Hi, suddenly Manjaro latest updated release starts to slow down until it crashes and is unable to start. Having dual boot with Windows 10 I tried to restart it too but the same problem happens. I’m afraid there is a hardware problem. Now I’m always live with Manjaro. What information can I give you to get your help? Thank you.
~ inxi -v7azy ✔
Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=it_IT keytable=it tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2210 quiet systemd.show_status=1
splash driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Vostro 3558 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 05W6N2 v: A00 serial: <superuser required> UEFI: Dell
v: A17 date: 09/11/2020
RAM: total: 7.67 GiB used: 2.95 GiB (38.5%)
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 high: 807 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 798 3: 798 4: 807
bogomips: 15968
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: Microdia Integrated Webcam type: USB driver: uvcvideo
bus-ID: 2-5:3 chip-ID: 0c45:6710 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c5 built: 2014 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:08b3 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: down mac: <filter>
bus-ID: 2-6:4 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 245.68 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intenso model: SSD Sata III
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 4A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 7.2 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C1
dev-links: cdrom
Message: No partition data found.
ID-1: /dev/dm-0 maj-min: 254:0 mapped: ventoy size: 3.89 GiB fs: iso9660
ID-2: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: 8415-4124
ID-3: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda3 maj-min: 8:3 size: 58.85 GiB fs: ntfs label: N/A
uuid: FA3A68C23A687D8F
ID-5: /dev/sda4 maj-min: 8:4 size: 521 MiB fs: ntfs label: N/A
uuid: 5C4A12DA4A12B12E
ID-6: /dev/sda5 maj-min: 8:5 size: 512 MiB fs: vfat label: N/A
uuid: EF17-3935
ID-7: /dev/sda6 maj-min: 8:6 size: 4 GiB fs: swap label: N/A
uuid: e9fe1e37-91cc-4933-8ab7-2dba61c68e4f
ID-8: /dev/sda7 maj-min: 8:7 size: 40 GiB fs: ext4 label: root
uuid: 4fb222bb-cc4f-4803-a376-819e074d82c4
ID-9: /dev/sda8 maj-min: 8:8 size: 100 GiB fs: ext4 label: home
uuid: a3dc1290-4cd8-4e21-8d9f-d4946224c56c
ID-10: /dev/sda9 maj-min: 8:9 size: 1.06 GiB fs: ntfs label: DELLSUPPORT
uuid: 30BAFF28BAFEE8EC
ID-11: /dev/sdb1 maj-min: 8:17 size: 7.17 GiB fs: exfat label: Ventoy
uuid: BC9E-47E4
ID-12: /dev/sdb2 maj-min: 8:18 size: 32 MiB fs: vfat label: VTOYEFI
uuid: C559-2E5D
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8001 class-ID: 0900
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 11 rev: 2.0
Device-1: 2-3:10 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 2-5:3 info: Microdia Integrated Webcam type: Video
Device-3: 2-6:4 info: Intel Bluetooth wireless interface type: Bluetooth
Device-4: 2-8:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 3-1:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 296mA chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 45.0 C mobo: N/A sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0 fan-2: 0 fan-3: 0
Processes: 179 Uptime: 53m wakeups: 3 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1208 libs: 330 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
But this is the information on Live I think, how can I get the information of the damaged system?
When did you last time update your system, before the current issue?
Can you post
cat /etc/fstab
Make sure Fastboot / Fast startup etc. is switched off in Windoze. Fully shutdown Win.
If the update was interrupted a good start could be to restore the boot loader and then to follow this guide:
I did an update yesterday and after that the problem showed up. First the internet started to slow down, then the whole system. I tried to restart thinking it was necessary for the update to be successful but then I was no longer able to enter Manjaro. The update did not stop for any reason and was successful.
You will need to use manjaro-chroot from the Live installer, to give output of the installed system. Once in that environment, please give the output of:
cat /etc/fstab
… as previously requested. Thank you.
For completeness, this is the manjaro-chroot command:
sudo manjaro-chroot -a
If you should need to perform boot operations, such as replacing Grub, follow directions found in Restore the GRUB Bootloader.
I hope this helps.
manjaro-chroot -a
will get you in to your installation so you can post the details requested in this thread.
df -h
will show available HDD space. Also important. Please post that here as well.
N.B. When you are running your installed OS (not the Live USB):
watch -n 30 free -h
might be useful to keep an eye on your memory usage. Browsers eat RAM for lunch when watching YouTube etc…
When RAM gets low, restart the browser. This usually works (for me) several times before it chokes … I can get at least a few weeks constant use before a reboot is needed this way.
Also, what @soundofthunder said
They provided an inxi from a Live USB.
SWAP is not enabled on live media by default.
It also doesnt show any partition data.
Whereas it appears their original system did/does have some SWAP:
Ah, didn’t spot that. That’ll teach me for skim-reading without my goggles on!
N.B. I edited my previous post to tidy it up.
Good morning and thanks for the replies. I restored Grub and managed to get into the system: 15 minutes to start, apps take biblical times to start and use them, it’s very, very, very, very slow, impossible to use it. Below are the outputs you requested.
~ sudo manjaro-chroot -a ✔
==> Mounting (ManjaroLinux) [/dev/sda7]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
--> mount: [/mnt/home]
[manjaro /]# cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=8415-4124 /boot/efi vfat umask=0077 0 2
UUID=4fb222bb-cc4f-4803-a376-819e074d82c4 / ext4 defaults,noatime 0 1
UUID=a3dc1290-4cd8-4e21-8d9f-d4946224c56c /home ext4 defaults,noatime 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
[manjaro /]# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sda7 40G 19G 19G 50% /
/dev/sda1 96M 32M 65M 33% /boot/efi
/dev/sda8 98G 33G 61G 35% /home
udev 3.9G 0 3.9G 0% /dev
shm 3.9G 0 3.9G 0% /dev/shm
run 3.9G 0 3.9G 0% /run
tmp 3.9G 0 3.9G 0% /tmp
overlay 5.8G 333M 5.5G 6% /etc/resolv.conf
[manjaro /]#
There are no obvious issues in /etc/fstab
; at least that’s ruled out.
Is your desktop portal installed? I don’t know which DE you use, so can’t be more specific than saying you can check with:
pamac search --installed desktop-portal
Where did this come from? Kind of unusual if not wrong…
Try the following IF @Mirdarthos suggested command reveals that xdg-desktop-portal-gnome
is installed:
sudo pacman -Rdd xdg-desktop-portal-gnome
sudo pacman -S xdg-desktop-portal-kde
More information: Stable Update 2023-06-04 under the heading Many applications (firefox, thunderbird, telegram, etc) slow to start on desktops other than Gnome.
However, I don’t see that this would necessarily cause the crash you describe.
Edit: Command updated to the kde backend.
This one , specifically:
/dev/shm is nothing but implementation of traditional shared memory concept. It is an efficient means of passing data between programs. One program will create a memory portion, which other processes (if permitted) can access. This will result into speeding up things on Linux.
shm / shmfs is also known as tmpfs, which is a common name for a temporary file storage facility on many Unix-like operating systems. It is intended to appear as a mounted file system, but one which uses virtual memory instead of a persistent storage device.
Reference: https://www.cyberciti.biz/tips/what-is-devshm-and-its-practical-usage.html
Along with:
Makes it look like this is still all from a Live Environment.
Hi, as a DE I use updated KDE, in fact I think the latest update made on Sunday, if I remember correctly, is the origin of the problem in question.
[manjaro /]# pamac search --installed desktop-portal
xdg-desktop-portal-kde 5.27.8-4 extra
A backend implementation for xdg-desktop-portal using Qt/KF5
xdg-desktop-portal 1.18.0-2 extra
Desktop integration portals for sandboxed apps
[manjaro /]# sudo pacman -Rdd xdg-desktop-portal-gnome
error: target not found: xdg-desktop-portal-gnome
[manjaro /]# sudo pacman -S xdg-desktop-portal-gtk
resolving dependencies...
Packages (1) xdg-desktop-portal-gtk-1.14.1-3
Total Download Size: 0.11 MiB
Total Installed Size: 0.48 MiB
:: Retrieving packages...
xdg-desktop-port... 113.7 KiB 160 KiB/s 00:01 [#########################] 100%
(1/1) checking keys in keyring [#########################] 100%
(1/1) checking package integrity [#########################] 100%
(1/1) loading package files [#########################] 100%
(1/1) checking for file conflicts [#########################] 100%
(1/1) checking available disk space [#########################] 100%
(1/1) installing xdg-desktop-portal-gtk [#########################] 100%
Optional dependencies for xdg-desktop-portal-gtk
evince: Print preview
(1/3) Arming ConditionNeedsUpdate...
(2/3) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
(3/3) Updating the desktop file MIME type cache...
[manjaro /]#
Uninstall the xdg-desktop-portal-gtk
backend. The example was given conditionally, based on whether xdg-desktop-portal-gnome
was found – it isn’t needed on KDE. Plus, I neglected to change the second command to -kde
as it should have been.
Regardless of this, neither command was needed. Uninstall with:
sudo pacman -R xdg-desktop-portal-gtk
OK done. Any other suggestions for solving the problem?
Without your help I won’t be able to exhume Manjaro, if you think there are no solutions tell me I’ll reinstall the system, I have some data I need inside the PC. Thank you.
manjaro-chroot -a ✔
==> ERROR: No Linux partitions detected!
At this point I think the SSD is gone.
