Hi folks, my problem seems very similar to this one: All desktop and menu icons missing
After a big update (yesterday), all my desktop icons are missing, fonts are wrong in some parts of the plasma UI and the system becomes unresponsive regularly (when clicking the plasma menu, for example).
Here’s a screenshot:
I have tried the same suggestions as that one post but nothing has solved my issue.
UPDATE: Looks like this is also the same problem All Icons are missing
~ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.19.17-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=a582533b-2210-4461-a2c5-4145e00d6b92 rw quiet apparmor=1
security=apparmor resume=UUID=8e350d61-3e66-41e5-beef-08ee6e158eb7
udev.log_priority=3 ibt=off
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: G5 5590 v: N/A
Mobo: Dell model: 0F3T2G v: A02 serial: <superuser required> UEFI: Dell
v: 1.14.0 date: 10/20/2020
ID-1: BAT0 charge: 41.8 Wh (100.0%) condition: 41.8/60.0 Wh (69.7%)
volts: 17.0 min: 15.2 model: LGC-LGC3.985 DELL 8622M07 type: Li-ion
serial: <filter> status: full
RAM: total: 15.44 GiB used: 13.4 GiB (86.8%)
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1607 high: 2600 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 2600 2: 900 3: 900 4: 2600
5: 885 6: 900 7: 900 8: 2600 9: 900 10: 900 11: 2600 12: 2600
bogomips: 62431
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Dell
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Turing code: TUxxx process: TSMC 12nm
built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0c45:671f class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: HDMI-1-0 pos: right res: 1920x1080 dpi: 96
size: 510x290mm (20.08x11.42") diag: 587mm (23.1") modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1920x1080 hz: 144 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Sound API: ALSA v: k5.19.17-2-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Realtek vendor: Dell driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:2502
class-ID: 0200
IF: enp60s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 3d:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 63.0 C
IF: wlp61s0 state: up mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
chip-ID: 0cf3:e007 class-ID: e001
Local Storage: total: 476.94 GiB used: 106.22 GiB (22.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: IM2P33F3 NVMe 512GB
lanes: 4 type: SSD serial: <filter> rev: 92009161 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 169.05 GiB size: 165.33 GiB (97.80%)
used: 102.78 GiB (62.2%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
label: N/A uuid: a582533b-2210-4461-a2c5-4145e00d6b92
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: E99C-100C
ID-1: swap-1 type: partition size: 16 GiB used: 3.44 GiB (21.5%)
priority: -2 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 8e350d61-3e66-41e5-beef-08ee6e158eb7
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 150 MiB fs: vfat label: ESP
uuid: 90DF-09C9
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 272.75 GiB fs: ntfs label: OS
uuid: 0046E19046E186AE
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs
label: WINRETOOLS uuid: 52640450640438ED
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 16.1 GiB fs: ntfs label: Image
uuid: 42F00479F0047587
ID-6: /dev/nvme0n1p6 maj-min: 259:6 size: 1.29 GiB fs: ntfs
label: DELLSUPPORT uuid: 2644868E44866103
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-3:2 info: ZSA Moonlander Mark I type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.1 speed: 12 Mb/s power: 500mA
chip-ID: 3297:1969 class-ID: 0300
Device-2: 1-5:3 info: Microdia Integrated_Webcam_HD type: Video
Device-3: 1-11:4 info: Alienware LED controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.1 speed: 12 Mb/s
chip-ID: 187c:0550 class-ID: 0300 serial: <filter>
Device-4: 1-14:5 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e007
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-3: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 51.0 C pch: 63.0 C mobo: N/A
Processes: 285 Uptime: 1h 43m wakeups: 10 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 2443 libs: 461 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Zsh v: 5.9 running-in: yakuake inxi: 3.3.23
