Kernels above 6.12 don't remember multi-monitor settings
I have a dual monitor setup, and with every kernel since 6.12 LTS, then the dual setup gets forgotten, and my 2nd monitor stops working after leaving unattended for a short time. I have disabled the screen saver and sleep timers, but still the problem occurs. Even the latest LTS (6.18) suffers from this problem. If I disconnect the 2nd monitor, and reconnect, or reboot then the 2nd monitor works fine.
If I use Display with any kernel after 6.12, then the settings are not remembered, and usually fail to take, however if I “revert” them, my previously working dual setup is enabled, until the next screen lock.
I’m running the latest stable version of Manjaro with the Cinnamon desktop, although I have tried KDE, and the problem also seems to occur with that desktop also.
I’ve tried EVERY kernel version (available in Manjaro settings) after 6.12, and they all exhibit this problem.
Suggestions?
Hi @gandaflmeister, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
inxi --filter --verbosity=8 --color=0
Please also note and heed: Forum Rules - Manjaro
Those with privacy concerns: note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output. :eyes:
Hope you manage!
:bangbang: Tip for legibility: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
This is with both monitors operational and running 6.12 kernel
  Kernel: 6.12.73-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=f8c56da1-6bd1-49c8-af22-8e04bbfba94f rw quiet apparmor=1
  Desktop: Cinnamon v: 6.6.7 tk: GTK v: 3.24.51 wm: Muffin v: 6.6.3 tools:
    avail: cinnamon-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: N/A model: N/A v: V1.0 serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: P6_F8_10_01.09 date: 01/19/2025
  System RAM: total: 32 GiB available: 27.02 GiB used: 4.62 GiB (17.1%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 5600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: N/A
    part-no: DDR5 NB 16GB 5600MHZ serial: N/A
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen AI 9 HX 370 w/ Radeon 890M bits: 64 type: MT MCP
    arch: Zen 5 gen: 5 level: v4 note: check built: 2024+ process: TSMC n4 (4nm)
    family: 0x1A (26) model-id: 0x24 (36) stepping: 0 microcode: 0xB204019
  Device-1: Advanced Micro Devices [AMD/ATI] Strix [Radeon 880M / 890M]
    driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: DP-1,HDMI-A-1 empty: DP-2, DP-3, DP-4, DP-5, DP-6, DP-7,
    Writeback-1 bus-ID: c7:00.0 chip-ID: 1002:150e class-ID: 0380 temp: 42.0 C
  Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3.2.1:5
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9 driver:
    X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 10240x2880 s-size: <missing: xdpyinfo>
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right
    model: BenQ PD3200Q serial: <filter> built: 2021 res: mode: 2560x1440 hz: 60
    scale: 50% (2) to: 5120x2880 dpi: 92 gamma: 1.2 chroma: red: x: 0.655
    y: 0.333 green: x: 0.306 y: 0.627 blue: x: 0.145 y: 0.047 white: x: 0.314
    y: 0.329 size: 708x399mm (27.87x15.71") diag: 813mm (32") ratio: 16:9
    modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624,
    800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: left model: Samsung U32R59x
    serial: <filter> built: 2018 res: mode: 3840x2160 hz: 60
    scale: 75% (1.33333333333333) to: 5120x2880 dpi: 140 gamma: 1.2 chroma:
    red: x: 0.651 y: 0.341 green: x: 0.298 y: 0.624 blue: x: 0.149 y: 0.071
    white: x: 0.314 y: 0.329 size: 697x392mm (27.44x15.43")
    diag: 800mm (31.5") ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1200,
    1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 95 3: parse_edid: unhandled CEA mode 96 4: parse_edid:
    unhandled CEA mode 93 5: parse_edid: unhandled CEA mode 94
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 890M Graphics (radeonsi
    gfx1150 LLVM 21.1.6 DRM 3.61 6.12.73-1-MANJARO) device-ID: 1002:150e
    memory: 3.91 GiB unified: no
  API: Vulkan v: 1.4.341 layers: 2 device: 0 type: integrated-gpu name: AMD
    Radeon 890M Graphics (RADV GFX1150) driver: mesa radv v: 25.3.5-arch1.1
    device-ID: 1002:150e surfaces: N/A
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo x11: xprop,xrandr
  Packages: 1447 pm: pacman pkgs: 1427 libs: 445 tools: pamac pm: flatpak
    pkgs: 20
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: https://manjaro.ynh.ovh/stable/$repo/$arch
    3: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 501
  1: cpu: 10.6% command: vivaldi-bin pid: 42840 mem: 271.1 MiB (0.9%)
  2: cpu: 9.6% command: vivaldi-bin pid: 42766 mem: 339.6 MiB (1.2%)
  3: cpu: 8.5% command: vivaldi-bin pid: 42718 mem: 361.4 MiB (1.3%)
  4: cpu: 5.1% command: vivaldi-bin pid: 42798 mem: 251.6 MiB (0.9%)
  5: cpu: 2.2% command: gnome-terminal-server pid: 43276
    mem: 57.4 MiB (0.2%)
  Memory top: 5 of 501
  1: mem: 430.8 MiB (1.5%) command: Xorg pid: 1003 cpu: 1.3%
  2: mem: 365.8 MiB (1.3%) command: cinnamon pid: 3693 cpu: 1.4%
  3: mem: 361.4 MiB (1.3%) command: vivaldi-bin pid: 42718 cpu: 8.5%
  4: mem: 339.6 MiB (1.2%) command: vivaldi-bin pid: 42766 cpu: 9.6%
  5: mem: 287.8 MiB (1.0%) command: /newerversion started-by: dropbox
    pid: 6577 cpu: 0.2%
  Processes: 501 Power: uptime: 5h 34m states: freeze,mem,disk suspend: s2idle
    image: 10.79 GiB services: csd-power,upowerd Init: systemd v: 259
  Compilers: clang: 21.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.9
    running-in: gnome-terminal inxi: 3.3.40
