00:01.2: bridge window [io 0xf000-0xffff]
[ 0.313357] pci 0000:00:01.2: bridge window [mem 0xf7200000-0xf76fffff]
[ 0.313362] pci 0000:00:03.1: PCI bridge to [bus 08]
[ 0.313363] pci 0000:00:03.1: bridge window [io 0xe000-0xefff]
[ 0.313366] pci 0000:00:03.1: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.313368] pci 0000:00:03.1: bridge window [mem 0xe0000000-0xf20fffff 64bit pref]
[ 0.313372] pci 0000:00:07.1: PCI bridge to [bus 09]
[ 0.313378] pci 0000:00:08.1: PCI bridge to [bus 0a]
[ 0.313381] pci 0000:00:08.1: bridge window [mem 0xf7700000-0xf79fffff]
[ 0.313385] pci 0000:00:08.2: PCI bridge to [bus 0b]
[ 0.313387] pci 0000:00:08.2: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.313392] pci 0000:00:08.3: PCI bridge to [bus 0c]
[ 0.313394] pci 0000:00:08.3: bridge window [mem 0xf7a00000-0xf7afffff]
[ 0.313399] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.313401] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.313402] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.313403] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.313403] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.313404] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.313405] pci_bus 0000:00: resource 10 [mem 0xe0000000-0xfec02fff window]
[ 0.313406] pci_bus 0000:00: resource 11 [mem 0xfee00000-0xffffffff window]
[ 0.313407] pci_bus 0000:01: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.313408] pci_bus 0000:02: resource 0 [io 0xf000-0xffff]
[ 0.313409] pci_bus 0000:02: resource 1 [mem 0xf7200000-0xf76fffff]
[ 0.313410] pci_bus 0000:03: resource 0 [io 0xf000-0xffff]
[ 0.313411] pci_bus 0000:03: resource 1 [mem 0xf7200000-0xf76fffff]
[ 0.313412] pci_bus 0000:04: resource 0 [io 0xf000-0xffff]
[ 0.313413] pci_bus 0000:04: resource 1 [mem 0xf7600000-0xf76fffff]
[ 0.313414] pci_bus 0000:05: resource 1 [mem 0xf7200000-0xf73fffff]
[ 0.313415] pci_bus 0000:06: resource 1 [mem 0xf7500000-0xf75fffff]
[ 0.313416] pci_bus 0000:07: resource 1 [mem 0xf7400000-0xf74fffff]
[ 0.313417] pci_bus 0000:08: resource 0 [io 0xe000-0xefff]
[ 0.313417] pci_bus 0000:08: resource 1 [mem 0xf6000000-0xf70fffff]
[ 0.313418] pci_bus 0000:08: resource 2 [mem 0xe0000000-0xf20fffff 64bit pref]
[ 0.313419] pci_bus 0000:0a: resource 1 [mem 0xf7700000-0xf79fffff]
[ 0.313420] pci_bus 0000:0b: resource 1 [mem 0xf7b00000-0xf7bfffff]
[ 0.313421] pci_bus 0000:0c: resource 1 [mem 0xf7a00000-0xf7afffff]
[ 0.313861] pci 0000:08:00.1: D0 power state depends on 0000:08:00.0
[ 0.313915] pci 0000:08:00.2: D0 power state depends on 0000:08:00.0
[ 0.314034] pci 0000:08:00.3: D0 power state depends on 0000:08:00.0
[ 0.314165] PCI: CLS 64 bytes, default 64
[ 0.314173] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.314203] pci 0000:00:01.0: Adding to iommu group 0
[ 0.314211] pci 0000:00:01.1: Adding to iommu group 1
[ 0.314216] Trying to unpack rootfs image as initramfs…
[ 0.314218] pci 0000:00:01.2: Adding to iommu group 2
[ 0.314227] pci 0000:00:02.0: Adding to iommu group 3
[ 0.314237] pci 0000:00:03.0: Adding to iommu group 4
[ 0.314244] pci 0000:00:03.1: Adding to iommu group 5
[ 0.314253] pci 0000:00:04.0: Adding to iommu group 6
[ 0.314261] pci 0000:00:05.0: Adding to iommu group 7
[ 0.314271] pci 0000:00:07.0: Adding to iommu group 8
[ 0.314278] pci 0000:00:07.1: Adding to iommu group 9
[ 0.314289] pci 0000:00:08.0: Adding to iommu group 10
[ 0.314296] pci 0000:00:08.1: Adding to iommu group 11
[ 0.314304] pci 0000:00:08.2: Adding to iommu group 12
[ 0.314311] pci 0000:00:08.3: Adding to iommu group 13
[ 0.314322] pci 0000:00:14.0: Adding to iommu group 14
[ 0.314328] pci 0000:00:14.3: Adding to iommu group 14
[ 0.314354] pci 0000:00:18.0: Adding to iommu group 15
[ 0.314361] pci 0000:00:18.1: Adding to iommu group 15
[ 0.314368] pci 0000:00:18.2: Adding to iommu group 15
[ 0.314374] pci 0000:00:18.3: Adding to iommu group 15
[ 0.314380] pci 0000:00:18.4: Adding to iommu group 15
[ 0.314386] pci 0000:00:18.5: Adding to iommu group 15
[ 0.314392] pci 0000:00:18.6: Adding to iommu group 15
[ 0.314399] pci 0000:00:18.7: Adding to iommu group 15
[ 0.314406] pci 0000:01:00.0: Adding to iommu group 16
[ 0.314414] pci 0000:02:00.0: Adding to iommu group 17
[ 0.314444] pci 0000:03:05.0: Adding to iommu group 18
[ 0.314454] pci 0000:03:08.0: Adding to iommu group 19
[ 0.314464] pci 0000:03:09.0: Adding to iommu group 20
[ 0.314474] pci 0000:03:0a.0: Adding to iommu group 21
[ 0.314504] pci 0000:04:00.0: Adding to iommu group 22
[ 0.314507] pci 0000:05:00.0: Adding to iommu group 19
[ 0.314510] pci 0000:05:00.1: Adding to iommu group 19
[ 0.314512] pci 0000:05:00.3: Adding to iommu group 19
[ 0.314515] pci 0000:06:00.0: Adding to iommu group 20
[ 0.314519] pci 0000:07:00.0: Adding to iommu group 21
[ 0.314536] pci 0000:08:00.0: Adding to iommu group 23
[ 0.314544] pci 0000:08:00.1: Adding to iommu group 23
[ 0.314552] pci 0000:08:00.2: Adding to iommu group 23
[ 0.314560] pci 0000:08:00.3: Adding to iommu group 23
[ 0.314567] pci 0000:09:00.0: Adding to iommu group 24
[ 0.314576] pci 0000:0a:00.0: Adding to iommu group 25
[ 0.314584] pci 0000:0a:00.1: Adding to iommu group 26
[ 0.314592] pci 0000:0a:00.3: Adding to iommu group 27
[ 0.314601] pci 0000:0a:00.4: Adding to iommu group 28
[ 0.314608] pci 0000:0b:00.0: Adding to iommu group 29
[ 0.314615] pci 0000:0c:00.0: Adding to iommu group 30
[ 0.320417] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.320422] AMD-Vi: Extended features (0x58f77ef22294ade): PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 0.320427] AMD-Vi: Interrupt remapping enabled
[ 0.320428] AMD-Vi: Virtual APIC enabled
[ 0.320428] AMD-Vi: X2APIC enabled
[ 0.320521] software IO TLB: tearing down default memory pool
[ 0.321225] LVT offset 0 assigned for vector 0x400
[ 0.321273] perf: AMD IBS detected (0x000003ff)
[ 0.321277] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.321932] Initialise system trusted keyrings
[ 0.321943] Key type blacklist registered
[ 0.321970] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.322654] zbud: loaded
[ 0.325289] Key type asymmetric registered
[ 0.325291] Asymmetric key parser ‘x509’ registered
[ 0.325301] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.325334] io scheduler mq-deadline registered
[ 0.325334] io scheduler kyber registered
[ 0.325354] io scheduler bfq registered
[ 0.325869] pcieport 0000:00:07.1: AER: enabled with IRQ 31
[ 0.325982] pcieport 0000:00:08.1: AER: enabled with IRQ 32
[ 0.326125] pcieport 0000:00:08.2: AER: enabled with IRQ 33
[ 0.326270] pcieport 0000:00:08.3: AER: enabled with IRQ 34
[ 0.327216] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.327299] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.327316] ACPI: button: Power Button [PWRB]
[ 0.327334] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.330387] ACPI: button: Power Button [PWRF]
[ 0.333718] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1110
[ 0.334198] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.334335] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.335485] Non-volatile memory driver v1.3
[ 0.335486] Linux agpgart interface v0.103
[ 0.335509] AMD-Vi: AMD IOMMUv2 loaded and initialized
[ 0.335840] nvme nvme0: pci function 0000:01:00.0
[ 0.335867] ahci 0000:06:00.0: version 3.0
[ 0.336016] ahci 0000:06:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.336019] ahci 0000:06:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.336136] scsi host0: ahci
[ 0.336175] ata1: SATA max UDMA/133 abar m2048@0xf7500000 port 0xf7500100 irq 43
[ 0.336293] ahci 0000:07:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.336295] ahci 0000:07:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.336392] scsi host1: ahci
[ 0.336416] ata2: SATA max UDMA/133 abar m2048@0xf7400000 port 0xf7400100 irq 44
[ 0.336511] ahci 0000:0b:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.336513] ahci 0000:0b:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.336608] scsi host2: ahci
[ 0.336629] ata3: SATA max UDMA/133 abar m2048@0xf7b00000 port 0xf7b00100 irq 46
[ 0.336724] ahci 0000:0c:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.336726] ahci 0000:0c:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.336816] scsi host3: ahci
[ 0.336836] ata4: SATA max UDMA/133 abar m2048@0xf7a00000 port 0xf7a00100 irq 48
[ 0.336854] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.336856] ehci-pci: EHCI PCI platform driver
[ 0.336862] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.336863] ohci-pci: OHCI PCI platform driver
[ 0.336868] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.336886] usbcore: registered new interface driver usbserial_generic
[ 0.336889] usbserial: USB Serial support registered for generic
[ 0.336931] rtc_cmos 00:02: RTC can wake from S4
[ 0.337102] rtc_cmos 00:02: registered as rtc0
[ 0.337129] rtc_cmos 00:02: setting system clock to 2022-06-11T20:53:28 UTC (1654980808)
[ 0.337137] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.337195] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.337316] efifb: probing for efifb
[ 0.337326] efifb: Ignoring BGRT: unexpected or invalid BMP data
[ 0.337326] efifb: framebuffer at 0xe0000000, using 3072k, total 3072k
[ 0.337327] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 0.337328] efifb: scrolling: redraw
[ 0.337328] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.337356] fbcon: Deferring console take-over
[ 0.337357] fb0: EFI VGA frame buffer device
[ 0.337369] hid: raw HID events driver (C) Jiri Kosina
[ 0.337406] ashmem: initialized
[ 0.337441] drop_monitor: Initializing network drop monitor service
[ 0.337486] Initializing XFRM netlink socket
[ 0.337536] NET: Registered PF_INET6 protocol family
[ 0.340536] nvme nvme0: missing or invalid SUBNQN field.
[ 0.349823] nvme nvme0: 15/0/0 default/read/poll queues
[ 0.351859] nvme0n1: p1 p2
[ 0.441798] Freeing initrd memory: 13024K
[ 0.444457] Segment Routing with IPv6
[ 0.444458] RPL Segment Routing with IPv6
[ 0.444468] In-situ OAM (IOAM) with IPv6
[ 0.444490] NET: Registered PF_PACKET protocol family
[ 0.444866] microcode: CPU0: patch_level=0x08701013
[ 0.444870] microcode: CPU1: patch_level=0x08701013
[ 0.444873] microcode: CPU2: patch_level=0x08701013
[ 0.444878] microcode: CPU3: patch_level=0x08701013
[ 0.444883] microcode: CPU4: patch_level=0x08701013
[ 0.444889] microcode: CPU5: patch_level=0x08701013
[ 0.444893] microcode: Microcode Update Driver: v2.2.
[ 0.444950] resctrl: L3 allocation detected
[ 0.444951] resctrl: MB allocation detected
[ 0.444952] resctrl: L3 monitoring detected
[ 0.444954] IPI shorthand broadcast: enabled
[ 0.444963] sched_clock: Marking stable (444597326, 345780)->(550783703, -105840597)
[ 0.445087] registered taskstats version 1
[ 0.445163] Loading compiled-in X.509 certificates
[ 0.447467] Loaded X.509 cert ‘Build time autogenerated kernel key: 44e1c42abf17943da1f3658949e0d628601db193’
[ 0.449716] zswap: loaded using pool zstd/z3fold
[ 0.449950] Key type ._fscrypt registered
[ 0.449951] Key type .fscrypt registered
[ 0.449951] Key type fscrypt-provisioning registered
[ 0.449986] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.450182] PM: Magic number: 10:288:902
[ 0.450334] RAS: Correctable Errors collector initialized.
[ 0.648262] ata3: SATA link down (SStatus 0 SControl 300)
[ 0.652648] ata4: SATA link down (SStatus 0 SControl 300)
[ 0.653866] ata1: SATA link down (SStatus 0 SControl 300)
[ 0.814935] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.815786] ata2.00: ATA-8: ST1000DM010-2EP102, CC43, max UDMA/133
[ 0.815997] ata2.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 0.816986] ata2.00: configured for UDMA/133
[ 0.841152] scsi 1:0:0:0: Direct-Access ATA ST1000DM010-2EP1 CC43 PQ: 0 ANSI: 5
[ 0.841270] sd 1:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 0.841271] sd 1:0:0:0: [sda] 4096-byte physical blocks
[ 0.841277] sd 1:0:0:0: [sda] Write Protect is off
[ 0.841278] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.841287] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 0.912439] sda: sda1 sda2
[ 0.922668] sd 1:0:0:0: [sda] Attached SCSI disk
[ 0.923494] Freeing unused decrypted memory: 2036K
[ 0.923781] Freeing unused kernel image (initmem) memory: 1864K
[ 0.923783] Write protecting the kernel read-only data: 28672k
[ 0.924181] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 0.924402] Freeing unused kernel image (rodata/data gap) memory: 1396K
[ 0.954391] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.954395] rodata_test: all tests were successful
[ 0.954400] Run /init as init process
[ 0.954401] with arguments:
[ 0.954402] /init
[ 0.954403] with environment:
[ 0.954403] HOME=/
[ 0.954403] TERM=linux
[ 0.954404] BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
[ 0.954404] cryptdevice=UUID=17195cdd-c5d7-4fef-a9c5-bfc24fa07c02:luks-17195cdd-c5d7-4fef-a9c5-bfc24fa07c02
[ 1.039373] cryptd: max_cpu_qlen set to 1000
[ 1.039540] xhci_hcd 0000:05:00.1: xHCI Host Controller
[ 1.039545] xhci_hcd 0000:05:00.1: new USB bus registered, assigned bus number 1
[ 1.039695] xhci_hcd 0000:05:00.1: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 1.040167] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.040169] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.040170] usb usb1: Product: xHCI Host Controller
[ 1.040171] usb usb1: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 1.040172] usb usb1: SerialNumber: 0000:05:00.1
[ 1.040243] hub 1-0:1.0: USB hub found
[ 1.040253] hub 1-0:1.0: 6 ports detected
[ 1.040713] xhci_hcd 0000:05:00.1: xHCI Host Controller
[ 1.040715] xhci_hcd 0000:05:00.1: new USB bus registered, assigned bus number 2
[ 1.040716] xhci_hcd 0000:05:00.1: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.040727] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.040739] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.040740] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.040741] usb usb2: Product: xHCI Host Controller
[ 1.040742] usb usb2: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 1.040743] usb usb2: SerialNumber: 0000:05:00.1
[ 1.040787] hub 2-0:1.0: USB hub found
[ 1.040795] hub 2-0:1.0: 4 ports detected
[ 1.041141] xhci_hcd 0000:05:00.3: xHCI Host Controller
[ 1.041144] xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 3
[ 1.041300] xhci_hcd 0000:05:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 1.041594] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.041595] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.041596] usb usb3: Product: xHCI Host Controller
[ 1.041597] usb usb3: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 1.041597] usb usb3: SerialNumber: 0000:05:00.3
[ 1.041645] hub 3-0:1.0: USB hub found
[ 1.041656] hub 3-0:1.0: 6 ports detected
[ 1.042109] xhci_hcd 0000:05:00.3: xHCI Host Controller
[ 1.042111] xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 4
[ 1.042112] xhci_hcd 0000:05:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.042124] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.042142] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.042143] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.042144] usb usb4: Product: xHCI Host Controller
[ 1.042145] usb usb4: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 1.042145] usb usb4: SerialNumber: 0000:05:00.3
[ 1.042428] hub 4-0:1.0: USB hub found
[ 1.042436] hub 4-0:1.0: 4 ports detected
[ 1.044275] xhci_hcd 0000:08:00.2: xHCI Host Controller
[ 1.044277] xhci_hcd 0000:08:00.2: new USB bus registered, assigned bus number 5
[ 1.044885] xhci_hcd 0000:08:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[ 1.044992] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.044993] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.044994] usb usb5: Product: xHCI Host Controller
[ 1.044995] usb usb5: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 1.044996] usb usb5: SerialNumber: 0000:08:00.2
[ 1.045045] hub 5-0:1.0: USB hub found
[ 1.045051] hub 5-0:1.0: 2 ports detected
[ 1.045131] xhci_hcd 0000:08:00.2: xHCI Host Controller
[ 1.045135] xhci_hcd 0000:08:00.2: new USB bus registered, assigned bus number 6
[ 1.045136] xhci_hcd 0000:08:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.045153] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.045165] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.045166] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.045167] usb usb6: Product: xHCI Host Controller
[ 1.045168] usb usb6: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 1.045168] usb usb6: SerialNumber: 0000:08:00.2
[ 1.049199] AVX2 version of gcm_enc/dec engaged.
[ 1.049225] AES CTR mode by8 optimization enabled
[ 1.051603] hub 6-0:1.0: USB hub found
[ 1.052070] hub 6-0:1.0: 4 ports detected
[ 1.052229] xhci_hcd 0000:0a:00.3: xHCI Host Controller
[ 1.052232] xhci_hcd 0000:0a:00.3: new USB bus registered, assigned bus number 7
[ 1.052336] xhci_hcd 0000:0a:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 1.052571] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.052572] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.052574] usb usb7: Product: xHCI Host Controller
[ 1.052574] usb usb7: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 1.052575] usb usb7: SerialNumber: 0000:0a:00.3
[ 1.052624] hub 7-0:1.0: USB hub found
[ 1.052630] hub 7-0:1.0: 4 ports detected
[ 1.052742] xhci_hcd 0000:0a:00.3: xHCI Host Controller
[ 1.052743] xhci_hcd 0000:0a:00.3: new USB bus registered, assigned bus number 8
[ 1.052745] xhci_hcd 0000:0a:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.052754] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.052765] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.052766] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.052767] usb usb8: Product: xHCI Host Controller
[ 1.052768] usb usb8: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 1.052769] usb usb8: SerialNumber: 0000:0a:00.3
[ 1.052814] hub 8-0:1.0: USB hub found
[ 1.052819] hub 8-0:1.0: 4 ports detected
[ 1.056865] ccp 0000:0a:00.1: enabling device (0000 → 0002)
[ 1.056948] ccp 0000:0a:00.1: ccp: unable to access the device: you might be running a broken BIOS.
[ 1.288664] usb 3-1: new high-speed USB device number 2 using xhci_hcd
[ 1.288671] usb 1-2: new full-speed USB device number 2 using xhci_hcd
[ 1.302010] usb 7-1: new low-speed USB device number 2 using xhci_hcd
[ 1.335339] tsc: Refined TSC clocksource calibration: 3949.998 MHz
[ 1.335346] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x71dfb64d697, max_idle_ns: 881591152217 ns
[ 1.335359] clocksource: Switched to clocksource tsc
[ 1.434524] usb 3-1: New USB device found, idVendor=1058, idProduct=1021, bcdDevice=20.21
[ 1.434526] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.434528] usb 3-1: Product: Ext HDD 1021
[ 1.434529] usb 3-1: Manufacturer: Western Digital
[ 1.434530] usb 3-1: SerialNumber: 574D415A4138393238363439
[ 1.438408] usb-storage 3-1:1.0: USB Mass Storage device detected
[ 1.438482] scsi host4: usb-storage 3-1:1.0
[ 1.438521] usbcore: registered new interface driver usb-storage
[ 1.441293] usbcore: registered new interface driver uas
[ 1.451770] usb 1-2: New USB device found, idVendor=1532, idProduct=0531, bcdDevice= 1.00
[ 1.451772] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.451773] usb 1-2: Product: Razer Seiren Mini
[ 1.451774] usb 1-2: Manufacturer: Razer Inc
[ 1.451775] usb 1-2: SerialNumber: UC2136L03203449
[ 1.452846] usb 7-1: New USB device found, idVendor=1bcf, idProduct=08a0, bcdDevice= 1.04
[ 1.452847] usb 7-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.466825] hid-generic 0003:1532:0531.0001: No inputs registered, leaving
[ 1.466847] hid-generic 0003:1532:0531.0001: hidraw0: USB HID v1.11 Device [Razer Inc Razer Seiren Mini] on usb-0000:05:00.1-2/input2
[ 1.466869] usbcore: registered new interface driver usbhid
[ 1.466870] usbhid: USB HID core driver
[ 1.479032] input: HID 1bcf:08a0 Mouse as /devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb7/7-1/7-1:1.0/0003:1BCF:08A0.0002/input/input3
[ 1.479080] input: HID 1bcf:08a0 Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb7/7-1/7-1:1.0/0003:1BCF:08A0.0002/input/input4
[ 1.535442] hid-generic 0003:1BCF:08A0.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [HID 1bcf:08a0] on usb-0000:0a:00.3-1/input0
[ 1.555335] usb 3-6: new full-speed USB device number 3 using xhci_hcd
[ 1.559666] device-mapper: uevent: version 1.0.3
[ 1.559699] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 1.566502] Key type encrypted registered
[ 1.581997] usb 1-3: new full-speed USB device number 3 using xhci_hcd
[ 1.658667] usb 7-2: new low-speed USB device number 3 using xhci_hcd
[ 1.709160] usb 3-6: config 1 has an invalid interface number: 2 but max is 1
[ 1.709161] usb 3-6: config 1 has no interface number 1
[ 1.721159] usb 3-6: New USB device found, idVendor=0b05, idProduct=18f3, bcdDevice= 1.00
[ 1.721161] usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.721162] usb 3-6: Product: AURA LED Controller
[ 1.721162] usb 3-6: Manufacturer: AsusTek Computer Inc.
[ 1.721163] usb 3-6: SerialNumber: 9876543210
[ 1.727806] random: fast init done
[ 1.739247] hid-generic 0003:0B05:18F3.0003: hiddev97,hidraw2: USB HID v1.11 Device [AsusTek Computer Inc. AURA LED Controller] on usb-0000:05:00.3-6/input2
[ 1.747769] usb 1-3: New USB device found, idVendor=045e, idProduct=02ea, bcdDevice= 4.08
[ 1.747771] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.747772] usb 1-3: Product: Controller
[ 1.747773] usb 1-3: Manufacturer: Microsoft
[ 1.747774] usb 1-3: SerialNumber: 3033363030313631353536373337
[ 1.836845] usb 7-2: New USB device found, idVendor=04f3, idProduct=152e, bcdDevice=3f.29
[ 1.836847] usb 7-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.836847] usb 7-2: Product: Gaming KB
[ 1.836848] usb 7-2: Manufacturer: Gaming KB
[ 1.867945] input: Gaming KB Gaming KB as /devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb7/7-2/7-2:1.0/0003:04F3:152E.0004/input/input5
[ 1.868008] hid-generic 0003:04F3:152E.0004: input,hidraw3: USB HID v1.11 Keyboard [Gaming KB Gaming KB] on usb-0000:0a:00.3-2/input0
[ 1.878039] input: Gaming KB Gaming KB Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb7/7-2/7-2:1.1/0003:04F3:152E.0005/input/input6
[ 1.878066] input: Gaming KB Gaming KB System Control as /devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb7/7-2/7-2:1.1/0003:04F3:152E.0005/input/input7
[ 1.878087] input: Gaming KB Gaming KB Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb7/7-2/7-2:1.1/0003:04F3:152E.0005/input/input8
[ 1.878109] input: Gaming KB Gaming KB as /devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb7/7-2/7-2:1.1/0003:04F3:152E.0005/input/input9
[ 1.878149] hid-generic 0003:04F3:152E.0005: input,hiddev98,hidraw4: USB HID v1.11 Keyboard [Gaming KB Gaming KB] on usb-0000:0a:00.3-2/input1
[ 3.468753] scsi 4:0:0:0: Direct-Access WD Ext HDD 1021 2021 PQ: 0 ANSI: 4
[ 5.664069] random: cryptsetup: uninitialized urandom read (2 bytes read)
[ 5.719264] fbcon: Taking over console
[ 5.719352] Console: switching to colour frame buffer device 128x48
[ 9.537644] sd 4:0:0:0: [sdb] Spinning up disk…
[ 12.588663] …not responding…
[ 117.964739] sd 4:0:0:0: [sdb] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_OK
[ 117.964742] sd 4:0:0:0: [sdb] Sense Key : Not Ready [current]
[ 117.964743] sd 4:0:0:0: [sdb] Add. Sense: Logical unit is in process of becoming ready
[ 117.964745] sd 4:0:0:0: [sdb] 0 512-byte logical blocks: (0 B/0 B)
[ 117.964746] sd 4:0:0:0: [sdb] 0-byte physical blocks
[ 119.987861] sd 4:0:0:0: [sdb] Test WP failed, assume Write Enabled
[ 122.010978] sd 4:0:0:0: [sdb] Asking for cache data failed
[ 122.010979] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 128.080030] sd 4:0:0:0: [sdb] Spinning up disk…
[ 132.135326] .
[ 133.139221] random: crng init done
[ 140.215322] …not responding…
[ 238.497961] sd 4:0:0:0: [sdb] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_OK
[ 238.497963] sd 4:0:0:0: [sdb] Sense Key : Not Ready [current]
[ 238.497964] sd 4:0:0:0: [sdb] Add. Sense: Logical unit is in process of becoming ready
[ 242.544202] sd 4:0:0:0: [sdb] Attached SCSI disk
[ 242.571893] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 242.633524] systemd[1]: systemd 250.5-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 242.648691] systemd[1]: Detected architecture x86-64.
[ 242.649234] systemd[1]: Hostname set to .
[ 242.787321] systemd[1]: Queued start job for default target Graphical Interface.
[ 242.787933] systemd[1]: Created slice Slice /system/getty.
[ 242.788095] systemd[1]: Created slice Slice /system/modprobe.
[ 242.788251] systemd[1]: Created slice Cryptsetup Units Slice.
[ 242.788434] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 242.788542] systemd[1]: Created slice User and Session Slice.
[ 242.788577] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 242.788601] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 242.788685] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 242.788711] systemd[1]: Reached target Login Prompts.
[ 242.788720] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 242.788733] systemd[1]: Reached target Remote File Systems.
[ 242.788740] systemd[1]: Reached target Slice Units.
[ 242.788758] systemd[1]: Reached target Local Verity Protected Volumes.
[ 242.788795] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 242.788909] systemd[1]: Listening on LVM2 poll daemon socket.
[ 242.789479] systemd[1]: Listening on Process Core Dump Socket.
[ 242.789549] systemd[1]: Listening on Journal Audit Socket.
[ 242.789597] systemd[1]: Listening on Journal Socket (/dev/log).
[ 242.789647] systemd[1]: Listening on Journal Socket.
[ 242.790016] systemd[1]: Listening on udev Control Socket.
[ 242.790056] systemd[1]: Listening on udev Kernel Socket.
[ 242.790495] systemd[1]: Mounting Huge Pages File System…
[ 242.790900] systemd[1]: Mounting POSIX Message Queue File System…
[ 242.791366] systemd[1]: Mounting Kernel Debug File System…
[ 242.791780] systemd[1]: Mounting Kernel Trace File System…
[ 242.792245] systemd[1]: Starting Load AppArmor profiles…
[ 242.792679] systemd[1]: Starting Create List of Static Device Nodes…
[ 242.793131] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 242.793577] systemd[1]: Starting Load Kernel Module configfs…
[ 242.794017] systemd[1]: Starting Load Kernel Module drm…
[ 242.794475] systemd[1]: Starting Load Kernel Module fuse…
[ 242.794522] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 242.795391] systemd[1]: Starting Load Kernel Modules…
[ 242.795792] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 242.795832] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 242.796315] systemd[1]: Starting Coldplug All udev Devices…
[ 242.797281] systemd[1]: Mounted Huge Pages File System.
[ 242.797324] systemd[1]: Mounted POSIX Message Queue File System.
[ 242.797362] systemd[1]: Mounted Kernel Debug File System.
[ 242.797395] systemd[1]: Mounted Kernel Trace File System.
[ 242.797493] systemd[1]: Finished Create List of Static Device Nodes.
[ 242.797641] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 242.797739] systemd[1]: Finished Load Kernel Module configfs.
[ 242.797855] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 242.797917] systemd[1]: Finished Load Kernel Module drm.
[ 242.798341] systemd[1]: Mounting Kernel Configuration File System…
[ 242.798675] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
[ 242.799412] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 242.799478] systemd[1]: Mounted Kernel Configuration File System.
[ 242.799955] systemd[1]: Activating swap /swapfile…
[ 242.799998] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 242.801238] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 242.802024] systemd[1]: Starting Load/Save Random Seed…
[ 242.802066] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 242.802611] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 242.802793] Adding 524284k swap on /swapfile. Priority:-2 extents:2 across:532476k SSFS
[ 242.802827] systemd[1]: Activated swap /swapfile.
[ 242.802858] systemd[1]: Reached target Swaps.
[ 242.807306] systemd[1]: Finished Load/Save Random Seed.
[ 242.807718] systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 242.807816] fuse: init (API version 7.34)
[ 242.808189] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 242.808267] systemd[1]: Finished Load Kernel Module fuse.
[ 242.808795] systemd[1]: Mounting FUSE Control File System…
[ 242.810171] sd 1:0:0:0: Attached scsi generic sg0 type 0
[ 242.810196] sd 4:0:0:0: Attached scsi generic sg1 type 0
[ 242.811163] systemd[1]: Mounted FUSE Control File System.
[ 242.816534] IPMI message handler: version 39.2
[ 242.819702] ipmi device interface
[ 242.829158] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 242.829211] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
[ 242.830074] systemd[1]: Starting Journal Service…
[ 242.830822] systemd[1]: Starting Rule-based Manager for Device Events and Files…
[ 242.832760] vboxdrv: loading out-of-tree module taints kernel.
[ 242.832926] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[ 242.835619] vboxdrv: Found 6 processor cores
[ 242.843605] audit: type=1400 audit(1654981051.001:2): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/lib/snapd/snap-confine” pid=332 comm=“apparmor_parser”
[ 242.843610] audit: type=1400 audit(1654981051.001:3): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/lib/snapd/snap-confine//mount-namespace-capture-helper” pid=332 comm=“apparmor_parser”
[ 242.847252] systemd[1]: Finished Coldplug All udev Devices.
[ 242.847318] audit: type=1130 audit(1654981051.004:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-udev-trigger comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 242.852954] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 242.853005] systemd[1]: Reached target Preparation for Local File Systems.
[ 242.853073] audit: type=1130 audit(1654981051.011:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=lvm2-monitor comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 242.853648] systemd[1]: Mounting /tmp…
[ 242.853672] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of a failed condition check (ConditionPathExists=/var/lib/machines.raw).
[ 242.854686] systemd[1]: Mounted /tmp.
[ 242.860322] audit: type=1400 audit(1654981051.018:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe” pid=328 comm=“apparmor_parser”
[ 242.860981] audit: type=1400 audit(1654981051.018:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe//kmod” pid=328 comm=“apparmor_parser”
[ 242.863676] audit: type=1400 audit(1654981051.021:8): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“lsb_release” pid=327 comm=“apparmor_parser”
[ 242.865590] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 242.865617] audit: type=1130 audit(1654981051.024:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-udevd comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 242.886503] vboxdrv: TSC mode is Invariant, tentative frequency 3949998258 Hz
[ 242.886507] vboxdrv: Successfully loaded version 6.1.34 r150636 (interface 0x00320000)
[ 242.889303] systemd[1]: Started Journal Service.
[ 242.889529] audit: type=1130 audit(1654981051.048:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-journald comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 242.898233] audit: type=1400 audit(1654981051.054:11): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“dovecot-script-login” pid=331 comm=“apparmor_parser”
[ 242.903276] systemd-journald[334]: Received client request to flush runtime journal.
[ 242.906296] VBoxNetAdp: Successfully started.
[ 242.909906] VBoxNetFlt: Successfully started.
[ 242.953387] acpi_cpufreq: overriding BIOS provided _PSD data
[ 243.012862] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 243.012952] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 243.036210] nvidia-gpu 0000:08:00.3: enabling device (0000 → 0002)
[ 243.063522] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 243.063526] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 243.063864] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 243.092420] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 243.092780] input: PC Speaker as /devices/platform/pcspkr/input/input10
[ 243.099653] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 243.109193] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 243.123513] mousedev: PS/2 mouse device common for all mice
[ 243.152283] mc: Linux media interface: v0.10
[ 243.159542] input: Microsoft X-Box One S pad as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.1/usb1/1-3/1-3:1.0/input/input11
[ 243.159602] usbcore: registered new interface driver xpad
[ 243.170175] r8169 0000:04:00.0 eth0: RTL8168h/8111h, 24:4b:fe:95:5e:72, XID 541, IRQ 87
[ 243.170181] r8169 0000:04:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 243.208554] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 243.208557] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 243.270538] snd_hda_intel 0000:08:00.1: enabling device (0000 → 0002)
[ 243.270600] snd_hda_intel 0000:08:00.1: Disabling MSI
[ 243.270605] snd_hda_intel 0000:08:00.1: Handle vga_switcheroo audio client
[ 243.270680] snd_hda_intel 0000:0a:00.4: enabling device (0000 → 0002)
[ 243.331565] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:08:00.1/sound/card0/input12
[ 243.331595] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:08:00.1/sound/card0/input13
[ 243.331642] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:08:00.1/sound/card0/input14
[ 243.331662] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:08:00.1/sound/card0/input15
[ 243.331681] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:08:00.1/sound/card0/input16
[ 243.331702] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:08:00.1/sound/card0/input17
[ 243.332682] snd_hda_codec_realtek hdaudioC1D0: ALCS1200A: SKU not ready 0x00000000
[ 243.333162] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALCS1200A: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[ 243.333165] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 243.333166] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 243.333168] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 243.333168] snd_hda_codec_realtek hdaudioC1D0: dig-out=0x1e/0x0
[ 243.333169] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 243.333170] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
[ 243.333171] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ 243.333172] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
[ 243.345033] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:0a:00.4/sound/card1/input18
[ 243.345066] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:0a:00.4/sound/card1/input19
[ 243.345088] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:0a:00.4/sound/card1/input20
[ 243.345109] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:0a:00.4/sound/card1/input21
[ 243.345129] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:0a:00.4/sound/card1/input22
[ 243.345150] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:0a:00.4/sound/card1/input23
[ 243.345185] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:0a:00.4/sound/card1/input24
[ 243.363541] kvm: Nested Virtualization enabled
[ 243.363543] SVM: kvm: Nested Paging enabled
[ 243.363544] SEV supported: 509 ASIDs
[ 243.363576] SVM: Virtual VMLOAD VMSAVE supported
[ 243.363576] SVM: Virtual GIF supported
[ 243.370059] MCE: In-kernel MCE decoding enabled.
[ 243.414443] usbcore: registered new interface driver snd-usb-audio
[ 243.418452] r8169 0000:04:00.0 enp4s0: renamed from eth0
[ 243.420717] asus_wmi: ASUS WMI generic driver loaded
[ 243.423820] asus_wmi: Initialization: 0x0
[ 243.423850] asus_wmi: BIOS WMI version: 0.9
[ 243.423979] asus_wmi: SFUN value: 0x0
[ 243.423980] eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
[ 243.424563] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input25
[ 243.520285] intel_rapl_common: Found RAPL domain package
[ 243.520291] intel_rapl_common: Found RAPL domain core
[ 243.708849] nvidia: module license ‘NVIDIA’ taints kernel.
[ 243.708853] Disabling lock debugging due to kernel taint
[ 243.787773] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[ 243.788712] nvidia 0000:08:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 243.831999] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 510.73.05 Sat May 7 05:30:26 UTC 2022
[ 243.883591] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 510.73.05 Sat May 7 05:21:20 UTC 2022
[ 243.936007] [drm] [nvidia-drm] [GPU ID 0x00000800] Loading driver
[ 243.936011] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:08:00.0 on minor 0
[ 244.420161] nvidia-gpu 0000:08:00.3: i2c timeout error e0000000
[ 244.420169] ucsi_ccg 0-0008: i2c_transfer failed -110
[ 244.420171] ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
[ 244.420175] ucsi_ccg: probe of 0-0008 failed with error -110
[ 244.444547] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 244.453412] nvidia-uvm: Loaded the UVM driver, major device number 506.
[ 244.568890] loop: module loaded
[ 244.569167] loop0: detected capacity change from 0 to 8
[ 244.573755] NET: Registered PF_QIPCRTR protocol family
[ 244.576092] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 244.605334] Generic FE-GE Realtek PHY r8169-0-400:00: attached PHY driver (mii_bus:phy_addr=r8169-0-400:00, irq=MAC)
[ 244.795446] r8169 0000:04:00.0 enp4s0: Link is Down
[ 247.260980] r8169 0000:04:00.0 enp4s0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 247.260993] IPv6: ADDRCONF(NETDEV_CHANGE): enp4s0: link becomes ready
[ 247.340649] ntfs3: Max link count 4000
[ 247.340652] ntfs3: Enabled Linux POSIX ACLs support
[ 247.340653] ntfs3: Read-only LZX/Xpress compression included
[ 247.341059] ntfs3: Unknown parameter ‘windows_names’
[ 247.345294] ntfs3: Unknown parameter ‘windows_names’
[ 251.281583] kauditd_printk_skb: 63 callbacks suppressed
[ 251.281585] audit: type=1334 audit(1654981059.438:69): prog-id=22 op=LOAD
[ 251.281590] audit: type=1300 audit(1654981059.438:69): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7ffe76be7100 a2=90 a3=fe items=0 ppid=1 pid=630 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm=“NetworkManager” exe=“/usr/bin/NetworkManager” subj==unconfined key=(null)
[ 251.281592] audit: type=1327 audit(1654981059.438:69): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
[ 254.581737] audit: type=1131 audit(1654981062.741:70): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 259.613711] audit: type=1131 audit(1654981067.771:71): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=snapd comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 274.566294] audit: type=1131 audit(1654981083.326:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-hostnamed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 274.649674] audit: type=1334 audit(1654981083.409:73): prog-id=0 op=UNLOAD
[ 274.649677] audit: type=1334 audit(1654981083.409:74): prog-id=0 op=UNLOAD
[ 274.649680] audit: type=1334 audit(1654981083.409:75): prog-id=0 op=UNLOAD
[ 274.681150] audit: type=1131 audit(1654981083.439:76): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-timedated comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 274.699745] audit: type=1334 audit(1654981083.459:77): prog-id=0 op=UNLOAD
[ 274.699748] audit: type=1334 audit(1654981083.459:78): prog-id=0 op=UNLOAD
[ 274.699751] audit: type=1334 audit(1654981083.459:79): prog-id=0 op=UNLOAD
[ 426.874542] audit: type=1100 audit(1654981235.627:80): pid=1327 uid=1000 auid=1000 ses=1 subj==unconfined msg=‘op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct=“luke” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/1 res=success’
[ 426.874633] audit: type=1101 audit(1654981235.630:81): pid=1327 uid=1000 auid=1000 ses=1 subj==unconfined msg=‘op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct=“luke” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/1 res=success’
[ 426.874999] audit: type=1110 audit(1654981235.630:82): pid=1327 uid=1000 auid=1000 ses=1 subj==unconfined msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/1 res=success’
[ 426.876317] audit: type=1105 audit(1654981235.630:83): pid=1327 uid=1000 auid=1000 ses=1 subj==unconfined msg=‘op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/1 res=success’
(Ps. if there is any better way to upload logs or files like .txt please let me know.)
Please format the output as described in the guide linked above.
Looks like one of your drives has a hard time starting, if not outright failing…
Is that an external drive? Can you try booting without it plugged?
Last night I turned off power to my external hard drive because it happens to bug me with a flashing light during the night. This morning when I booted It booted perfectly earlier this morning with no problems. The external hard drive is pretty old. I use it in place of a USB stick to boot new os and such.
Then this pretty much confirms the issue comes from the external drive, that fails to start in a timely manner.
Have you configured your system to mount that drive on boot when present?
cat /etc/fstab
Here is the output of the file I had to stop from booting on startup because of a previous issue. /dev/sdb is my external hard drive.
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=1882-7248                                          /boot/efi                                  vfat    umask=0077          0 2
/dev/mapper/luks-17195cdd-c5d7-4fef-a9c5-bfc24fa07c02   /                                          ext4    noatime             0 1
/swapfile                                               swap                                       swap    noatime             0 0
tmpfs                                                   /tmp                                       tmpfs   noatime,mode=1777   0 0
#/dev/sdb                                                /home/username/Desktop/Mount\040Point\040Usb   udf     users               0 0
The line is commented, so it is not used. Your system may try to mount it nonetheless if it spots it when booting.
Also, were it not commented, it wouldn’t work correctly: the line points the drive instead of its partition.
It might be worth setting a proper mount configuration, and using the noauto option so that it doesn’t try to mount it on boot.
I did this recently but I came upon an error after running mount -a while in Sudo -i mode I just wanted to ask if this is okay and if anything is wrong. It told me this.
mount -a
mount: /etc/fstab: parse error at line 13 -- ignored
mount: /etc/fstab: parse error at line 14 -- ignored
mount: /etc/fstab: parse error at line 16 -- ignored
mount: /HardDriveMount: special device 2725-614A does not exist.
       dmesg(1) may have more information after failed mount system call.
mount: (hint) your fstab has been modified, but systemd still uses
       the old version; use 'systemctl daemon-reload' to reload.
mount: defaults,noatime: mount point does not exist.
Thanks for the help.
You don’t need sudo -i for testing mount -a.
Those messages already hint at what is wrong.
