i’ve been in this problem before and i know it’s because of sound drivers, where can i download sound drivers?
if you think there is another sulotion please tell me. i am new to manjaro
mhwd -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
and here is the terminal when i check sound devices
aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
sysdefault
Default Audio Device
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PipeWire Media Server)
usbstream:CARD=Device
USB PnP Sound Device
USB Stream Output
sysdefault:CARD=PCH
HDA Intel PCH, ALC221 Analog
front:CARD=PCH,DEV=0
Front output / input
surround21:CARD=PCH,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
hdmi:CARD=HDMI,DEV=0
HDA ATI HDMI, HDMI 0
HDMI Audio Output
usbstream:CARD=HDMI
HDA ATI HDMI
USB Stream Output
Follow the link in the fourth bullet point in the link above, which is this:
Please format command output as Preformatted text
this symbol: </> or CTRL+e
System is using PipeWire as default audio server
I suggest check audio devices detected in PipeWire
pactl list cards
ALSA data shows Realtek ALC221 Analog
audio codec and is probably using snd_hda_intel driver
Please post more information about system
inxi -SMAa
To further complicate your life; a little housekeeping…
Hi @OddToast and welcome to the Manjaro community.
As a new user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit. To that end, some or all these links will be invaluable:
- [How to] Request Support
- [How to] Find Error Logs
- [How to] Find System Information
[How to] Post Screenshots and Links- [How to] Post Command Output and File Content as Formatted Text
- The Tutorials category, generally
- Forum Rules
- Strict Forum Rules and Guidelines
And last, but not least, the Stable Update Announcements, which you should check frequently for important update related information. Occasionally an issue might be directly related to a particular update; it’s always best to check those announcements.
I hope this helps. Cheers.
hey buddy i was wondering if you fixed this yet? just an FYI its always wise to test things before installing to make sure things work
things i do before fully installing any linux distro
- check to see if i can connect to wifi
- go to youtube to make sure my audio and video drivers work and function properly
- then try out the environment as a whole and play around a bit to get used to the new environment and make sure apps load
doing these things before installing linux distros usually help negate these issues
I’m guessing not.
