As a guess - a missing home folder can cause this - but you have provided no information - so there is really not much to say.
Please see the following articles if you need help - please provide the necessary information
stuck at the login screen, after typing my password the screen goes black for a second then I’m back at the login again.
Yup,just like this
Hi @John728,
Boot into a Live Environment, from there enter a chroot
environment, and use that to be able to provide more information. I’m guessing that might also be neccessary to fix anything after diagnosing it.
How to chroot
Ensure you’ve got a relatively new ISO or at least one with a still supported LTS kernel.
Write/copy/
dd
the ISO to a USB thumb drive. -
When done, boot with the above mentioned USB thumb drive into the live environment.
Once booted, open a terminal and enter the following command to enter the
chroot
environment:
manjaro-chroot -a
- If you have more than one Linux installation, select the correct one to use from the list provided.
When done, you should now be in the chroot
environment.
But, be careful, as you’re now in an actual root environment on your computer, so any changes you make will persist after a restart.
Tip
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
Is it the same in TTY?
CTR+ALT+F3 (for instance)
can you log in there?
If not: … what @Mirdarthos said
see where you /home/$user went —
Yes,I can log in tty
You must have done something - this does not just happen on it’s own.
I have some ideas, but no patience to explore them here.
Someone else might speculate and help.
I’ve not tried it, but perhaps you can then use useradd
from the command line to add a new user and see if that user can successfully login? If it can, you know it is (probably) the original user’s config which is causing the problem.
Also, from the tty you can get system information as requested above by @linux-aarhus
You can share it from the tty
without having to be able to copy-and-paste to a browser, for instance by sending the output to public sharing services:
Still looping after creating new user
