Low speed of network using Wifi connection
Hi I have problem with speed of Wifi internet connection in Manjaro XFCE 21.2.5 . It download from internet in speed 1,7 MB/s and it should be 3,5 MB/s . I had same problem in Ubuntu 20.4 and it was kernel problem, I have 1,5 year old laptop and in Ubuntu I used older kernel and internet worked in good speed . I tried in Manjaro older kernels, but internet not work , so I used 3. newest kernel, internet connection works, but in low speed , What to do ? Thanks and sorry my English .
Hi @Fitness
Maybe you need to install drivers. It happened with me before (but on Artix).
Check this Internet connection is way too slow
Please let me know how it go with you.
I hope this helps.
Hi @Fitness,
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
Thanks Mirdarthos , it takes me some time to learn .
As long as you stay teachable!
  Kernel: 5.16.2-2-rt19-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-rt-x86_64
    root=UUID=9f213b02-a646-4aea-be7b-746332afcd82 rw quiet apparmor=1
  Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X571GD_X571GD
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X571GD v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: X571GD.312 date: 09/15/2021
  ID-1: BAT1 charge: 27.2 Wh (99.3%) condition: 27.4/42.3 Wh (64.6%)
    volts: 11.4 min: 11.6 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: discharging
  RAM: total: 7.62 GiB used: 1.6 GiB (21.0%)
  RAM Report:
  Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
    family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 799 high: 800 min/max: 800/4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 799 6: 800 7: 800 8: 800 bogomips: 36799
    arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
    cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
    epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
    ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
    smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
    tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
    driver: i915 v: kernel ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
    driver: nouveau v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
    gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c92 class-ID: 0302
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 1-7:4 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
    X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
    screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: LG Display 0x0563 built: 2018 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.16.2-2-rt19-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.48 running: yes
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 03:00.0
    chip-ID: 10ec:c821 class-ID: 0280
    vendor: ASUSTeK driver: N/A modules: r8169 pcie: speed: Unknown lanes: 63
    link-max: gen: 6 speed: 64 GT/s port: 3000 bus-ID: 04:00.0
  Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 1-14:5 chip-ID: 13d3:3529 class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 1.14 TiB used: 9.58 GiB (0.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: HFM256GDJTNG-8310A size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
    rev: 80001C00 temp: 31.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    type: HDD rpm: 5400 serial: <filter> rev: 1J scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 9.58 GiB (1.0%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 9f213b02-a646-4aea-be7b-746332afcd82
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 4D79-483B
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 512 MiB fs: vfat label: N/A
    uuid: 9BFE-DC07
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 237.97 GiB fs: ext4 label: N/A
    uuid: c70740ea-f645-4222-a7fe-778397922be1
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-1:2 info: Sunplus Innovation Optical Mouse type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
    power: 98mA chip-ID: 1bcf:0005 class-ID: 0301
  Device-2: 1-6:3 info: Realtek RTS5129 Card Reader Controller
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
    class-ID: ff00 serial: <filter>
  Device-3: 1-7:4 info: IMC Networks USB2.0 HD UVC WebCam type: Video
  Device-4: 1-14:5 info: IMC Networks Bluetooth Radio type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
  Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 38.0 C pch: 44.0 C mobo: 27.8 C gpu: nouveau
    temp: 34.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 305 Uptime: 5m wakeups: 1 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1085 lib: 316
  flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
I suspect it is the driver try to follow on the first few search results:
Thanks
Hi @Fitness, and sorry for now only coming back to you.
I see there’s what appears to be another driver for this adapter in the AUR:
$ pamac search RTL8821CE
rtl8821ce-dkms-git        1.0.5.r36.gca4abd8-1  AUR
rtl8821CE driver with firmware
And it might even be newer. So you can install it using:
pamac build rtl8821ce-dkms-git
Followed by rebooting and seeing if it works. Report back.
If perhaps it looks as if it doesn’t, when you report back, please post the output the previous command returned, as well as a new updated inxi as you did above. If I’m not available then, someone else should be able to assist you.
Hope you come right.
Thanks for help, I tried and internet wifi connection is still slow .
That’s why I said, provide the output of the previous command. Which would be this one:
Připravuji...
Klonování rtl8821ce-dkms-git sestavovacích souborů...
Generování rtl8821ce-dkms-git informace...
Kontrola rtl8821ce-dkms-git závislostí...
Varování: rtl8821ce-dkms-git-1.0.5.r134.gdce62b9-1 je aktuální -- přeinstalovat
Řešení závislostí...
Kontroluji konflikty...
K sestavení (1):
 rtl8821ce-dkms-git  1.0.5.r134.gdce62b9-1                           AUR
Upravit konfigurační soubory : [e]
Aplikovat změny ? [e/a/N] a
Sestavuji rtl8821ce-dkms-git...
==> Vytváří se balíček: rtl8821ce-dkms-git 1.0.5.r134.gdce62b9-1 (Pá 15. dubna 2022, 16:22:13)
==> Kontrola runtime závislostí...
==> Kontrola buildtime závislostí...
==> Získávají se zdrojové soubory...
 -> Aktualizuji repozitář rtl8821ce git ...
Fetching origin
==> Kontrola source souborů pomocí sha256sums...
   rtl8821ce ... Vynecháno
==> Odstraňuje se existující adresář $srcdir/ ...
==> Rozbalují se zdrojové soubory...
 -> Vytváření pracovní kopie repozitáře rtl8821ce git ...
Cloning into 'rtl8821ce'...
done.
==> Spouští se pkgver()...
==> Vstupuje se do fakeroot prostředí...
==> Spouští se package()...
==> Pročišťuje se instalace...
 -> Odstraňují se libtool soubory...
 -> Promazávají se zbytečné soubory...
 -> Odstraňování souborů statických knihoven...
 -> Odstraňují se nepotřebné ladící informace z binárních souborů a knihoven...
 -> Komprimují se man a info stránky...
==> Kontrola chyb při balení...
==> Vytváří se balíček "rtl8821ce-dkms-git"...
 -> Vytváření .PKGINFO souboru...
 -> Vytváření .BUILDINFO souboru...
 -> Vytváření .MTREE souboru ...
 -> Komprimuje se balíček...
==> Opouští se prostředí fakeroot.
==> Dokončeno vytváření: rtl8821ce-dkms-git 1.0.5.r134.gdce62b9-1 (Pá 15. dubna 2022, 16:22:31)
==> Probíhá čištění...
Kontrola klíčenky...                                                       [1/1]
Kontrola integrity...                                                      [1/1]
Načítání balíčků...                                                        [1/1]
Kontrola konfliktních souborů...                                           [1/1]
Kontrola dostupného místa na disku...                                      [1/1]
Spouští se před-transakční nastavení...
Creating Timeshift snapshot before upgrade...                              [1/2]
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Remove upgraded DKMS modules                                               [2/2]
==> dkms remove --no-depmod rtl8821ce/1.0.5.r134.gdce62b9 -k 5.15.32-1-rt39-MANJARO
==> dkms remove --no-depmod rtl8821ce/1.0.5.r134.gdce62b9 -k 5.16.2-3-rt19-MANJARO
Přeinstalování rtl8821ce-dkms-git (1.0.5.r134.gdce62b9-1)...               [1/1]
Spouští se po-transakční nastavení...
Arming ConditionNeedsUpdate...                                             [1/2]
Install DKMS modules                                                       [2/2]
==> dkms install --no-depmod rtl8821ce/1.0.5.r134.gdce62b9 -k 5.15.32-1-rt39-MANJARO
==> dkms install --no-depmod rtl8821ce/1.0.5.r134.gdce62b9 -k 5.16.2-3-rt19-MANJARO
==> depmod 5.16.2-3-rt19-MANJARO
==> depmod 5.15.32-1-rt39-MANJARO
Transakce úspěšně dokončena.
 Kernel: 5.16.2-3-rt19-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
   root=UUID=b27f5a46-7d3c-4a6b-8567-1999d9a6a38f rw quiet apparmor=1
 ID-1: BAT1 charge: 14.7 Wh (54.6%) condition: 26.9/42.3 Wh (63.6%)
   volts: 10.6 min: 11.6 model: ASUS A32-K55 type: Li-ion serial: N/A
   status: discharging
 RAM: total: 7.62 GiB used: 1.64 GiB (21.5%)
 RAM Report:
 Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
   governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
 Type: l1tf
   driver: N/A alternate: nouveau pcie: speed: Unknown lanes: 63 link-max:
   gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c92 class-ID: 0302
   screens: 1
 Sound Server-1: ALSA v: k5.16.2-3-rt19-MANJARO running: yes
 Sound Server-4: PipeWire v: 0.3.49 running: yes
   vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce,8821ce
   pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 03:00.0
   vendor: ASUSTeK driver: r8169 v: kernel pcie: speed: Unknown lanes: 63
 IF: enp4s0 state: down mac: <filter>
 Local Storage: total: 1.14 TiB used: 31.44 GiB (2.7%)
   rev: 80001C00 temp: 30.9 C scheme: GPT
   used: 31.44 GiB (3.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
   uuid: b27f5a46-7d3c-4a6b-8567-1999d9a6a38f
   uuid: 8D9C-35AF
   uuid: 9BFE-DC07
 System Temperatures: cpu: 37.0 C pch: 42.0 C mobo: 27.8 C
 Processes: 304 Uptime: 3m wakeups: 1 Init: systemd v: 250 tool: systemctl
 Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1119 lib: 321
 flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.15
Download speed of internet is better and more stable , speed is 2 MB/s . Thanks
Edit : Its ok , now with this driver works connection with older kernels and speed of internet is good. Thank you
