Lots of interrupts and stutter in 3d aplications
Hi,
Can someone with more experience help point me in the right direction. I have managed to get everything running really well with steam and a number of games. But after about 1 hour of a game being open I start to get game break stutter. I posted here because I believe this problem to be system as my games are running amazingly. Thanks to the help of chatgpt, But I feel like I have hit a brick wall.
I think I have found the problem but unsure on how to fix it. Here is a screen shot of what I believe is the clue as to what might be happening. I am new to all of this and I think the kernel is basically reacting to a high number or interrupts. I believe the kernel it just trying to prevent a unstable condition.
Everything is upto date. I have doom 3 running on vulken and elder scrolls online also running well. But other games do the same thing after about 40mins of gameplay. Its not overheating or power management problem or a memory leak.
system information:
$ inxi -zv8
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=f806604e-3076-43c2-ab49-1bb7587e42da rw quiet splash apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver dm: LightDM v: 1.32.0
  Type: Desktop Mobo: Gigabyte model: Z77X-UD3H serial: N/A
    uuid: 032b0290-0434-0551-c706-530700080009 UEFI: American Megatrends v: F18
    date: 10/24/2012
  System RAM: total: 12 GiB available: 11.64 GiB used: 7.14 GiB (61.4%)
  Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
  Device-1: ChannelB-DIMM1 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Corsair part-no: CMZ8GX3M2A1600C8 serial: N/A
  Device-2: ChannelA-DIMM1 type: DDR3 detail: synchronous size: 2 GiB
    manufacturer: Corsair part-no: CMX6GX3M3A1600C9 serial: N/A
  Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
  Device-4: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 2 GiB
  Slot: 0 type: PCIe status: in use info: J6B2 length: long volts: 3.3
    bus-ID: 00:02.0
  Slot: 1 type: PCIe status: in use info: J6B1 length: short volts: 3.3
    bus-ID: 00:1c.0
  Slot: 2 type: PCIe status: in use info: J6D1 length: short volts: 3.3
    bus-ID: 00:01.0 children: 1: 01:00.0 class-ID: 0300 type: display 2: 01:00.1
    class-ID: 0403 type: audio
  Slot: 3 type: PCIe status: in use info: J7B1 length: short volts: 3.3
    bus-ID: 00:03.0
  Slot: 4 type: PCIe status: in use info: J8B4 length: short volts: 3.3
    bus-ID: 00:1c.7 children: 1: 07:00.0 class-ID: 0106 type: mass-storage
  Slot: 6 type: PCI status: in use info: J8B3 length: short volts: 3.3
    bus-ID: 14:1e.0
  Info: model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 2101 min/max: 1600/4100 base/boost: 4100/7000 scaling:
    driver: intel_cpufreq governor: performance volts: 1.2 V ext-clock: 100 MHz
    cores: 1: 2101 2: 2101 3: 2101 4: 2101 5: 2101 6: 2101 7: 2101 8: 2101
    bogomips: 54472
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    erms est f16c flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida lahf_lm lm mca
    mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
    rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
    tm tm2 tsc tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: PC Partner / Sapphire
    driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm
    built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DVI-D-1
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0 chip-ID: 1002:67df
    class-ID: 0300 temp: 44.0 C
  Display: x11 server: X.org v: 1.21.1.14 compositor: xfwm4 v: 4.18.0
    driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: DVI-D-1 mapped: DVI-D-0 model: Samsung SyncMaster
    serial: <filter> built: 2010 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
    chroma: red: x: 0.651 y: 0.337 green: x: 0.290 y: 0.612 blue: x: 0.145
    y: 0.071 white: x: 0.314 y: 0.329 size: 530x300mm (20.87x11.81")
    diag: 609mm (24") ratio: 16:9 modes: 1920x1080, 1600x1200, 1680x1050,
    1280x1024, 1440x900, 1280x960, 1280x800, 1280x720, 1024x768, 800x600,
    640x480
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 480 Graphics
    (radeonsi polaris10 LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO)
    device-ID: 1002:67df memory: 3.91 GiB unified: no
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: discrete-gpu name: AMD
    Radeon RX 480 Graphics (RADV POLARIS10) driver: N/A device-ID: 1002:67df
    surfaces: xcb,xlib
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon
    RX 470/480 / 570/580/590] vendor: PC Partner / Sapphire
    bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
  Device-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: Gigabyte
    driver: atl1c v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 06:00.0 chip-ID: 1969:1083 class-ID: 0200
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 465.76 GiB used: 240.17 GiB (51.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
  ID-1: / raw-size: 452.77 GiB size: 444.59 GiB (98.19%)
    used: 240.16 GiB (54.0%) fs: ext4 block-size: 4096 B dev: /dev/sda2
    maj-min: 8:2 label: N/A uuid: f806604e-3076-43c2-ab49-1bb7587e42da
    used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
    label: N/A uuid: EFBB-AE40
  ID-1: swap-1 type: partition size: 12.7 GiB used: 2.5 MiB (0.0%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: e2b46ab8-dc77-4dc7-8478-a89ef1122319
  Device-1: 1-3:2 info: SteelSeries ApS Apex 3 type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 1038:161a class-ID: 0300
  Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-4: 3-1:2 info: VIA Labs Hub ports: 4 rev: 2.0
    chip-ID: 2109:0811 class-ID: 0900
  Device-1: 3-1.3:3 info: Corsair Gaming HARPOON RGB Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 1b1c:1b3c class-ID: 0300
    serial: <filter>
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
  Hub-6: 5-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-7: 5-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Hub-8: 6-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-9: 6-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 1619
  Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1122 libs: 373 tools: pamac,yay
    pm: flatpak pkgs: 0
    1: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    3: http://manjaro.mirror.ac.za/stable/$repo/$arch
Processes:
  CPU top: 5 of 295
  1: cpu: 396% command: S:\common\Zenimax pid: 3475 mem: 4217.5 MiB (35.3%)
  2: cpu: 10.8% command: Proton pid: 3177 mem: 25.9 MiB (0.2%)
  3: cpu: 8.4% command: firefox pid: 3744 mem: 497.4 MiB (4.1%)
  4: cpu: 7.9% command: firefox pid: 3970 mem: 273.4 MiB (2.2%)
  5: cpu: 4.7% command: Xorg pid: 847 mem: 165.8 MiB (1.3%)
  Memory top: 5 of 295
  1: mem: 4217.5 MiB (35.3%) command: S:\common\Zenimax pid: 3475 cpu: 396%
  2: mem: 497.4 MiB (4.1%) command: firefox pid: 3744 cpu: 8.4%
  3: mem: 405.5 MiB (3.4%) command: ./steamwebhelper pid: 2564 cpu: 0.7%
  4: mem: 388.8 MiB (3.2%) command: steamwebhelper pid: 2657 cpu: 0.2%
  5: mem: 273.4 MiB (2.2%) command: firefox pid: 3970 cpu: 7.9%
  Processes: 295 Power: uptime: 52m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 4.63 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: N/A Shell: Sudo (sudo) v: 1.9.16p2 default: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.36
I have updated this system info with current changes I’ve made.
ok just created partition linux-swap and enabled swap. testing now.
NAME      TYPE       SIZE USED PRIO
/dev/sda3 partition 12.7G 256K   -2
That didn’t seem to make a difference but I did notice something this time. Providing I don’t put any input into the mouse or keyboard, the game (Elder scroll online) would continue to run smooth, even in the heart of the battle. The second I move the mouse or press a key, the stutter starts.
So I’ve gone back to look at the interrupts and found just moving the mouse is generating a lot. what do you guys think?
$ cat /proc/interrupts
           CPU0       CPU1       CPU2       CPU3       CPU4       CPU5       CPU6       CPU7
  8:          0          0          0          0          0          0          0          0  IR-IO-APIC   8-edge      rtc0
  9:          0          0          0          0          0          0          0          0  IR-IO-APIC   9-fasteoi   acpi
 16:          0          0          0          0         31          0          0          0  IR-IO-APIC  16-fasteoi   ehci_hcd:usb1
 18:          0          0         16          0          0          0          0          0  IR-IO-APIC  18-fasteoi   i801_smbus
 23:          0          0          0          0          0         35          0          0  IR-IO-APIC  23-fasteoi   ehci_hcd:usb4
 25:          0          0     109803          0          0          0          0          0  IR-PCI-MSI-0000:00:1f.2   0-edge      ahci[0000:00:1f.2]
 26:          0          0          0          0          0          0          0          0  IR-PCI-MSI-0000:07:00.0   0-edge      ahci[0000:07:00.0]
 27:          0          0          0          0          0       8469          0          0  IR-PCI-MSI-0000:00:14.0   0-edge      xhci_hcd
 35:          0          0          0          0          0          0     585985          0  IR-PCI-MSI-0000:03:00.0   0-edge      xhci_hcd
 36:    1665032          0          0          0          0          0          0          0  IR-PCI-MSI-0000:01:00.0   0-edge      amdgpu
 37:          0         21          0          0          0          0          0          0  IR-PCI-MSI-0000:00:16.0   0-edge      mei_me
 38:          0          0          0        832          0          0          0          0  IR-PCI-MSI-0000:00:1b.0   0-edge      snd_hda_intel:card0
 39:          0          0          0          0        646          0          0          0  IR-PCI-MSI-0000:01:00.1   0-edge      snd_hda_intel:card1
 40:          0          0          0          0          0     157878          0          0  IR-PCI-MSI-0000:06:00.0   0-edge      enp6s0
NMI:        161        158        164        155        151        156        159        162   Non-maskable interrupts
LOC:    1614684    1408763    1376624    1416652    2119733    1433071    1398561    1387949   Local timer interrupts
SPU:          0          0          0          0          0          0          0          0   Spurious interrupts
PMI:        161        158        164        155        151        156        159        162   Performance monitoring interrupts
IWI:     812197          0          0       1686       3955          3          2       1058   IRQ work interrupts
RTR:          0          0          0          0          0          0          0          0   APIC ICR read retries
RES:     476441     338308     329485     661907     796410     355415     343914     459974   Rescheduling interrupts
CAL:    2054848    2006180    1944702    2011357    2062412    1984551    1998779    1974115   Function call interrupts
TLB:    1156020    1165600    1122893    1130845    1104894    1119735    1121458    1145987   TLB shootdowns
TRM:          0          0          0          0          0          0          0          0   Thermal event interrupts
THR:          0          0          0          0          0          0          0          0   Threshold APIC interrupts
DFR:          0          0          0          0          0          0          0          0   Deferred Error APIC interrupts
MCE:          0          0          0          0          0          0          0          0   Machine check exceptions
MCP:         10         11         11         11         11         11         11         11   Machine check polls
ERR:          0
MIS:          0
PIN:          0          0          0          0          0          0          0          0   Posted-interrupt notification event
NPI:          0          0          0          0          0          0          0          0   Nested posted-interrupt event
PIW:          0          0          0          0          0          0          0          0   Posted-interrupt wakeup event
PMN:          0          0          0          0          0          0          0          0   Posted MSI notification event
Things I have tried already
*Enable xHCI
*Disable EHCI handoff
*USB 2.0 controller
*Disable legacy USB
Moderator edit: Removed unnecessary screenshot.
Hi @Dreamer, ad welcome!
Hi @, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
(P.S.: I have removed the image for now, please replace it with text as per the provided guide.)
Then you may need to ask Chatgpt whether you have enough swap.
:footprints:
Doesn’tlook that way…
Steam recently introduced a memory bug that showed up after around 30min while gaming, that lead to fps spikes.
Workaround till Steam finally fix it, right click on your Steam Game>Properties and put this in Launch Parameter:
LD_PRELOAD=“” %COMMAND%
Yes this has fixed the stuttering. Thank you!
I did some more research and found a newer version of proton called GE-proton. Using a tool ProtonUp-Qt, I’m able to install newer versions and add them to steam compatibility.
I will check tomorrow how this runs, as its 3am now and nobody is online to stress test it lol.
I’m glad i could help :slight_smile: :christmas_tree:
