Lenovo t14s (gen 1 amd) problems with displaylink (dockingstation + 2 external monitors)
Just got a good deal on awsome t14s, installed manjaro and everything works as wanted…except the docking station.
Im using a hp docking (universal dock G2). its working perfectly in windows.
But in manjaro I dont know where to begin… all the other things in the dockingstation works fine
the usb hub, and the intergrated gigabit ethernet card…except for the displays…
I have tried xrandr --listproviders with the result 0.
please help me out :slight_smile:
Hi @palmekiller, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
inxi --full --admin --filter --width                             ✔
  Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=0b54f2d1-7401-4493-ae10-d2948ad10e8d rw quiet
    cryptdevice=UUID=83363d02-507d-4c52-8e3c-24fc2004a8ee:luks-83363d02-507d-4c52-8e3c-24fc2004a8ee
    root=/dev/mapper/luks-83363d02-507d-4c52-8e3c-24fc2004a8ee splash
  Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Laptop System: LENOVO product: 20UJ001RMX v: ThinkPad T14s Gen 1
  Mobo: LENOVO model: 20UJ001RMX v: SDK0J40697 WIN
    serial: <superuser required> UEFI: LENOVO v: R1CET76W(1.45 ) date: 07/31/2023
  ID-1: BAT0 charge: 43.8 Wh (78.6%) condition: 55.7/57.0 Wh (97.7%)
    power: 26.4 W volts: 13.1 min: 11.5 model: Celxpert 5B10W139 type: Li-poly
    serial: <filter> status: charging cycles: 7
  Info: model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600109
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1695 high: 3955 min/max: 1400/1700 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 2733
    3: 1474 4: 1397 5: 1397 6: 1397 7: 1397 8: 1476 9: 1629 10: 1684 11: 1398
    12: 3955 13: 1397 14: 1606 15: 1397 16: 1397 bogomips: 54304
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spec_rstack_overflow mitigation: safe RET
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:1636 class-ID: 0300
    temp: 38.0 C
  Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-2:2 chip-ID: 04f2:b6cb
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0x573d built: 2018 res: 1920x1080
    dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon Graphics (renoir LLVM
    15.0.7 DRM 3.49 6.1.44-1-MANJARO) direct-render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
    link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: DisplayLink HP USB-C Universal Docking Station
    driver: snd-usb-audio type: USB rev: 3.2 speed: 5 Gb/s lanes: 1
    mode: 3.2 gen-1x1 bus-ID: 5-1.2:3 chip-ID: 17e9:601e class-ID: 0102
    serial: <filter>
  API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.77 status: off tools: pw-cli
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2400 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0f0 state: down mac: <filter>
  Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 5-1.4:5
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp6s0f3u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 6-4:3
    chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
  Local Storage: total: 238.47 GiB used: 17.19 GiB (7.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS256GDE9X081N
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 41730C20 temp: 32.9 C
    scheme: GPT
  ID-1: / raw-size: 130.74 GiB size: 127.63 GiB (97.62%)
    used: 17.15 GiB (13.4%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-83363d02-507d-4c52-8e3c-24fc2004a8ee
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 31.9 MiB (12.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 56.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  Processes: 446 Uptime: 12h 59m wakeups: 8295 Memory: total: 16 GiB note: est.
  available: 14.86 GiB used: 11.45 GiB (77.1%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1218 libs: 354 tools: gnome-software,pamac
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.29
You have to install proprietary display link drivers.
Google should help you. I don’t know the exact steps anymore, as I had the same issue 2 years ago.
After installing the drivers everything worked as expected.
I have looked into displaylink offical webpage, and the only linux installer they have is for ubuntu.
will it work for manjaro ?
or how do I find the proprietary drivers (except from the official displaylink webpage) ?
I have tried the yay -S displaylink.
thought it would work…but when I ran the systemctl status displaylinkservice i got:
systemctl status displaylink.service         INT ✘  21s 
● displaylink.service - DisplayLink Manager Service
     Loaded: loaded (/usr/lib/systemd/system/displaylink.service; disabled; preset: disabled)
     Active: activating (auto-restart) (Result: exit-code) since Sat 2023-08-26 12:26:50 CEST; 4s ago
    Process: 3793 ExecStartPre=/sbin/modprobe evdi (code=exited, status=1/FAILURE)
        CPU: 5ms
so the evdi driver/module dont seems to be working for some reason…dunno if this is the right way to go either.
I don’t know if this’ll help, but maybe it does:
https://forums.linuxmint.com/viewtopic.php?p=1673062&sid=6fc8956e08018a9d4c1d81f92c88f168#p1673062
The bolt package is in the AUR:
$ pamac search bolt
bolt  0.9.5-1        extra
Thunderbolt 3 device manager
So can be installed with:
pamac build bolt
But other than that, I’ve got absolutely positivly a negative amount of ideas.
no…
have installed boltctl…but it dont works. (or it maby works but dont help the case).
When I run it it just exits. I have tried using the --help option it shows commands but dont work.
I have absolutely no idea, except I get the feeling you are expecting a GUI interface and that is CLI. Because, this:
…is expected, and I don’t think it has a window, so it looks like:
All I can do is point you here:
https://wiki.archlinux.org/title/Lenovo_ThinkPad_T14s_(AMD)_Gen_1
No I dont get an output in the terminal (after I run the program) see the print.
https://paste.pics/23893b02d34cbfe937d42a9cef9c816a
And what’s the output of:
boltctl list
Edit:
See:
https://www.reddit.com/r/thinkpad/comments/lhwc6i/t14s_amd_dock_without_displaylink/gn032x0/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
…and:
same as boltctl,
yes I have read the links…but it seems like the displaylink.service is needed. and I get a error when trying to run it:
 systemctl status displaylink.service                             ✔
     Loaded: loaded (/usr/lib/systemd/system/displaylink.service; disabled; pre>
     Active: activating (auto-restart) (Result: exit-code) since Sat 2023-08-26>
    Process: 10854 ExecStartPre=/sbin/modprobe evdi (code=exited, status=1/FAIL>
        CPU: 5ms
its very little information about arch/manjaro and displaylink out there…
Let’s see if we can find more info. Please provide the output of
journalctl --unit=displaylink.service --no-pager
yes alot of the same errors seems like the evdi module is missing:
aug 26 14:08:33 laptopen systemd[1]: displaylink.service: Failed with result 'exit-code'.
aug 26 14:08:33 laptopen systemd[1]: Failed to start DisplayLink Manager Service.
aug 26 14:08:39 laptopen systemd[1]: displaylink.service: Scheduled restart job, restart counter is at 262.
aug 26 14:08:39 laptopen systemd[1]: Stopped DisplayLink Manager Service.
aug 26 14:08:39 laptopen systemd[1]: Starting DisplayLink Manager Service...
aug 26 14:08:39 laptopen modprobe[11601]: modprobe: FATAL: Module evdi not found in directory /lib/modules/6.1.44-1-MANJARO
aug 26 14:08:39 laptopen systemd[1]: displaylink.service: Control process exited, code=exited, status=1/FAILURE
aug 26 14:08:39 laptopen systemd[1]: displaylink.service: Failed with result 'exit-code'.
aug 26 14:08:39 laptopen systemd[1]: Failed to start DisplayLink Manager Service.
aug 26 16:03:40 laptopen systemd[1]: displaylink.service: Scheduled restart job, restart counter is at 263.
aug 26 16:03:40 laptopen systemd[1]: Stopped DisplayLink Manager Service.
aug 26 16:03:40 laptopen systemd[1]: Starting DisplayLink Manager Service...
aug 26 16:03:40 laptopen modprobe[11787]: modprobe: FATAL: Module evdi not found in directory /lib/modules/6.1.44-1-MANJARO
aug 26 16:03:40 laptopen systemd[1]: displaylink.service: Control process exited, code=exited, status=1/FAILURE
aug 26 16:03:40 laptopen systemd[1]: displaylink.service: Failed with result 'exit-code'.
aug 26 16:03:40 laptopen systemd[1]: Failed to start DisplayLink Manager Service.
aug 26 16:03:45 laptopen systemd[1]: displaylink.service: Scheduled restart job, restart counter is at 264.
aug 26 16:03:45 laptopen systemd[1]: Stopped DisplayLink Manager Service.
aug 26 16:03:45 laptopen systemd[1]: Starting DisplayLink Manager Service...
aug 26 16:03:45 laptopen modprobe[11861]: modprobe: FATAL: Module evdi not found in directory /lib/modules/6.1.44-1-MANJARO
aug 26 16:03:45 laptopen systemd[1]: displaylink.service: Control process exited, code=exited, status=1/FAILURE
aug 26 16:03:45 laptopen systemd[1]: displaylink.service: Failed with result 'exit-code'.
aug 26 16:03:45 laptopen systemd[1]: Failed to start DisplayLink Manager Service.
aug 26 16:03:51 laptopen systemd[1]: displaylink.service: Scheduled restart job, restart counter is at 265.
aug 26 16:03:51 laptopen systemd[1]: Stopped DisplayLink Manager Service.
aug 26 16:03:51 laptopen systemd[1]: Starting DisplayLink Manager Service...
aug 26 16:03:51 laptopen modprobe[11863]: modprobe: FATAL: Module evdi not found in directory /lib/modules/6.1.44-1-MANJARO
aug 26 16:03:51 laptopen systemd[1]: displaylink.service: Control process exited, code=exited, status=1/FAILURE
aug 26 16:03:51 laptopen systemd[1]: displaylink.service: Failed with result 'exit-code'.
aug 26 16:03:51 laptopen systemd[1]: Failed to start DisplayLink Manager Service.
aug 26 16:03:56 laptopen systemd[1]: displaylink.service: Scheduled restart job, restart counter is at 266.
aug 26 16:03:56 laptopen systemd[1]: Stopped DisplayLink Manager Service.
aug 26 16:03:56 laptopen systemd[1]: Starting DisplayLink Manager Service...
aug 26 16:03:56 laptopen modprobe[11870]: modprobe: FATAL: Module evdi not found in directory /lib/modules/6.1.44-1-MANJARO
aug 26 16:03:56 laptopen systemd[1]: displaylink.service: Control process exited, code=exited, status=1/FAILURE
aug 26 16:03:56 laptopen systemd[1]: displaylink.service: Failed with result 'exit-code'.
aug 26 16:03:56 laptopen systemd[1]: Failed to start DisplayLink Manager Service.
aug 26 16:04:01 laptopen systemd[1]: displaylink.service: Scheduled restart job, restart counter is at 267.
aug 26 16:04:01 laptopen systemd[1]: Stopped DisplayLink Manager Service.
aug 26 16:04:01 laptopen systemd[1]: Starting DisplayLink Manager Service...
aug 26 16:04:01 laptopen modprobe[11889]: modprobe: FATAL: Module evdi not found in directory /lib/modules/6.1.44-1-MANJARO
aug 26 16:04:01 laptopen systemd[1]: displaylink.service: Control process exited, code=exited, status=1/FAILURE
aug 26 16:04:01 laptopen systemd[1]: displaylink.service: Failed with result 'exit-code'.
aug 26 16:04:01 laptopen systemd[1]: Failed to start DisplayLink Manager Service.
Ah, it looks like now we’re getting somewhere. If that is, indeed, the cause, the evdi module in in the AUR:
$ pamac search evdi
evdi-compat-git  1.14.03-1        AUR
kernel module for DisplayLink driver, aimed at compatibility with DisplayLink package and Official kernels
So try and install it with:
pamac build evdi-compat-git
Reboot and see what happens.
If the OP does that; in the comments of this package:
The current version of this package (1.14.03.r0.g19476e7-1) does not work for me with up to date displaylink (5.7-1) and up to date arch kernel (6.3.8-arch1-1) using wayland.
and the pkg maintainer answers:
I use x btw, for me wayland doesn’t show in gdm from a long time. and I am too lazy to get wayland to work.
pamac search evdi         1 ✘
evdi  1.14.1-0 [Installed]
    A Linux® kernel module that enables management of multiple screens.
That’s why I said:
From the Arch wiki:
If you encounter issues, there are some upstream patches applied to evdi-compat-gitAUR as an alternative.
However, @6x12, may be right since AFAIK Gnome uses Wayland…so I guess if you want to continue using it, you’d have to switch to X…
yes thank you its working now !
works fine with kernel 6.1.44-1
Edit:
everything works perfect !
again thanks.
