Stucks in .
/dev/sdc4: clean 464359/1978592 files, 4882161/7899648 blocks
Any other info required just ask me please!
Thanks.
Stucks in .
Thanks.
There’s much more information that can be provided.
Do you have multiple kernel versions installed? Does it work with a different kernel version?
Can you switch to a TTY prompt, such as CTRL + ALT + F2?
If so, what happens if you run,
sudo systemctl restart display-manager.service
hi winnie thanks for your asnwer, well, how to know how many kernel version i have installed?
but when run: uname -r
returns: 5.15.32-1-MANJARO
Yes, i can switch to tty promp with ctrl alt f2
and i could logged in with my account but the xfce gui still doesnt show up so i ran the line you told me to restart the display-manager service and nothing happens
so i ran sudo systemctl status display-manager.service
and show me that the lightdm.service
was active(running)
what else could i do?
After attempting to restart the display manager, do the logs show any errors?
You can check with either,
journalctl -e
or
sudo dmesg | tail -n 100
Press Q to exit the journalctl
view.
no, these logs doesnt show any errors with display manager, everything with it seems to be ok
Can you post your system info? Especially the GPU.
Is there anything under /etc/X11/xorg.conf.d/
inside /etc/X11/xorg.conf.d/
only have 2 files:
00-keyboard.conf
90-mhwd.conf
About my gpu if i run mhwd -li
it shows:
linux515-nvidia-390xx
What are the contents of 90-mhwd.conf
Let’s not forget the basics.
content of 90-mhwd.conf
, thanks for helping me i really appreciate it
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 390.147 (dvs-builder@U64-E08-29-1) Mon Dec 13 13:50:12 UTC 2021
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "NoLogo" "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
Section "ServerFlags"
Option "IgnoreABI" "1"
EndSection
if you want i can share you the file
Those are older drivers. Does your card not support the latest Nvidia drivers?
To rule something out, you can temporarily rename the file to 90-mhwd.conf.disabled
, and then try to reboot the computer.
There has to be some error message showing in your logs when your display manager won’t start.
my graphic card is old, an 560 SE how to know or force the update of those drivers
im going to try the .disabled file and tell you later
hey winnie i made the change and rename 90-mhwd.conf
as 90-mhwd.conf.disabled
and reboot my pc, but keep the same issue, no gui at all
That’s not what this command would tell you. I’m not saying this is not the driver version you have installed but this is not a MHWD output it wouldn’t list the kernel version in the driver name. That lead to me wondering if you’re looking at the proper things people ask you to. For example seems like it should have some errors in log as said by winnie, but you have none, are you sure you’re doing what is asked to look at it?
//EDIT: are you sure you are up to date? do a sudo pacman -Syyu
I have to revisit this. I took your word for it, but how do you know there are no issues or errors?
thanks for answer, i will run sudo pacman -Syyu
and tell you later
sorry but im a little unexperienced with arch and linux in general, well, i can copy the content of any log file if you need it, just tell me what log file and i will share the file here
i ran de command and pacman updates 1 package and reboot but the GUI still doesnt show up
hi winnie i checked again the journalctl -e
and i found something new i pass trough previously, this error:
``Failed to insert ‘nvidia’: No such file or directory
ctx=HEX# path=/lib/modules/5.15.32-1-MANJARO/extramodules/nvidia-modeset.ko.gz error=No such file or directory
ctx=HEX# path=/lib/modules/5.15.32-1-MANJARO/extramodules/nvidia.ko.gz error=No such file or directory
ctx=HEX# path=/lib/modules/5.15.32-1-MANJARO/kernel/arch/x86/kvm/kvm.ko.gz error=No such file or directory
hope this tell you something!
