Disclaimer, I am 1 day old as a Linux user, and Manjaro is the distro I decided to go with given the positive things I saw online.
I am in Japan and often have to type in Japanese language. In the windows world this was quite easy and straightforward with the Japanese IME.
Can I obtain some guidance for dummies to have similar IME kind of Japanese input solution in Manjaro? I am using GNOME.
I found this article, but kinda lost on say, for example, how to enable UIM.
I have tried to enable Japanese input from the settings > regions and language, but this does not seem to work.
For GNOME, you add those variables to the file ~/.xprofile or in ~/.bashrc or ~/.zshrc
Or probably youâll need to change its settings either with this command from terminal:
gsettings set org.gnome.settings-daemon.plugins.xsettings overrides "{'Gtk/IMModule':<'fcitx'>}"
Probably you have to install fcitx-configtool fcitx-gtk2 fcitx-gtk3 fcitx-qt5 and a dictionary such as fcitx-mozc-ut2 from AUR or fcitx-mozc from community.
Install ibus and ibus-mozc i think, gnome integrates with them, you should after be able to select language in the settings app, i cannot verify now, (I now ise KDE) but if it doesnât work i can spin up a VM and figure it out.
but you should only need to install those two packages and it should work
EDIT: you will need to install it from the AUR IBus - ArchWiki
You can use Ibus-anthy or ibus-kkc however Ibus-mozc for me is easily the best experience out of box, Anthy is effectively dead and kkc is just kana string to kana-kanji string
As for installing fonts I reccomend you install
otf-ipafont - likely will be the main font you want to use
ttf-hanazono - a good quality font for backup
ttf-sazami - outdated but some old programs work best with it, likely wont use but good to have anyway
Some other fonts are listed here Localization/Japanese - ArchWiki but the ones I listed will cover you in most cases
Its a shame that mozc ibus is not in the main repository in manjaro or arch in general, despite it being pretty much the best experience (Both KDE, and Gnome have native integration for it and nothing else making it pretty much the defacto âeasiest useâ setup
EDIT2: KDE DOES have native fctix integration too with kcm-fcitx package, and does work better than Ibus, as Ibus just works within kimpanel
Having the issue with Japanese input as well. Having been reading around I get that Japanese input is not on the top of the priority list due to having a small user base in Manjaro community.
Still, I really love Manjaro, but need to get Japanese context aware input working. Used mozc on fcitx in Linux Mint were it worked almost like IME in Windows.
P.S.
Build of the package ibus-mozc-ut took time around 20 min. In addition to that, it might be possible that I already installed some Japanese fonts when I was trying to get fcitx working in Manjaro.
It was good for me on Linux Mint. Couldnât get it work here, but it seems ibus is integrated already. I also read somewhere that ibus is integrated better into Gnome than fcitx. My issue might be that I wasnât very version aware when I tried to install fcitx.
Does setting up fcitx5 work the same way as I described for ibus?
I just had Japanese input interupting input while typing kanji while commenting on Instagram Stories.
Iâll see some time, maybe today, if I can set up fcitx5. My issue with it was, that in the configtool I was unable to select any languages. No input methods either. They just werenât there.
It might be a noob issue, but If I manage to get past that and get fcitx5 working as well (not at the same time, since it might cause issues, I guess), it would be amazing for newcomers to refer to this post in the future.
Realmain, do you have any ideas, why that not having any languages in theconfigtoolsetup menu is happening?
You donât use fcitx for language?
I actually meant the GUI for config called fcitx-configtool. Actually it didnât occur to me that manjaro might already have a GUI which works with fcitx - that might be the issue
That fcitx-configtool is a default GUI for fcitx in Linux Mint which works alright with the panel. I actually didnât know it was a separate package before Manjaro, since Mint has a GUI for IM setup for all possible languages built in and where it guides you through fcitx install ( akin - push that button to downlaod and install the packages, then log out and log in, set up the configure tool on the panel) All the command line part is just hidden away.
Ohhhh thatâs what you meant. I forgot that I did use GUI. But for this one itâs fcitx5-configtool. I never had issues with it personally on Manjaro Openbox, KDE, or LXQt.
I really only used it once to select language (English, Vietnamese, Japanese), and never touched it again, since I use a hotkey to change languages.
You can also manually edit the file at ~/.config/fcitx5 instead (a lot more work though imo)
Yeah. I tried to combine fcitx packages with fcitx5. That might have been my undoing. I have some small issues with ibus right now, which I didnât have with fcitx in Linux Mint.
Iâd mark it solved if I were the OP. Now when we have âeverythingâ here. I probably will need to test it on my Gnome install I am currently running though, to be sure.
fcitx5 is much easier to set up than ibus. Just tried it out. In addition to what you said in that post, fcitx5-config-tool is also necessary for configuration.
To sum it up - it is actually really easy (with your guide) and fast to set up fcitx and everything is in Manjaro repositories! Config-tool has more options and it is more particular in terms of keyboard shortcuts and usabilty set up.
Good we have instructions for ibus and fcitx5 out, so newcomers could refer this thread.
One remark: it is probably a Gnome thing - the integrated Language settings toolbar menu is for ibus. fcitx5 creates a separate keyboard icon on the top bar for choosing input methods manually.
Sorry to excavate this thread but I am currently facing a rather similar issueâŠ
I am using KDE desktop and so far had nothing but trouble with fcitx mozc since it strangely refuses to work anywhere except for firefox⊠so I can write ăČăăăȘ ă«ăżă«ă æŒąć without any issues here, but once I switch to any other application it just refuses to activate.
I tried switching from fcitx to fcitx5⊠but that also did not fix the issue. Since I am also living in Japan, being able to input Japanese text is kinda essentialâŠ
I think I have tried everything suggested in this and the other thread without any results
(I hope I havenât overlooked anything?)
Any ideas?
Thank you in advance!
edit: found this japanese person who seemed to have had a very similar issue:
only with Mint and the flatpak version of office.
he resolved the issue using
But thatâs not going to help me in my case⊠but it may help you, help me?
edit2: so I reset my setup back to fcitx from fcitx5 with timeshift⊠and now it suddenly just works⊠what? Not sure if this is just a lucky fluke of itâs permanent but⊠I guess issue solved (for now)
Could have been some package issue. Most probably based on my newbie experience, this âsuddenly just worksâ situation happens, because OS starts reading modified config files or .xprofile after you log in again or do a restart (more fool proof).
I had this âdoesnât work - Oh! It now worksâ moment, literally, with both when setting up Japanese-Mozc with IBUS and with FCITX5 (coming from Linux Mint wasnât aware that Fcitx5 exists, the GUI is much easier to understand in FCITX5). My âmagicâ was based on 2 factors: correct .xprofile contents and reboot after changing .xprofile.
Wrote here ârebootâ, but I guess it was enough of log out - log in for fcitx5.
If that issue is based on that (most probably). You wonât encounter it again, unless you decide to start changing up the input method part in .xprofile, which I donât think anybody would, since it sits unchanged from the day I configured it for myself as described above.
Edit: under .xprofileI mean a hidden file in your home folder - i.e ~/.xprofile.
Iâve been using fcitx without issue for a while, but ran into the blackscreen after log in bug after I used SUPER+SPACE, which brings up the Gnome language selector, while fcitx didnât want to activate.
Had to remove fcitx to get my desktop working again. Trying ibus-mozc, since I would prefer a more integrated solution.
In Manjaro 21.1 gnome40 there is a module to install in software GUI (pamac) called Fcitx5-mozc (2.26)
Is it enough to install that & then be able to add Japanese input source in settings>keyboard ?
I have a Japanese laptop, I live in Japan.
In Ubuntu21.4 it was simple to add mozc input, but not looking quite so easy from the above messages, im having difficulty as a beginner to follow whats required.
