{ resolving dependencies…
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: jdk-openjdk and jre-openjdk are in conflict )
This is end of outcome of < sudo pacman -Syyu >
I attempted to follow the steps in this solution
https://forum.manjaro.org/t/jdk-openjdk-and-jre-openjdk-are-in-conflict/150867/12
but I ran into this problem
:: Starting full system upgrade…
:: Replace kdsoap with extra/kdsoap-qt5? [Y/n] Y
:: Replace kuserfeedback with extra/kuserfeedback5? [Y/n] Y
:: Replace libqaccessibilityclient with extra/libqaccessibilityclient-qt5? [Y/n] Y
~ sudo pacman -R jre-openjdk jdk-openjdk 1 ✘ 1m 8s
[sudo] password for oldgadfly:
checking dependencies…
:: removing jdk-openjdk breaks dependency ‘java-environment’ required by junit
I am not wise enough to know what to do next,
Your assistance will be gratefully appreciated
MCD
