Low frame rate or stuttering window animations on Manjaro KDE (beginner user)
Hello everyone
I’m a complete beginner with Linux and I recently installed Manjaro KDE.
However, I’m experiencing a problem with low frame rate or stuttering animations when opening, closing, or minimizing windows.
The animations don’t look smooth — it feels like they’re being “cut off” or running at a much lower FPS than normal.
Here are my system specs:
CPU: AMD Ryzen 7 7530U
GPU: Integrated AMD Radeon Graphics
RAM: 16 GB
Storage: 512 GB SSD
Display: 1920×1080
Environment: KDE Plasma (latest Manjaro stable release)
I don’t think it’s a hardware issue, because I tested Linux Mint on the same machine and its animations were perfectly smooth.
Thank you in advance for your help — and sorry if this is a basic question, I’m still learning how Linux works.
Hi @korniienkoom, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
inxi --filter --verbosity=8 --color=0
Please also note and heed: Forum Rules - Manjaro
Those with privacy concerns: note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output. :eyes:
Hope you manage!
:bangbang: Tip for legibility: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
I’d say this is unexpected and not something I’ve seen before…
First, make sure you’re properly synchronised/updated (pacman -Syu) and after that, create a new USER and verify it’s working with a fresh $HOME (defaults).
Integrated graphics (iGPU) can sometimes not be as performant as one might expect.
Whether that is the case here, I can’t say – with more information about your system, and how it is configured, perhaps someone will have a better chance of taking an educated guess.
Please provide your system information as described (above) by @Mirdarthos and be prepared to give additional detail, as needed.
Creating a new User account as @Ben suggests is a valid troubleshooting step to help rule out local (mis)configuration as the culprit.
One of the first things we’d obviously need to know is whether or not the issue you describe persists in the fresh environment.
This is often caused by a driver conflict.
Check if you have the package xf86-video-amdgpu on the system. Output will be empty you the package is not present.
pamac search xf86-video-amdgpu -i
Only a few days ago - another user had some display degradation caused by conflicting drivers. Removing the mentioned package solved the issue.
It may not be the solution - but certainly worth a try.
sudo pacman -Rns xf86-video-amdgpu
Also worth mentioning the above package is related to older AMD cards and is not necessary on modern systems where AMD drivers are provided by the kernel.
On a similar theme, please also check that the AMD firmware is installed
The AMD firmware should arguably be already installed, but on the chance that it isn’t, please confirm with:
pacman -Ss linux-firmware-amdgpu
(paste the output into your next post)
If it isn’t installed, this command will install it:
sudo pacman -Syu linux-firmware-amdgpu
Reboot.
