Laptop keeps freezing
I am experiencing random freezing no matter what i do .
In the logs i found an error which idk if it has something to do with the freezing:
19-02-2023 21:16 kernel rtl_usb: Urb has error status 0xFFFFFFB9
Its being spammed most of the time
I can still swap tabs and use my mouse like normal .
If i for example try to watch a video and enter yay in my bash both will after waiting a little begin doing something at the same time.
OS: Manjaro Linux x86_64
Host: Latitude E6510 0001
Kernel: 6.1.11-1-MANJARO
Uptime: 24 mins
Packages: 1197 (pacman), 4 (flatpak)
Shell: bash 5.1.16
Resolution: 1920x1080 @ 60.00Hz, 1680x1050 @ 59.88Hz
DE: Plasma 5.26.5
WM: KWin
Theme: [Plasma], Breeze [GTK2/3]
Icons: [Plasma], breeze [GTK2/3]
Terminal: konsole
CPU: Intel i7 Q 720 (8) @ 1.600GHz [57.0°C]
GPU: NVIDIA NVS 3100M
Memory: 2303MiB / 15933MiB
Hi there.
Just to rule it out, have you tried running a more mature LTS kernel for a while, to see if you experience the same issues? Try 5.15 & see how you go. I can’t help beyond that.
All the best with this one, Ruziel :slight_smile:
Hi @Lukas, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
