I tried several usb drives. I insert one, Manjaro detects it. After I open it in Nautilus system freezes and after some seconds crashes. Is there any way I can fix it or download another program for reading and editing usb drives? (the same happens if i open trash bin)
I solved it myself: These crashes are caused by an error in manjaro visible dock extension. Go to extensions and if it shows an issue (red sign and letters) just remove it and it should work.
Hi @fuavel8, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Erm…this wasn’t supposed to be a solution, so I’ve removed the tag.
There’s no such extension provided by Manjaro or otherwise. Do you mean Dash to Dock?
