Jdk-openjdk and jre-openjdk are in conflict
I got this error today
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: jdk-openjdk and jre-openjdk are in conflict
AND
$ paru -R jre-openjdk
checking dependencies...
:: removing jre-openjdk breaks dependency 'jre21-openjdk=21.u35-3' required by jdk-openjdk
See
https://archlinux.org/news/incoming-changes-in-jdk-jre-21-packages-may-require-manual-intervention/
I got
$ sudo pacman -Syu jdk-openjdk
 mesa-nonfree is up to date
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
 repo-ck is up to date
resolving dependencies...
If you can’t be bothered to watch the Unstable Updates threads, then you have no business using the unstable branch.
I have tried this, it didn’t solve anything, see Jdk-openjdk and jre-openjdk are in conflict - #3 by Lycan
You have tried what? No one knows what this is.
 core is up to date
 extra is up to date
Even more
$ sudo pacman -R jre-openjdk jdk-openjdk
[sudo] password for alex:
:: brltty optionally requires java-runtime: Java support
:: erlang-nox optionally requires java-environment: for Java support
:: libbluray optionally requires java-runtime: BD-J library
:: libjpeg-turbo optionally requires java-runtime>11: for TurboJPEG Java wrapper
:: libjxl optionally requires java-runtime: for JNI bindings
:: opencv optionally requires java-runtime: Java interface
:: subversion optionally requires java-environment: for Java support
:: texlive-latexextra optionally requires java-runtime: for pdfannotextractor
Packages (2) jdk-openjdk-21.u35-3  jre-openjdk-21.u35-3
Total Removed Size:  309.56 MiB
:: Do you want to remove these packages? [Y/n]
(1/2) removing jdk-openjdk                                               [########################################] 100%
(2/2) removing jre-openjdk                                               [########################################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating icon theme caches...
(3/3) Updating the desktop file MIME type cache...
--------------------------------------------------------------------------------------------------------------- 19:36:37
[alex@alex-b450aoruselite ~]$ sudo pacman -Syu jdk-openjdk
 core is up to date
 extra is up to date
:: jdk-openjdk and jre-openjdk-headless are in conflict
OK, I needed to remove also jre-openjdk-headless
$ paru -R jre-openjdk-headless
Packages (1) jre-openjdk-headless-21.u35-3
Total Removed Size:  192.59 MiB
(1/1) removing jre-openjdk-headless                                      [########################################] 100%
(1/1) Arming ConditionNeedsUpdate...
Then installing jdk-openjdk works
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
Well, yes. That’s what it says:
@Lycan I realize I may have come across a little impolitely if not rude. That was not my intention and I apologize.
I’ve reopened the thread and unmarked the solution so you can reply and mark your own solution.
