Installing driver for 10a5:9800 fingerprinter
Hello,
I am new to Manjaro and tried to install the driver for my fingerprinter.
When using lsusb i see that my fingerprinter is
Bus 003 Device 002: ID 10a5:9800 FPC FPC Sensor Controller L:0001 FW:16.26.23.14
Lenovo published an offical driver for it for Ubuntu which could be found here:
FPC FingerPrint Driver for Ubuntu 20.04, Ubuntu 22.04 - ThinkPad E14 Gen 4, E15 Gen 4 - Lenovo Support AT.
I found this (AUR (en) - libfprint-fpcmoh-git) AUR package where i thinked it should be the published driver from Lenovo for Arch. However after installing i still get the error:
Impossible to enroll: GDBus.Error:net.reactivated.Fprint.Error.NoSuchDevice: No devices available. when i use the fprintd-enroll command. Does some one know if i miss a step or did something wrong?
Hi @mol97lpo, and welcome!
How did you find this?
Where did you get this? Searching for those details here only yields failed results and a message:
We have not found a driver for the device in any Linux kernel versions up to 6.3 according to the LKDDb.
As well as:
We have not found a driver for the device in known additional packages.
Which makes me think it’s too new. But I might be wrong. To get a more definite answer, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Thank you for your answer I updated my post with more information.
Hmmm…
As requested in:
…please provide the output of:
Here the output
  Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=6464b0d6-8375-48fe-9bd2-bc6fb8b349e1 rw quiet splash apparmor=1
    security=apparmor resume=UUID=2125712f-c788-446c-b3e4-1e71c73a84e8
    udev.log_priority=3
  Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Laptop System: LENOVO product: 21EES00100 v: ThinkPad E15 Gen 4
  Mobo: LENOVO model: 21EES00100 v: ThinkPad serial: <superuser required>
    UEFI: LENOVO v: R20ET26W (1.06 ) date: 02/18/2022
  ID-1: BAT0 charge: 10.7 Wh (21.1%) condition: 50.7/57.0 Wh (89.0%)
    power: 35.2 W volts: 11.9 min: 11.5 model: SMP LNV-5B11C73244 type: Li-poly
    serial: <filter> status: charging cycles: 161
  System RAM: total: 16 GiB note: est. available: 14.46 GiB
    used: 4.42 GiB (30.6%)
  Info: model: AMD Ryzen 7 5825U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    microcode: 0xA50000C
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 1443 high: 3878 min/max: 400/4546 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3632 2: 400 3: 400
    4: 400 5: 400 6: 400 7: 3378 8: 2918 9: 1900 10: 3878 11: 400 12: 400
    13: 1397 14: 400 15: 1397 16: 1397 bogomips: 63917
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
  Type: spec_rstack_overflow mitigation: safe RET, no microcode
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1,eDP-1
    empty: DP-1 bus-ID: 04:00.0 chip-ID: 1002:15e7 class-ID: 0300 temp: 47.0 C
  Device-2: Bison Integrated RGB Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 5986:2146
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.1
    compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-1 model: BenQ RL2450H serial: <filter> built: 2012
    res: 1920x1080 dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73")
    diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: eDP-1 model: ChiMei InnoLux 0x151e built: 2019 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
    device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
    drv: radeonsi inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
    16.0.6 DRM 3.54 6.5.5-1-MANJARO) device-ID: 1002:15e7 memory: 1000 MiB
    unified: no display-ID: :0.0
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.80 status: off tools: pw-cli
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek vendor: Lenovo driver: rtw89_8852be v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:b852
    class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:4853
  Local Storage: total: 476.94 GiB used: 15.63 GiB (3.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
    model: UMIS RPJTJ512MGE1QDQ size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 1.5Q0630 temp: 21.9 C scheme: GPT
  ID-1: / raw-size: 21.48 GiB size: 20.98 GiB (97.65%) used: 11.13 GiB (53.1%)
    fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
    uuid: 6464b0d6-8375-48fe-9bd2-bc6fb8b349e1
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: 3A59-435A
  ID-3: /home raw-size: 110.51 GiB size: 108.22 GiB (97.92%)
    used: 4.5 GiB (4.2%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
    uuid: a8afa435-a006-4999-bb5c-6334a84cd0c2
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-2: swap-2 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -3
    dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: 2125712f-c788-446c-b3e4-1e71c73a84e8
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 560F-8161
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 341.7 GiB fs: ntfs label: N/A
    uuid: DA6E12A16E12768B
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 641 MiB fs: ntfs label: N/A
    uuid: 121E50261E50055F
  Device-1: 1-2:2 info: Razer USA RZ01-0321 Gaming Mouse [DeathAdder V2]
    type: mouse,keyboard driver: hid-generic,usbhid interfaces: 4 rev: 2.0
    chip-ID: 1532:0084 class-ID: 0300
  Device-2: 1-3:3 info: Bison Integrated RGB Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 5986:2146 class-ID: fe01 serial: <filter>
  Device-1: 3-3:2 info: FPC Sensor Controller L:0001 FW:16.26.23.14
    type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1
    chip-ID: 10a5:9800 class-ID: 0000
  Device-2: 3-4:3 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
    interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
  System Temperatures: cpu: 56.0 C mobo: N/A gpu: amdgpu temp: 47.0 C
  Fan Speeds (rpm): fan-1: 2200 fan-2: 2200
  Processes: 359 Uptime: 35m wakeups: 1 Init: systemd v: 254 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
  pkgs: 1214 libs: 344 tools: gnome-software,pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.30
Please provide the output of:
systemctl status fprintd.service
Edit:
According to this page:
Unfortunately, as I understand now from the Linux hardware database for this device, there are no drivers for this fingerprint scanner model.
And while this is for Ubuntu, Ubuntu is also a Linux Distribution, so it applies to Manjaro as well in this case.
Which is actually what I said earlier:
Edit #2:
That driver you tried to install, what was the output during the process? Maybe, since the AUR package is there, and available to be installed, you’re simply missing the kernel headers or something…
Without more information, it is impossible to be :100: sure…
Thats the output:
○ fprintd.service - Fingerprint Authentication Daemon
     Loaded: loaded (/usr/lib/systemd/system/fprintd.service; static)
     Active: inactive (dead)
       Docs: man:fprintd(1)
Okt 15 10:27:04 mollpo-21ees00100 systemd[1]: Starting Fingerprint Authentication Daemon...
Okt 15 10:27:04 mollpo-21ees00100 systemd[1]: Started Fingerprint Authentication Daemon.
Okt 15 10:27:35 mollpo-21ees00100 systemd[1]: fprintd.service: Deactivated successfully.
Okt 15 10:27:37 mollpo-21ees00100 systemd[1]: Starting Fingerprint Authentication Daemon...
Okt 15 10:27:37 mollpo-21ees00100 systemd[1]: Started Fingerprint Authentication Daemon.
Okt 15 10:28:07 mollpo-21ees00100 systemd[1]: fprintd.service: Deactivated successfully.
Okt 15 10:29:41 mollpo-21ees00100 systemd[1]: Starting Fingerprint Authentication Daemon...
Okt 15 10:29:41 mollpo-21ees00100 systemd[1]: Started Fingerprint Authentication Daemon.
Okt 15 10:30:12 mollpo-21ees00100 systemd[1]: fprintd.service: Deactivated successfully.
and thats the output if I reinstall it:
==> Making package: libfprint-fpcmoh-git 1.94.6.r10.g2414dbd-1 (So 15 Okt 2023 10:42:13)
==> Retrieving sources...
  -> Updating libfprint git repo...
  -> Found fpcbep.zip
  -> Found 396.patch
    libfprint ... Skipped
    fpcbep.zip ... Passed
    396.patch ... Skipped
==> Extracting sources...
  -> Creating working copy of libfprint git repo...
Cloning into 'libfprint'...
done.
  -> Extracting fpcbep.zip with bsdtar
==> Starting prepare()...
==> Starting pkgver()...
==> Removing existing $pkgdir/ directory...
==> Starting build()...
+ exec meson setup --prefix /usr --libexecdir lib --sbindir bin --buildtype plain --auto-features enabled --wrap-mode nodownload -D b_lto=true -D b_pie=true -D python.bytecompile=1 libfprint build
The Meson build system
Version: 1.2.2
Source dir: /home/mollpo/libfprint-fpcmoh-git/src/libfprint
Build dir: /home/mollpo/libfprint-fpcmoh-git/src/build
Build type: native build
Project name: libfprint
Project version: 1.94.6
C compiler for the host machine: cc (gcc 13.2.1 "cc (GCC) 13.2.1 20230801")
C linker for the host machine: cc ld.bfd 2.41.0
C++ compiler for the host machine: c++ (gcc 13.2.1 "c++ (GCC) 13.2.1 20230801")
C++ linker for the host machine: c++ ld.bfd 2.41.0
Host machine cpu family: x86_64
Host machine cpu: x86_64
Compiler for C supports arguments -Wall: YES
Compiler for C supports arguments -Wcast-align: YES
Compiler for C supports arguments -Wformat-nonliteral: YES
Compiler for C supports arguments -Wformat-security: YES
Compiler for C supports arguments -Wformat=2: YES
Compiler for C supports arguments -Wignored-qualifiers: YES
Compiler for C supports arguments -Wlogical-op: YES
Compiler for C supports arguments -Wmissing-declarations: YES
Compiler for C supports arguments -Wmissing-format-attribute: YES
Compiler for C supports arguments -Wmissing-include-dirs: YES
Compiler for C supports arguments -Wmissing-noreturn: YES
Compiler for C supports arguments -Wpointer-arith: YES
Compiler for C supports arguments -Wshadow: YES
Compiler for C supports arguments -Wswitch-enum: YES
Compiler for C supports arguments -Wtype-limits: YES
Compiler for C supports arguments -Wundef: YES
Compiler for C supports arguments -Wunused: YES
Compiler for C supports arguments -Werror=address: YES
Compiler for C supports arguments -Werror=array-bounds: YES
Compiler for C supports arguments -Werror=empty-body: YES
Compiler for C supports arguments -Werror=init-self: YES
Compiler for C supports arguments -Werror=int-to-pointer-cast: YES
Compiler for C supports arguments -Werror=main: YES
Compiler for C supports arguments -Werror=missing-braces: YES
Compiler for C supports arguments -Werror=nonnull: YES
Compiler for C supports arguments -Werror=redundant-decls: YES
Compiler for C supports arguments -Werror=return-type: YES
Compiler for C supports arguments -Werror=sequence-point: YES
Compiler for C supports arguments -Werror=trigraphs: YES
Compiler for C supports arguments -Werror=write-strings: YES
Compiler for C supports arguments -fno-strict-aliasing: YES
Compiler for C supports arguments -DGLIB_VERSION_MIN_REQUIRED=GLIB_VERSION_2_56: YES
Compiler for C supports arguments -DGLIB_VERSION_MAX_ALLOWED=GLIB_VERSION_2_56: YES
Compiler for C supports arguments -D_GNU_SOURCE: YES
Compiler for C supports arguments -DG_LOG_DOMAIN="libfprint": YES
Compiler for C supports arguments -Wimplicit-function-declaration: YES
Compiler for C supports arguments -Wmissing-prototypes: YES
Compiler for C supports arguments -Wnested-externs: YES
Compiler for C supports arguments -Wold-style-definition: YES
Compiler for C supports arguments -Wstrict-prototypes: YES
Compiler for C supports arguments -Werror=implicit: YES
Compiler for C supports arguments -Werror=pointer-to-int-cast: YES
libfprint/meson.build:74: WARNING: Consider using the built-in warning_level option instead of using "-Wall".
libfprint/meson.build:75: WARNING: Consider using the built-in warning_level option instead of using "-Wall".
Found pkg-config: /usr/bin/pkg-config (1.8.1)
Run-time dependency glib-2.0 found: YES 2.78.0
Run-time dependency gio-unix-2.0 found: YES 2.78.0
Run-time dependency gobject-2.0 found: YES 2.78.0
Run-time dependency gusb found: YES 0.4.6
Library m found: YES
Run-time dependency cairo found: YES 1.18.0
Run-time dependency gobject-introspection-1.0 found: YES 1.78.1
Run-time dependency pixman-1 found: YES 0.42.2
Run-time dependency nss found: YES 3.94
Library fpcbep found: YES
Run-time dependency gudev-1.0 found: YES 238
Run-time dependency udev found: YES 254
libfprint/meson.build:259: WARNING: Project targets '>= 0.56.0' but uses feature deprecated since '0.56.0': dependency.get_pkgconfig_variable. use dependency.get_variable(pkgconfig : ...) instead
Dependency udev found: YES 254 (cached)
libfprint/meson.build:290: WARNING: udev hwdb will be installed by both systemd and libfprint
libfprint/meson.build:296: WARNING: Project targets '>= 0.56.0' but uses feature deprecated since '0.56.0': dependency.get_pkgconfig_variable. use dependency.get_variable(pkgconfig : ...) instead
Dependency glib-2.0 found: YES 2.78.0 (cached)
Program glib-mkenums found: YES (/usr/bin/glib-mkenums)
Configuring fpi-drivers.c with command
Compiler for C supports arguments -Wno-error=redundant-decls: YES
Compiler for C supports arguments -Wno-redundant-decls: YES
Compiler for C supports arguments -Wno-discarded-qualifiers: YES
Compiler for C supports arguments -Wno-array-bounds: YES
Compiler for C supports arguments -Wno-array-parameter: YES
Dependency gobject-introspection-1.0 found: YES 1.78.1 (cached)
Program g-ir-scanner found: YES (/usr/bin/g-ir-scanner)
Program g-ir-compiler found: YES (/usr/bin/g-ir-compiler)
Configuring config.h using configuration
Configuring gtkdocentities.ent using configuration
libfprint/doc/meson.build:22: WARNING: Project targets '>= 0.56.0' but uses feature deprecated since '0.56.0': dependency.get_pkgconfig_variable. use dependency.get_variable(pkgconfig : ...) instead
Program gtkdoc-scan found: YES (/usr/bin/gtkdoc-scan)
Program gtkdoc-scangobj found: YES (/usr/bin/gtkdoc-scangobj)
Program gtkdoc-mkdb found: YES (/usr/bin/gtkdoc-mkdb)
Program gtkdoc-mkhtml found: YES (/usr/bin/gtkdoc-mkhtml)
Program gtkdoc-fixxref found: YES (/usr/bin/gtkdoc-fixxref)
Program python3 found: YES (/usr/bin/python3)
Configuring create-driver-test.py using configuration
Program unittest_inspector.py found: YES (/home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/unittest_inspector.py)
Program umockdev-test.py found: YES (/home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/umockdev-test.py)
Program sh found: YES (/usr/bin/sh)
Configuring driver-aes2501.test using configuration
Configuring driver-aes3500.test using configuration
Configuring driver-elan.test using configuration
Configuring driver-elan-cobo.test using configuration
Configuring driver-elanmoc.test using configuration
Configuring driver-elanspi.test using configuration
Configuring driver-synaptics.test using configuration
Configuring driver-upektc_img.test using configuration
Configuring driver-upektc_img-tcs1s.test using configuration
Configuring driver-uru4000-msv2.test using configuration
Configuring driver-uru4000-4500.test using configuration
Configuring driver-vfs0050.test using configuration
Configuring driver-vfs301.test using configuration
Configuring driver-vfs5011.test using configuration
Configuring driver-vfs7552.test using configuration
Configuring driver-goodixmoc.test using configuration
Configuring driver-nb1010.test using configuration
Configuring driver-egis0570.test using configuration
Configuring driver-fpcmoc.test using configuration
Configuring fpi-device.test using configuration
Configuring fpi-ssm.test using configuration
Configuring fpi-assembling.test using configuration
Program test-generated-hwdb.sh found: YES (/home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/test-generated-hwdb.sh)
Program gdb found: NO
Program valgrind found: NO
Build targets in project: 29
WARNING: Deprecated features used:
 * 0.56.0: {'dependency.get_pkgconfig_variable'}
libfprint 1.94.6
  Drivers
    Drivers           : upektc_img
                        vfs5011
                        vfs7552
                        aes3500
                        aes4000
                        aes1610
                        aes1660
                        aes2660
                        aes2501
                        aes2550
                        vfs101
                        vfs301
                        vfs0050
                        etes603
                        egis0570
                        vcom5s
                        synaptics
                        elan
                        elanmoc
                        uru4000
                        upektc
                        upeksonly
                        upekts
                        goodixmoc
                        nb1010
                        fpcmoc
                        fpcmoh
                        elanspi
  User defined options
    auto_features     : enabled
    buildtype         : plain
    libexecdir        : lib
    prefix            : /usr
    sbindir           : bin
    wrap_mode         : nodownload
    python.bytecompile: 1
    b_lto             : true
    b_pie             : true
Found ninja-1.11.1 at /usr/bin/ninja
INFO: autodetecting backend as ninja
INFO: calculating backend command to run: /usr/bin/ninja -C /home/mollpo/libfprint-fpcmoh-git/src/build
ninja: Entering directory `/home/mollpo/libfprint-fpcmoh-git/src/build'
[134/134] Generating libfprint/udev-rules with a custom command (wrapped by meson to capture output)
==> Entering fakeroot environment...
==> Starting package()...
ninja: no work to do.
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/aes2501 to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/aes2501
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/aes2501/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/aes2501
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/aes2501/capture.pcapng to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/aes2501
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/aes2501/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/aes2501
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/aes3500 to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/aes3500
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/aes3500/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/aes3500
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/aes3500/capture.ioctl to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/aes3500
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/aes3500/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/aes3500
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elan to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elan
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elan/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elan
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elan/capture.ioctl to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elan
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elan/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elan
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elan/capture.ioctl-recording to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elan
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elan-cobo to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elan-cobo
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elan-cobo/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elan-cobo
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elan-cobo/capture.pcapng to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elan-cobo
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elan-cobo/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elan-cobo
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elanmoc to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elanmoc
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elanmoc/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elanmoc
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elanmoc/custom.py to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elanmoc
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elanmoc/custom.pcapng to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elanmoc
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elanspi to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elanspi
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elanspi/capture.ioctl to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elanspi
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elanspi/device-hidraw to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elanspi
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elanspi/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elanspi
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/elanspi/device-spi to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/elanspi
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/synaptics to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/synaptics
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/synaptics/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/synaptics
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/synaptics/custom.py to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/synaptics
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/synaptics/custom.pcapng to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/synaptics
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/upektc_img to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/upektc_img
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/upektc_img/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/upektc_img
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/upektc_img/capture.pcapng to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/upektc_img
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/upektc_img/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/upektc_img
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/upektc_img-tcs1s to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/upektc_img-tcs1s
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/upektc_img-tcs1s/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/upektc_img-tcs1s
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/upektc_img-tcs1s/capture.pcapng to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/upektc_img-tcs1s
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/upektc_img-tcs1s/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/upektc_img-tcs1s
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/uru4000-msv2 to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/uru4000-msv2
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/uru4000-msv2/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/uru4000-msv2
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/uru4000-msv2/capture.pcapng to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/uru4000-msv2
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/uru4000-msv2/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/uru4000-msv2
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/uru4000-4500 to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/uru4000-4500
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/uru4000-4500/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/uru4000-4500
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/uru4000-4500/capture.pcapng to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/uru4000-4500
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/uru4000-4500/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/uru4000-4500
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs0050 to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs0050
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs0050/capture-recorded.ioctl to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs0050
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs0050/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs0050
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs0050/capture.ioctl to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs0050
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs0050/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs0050
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs301 to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs301
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs301/capture-recorded.ioctl to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs301
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs301/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs301
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs301/capture.ioctl to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs301
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs301/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs301
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs5011 to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs5011
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs5011/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs5011
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs5011/capture.ioctl to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs5011
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs5011/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs5011
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs7552 to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs7552
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs7552/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs7552
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs7552/capture.ioctl to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs7552
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/vfs7552/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/vfs7552
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/goodixmoc to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/goodixmoc
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/goodixmoc/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/goodixmoc
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/goodixmoc/custom.py to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/goodixmoc
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/goodixmoc/custom.pcapng to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/goodixmoc
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/nb1010 to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/nb1010
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/nb1010/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/nb1010
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/nb1010/capture.ioctl to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/nb1010
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/nb1010/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/nb1010
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/egis0570 to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/egis0570
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/egis0570/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/egis0570
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/egis0570/capture.pcapng to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/egis0570
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/egis0570/capture.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/egis0570
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/fpcmoc to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/fpcmoc
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/fpcmoc/device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/fpcmoc
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/fpcmoc/custom.py to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/fpcmoc
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/fpcmoc/custom.pcapng to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/fpcmoc
Installing subdir /home/mollpo/libfprint-fpcmoh-git/src/libfprint/examples/prints to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/prints
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/examples/prints/whorl.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/prints
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/examples/prints/arch.jpg to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/prints
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/examples/prints/loop-right.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/prints
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/examples/prints/README to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/prints
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/examples/prints/tented_arch.jpg to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/prints
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/examples/prints/whorl.jpg to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/prints
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/examples/prints/tented_arch.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/prints
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/examples/prints/arch.png to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/prints
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/examples/prints/loop-right.jpg to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2/prints
Installing libfprint/fp-enums.h to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/include/libfprint-2
Installing libfprint/libfprint-2.so.2.0.0 to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/lib
Installing libfprint/70-libfprint-2.rules to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/lib/udev/rules.d
Installing libfprint/FPrint-2.0.gir to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/gir-1.0
Installing libfprint/FPrint-2.0.typelib to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/lib/girepository-1.0
Installing tests/test-fpi-device to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/lib/installed-tests/libfprint-2
Installing tests/test-fpi-ssm to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/lib/installed-tests/libfprint-2
Installing tests/test-fpi-assembling to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/lib/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/libfprint/fprint.h to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/include/libfprint-2/
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/libfprint/fp-context.h to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/include/libfprint-2/
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/libfprint/fp-device.h to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/include/libfprint-2/
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/libfprint/fp-image-device.h to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/include/libfprint-2/
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/libfprint/fp-image.h to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/include/libfprint-2/
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/libfprint/fp-print.h to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/include/libfprint-2/
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/data/autosuspend.hwdb to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/lib/udev/hwdb.d
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-aes2501.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-aes3500.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-elan.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-elan-cobo.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-elanmoc.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-elanspi.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-synaptics.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-upektc_img.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-upektc_img-tcs1s.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-uru4000-msv2.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-uru4000-4500.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-vfs0050.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-vfs301.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-vfs5011.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-vfs7552.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-goodixmoc.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-nb1010.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-egis0570.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/driver-fpcmoc.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/umockdev-test.py to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/lib/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/libfprint/tests/capture.py to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/lib/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/fpi-device.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/fpi-ssm.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/tests/fpi-assembling.test to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/share/installed-tests/libfprint-2
Installing /home/mollpo/libfprint-fpcmoh-git/src/build/meson-private/libfprint-2.pc to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/lib/pkgconfig
Installing symlink pointing to libfprint-2.so.2.0.0 to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/lib/libfprint-2.so.2
Installing symlink pointing to libfprint-2.so.2 to /home/mollpo/libfprint-fpcmoh-git/pkg/libfprint-fpcmoh-git/usr/lib/libfprint-2.so
Running custom install script '/usr/bin/meson --internal gtkdoc --sourcedir=/home/mollpo/libfprint-fpcmoh-git/src/libfprint --builddir=/home/mollpo/libfprint-fpcmoh-git/src/build --subdir=doc --headerdirs=/home/mollpo/libfprint-fpcmoh-git/src/libfprint/libfprint --mainfile=libfprint-docs.xml --modulename=libfprint-2 --moduleversion= --mode=auto --gtkdoc-scan=/usr/bin/gtkdoc-scan --gtkdoc-scangobj=/usr/bin/gtkdoc-scangobj --gtkdoc-mkdb=/usr/bin/gtkdoc-mkdb --gtkdoc-mkhtml=/usr/bin/gtkdoc-mkhtml --gtkdoc-fixxref=/usr/bin/gtkdoc-fixxref --htmlargs= --scanargs= --scanobjsargs= --gobjects-types-file=/home/mollpo/libfprint-fpcmoh-git/src/libfprint/doc/libfprint-2.types --fixxrefargs=--html-dir=share/gtk-doc/html@@--extra-dir=/usr/share/gtk-doc/html/glib@@--extra-dir=/usr/share/gtk-doc/html/gobject --mkdbargs= --html-assets= --content-files=/home/mollpo/libfprint-fpcmoh-git/src/libfprint/doc/intro.xml --expand-content-files=/home/mollpo/libfprint-fpcmoh-git/src/libfprint/doc/intro.xml --ignore-headers=config.h@@nbis-helpers.h@@fprint.h@@drivers@@nbis --installdir= --cc=cc --ld=cc --cflags=-I/home/mollpo/libfprint-fpcmoh-git/src/libfprint/. -I/home/mollpo/libfprint-fpcmoh-git/src/build/. -I/usr/include/gio-unix-2.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/libmount -I/usr/include/blkid -pthread -I/usr/include/gusb-1 -I/usr/include/libusb-1.0 -I/usr/include/json-glib-1.0 -I/usr/include/pixman-1 -I/usr/include/nss -I/usr/include/nspr -I/usr/include/gudev-1.0 -I/home/mollpo/libfprint-fpcmoh-git/src/libfprint/doc/../libfprint -I/home/mollpo/libfprint-fpcmoh-git/src/build/doc/../libfprint -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -Wall -Wcast-align -Wformat-nonliteral -Wformat-security -Wformat=2 -Wignored-qualifiers -Wlogical-op -Wmissing-declarations -Wmissing-format-attribute -Wmissing-include-dirs -Wmissing-noreturn -Wpointer-arith -Wshadow -Wswitch-enum -Wtype-limits -Wundef -Wunused -Werror=address -Werror=array-bounds -Werror=empty-body -Werror=init-self -Werror=int-to-pointer-cast -Werror=main -Werror=missing-braces -Werror=nonnull -Werror=redundant-decls -Werror=return-type -Werror=sequence-point -Werror=trigraphs -Werror=write-strings -fno-strict-aliasing -DGLIB_VERSION_MIN_REQUIRED=GLIB_VERSION_2_56 -DGLIB_VERSION_MAX_ALLOWED=GLIB_VERSION_2_56 -D_GNU_SOURCE \'-DG_LOG_DOMAIN="libfprint"\' -Wimplicit-function-declaration -Wmissing-prototypes -Wnested-externs -Wold-style-definition -Wstrict-prototypes -Werror=implicit -Werror=pointer-to-int-cast --ldflags=-L/home/mollpo/libfprint-fpcmoh-git/src/build/libfprint -Wl,-rpath,/home/mollpo/libfprint-fpcmoh-git/src/build/libfprint -L/home/mollpo/libfprint-fpcmoh-git/src/build/../libfprint/ -Wl,-rpath,/home/mollpo/libfprint-fpcmoh-git/src/build/../libfprint/ -lfprint-2 -lgio-2.0 -lgobject-2.0 -lglib-2.0 -lgusb -lusb-1.0 -ljson-glib-1.0 -lm -lpixman-1 -lssl3 -lsmime3 -lnss3 -lnssutil3 -lplds4 -lplc4 -lnspr4 /home/mollpo/libfprint-fpcmoh-git/src/libfprint/libfpcbep.so -lgudev-1.0 -Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection'
==> Tidying install...
  -> Removing libtool files...
  -> Purging unwanted files...
  -> Removing static library files...
  -> Stripping unneeded symbols from binaries and libraries...
  -> Compressing man and info pages...
==> Checking for packaging issues...
==> WARNING: Package contains reference to $srcdir
usr/share/installed-tests/libfprint-2/driver-fpcmoc.test
usr/share/installed-tests/libfprint-2/driver-aes3500.test
usr/share/installed-tests/libfprint-2/fpi-ssm.test
usr/share/installed-tests/libfprint-2/driver-vfs7552.test
usr/share/installed-tests/libfprint-2/fpi-assembling.test
usr/share/installed-tests/libfprint-2/driver-uru4000-4500.test
usr/share/installed-tests/libfprint-2/driver-egis0570.test
usr/share/installed-tests/libfprint-2/driver-uru4000-msv2.test
usr/share/installed-tests/libfprint-2/driver-goodixmoc.test
usr/share/installed-tests/libfprint-2/driver-vfs0050.test
usr/share/installed-tests/libfprint-2/driver-vfs5011.test
usr/share/installed-tests/libfprint-2/driver-aes2501.test
usr/share/installed-tests/libfprint-2/driver-synaptics.test
usr/share/installed-tests/libfprint-2/driver-elanmoc.test
usr/share/installed-tests/libfprint-2/fpi-device.test
usr/share/installed-tests/libfprint-2/driver-upektc_img.test
usr/share/installed-tests/libfprint-2/driver-upektc_img-tcs1s.test
usr/share/installed-tests/libfprint-2/driver-elan.test
usr/share/installed-tests/libfprint-2/driver-elan-cobo.test
usr/share/installed-tests/libfprint-2/driver-elanspi.test
usr/share/installed-tests/libfprint-2/driver-nb1010.test
usr/share/installed-tests/libfprint-2/driver-vfs301.test
usr/lib/libfprint-2.so.2.0.0
==> Creating package "libfprint-fpcmoh-git"...
  -> Generating .PKGINFO file...
==> WARNING: Library listed in 'provides' is not versioned: libfpcbep.so
  -> Generating .BUILDINFO file...
  -> Generating .MTREE file...
  -> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: libfprint-fpcmoh-git 1.94.6.r10.g2414dbd-1 (So 15 Okt 2023 10:42:28)
OK, it looks like everything installed OK, but
…seems dead. So let’s see what happens when it has been started:
sudo systemctl enable --now fprintd.service
And see if that works.
If you try this i get:
The unit files have no installation config (WantedBy=, RequiredBy=, UpheldBy=,
Also=, or Alias= settings in the [Install] section, and DefaultInstance= for
template units). This means they are not meant to be enabled or disabled using systemctl.
Possible reasons for having this kind of units are:
• A unit may be statically enabled by being symlinked from another unit's
  .wants/ or .requires/ directory.
• A unit's purpose may be to act as a helper for some other unit which has
  a requirement dependency on it.
• A unit may be started when needed via activation (socket, path, timer,
  D-Bus, udev, scripted systemctl call, ...).
• In case of template units, the unit is meant to be enabled with some
  instance name specified.
AHA!
Well now, try the following first:
sudo systemctl start fprintd.service
And, if there were no errors, try the enroll again.
But either way, provide the output of:
sudo systemctl status fprintd.service
…and:
sudo systemctl cat fprintd.service
…please.
● fprintd.service - Fingerprint Authentication Daemon
     Active: active (running) since Sun 2023-10-15 11:33:47 CEST; 20s ago
   Main PID: 18916 (fprintd)
      Tasks: 6 (limit: 17744)
     Memory: 3.6M
        CPU: 45ms
     CGroup: /system.slice/fprintd.service
             └─18916 /usr/lib/fprintd
Okt 15 11:33:47 mollpo-21ees00100 systemd[1]: Starting Fingerprint Authentication Daemon...
Okt 15 11:33:47 mollpo-21ees00100 systemd[1]: Started Fingerprint Authentication Daemon.
# /usr/lib/systemd/system/fprintd.service
[Unit]
Description=Fingerprint Authentication Daemon
Documentation=man:fprintd(1)
[Service]
Type=dbus
BusName=net.reactivated.Fprint
ExecStart=/usr/lib/fprintd
# Filesystem lockdown
ProtectSystem=strict
ProtectKernelTunables=true
ProtectKernelLogs=true
ProtectControlGroups=true
# This always corresponds to /var/lib/fprint
StateDirectory=fprint
StateDirectoryMode=0700
ProtectHome=true
PrivateTmp=true
SystemCallFilter=@system-service
It still dont find the devie on enroll
OK, I’m sorry, then. I don’t know where to go from here…
:sob:
Oke thank you for your help :slight_smile:
Online check of device ID 10a5:9800 shows this device as ‘Failed’ on multiple distributions, including Ubuntu
