[Stable Update] 2024-08-20 - Kernels, Mesa, COSMIC, GNOME, Phosh, OGUI
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: Get 3 months extra
Recent News
Previous News
Notable Package Updates
Additional Info
Python 3.12 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.11.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.11/ :
pacman -Qoq /usr/lib/python3.11/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.11)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
Our current supported kernels
  • linux419 4.19.319
  • linux54 5.4.281
  • linux510 5.10.223
  • linux515 5.15.164
  • linux61 6.1.105
  • linux66 6.6.46
  • linux69 6.9.12 [EOL]
  • linux610 6.10.5
  • linux611 6.11.0 rc3
  • linux61-rt 6.1.102_rt37
  • linux66-rt 6.6.44_rt39
  • linux69-rt 6.9_rt5
  • linux610-rt 6.10.2_rt14
Package Changes (Sun Aug 18 06:01:31 CEST 2024)
  • stable core x86_64: 77 new and 77 removed package(s)
  • stable extra x86_64: 2389 new and 2482 removed package(s)
  • stable multilib x86_64: 34 new and 34 removed package(s)
A list of all package changes can be found here and here
0 voters
Known issues and solutions
:warning: Linux 6.9 is EOL
Linux 6.9 is EOL and will - at some point - be removed from the repo.
Please ensure your system use a supported kernel mhwd-kernel -l
:zap: KERNELS REMOVED
Linux 6.8 has been removed from repo.
:arrow_right: 2024-08-20
Some GTK apps on Gnome suddenly changed to other (bright) theme
The adw-gtk3 package is now called adw-gtk-theme which replaces the old adw-gtk-theme.
With that change, you may need to set Legacy Applications to Adw-gtk3-dark in the Tweaks application under Appearance. It may have been set to the now removed Adw-dark previously.
2024-08-08
pipewire-pulse conflicts with pulseaudio-ctl
pulseaudio-ctl is not compatible with PipeWire and should be removed:
pamac remove pulseaudio-ctl
Noisetorch from Extra repository cannot be updated
noisetorch on AUR has been updated to change pulseaudio dependency to pulse-native-provider
A similar change has not been implemented for repository package yet, so pipewire-pulse users may need to remove package before update
pamac remove noisetorch
Noisetorch 0.12.2-4 with pulse-native-provider dependency has been released to all Manjaro branches - Branch compare for Manjaro - noisetorch
2024-07-29
[details=]
[/details]
2024-07-01
The sshd service needs to be restarted after upgrading to openssh-9.8p1
2024-07-01 - Robin Candau
After upgrading to openssh-9.8p1, the existing SSH daemon will be unable to accept new connections (see Can't login after openssh 9.8p1-1 upgrade, MUST restart sshd (#5) · Issues · Arch Linux / Packaging / Packages / openssh · GitLab).
When upgrading remote hosts, please make sure to restart the sshd service using systemctl try-restart sshd right after upgrading.
We are evaluating the possibility to automatically apply a restart of the sshd service on upgrade in a future release of the openssh-9.8p1 package.
Arch Linux - News: The sshd service needs to be restarted after upgrading to openssh-9.8p1
Virtual machines using libvirt have no internet if the host uses UFW
This is a known bug. “Workaround” is to change the firewall with firewalld or to disable UFW.
Another easier workaround is to edit /etc/libvirt/network.conf, and add
firewall_backend = "iptables"
2024-05-14
No plasma interface with kernel 6.9 + Nvidia gpu + Wayland
If you encouter a black screen with no inteface after login in, it’s probably a problem with simpledrm loading.
To solve it add nvidia_drm.fbdev=1 to /etc/default/grub
in the line begining with GRUB_CMDLINE_LINUX=" .
Verify that you also have nvidia_drm.modeset=1 in the same line.
Then exec sudo update-grub
Also, verify that you have nvidia_drm in /etc/mkinitcpio.conf in the MODULES= or HOOKS= line.
Exemple :
MODULES=(nvidia nvidia_modeset nvidia_uvm nvidia_drm)
If it was not present, then run sudo mkinitcpio -P after adding it.
2024-05-13
Python interpreter upgrade
If you have a lot of pip/AUR packages to upgrade to Python 3.12, read this.
If you installed python312 from the AUR, you need to uninstall it before running this update.
Qemu: MacOS is not bootable with 9.0
Due to a bug MacOS is not bootable with 9.0: [9.0.0] qemu breaks mac os vm (#2334) · Issues · QEMU / QEMU · GitLab
Workaround: remove virtio-serial and org.qemu.guest_agent.0 from libvirt XML until bug will be fixed.
If you use KDE you better logout of your session and do the update via Pacman or Pamac in tty.
Helper script to reset plasma The balance of power and brought up from that fact. The Party said that. @liinux-aarhus
Also I would, before the update:
  • make a Timeshift snapshot if you ain’t got no recent one.
  • ( export content of widgets like your radio stations in Advanced Radio Player or your Podcasts in Kasts or any podcatcher as a backup )
  • make a fresh boot, but before that even:
  • System Settings > Appearance > Global Theme > set to Breath and tick both options for defaults
  • You might go to the hamburger menu in System Settings and look what changes you made away from default by selecting: Highlight Changed Settings and see if you want to make the effort to get back more defaults
  • System Settings > Workspace > Startup and Shutdown: SDDM defaults and Desktop Session: Start with empty session
  • disable all user-installed widgets that are still on your desktop, panels and even lock screen or wallpaper (e.g. Active Blur)
  • Export your custom shortcuts or mouse gestures in SS> Workspace > Shortcuts
  • Reboot, Timeshift snapshot, reboot
  • then do not log in, do the update via tty (CTRL+ALT+F3, same with F2 gets you back)
  • reboot, login, check through System Settings
  • reboot again
  • enjoy 8)
post-install:
  • look for Plasma 6 replacements for your widgets after the install
  • in case you have Github-installed theming: uninstall the KDE5-version of klassy, install the Plasma 6 version of klassy, maybe reinstall lightly
(greetings, @1efaf7d71a8637c6800a , PS: these are just my thoughts; I didn’t do this update yet!)
How to fix `plasma-firewall` error in System Settings GUI when running `ufw`
Open /usr/lib/kde_ufw_plugin_helper.py and change the first line from #!/usr/bin/python3.11 to #!/usr/bin/python3.12. This fixed the issue for me immediately and makes sense since Manjaro is currently on Python 3.12.
Xfce has inconsistent themes for Qt applications
Qt 6 is now default but some apps are still using Qt 5
To restore the look of QT apps after this update
pamac install kvantum-qt5
Manjaro-settings-manager has light theme instead of dark
2024-04-04
DKMS fails for v4l2loopback on 6.8 kernel
DKMS fails for v4l2loopback on 6.8 kernel (#2) · Issues · Arch Linux / Packaging / Packages / v4l2loopback · GitLab
issues with auto-mount of ntfs filesystem using Kernel 6.8
The kernel changed default ntfs driver from FUSE one to ntfs3.
These two are not fully compatible, mainly as far as mount options go. If you have custom mount options in the fstab (or any other application, such as VeraCrypt) they need to be changed.
Symptoms:
Mount fails with: Device or resource busy
DMesg reports: Can't open blockdev
Solution:
Migrate your mount options. For me the changes were:
  • allow_otherumask=000
  • default_permissions → [drop]
  • user_id=1000uid=1000
  • group_id=1000gid=1000
2024-03-06
gnome-keyring: ssh component is not included
ssh component is not included (#3) · Issues · Arch Linux / Packaging / Packages / gnome-keyring · GitLab
2024-02-21
plymouth update may cause black screens
With a newer version of plymouth than 22.02.122 you may experience an unbootable system with a black screen. This might be due to not having early KMS enabled. If you have an Nvidia GPU you could set nvidia_drm.modeset=1 nvidia_drm.fbdev=1 to the kernel parameters in your bootloader config to avoid the need of KMS. However, with Wayland around the corner, KMS will be needed.
To “fix” the current problem, we have downgraded plymouth once again to have more time to find a proper solution to migrate most of your installations to a working state with newer plymouth versions.
sudo pacman -Syuu
Those who don’t have issues can enjoy the newer version of plymouth.
Directions for adding kms to your system configuration and how you can help troubleshooting by providing some sysinfo, read more → Black Screen with Plymouth - Cause and Solution
polkit update might remove your local modified config
With polkit 124-1 there were changes made to etc/pam.d/polkit-1. So check if you made local changes to the file. See also: https://www.reddit.com/r/archlinux/comments/19bnj0i/comment/kit2v33/
bashrc-manjaro is now merged into bash
  • Yes, replace bashrc-manjaro with bash
  • Please also compare your:
    /etc/bash.bashrc
    with the generated
    /etc/bash.bashrc.pacsave
    and retrofit all of your customisations as there was no .pacnew file generated.
  • Same goes for /etc/skel/.bashrc
pacman and pacman-contrib changes
pacman-contrib is now split out from pacman. If you have anything installed that depends on pacman-contrib, update (after you finished the Release Update) with:
sudo pacman -Syu pacman-contrib
2024-01-13
Initramfs image can be bigger on 6.7 kernel due to Nvidia GSP Boot firmware
We all known that kernel 6.7 is very feature rich. One of the features is the inclusion of Nvidia’s GSP Boot firmware into Initramfs. However this will increase your image by 150 MB and the fallback image might be 240 MB in size. A way would be to remove kms from mkinitcpio.conf and redo your initramfs images. A discussion regarding that can be found at Arch Gitlab: kms hook increases the initramfs size heavily starting with 6.7 kernel (#238) · Issues · Arch Linux / Mkinitcpio / mkinitcpio · GitLab
To reduce size add fallback_options="-S autodetect -S kms" to /etc/mkinitcpio.d/linux67.preset
Making dbus-broker our default D-Bus daemon
2024-01-09 - Jan Alexander Steffens
We are making dbus-broker our default implementation of D-Bus, for improved performance, reliability and integration with systemd.
For the foreseeable future we will still support the use of dbus-daemon, the previous implementation. Pacman will ask you whether to install dbus-broker-units or dbus-daemon-units. We recommend picking the default.
For a more detailed rationale, please see our RFC 25.
Arch Linux - News: Making dbus-broker our default D-Bus daemon
In some cases, however it is better to keep the legacy way. Here are some examples: Dbus-broker warnings
22 posts were split to a new topic: What’s the holdup for Plasma 6.1?
4 posts were merged into an existing topic: What’s the holdup for Plasma 6.1?
Had a slightly different experience applying this update between my laptop and desktop… I assume this is because of ruby package differences when installing Manjaro on my laptop 6 months ago versus the desktop 2-3 years ago.
There were many prompts asking to replace ruby-<something> with /etc/ruby? Agreed with the replacement on the desktop, completed the update, rebooted, and all seems to be well post boot.
Only slight hiccup was when rebooting, got stuck at these messages following the System Reboot target, each appearing after considerable delay:
[  OK  ] Reached target System Reboot.
[04700.337097] systemd-journald[287]: Failed to send WATCHDOG=1 notification message: Connection refused
[04820.336831] systemd-journald[287]: Failed to send WATCHDOG=1 notification message: Transport endpoint is not connected
[04880.336713] systemd-journald[287]: Failed to send WATCHDOG=1 notification message: Transport endpoint is not connected
… etc., so I did a hard reset (REISUB not an option; no SysRq key on this machine) and all seems fine.
Only reason I mention it is I’ve not seen this before as far as I can remember. System was previously rebooted last night with no issues.
The system messages you encountered after a Manjaro update are related to the shutdown or reboot process. They indicate that the systemd-journald service attempted to send a watchdog notification to the system but failed due to connection issues. These errors are normal during shutdown or reboot and usually aren’t a cause for concern. If the messages only appear during these times, there’s nothing to worry about. However, if they occur during normal operation, you may need to investigate further.
Thanks, I guessed as much. I’ll see what happens next time I reboot. This could be weeks away though!
Where are the source files for mesa 24.1.6 on Gitlab to allow recompiling with “-D video-codecs=vc1dec,h264dec,h264enc,h265dec,h265enc” in PKGBUILD.
Used the following url to build mesa 24.1.5:
No need to compile anything, just install the current repo package inherited from Arch. By the way, those are old build flags.
Don’t do that. Notice that’s now an archived project and not up to date.
Hey all! in todays update gtk got updated and now most windows dark theme breaks. It was working just fine before that, could I be missing a dependency?
From the list of dependencies affected:
:: Different overlay package(s) in repository extra x86_64
                             PACKAGE           2024-08-04           2024-08-16
                            adjustor              3.4.2-1              3.4.4-1
                        adjustor-git3.4.2.r276.20240728.e33ecc0-13.4.4+4.r287.20240811.f9d262b-1
                       adw-gtk-theme                1.1-2                5.3-3
Nautilus applies the dark theme but other apps like Timeshift, VSCode, GRSync, etc are now applying the light theme even tho in Gnome-Settings under display, Dark Theme is still selected.
Similar case with me. Gedit is stuck in dark mode.
So apparently with this upgrade, gnome-tweak tool under appearance has selected Adw-gtk3. Changing to Adw-gtk3-dark solved my issue. :+1:
A post was split to a new topic: PGP key issue updating mullvad-vpn-beta
Error in this update
авг 21 11:46:07 sirena udisksd[1023]: Error probing device: Error sending ATA command IDENTIFY DEVICE to ‘/dev/sda’: Unexpected sense data returned:
0000: f0 00 01 00 50 e0 01 0a 00 00 00 00 00 1d 00 00 …P…
0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
(g-io-error-quark, 0)
авг 21 11:46:07 sirena udisksd[1023]: Error probing device: Error sending ATA command IDENTIFY DEVICE to ‘/dev/sdb’: Unexpected sense data returned:
0000: f0 00 01 00 50 00 01 0a 00 00 00 00 00 1d 00 00 …P…
It will be fixed in next kernel update 6.11.0rc4 or 6.10.6 or 6.6.47
I asked manjaro team in testing thread to push those kernel updates so we can get rid of this error.
Was using 6.6.46-1 kernel before upgrade with X230. But I have black screen right after decrypting LUKS. Switching to another kernel 6.10.5 solved the problem for me.
Which Error? :thinking:
3 posts were split to a new topic: Vlc player misbehaves
Visit link i posted and you will find out.
