Hello, I am using Manjaro KDE distro on my desktop without any problem but on my laptop I have always some freezes. I have to shutdown by pressing power button for 10sec.
And this problem only appears on KDE Distros. With Linux Mint or Ubuntu I don´t have this problem.
I tried different kernel from 4.19 to 5.18 all LTS but nothing improves the situation.
The thing is I don´t know any command that will show the probem in a journal.
Looking forward for your help
I just get a double freeze in 5 minutes.
I am posting the result of this command: journalctl --boot=-1 --priority=3 --catalog --no-pager
Sep 28 14:34:19 flyZ kernel: x86/cpu: SGX disabled by BIOS.
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/261)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/38146)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/2317)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/405)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/12297)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/2305)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/3333)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/29954)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/870)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/885)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/33025)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/65535)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/38145)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/1925)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/38408)
Sep 28 14:34:20 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/689)
Sep 28 14:34:26 flyZ kwin_x11[584]: kwin_xkbcommon: XKB: couldn't find a Compose file for locale "co_FR.UTF-8" (mapped to "co_FR.UTF-8")
Sep 28 14:34:27 flyZ kded5[581]: org.kde.plasma.dataengine.geolocation: error: "Unknown host location.services.mozilla.com: Host not found"
Hope someone can understand the problem
brahma
28 September 2022 19:47
4
this looks like the freezes could be because of baloo… go to system settings/search/file search and unchek all the options, click apply and see if it helped…
I don’t thinks there is anything relevant in there…
Just checking: did you actually force reboot as described before searching for those logs? Since you extracted logs from the previous boot.
It may also be relevant to monitor CPU, RAM and disk i/o usage for any resource consuming process.
I did deactivate baloo but it still freezes today :
Sep 29 14:03:09 flyZ kernel: x86/cpu: SGX disabled by BIOS.
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/261)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/38146)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/2317)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/405)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/12297)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/2305)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/3333)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/29954)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/870)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/885)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/33025)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/65535)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/38145)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/1925)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/38408)
Sep 29 14:03:10 flyZ kernel: i2c_hid_acpi i2c-HTIX5288:00: i2c_hid_get_input: incomplete report (27/689)
Sep 29 14:03:15 flyZ kwin_x11[567]: kwin_xkbcommon: XKB: couldn’t find a Compose file for locale “co_FR.UTF-8” (mapped to “co_FR.UTF-8”)
Sep 29 14:03:16 flyZ kded5[564]: org.kde.plasma.dataengine.geolocation: error: “Unknown host location.services.mozilla: Host not found”
Yes I force reboot and then type the command.
Do you have an idea, how to solve this? Brahma´s solution did not work
How I do that ? Is it possible to keep data after boot?
You can use the system monitor and applets shipped with KDE Plasma.
You can also save the monitoring into a file. This will create a rather big file on the long run, so you should modulate the frequency of update (in seconds). For updating every 30s:
top -b -d30 > ~/top.log
Use Ctrl +C to kill the process.
brahma
30 September 2022 06:50
10
provide also system info:
inxi -Faz
When I started to use Manjaro KDE 10 months ago, I always got the whole system freezed at simple launch any game (be this ARK or even Rocket League) and the only thing I noticed after updating all graphical drivers (Nvidia, proprietary) was missing swap partition or file by default after installation (I also got this in KDE System Monitor), so when I create it, for my 8GB DDR3/1333 it was the fix I needed.
If your problem is RAM this also may help you too. You can just start the Recourse Monitor and watch at this before system freeze to understand what gets stuck at 90+% (CPU, GPU, RAM or disks i/o).
toast
30 September 2022 09:27
12
Is it by any chance an MSI laptop, as I had the same problem with an MSI laptop. Wouldn’t run Manjaro KDE but was ok with Mint, Manjaro Gnome.
I never got to the bottom of the problem. I just got another laptop. My gut feeling was that there was some hardware in it that did not get on with KDE.
Disabling baloo helped but still I was never able to get Manjaro KDE to run very well.
Kernel: 5.18.19-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=4e26535a-4788-4032-9938-a40ba48c5637 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop Mobo: N/A model: N/A serial: <superuser required>
UEFI: American Megatrends v: G13GR100_8G_R4 date: 04/29/2020
ID-1: BAT0 charge: 29.6 Wh (77.9%) condition: 38.0/N/A Wh volts: 7.6
min: N/A model: N/A type: Unknown serial: <filter> status: discharging
Info: model: Intel Celeron J4115 bits: 64 type: MCP arch: Goldmont Plus
level: v3 built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122)
stepping: 1 microcode: 0x3C
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 985 high: 1120 min/max: 800/2500 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1120 2: 967 3: 846
4: 1010 bogomips: 14288
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0300
Device-2: Realtek USB 2.0 Camera type: USB driver: uvcvideo bus-ID: 1-8:5
chip-ID: 0bda:0561 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0877 built: 2019 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:3198 class-ID: 0403
Sound Server-1: ALSA v: k5.18.19-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 10ec:c821
class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
IF-ID-1: enp0s21f0u4 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Google Nexus/Pixel Device (tether) type: USB driver: rndis_host
v: kernel bus-ID: 1-4:2 chip-ID: 18d1:4ee3 class-ID: 0a00 serial: <filter>
Device-2: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-7:4 chip-ID: 0bda:c821 class-ID: e001 serial: <filter>
Report: ID: hci0 rfk-id: 1 state: up address: <filter>
Local Storage: total: 476.94 GiB used: 416.34 GiB (87.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Smart Modular Tech.
model: ShanDianZhe-512GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 8A0
scheme: GPT
ID-1: / raw-size: 65.46 GiB size: 63.88 GiB (97.59%) used: 52.41 GiB
(82.1%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 11.4 MiB
(2.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 214 Uptime: 10m wakeups: 1 Memory: 7.59 GiB used: 2.35 GiB
(30.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1322 pm: pacman pkgs: 1317
libs: 372 tools: pamac pm: flatpak pkgs: 5 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.21
Thanks for your feedback, but I don´t have a msi laptop. It´s a Chinese crappy brand : kuu k2
brahma
1 October 2022 06:39
15
you are using this kernel which is going to be end of life, so install the newer 5.19 and try with it, maybe it will help with the freezes …
also provide logs:
journalctl -b0 -p4 --no-pager
sudo dmesg -l err,warn,emerg,alert,crit
system
Closed
19 October 2022 15:08
16
