I have two monitors attached to my nvidia card. To run them both, I had to run both on nvidia card. But I am running into another problem. When I start my laptop, the primary display starts until it reaches the login screen. The login screen is then switched to my external display while the laptop goes blank. After logging in, both monitors start working. This creates a problem when the external monitor is disconnected. The login screen doesn’t appear even then on the laptop, and I am not able to login. Is there a way to shift the login screen to my laptop display?
I am running i3wm with light-dm.
xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 510mm x 287mm
1920x1080 60.00*+ 59.94 50.00 60.00 50.04 50.04
1680x1050 59.95
1600x1200 60.00
1440x900 74.98 59.89
1400x1050 59.98
1360x768 60.02
1280x1024 75.02 60.02
1280x960 60.00
1280x720 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
eDP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
1920x1080 60.02*+ 59.93
1680x1050 59.88
1400x1050 59.98
1600x900 60.00 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1368x768 60.00 59.88 59.85
1280x800 59.81 59.91
1280x720 59.86 60.00 59.74
1024x768 60.00
1024x576 60.00 59.90 59.82
960x540 60.00 59.63 59.82
800x600 60.32 56.25
864x486 60.00 59.92 59.57
640x480 59.94
720x405 59.51 60.00 58.99
640x360 59.84 59.32 60.00
I am getting errors while trying to switch to integrated graphics(only laptop). and also when trying to switch from laptop to nvidia.
autorandr -c laptop
Failed to apply profile 'laptop' (line 860):
New profile configures output eDP-1 which does not exist in current xrandr --verbose output. Don't know how to proceed. (line 860)
I tried logging in through terminal and then starting X server, this doesn’t work also.
Yes, it should be eDP1. Changed the config file, and it worked from terminal. Now let me check the auto mode when the monitor is disconnected.
Edit: Checked, doesn’t work automatically. I think the main issue is with optimus which is not able to switch to integrated even when told to boot in integrated mode
that’s propably the issue. may you post your last config file so i can use it as example ? i will check optimus-manager and the autorandr but i need some days because i’m busy. propably it’s the solution to switch not in grub but in /etc/optimus-manager/optimus-manager.conf as described here.
in this case the grub has also be reedited and the two entries for nvidia must be deleted and grub must be updated. i’ll try it but please post the output of the last config and the path where it is stored.
hello @kramer ,
it’s okay, this is a interesting theme and i’ll check this autorandr in the following days and also if there are other options to change the displays at login. but it takes 2-3 days cause i’m busy with other problems actually.
