Installed it by unzipping the tar file and running the studio.sh file. I have made a mistake and want to re-install it. Please help I am new to Manjaro!
Hi @adarsh, and welcome!
You can ditch the cry for help, seeing as everyone here knows that’s why you’re here.
That is something you shouldn’t do, not with Linux and not Manjaro in particular.
The only way to remove it now is to undo what the script did, so that would be necessary to start with.
I think you should go thorough this:
And then:
And keep this in mind for the Forum:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as preformatted text.
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
While this is generally true, in that particular case the start script does not install anything and runs the program from the folder. So if you want to reset your user settings in the program and start anew, all you have to do is to look at/delete the ~/.config/Google/… folder where the settings are kept.
But i am not sure you have to be developing anything under linux if have no basic understanding for the OS (yes, not reading the readme, not opening the .sh script, not knowing about the .config folder is lack of basic linux competence). Maybe stick with windows for now?
simply delete the files from your home
Once you delete the files from your home, android-studio is available from the AUR. The easiest way for you to install it would be via pamac GUI or in terminal:
pamac build android-studio
In that particular case it does not matter much, he will maybe have semiautomatic updates and an icon. That aur pkgbuild pretty much just unzips and copies the files in /opt.
His problem is the config folder.
