Issue with Running Rise of Kingdoms on Manjaro Linux: Stuck at 6% and Black Screen
Hello,
I am a Linux user and I am using Manjaro, which is based on Arch Linux. I have been trying to run the game Rise of Kingdoms on my system, but I’m encountering some issues. When I try to launch the game, the loading screen gets stuck at 6%, and after the intro video finishes, the window just shows a black screen.
I have tried running the game on both Bottles and Lutris, but the issue persists on both platforms. The intro video finishes, but then the screen remains black, and the game doesn’t start.
Any suggestions or help would be appreciated. Thank you!
Hi @Novus_Exodus1, and welcome!
Considering you’re here, I’d hope so! :wink:
:wink:
All I can think of is perhaps trying a different, possibly newer Wine/Proton version.
But anyhoo, as a new forum user, please familiarise yourself with the many ways to use the forum efficiently, thereby saving both you and those trying to help much time and headaches
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip for legibility: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum Users. Please take the time to follow links given and learn how to create effective Support requests and encourage quality responses.
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=fe0fd7d9-3e73-4e89-a978-5caea4a31a8a rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
    wm: kwin_x11 with: Docker vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: A320M-A PRO (MS-7C51) v: 1.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 1.71 date: 07/20/2022
  System RAM: total: 24 GiB available: 23.39 GiB used: 15.83 GiB (67.7%)
  Array-1: capacity: 128 GiB slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
    (unregistered) size: 16 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF3200C16D4/16GX serial: <filter>
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Geil
    part-no: GD2.1527WC.002 serial: <filter>
  Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen+ gen: 1+
    level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
    model-id: 8 stepping: 2 microcode: 0x800820D
    smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
    desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 3167 min/max: 1550/3200 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 3167 2: 3167 3: 3167
    4: 3167 5: 3167 6: 3167 7: 3167 8: 3167 9: 3167 10: 3167 11: 3167 12: 3167
    bogomips: 76831
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
    XT/6600M] vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1,
    Writeback-1 bus-ID: 2b:00.0 chip-ID: 1002:73ff class-ID: 0300
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4 compositors:
    1: kwin_x11 2: SurfaceFlinger 3: Weston v: 14.0.0 driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: DP-1 mapped: DisplayPort-0 model: Kingston W2712RUC
    serial: <filter> built: 2020 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 82 gamma: 1.2 chroma: red: x: 0.663 y: 0.325 green: x: 0.271 y: 0.596
    blue: x: 0.133 y: 0.118 white: x: 0.302 y: 0.365
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x960,
    1360x768, 1280x800, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480, 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
    LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:73ff
    memory: 7.81 GiB unified: no
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: discrete-gpu name: AMD
    Radeon RX 6600 (RADV NAVI23) driver: N/A device-ID: 1002:73ff
    surfaces: xcb,xlib
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 2b:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 2d:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-3: Razer USA Seiren Mini driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
    chip-ID: 1532:0531 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Message: No PCI device data found.
  Device-1: Realtek RTL8188GU 802.11n WLAN Adapter (After Modeswitch)
    driver: rtl8xxxu type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-7:8 chip-ID: 0bda:b711 class-ID: 0000 serial: <filter>
  IF: wlp3s0f0u7 state: up mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  IF-ID-2: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  IF-ID-3: vethtdKfUM state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-4: waydroid0 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  Local Storage: total: 1.12 TiB used: 157.66 GiB (13.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 240GB SSD
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0M13 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: HD502HJ
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 00E4 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 model: SATA SSD size: 223.57 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 81.3 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST9250315AS
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM1 scheme: MBR
  ID-1: / raw-size: 223.28 GiB size: 218.71 GiB (97.96%)
    used: 157.66 GiB (72.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: fe0fd7d9-3e73-4e89-a978-5caea4a31a8a
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 0CA4-2C24
  ID-1: /dev/sdc1 maj-min: 8:33 size: 223.57 GiB fs: ntfs label: ssd2
    uuid: AECABEFBCABEBF41
  ID-2: /dev/sdd1 maj-min: 8:49 size: 232.88 GiB fs: ntfs
    label: ayr\xc4\xb1kotu uuid: 7AF87CB5F87C70ED
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
  Device-1: 1-3:2 info: Razer USA Seiren Mini type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  Device-2: 1-7:8 info: Realtek RTL8188GU 802.11n WLAN Adapter (After
    Modeswitch) type: Network driver: rtl8xxxu interfaces: 1 rev: 2.0
  Device-3: 1-8:9 info: Thetis Security Key(F825) type: HID,smart card
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1ea8:f825 class-ID: 0b00
  Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
  Device-1: 3-2:2 info: ASUSTek TUF GAMING M3 type: mouse,HID,keyboard
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 0b05:1910 class-ID: 0300
  Device-2: 3-3:3 info: China Resource Semico USB Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 98mA chip-ID: 1a2c:2c27 class-ID: 0300
  Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 52.8 C mobo: N/A gpu: amdgpu temp: 49.0 C
    mem: 52.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: 1533 pm: pacman pkgs: 1485 libs: 398 tools: pamac,yay pm: flatpak
    pkgs: 23 pm: snap pkgs: 25
    1: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    2: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    3: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    4: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    6: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    7: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    8: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 520
  1: cpu: 202% command: qemu-system-x86_64 pid: 49074 mem: 3842.1 MiB (16.0%)
  2: cpu: 97.2% command: clamscan pid: 105020 mem: 1365.0 MiB (5.6%)
  3: cpu: 46.1% command: player pid: 49045 mem: 730.7 MiB (3.0%)
  4: cpu: 20.4% command: steamwebhelper pid: 65959 mem: 218.9 MiB (0.9%)
  5: cpu: 12.1% command: clamtk started-by: perl pid: 103057
    mem: 103.8 MiB (0.4%)
  Memory top: 5 of 520
  1: mem: 3842.1 MiB (16.0%) command: qemu-system-x86_64 pid: 49074 cpu: 202%
  2: mem: 1365.0 MiB (5.6%) command: clamscan pid: 105020 cpu: 97.2%
  3: mem: 1358.1 MiB (5.6%) command: clamd pid: 980 cpu: 0.1%
  4: mem: 781.6 MiB (3.2%) command: firefox pid: 2698 cpu: 10.4%
  5: mem: 730.7 MiB (3.0%) command: player pid: 49045 cpu: 46.1%
  Processes: 520 Power: uptime: 5h 49m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 9.34 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
Hello,
First of all, I apologize for the delayed response. Here’s the issue I’m facing: The game’s launcher works without any problems, and I can receive updates. However, when I try to launch the game through the launcher, I get an error. Could you please assist me with this?
Additionally, I am a new Linux user, so I believe I will need more guidance. Could you kindly explain the steps in a simple and clear manner? I greatly appreciate your help in advance.
Never played this but does this help:
https://www.reddit.com/r/RiseofKingdoms/comments/10l9mbi/how_to_play_rise_of_kingdoms_pc_version_on_linux/
The post does link to specific distribution steps, on arch you have to find the correct steps yourself or ask again here, there might be someone to help.
Forum users are no psychic, please share the error message.
You are right, but the game goes black and crashes without showing any error message.
I misunderstood and assumed there was an error message since you posted.
(google translate: Yanlış anladım ve siz gönderdiğinizden beri bir hata mesajı olduğunu varsaydım.)
I’ve added the language tag Turkish since that is what google translate tells me.
Google çeviri bana bunu söylediği için Türkçe dil etiketini ekledim.
There is probably not enough information here to guess.
All I see is that the game seems to crash; this could be related to how you have installed and configured the game or possibly a variety of other factors.
I note that in the 2 year old Reddit thread referenced by @Hanzel there are others obviously having difficulty with those instructions.
There’s the issue at “6%” that you mentioned, for example.
I don’t know if the above comment from that thread helps, but I also note a comment from the tutorial creator:
So, it would seem that Rise of Kingdoms is not an easy beast to tame on Linux, generally.
To the extent that it might potentially be contributing, I note you have no swap space configured. This can often be overlooked when installing Manjaro, but likely has no bearing on the immediate issue.
I’m not a Gamer but those Members who seem to live and breathe this type of game may potentially have something to add.
In the meantime, some resources which may be useful:
