I can't suspend my system
I can’t suspend or hibernate my system.
after I suspend (or hibernate) my system, it’s goes to a black screen and then I can’t turn on the system again. The noteworthy point is that my cooling fans are working hard and my light check is on (my computer is on) and to fix that I have to reboot my computer.
important information about my system are listed below:
model name : Intel(R) Pentium(R) CPU B950 @ 2.10GHz
lsb_release -a
LSB Version:	n/a
Distributor ID:	ManjaroLinux
Description:	Manjaro Linux
Release:	23.0.4
Codename:	Uranos
sudo fdisk -l /dev/sda
Disk /dev/sda: 698.64 GiB, 750156374016 bytes, 1465149168 sectors
Disk model: WDC WD7500BPVT-8
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0xc5a29d8b
Device     Boot    Start        End    Sectors   Size Id Type
/dev/sda1  *        2048     616447     614400   300M  c W95 FAT32 (LBA)
/dev/sda2         616448   12904447   12288000   5.9G 82 Linux swap / Solaris
/dev/sda3       81922048 1465145343 1383223296 659.6G  7 HPFS/NTFS/exFAT
/dev/sda4       12904448   81922047   69017600  32.9G 83 Linux
Partition table entries are not in disk order.
uname -a
Linux manjaro 6.1.55-1-MANJARO #1 SMP PREEMPT_DYNAMIC Sat Sep 23 12:13:56 UTC 2023 x86_64 GNU/Linux
the output of inxi --full --admin --filter --width :
  Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=f2734e89-3eb2-441f-bf73-e680b9544662 rw quiet splash apparmor=1
    security=apparmor resume=UUID=53313838-cd3e-4295-8e2a-a62e8476445c
    udev.log_priority=3 nouveau.modeset=0
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: K84L v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: K84L v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: K84L.207 date: 09/26/2011
  Info: model: Intel Pentium B950 bits: 64 type: MCP arch: Sandy Bridge
    level: v2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42)
    stepping: 7 microcode: 0x2F
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 2 MiB
    desc: 1x2 MiB
  Speed (MHz): avg: 798 min/max: 800/2100 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 798 2: 798 bogomips: 8385
  Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  Type: itlb_multihit status: KVM: VMX unsupported
    STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: ASUSTeK driver: i915 v: kernel arch: Gen-6 code: Sandybridge
    process: Intel 32nm built: 2011 ports: active: LVDS-1
    empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0106
    class-ID: 0300
  Device-2: Alcor Micro Asus Integrated Webcam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.2:4
    chip-ID: 058f:a014 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31") monitors: <missing: xrandr>
  Monitor-1: LVDS-1 model: Seiko Epson 0x3849 built: 2011 res: 1366x768
    dpi: 112 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1366x768
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
    vendor: ASUSTeK 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1c20 class-ID: 0403
  API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.80 status: off tools: pw-cli
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: AzureWave
    AW-NB037H 802.11bgn driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:002b class-ID: 0280
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: a000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: down mac: <filter>
  Device-1: Qualcomm Atheros AR3011 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.1:6 chip-ID: 0cf3:3005
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 698.64 GiB used: 25.14 GiB (3.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD7500BPVT-80HXZT3 size: 698.64 GiB block-size: physical: 4096 B
    logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 1A01 scheme: MBR
  ID-1: / raw-size: 32.91 GiB size: 32.1 GiB (97.53%) used: 24.78 GiB (77.2%)
    fs: ext4 dev: /dev/sda4 maj-min: 8:4
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-1: swap-1 type: partition size: 5.86 GiB used: 368.8 MiB (6.1%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2
  System Temperatures: cpu: 54.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2300
  Processes: 197 Uptime: 5h 30m wakeups: 8 Memory: total: 4 GiB
  available: 3.73 GiB used: 2.77 GiB (74.3%) Init: systemd v: 254
  Packages: pm: pacman pkgs: 1259 libs: 402 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 running-in: xfce4-terminal inxi: 3.3.30
the output of cat /etc/systemd/sleep.conf :
[Sleep]
#AllowSuspend=yes
#AllowHibernation=yes
#AllowSuspendThenHibernate=yes
#AllowHybridSleep=yes
#SuspendMode=
#SuspendState=mem standby freeze
#HibernateMode=platform shutdown
#HibernateState=disk
#HybridSleepMode=suspend platform shutdown
#HybridSleepState=disk
#HibernateDelaySec=
#SuspendEstimationSec=60min
Will probably be update :hammer_and_wrench: …
Hi @alimirzaeimajd, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Please update your system first. Your system and your kernel are already hopelessly out of date. This below is what the lsb_release and uname commands should yield… :point_down:
[nx-74205:/dev/pts/3][/home/aragorn]
[aragorn] >  lsb_release -a
LSB Version:    n/a
Release:        23.1.3
Codename:       Vulcan
[aragorn] >  uname -r
6.1.71-1-MANJARO
Manjaro is a (curated) rolling-release distribution and must be kept up to date — we cannot offer any support for systems which have not been updated in a long time, or which have only partly been updated.
Please also take the time to read the following short essay… :point_down:
If for whatever reason you do not or cannot keep your system up to date — and maintained, because you probably also have lots of .pacnew files to tend to — then you will be better off switching to a point-release distribution such as Debian, Mint, Ubuntu, Mageia, AlmaLinux, Rocky Linux, et al.
Please do not include screenshots of text !
Instead include the text by copy and paste !
Pictures are
  • not searchable in the forum and are
  • heavyweight on the server and
  • we can’t respond to a part of a picture by marking it
:footprints:
hi, thank you for your answer.
for your reply I should say I’m not an absolute beginner in linux, not professional but not beginner. of course I’m absolute beginner in manjaro forums. (this is my first post)
and yes I have to update my system.
Before anything else.
:wink:
It is important that you do so. This alone already could solve your problem. I’m not saying that it will, but it might, for instance if you are using a proprietary graphics driver.
It may also be worth trying a later kernel version — 6.7 is also an LTS kernel — but of course, you should update your system first. :point_down:
sudo pacman-mirrors -f && sudo pacman -Syu
sudo mhwd-kernel -i linux67
Then, upon rebooting, select the 6.7 kernel from the “Advanced options for Manjaro Linux” menu in GRUB. Leave the 6.1 kernel installed — it will be updated to the latest patch level by the pacman command above anyway.
thank you very much for your strong answer.
trying to be better…
That is new info … last time I checked it is 6.6.
6.7 is the latest ‘stable’ kernel.
My mistake. :facepalm:
Still, OP can choose to try 6.7 if it might solve the suspend problem. :man_shrugging:
Have you checked for BIOS updates?
You have an msdos parted disk but booted in UEFI mode? Never seen before. Or do you still boot in BIOS mode and have - without any meaning - just mounted /dev/sda1 as /boot/efi? Usually, msdos coresponds to BIOS boot or you have a GPT parted disk which could be used with UEFI boot mode or kind of “mis-used” in BIOS boot mode…
thank’s for your helpful answer
