I can't connect to wifi because of a problem in the Network driver
I tried with inxi -Nazy
 Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
   vendor: Hewlett-Packard driver: rtw_8821ce v: kernel modules: rtw88_8821ce
   pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0
   chip-ID: 10ec:c821 class-ID: 0280
Output to inxi --admin
CPU: 6-core AMD Ryzen 5 5625U with Radeon Graphics (-MT MCP-)
speed/min/max: 400/400/4388 MHz Kernel: 6.12.4-1-MANJARO x86_64 Up: 53m
Mem: 2.4/14.97 GiB (16.1%) Storage: 476.94 GiB (2.1% used) Procs: 289
Shell: Bash 5.2.37 inxi: 3.3.36
Output to inxi --verbosity=8
 Host: tomm-hplaptop15seq3xxx Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64
   compiler: gcc v: 14.2.1 clocksource: tsc avail: hpet,acpi_pm
   root=UUID=e4551671-5815-4205-96a4-9afefb13280c rw quiet splash apparmor=1
 Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
   with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
 Type: Laptop System: HP product: HP Laptop 15s-eq3xxx v: N/A
 Mobo: HP model: 89FC v: 12.17 serial: <superuser required>
   part-nu: 6X4A4PA#ABG uuid: <superuser required> UEFI: AMI v: F.17
   date: 12/20/2023
 ID-1: BAT0 charge: 20.7 Wh (51.9%) condition: 39.9/39.9 Wh (100.0%)
   volts: 12.0 min: 11.3 model: HP Primary type: Li-ion serial: SerialNumber
   status: charging
 System RAM: total: 16 GiB available: 14.97 GiB used: 2.41 GiB (16.1%)
 Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
 Device-1: Bottom - Slot 1 (left) type: DDR4 detail: synchronous
   unbuffered (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check
   curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
   manufacturer: Micron Technology part-no: 4ATF1G64HZ-3G2F1 serial: D0F6551B
 Device-2: Bottom - Slot 2 (right) type: DDR4 detail: synchronous
   curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Hynix
   part-no: HMA81GS6DJR8N-XN serial: 968DAD75
 Info: model: AMD Ryzen 5 5625U with Radeon Graphics bits: 64 type: MT MCP
   arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
   microcode: 0xA500011
   desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
 Speed (MHz): avg: 400 min/max: 400/4388 boost: enabled scaling:
   driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400
   4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
   bogomips: 55116
   vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
   xtopology
   affected
 Device-1: Advanced Micro Devices [AMD/ATI] Barcelo vendor: Hewlett-Packard
   driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
   built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
   speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0
   chip-ID: 1002:15e7 class-ID: 0300 temp: 45.0 C
 Display: x11 server: X.org v: 1.21.1.14 compositor: xfwm4 v: 4.18.0
   driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
   dri: radeonsi gpu: amdgpu display-ID: :0.0
   note: <missing: xdpyinfo/xrandr>
 Monitor-1: eDP-1 model: AU Optronics 0x499f built: 2021 res: 1920x1080
   dpi: 142 gamma: 1.2 chroma: red: x: 0.561 y: 0.337 green: x: 0.345 y: 0.576
   blue: x: 0.161 y: 0.125 white: x: 0.314 y: 0.329
   size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
   modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
   1024x768, 800x600, 640x480
 EDID-Warnings: 1: parse_edid: unknown flag 2
   device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
 API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
   renoir LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:15e7
   memory: 500 MiB unified: no
 Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
   Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
   speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1
   chip-ID: 1002:1637 class-ID: 0403
 Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
   vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
   alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
   snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
   snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3
   speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
   chip-ID: 1022:15e2 class-ID: 0480
   speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6
   chip-ID: 1022:15e3 class-ID: 0403
 API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
 Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
 IF: wlo1 state: down mac: 56:5d:b1:27:77:d7
 IF-ID-1: enp3s0f4u2 state: unknown speed: -1 duplex: half
   mac: 7a:9e:09:52:d7:df
 IP v4: 192.168.240.41/24 type: dynamic noprefixroute scope: global
   broadcast: 192.168.240.255
 IP v6: 2405:6e00:2631:2670:f0e0:cdd2:3dec:3637/64
 IP v6: fe80::61df:210e:d431:aa5c/64 type: noprefixroute scope: link
 WAN IP: 120.16.42.148
 Device-1: OPPO A40 driver: rndis_host v: kernel type: USB rev: 2.1
   speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 22d9:276a
   class-ID: 0a00 serial: c169d347
 Local Storage: total: 476.94 GiB used: 9.92 GiB (2.1%)
 ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: solidgm model: SSDPFKNU512GZH
   size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
   lanes: 4 tech: SSD serial: PHEH338005M1512A fw-rev: HPS3 temp: 29.9 C
   scheme: GPT
 ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 9.92 GiB (2.1%)
   fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
   uuid: e4551671-5815-4205-96a4-9afefb13280c
   used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
   uuid: F2C7-6C75
 Device-1: 3-2:3 info: OPPO A40 type: bluetooth,CDC-data driver: rndis_host
   interfaces: 2 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
   power: 500mA chip-ID: 22d9:276a class-ID: 0a00 serial: c169d347
 System Temperatures: cpu: 56.5 C mobo: N/A gpu: amdgpu temp: 46.0 C
 Fan Speeds (rpm): fan-1: 0 fan-2: 0
 Packages: pm: pacman pkgs: 1068 libs: 321 tools: pamac,yay pm: flatpak
   pkgs: 0
   1: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
   2: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
   3: https://mirrors2.manjaro.org/stable/$repo/$arch
   4: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
   5: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
   6: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
   7: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
   8: https://mirror.koddos.net/manjaro/stable/$repo/$arch
   9: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
   10: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
   11: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
   12: http://manjaro.grena.ge/stable/$repo/$arch
   13: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
   14: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
   15: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
   16: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
   17: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
   18: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
   19: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
   20: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
   21: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
   22: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
   23: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
   24: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
   25: https://mirror.init7.net/manjaro/stable/$repo/$arch
   26: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
   27: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
   28: https://mirror.seahost.de/manjaro/stable/$repo/$arch
   29: https://manjaro.kurdy.org/stable/$repo/$arch
   30: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
   31: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
   32: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
   33: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
   34: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
   35: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
   36: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
   37: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
   38: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
   39: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
   40: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
   41: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
   42: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
   43: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
   44: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
   45: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
   46: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
   47: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
   48: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
   49: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
   50: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
   51: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
   52: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
   53: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
   54: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
   55: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
   56: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
   57: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
   58: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
   59: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
   60: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
   61: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
   62: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
   63: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
   64: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
   65: https://mirror.funami.tech/manjaro/stable/$repo/$arch
   66: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
   67: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
   68: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
   69: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
   70: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
   71: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
   72: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
   73: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
   74: http://mirror.fcix.net/manjaro/stable/$repo/$arch
   75: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
   76: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
   77: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
   78: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
   79: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
   80: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
   81: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
   82: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
   83: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
   84: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
   85: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
   86: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
   87: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
   88: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
   89: https://muug.ca/mirror/manjaro/stable/$repo/$arch
   90: https://mirror.easyname.at/manjaro/stable/$repo/$arch
   91: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
   92: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
   93: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
   94: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
   95: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
   96: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
   97: https://mirror.23m.com/manjaro/stable/$repo/$arch
   98: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
   99: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
   100: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
   101: https://linorg.usp.br/manjaro/stable/$repo/$arch
   102: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
   103: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
   104: https://repos.silknet.com/manjaro/stable/$repo/$arch
   105: https://mirror.dc.uz/manjaro/stable/$repo/$arch
   106: https://mirror.zetup.net/manjaro/stable/$repo/$arch
   107: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
   108: https://mirrors.manjaro.org/repo/stable/$repo/$arch
   109: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
   110: https://manjaro.ynh.ovh/stable/$repo/$arch
   111: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
   112: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
   113: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
   114: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
   115: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
   116: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
   117: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
   118: http://manjaro.mirror.ac.za/stable/$repo/$arch
   119: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
   120: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
   121: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
   122: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
   123: https://mirrors.netix.net/manjaro/stable/$repo/$arch
   124: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
   125: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
   126: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
   127: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
   128: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
   129: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
   130: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
   131: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
   132: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
 CPU top: 5 of 285
 1: cpu: 12.2% command: firefox pid: 1662 mem: 789.9 MiB (5.1%)
 2: cpu: 2.9% command: firefox pid: 8150 mem: 299.3 MiB (1.9%)
 3: cpu: 2.1% command: firefox pid: 7109 mem: 354.5 MiB (2.3%)
 4: cpu: 2.0% command: Xorg pid: 865 mem: 156.3 MiB (1.0%)
 5: cpu: 1.2% command: firefox pid: 4191 mem: 189.4 MiB (1.2%)
 Memory top: 5 of 285
 1: mem: 789.9 MiB (5.1%) command: firefox pid: 1662 cpu: 12.2%
 2: mem: 354.5 MiB (2.3%) command: firefox pid: 7109 cpu: 2.1%
 3: mem: 299.3 MiB (1.9%) command: firefox pid: 8150 cpu: 2.9%
 4: mem: 199.5 MiB (1.3%) command: firefox pid: 1890 cpu: 1.1%
 5: mem: 189.4 MiB (1.2%) command: firefox pid: 4191 cpu: 1.2%
 Processes: 285 Power: uptime: 55m states: freeze,mem,disk suspend: s2idle
   image: 5.97 GiB services: upowerd,xfce4-power-manager Init: systemd v: 256
 Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: xfce4-terminal
   inxi: 3.3.36
output to inxi --filter
speed/min/max: 400/400/4388 MHz Kernel: 6.12.4-1-MANJARO x86_64 Up: 57m
Mem: 2.44/14.97 GiB (16.3%) Storage: 476.94 GiB (2.1% used) Procs: 287
Shell: Bash inxi: 3.3.36
Output to inxi --no-host
speed/min/max: 400/400/4388 MHz Kernel: 6.12.4-1-MANJARO x86_64 Up: 59m
Mem: 2.4/14.97 GiB (16.1%) Storage: 476.94 GiB (2.1% used) Procs: 287
Output to inxi --width
speed/min/max: 400/400/4388 MHz Kernel: 6.12.4-1-MANJARO x86_64 Up: 1h 0m
Mem: 2.43/14.97 GiB (16.2%) Storage: 476.94 GiB (2.1% used) Procs: 287
Hi @delfi770, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Edit:
According to what I could find on Realtek Semiconductor RTL8821CE 802.11ac PCIe Wireless Network Adapter it would seem this NIC is…a problem child…so I don’t know if there is anything that can be done, really. Except perhaps trying a different kernel. For that, see:
https://wiki.manjaro.org/index.php/Manjaro_Kernels/en
ooh ok, thx, I’ll try with a different kernel
By the way after installing 7 different kernels I arrived to the Linux 6.6.63 rt46-3 that worked but then after 2 minutes stopped working, and now I’m with Linux 6.11_rt7-3 and is currently working good.
uh yeah, as I thought it’s happen the same to Linux 6.11_rt7-3 and now I tried all kernel and nothing work. What else could I do?
Short of buying and using a relatively cheap USB WiFi dongle, I have no idea. In fact, I don’t think there’s anything else to do.
Or switch to copper.
Sorry.
:sob:
See → AUR (en) - rtl8821ce-dkms-git
Remove all kernels except linux612
Then install support packages
sudo pacman -Syu linux612 dkms base-devel --needed
Clone the package and build
git clone https://aur.archlinux.org/packages/rtl8821ce-dkms-git
cd rtl8821ce-dkms-git
makepkg -iscC
Note:
thanks for the answer, but unluckily after reboot it, it didn’t work
For contest this was the code it gave me after the
makepkg -iscC
==> Package creation: rtl8821ce-dkms-git 1.0.5.r36.gca4abd8-1 (Sat 28 Dec 2024 20:31:54)
==> Checking dependencies during running boot...
==> Dependency checking during ongoing compilation...
==> Source downloading in progress...
  -> Cloning rtl8821ce git repository in progress...
Clone into the bare repository '/home/tomm/rtl8821ce-dkms-git/rtl8821ce' in progress...
remote: Enumerating objects: 1973, done.
remote: Counting objects: 100% (236/236), done.
remote: Compressing objects: 100% (156/156), done.
remote: Total 1973 (delta 111), reused 160 (delta 80), pack-reused 1737 (from 1)
Receiving objects: 100% (1973/1973), 6.11 MiB | 4.57 MiB/s, done.
Delta resolution: 100% (1077/1077), done.
==> Validation of source file with sha256sums...
    rtl8821ce ... Ignored
==> Removal of existing $srcdir/ directory in progress...
==> Source extraction in progress...
  -> Creating a working copy of the rtl8821ce git repository in progress...
Clone to 'rtl8821ce' in progress...
done.
==> Starting pkgver() in progress...
==> Updated version: rtl8821ce-dkms-git 1.0.5.r172.gf119398-1
==> I enter the fakeroot environment...
==> Starting package() in progress...
==> Removing superfluous data in progress...
  -> Removing libtool files in progress...
  -> Removing unwanted files in progress...
  -> Removing files from static libraries...
  -> Removal of unnecessary symbols from binaries and libraries in progress...
  -> Compression of man and info pages in progress...
==> Control for release of packages in progress...
==> “rtl8821ce-dkms-git” package creation in progress...
  -> Generation of the .PKGINFO file in progress...
  -> Generation of the .BUILDINFO file in progress...
  -> Generation of the .MTREE file in progress...
  -> Packet compression in progress...
==> Exiting the fakeroot environment.
==> Compilation finished: rtl8821ce-dkms-git 1.0.5.r172.gf119398-1 (Sat 28 Dec 2024 20:32:03)
==> Installing rtl8821ce-dkms-git package with pacman -U running...
[sudo] tomm password:
package loading in progress...
warning: rtl8821ce-dkms-git-1.0.5.r172.gf119398-1 is updated but will be reinstalled
dependency resolution in progress...
search for conflicting packages in progress...
Packages (1) rtl8821ce-dkms-git-1.0.5.r172.gf119398-1
Total size of packages to be installed: 30.17 MiB
Net size of the update: 0.00 MiB
:: Do you want to proceed with the installation? [S/n] s
(1/1) verification of the keys in the keyring [##############################] 100%.
(1/1) verification of package integrity [##############################] 100%
(1/1) loading of package files [##############################] 100%
(1/1) checking for ongoing conflicts [##############################] 100%
(1/1) checking for available disk space [##############################] 100%
:: Execution of pre-transaction hooks...
(1/2) Creating timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/2) Remove upgraded DKMS modules.
==> dkms remove --no-depmod rtl8821ce/1.0.5.r172.gf119398 -k 4.19.325-1-MANJARO
==> dkms remove --no-depmod rtl8821ce/1.0.5.r172.gf119398 -k 6.12.4-1-MANJARO
(1/1) reinstalling rtl8821ce-dkms-git [##############################] 100%.
(1/3) Arming ConditionNeedsUpdate...
(2/3) Install DKMS modules
==> dkms install --no-depmod rtl8821ce/1.0.5.r172.gf119398 -k 6.12.4-1-MANJARO
==> dkms install --no-depmod rtl8821ce/1.0.5.r172.gf119398 -k 4.19.325-1-MANJARO
==> depmod 4.19.325-1-MANJARO
==> depmod 6.12.4-1-MANJARO
(3/3) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-4.19-x86_64 -g /boot/initramfs-4.19-x86_64.img
==> Starting build: '4.19.325-1-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [microcode]
  -> Running build hook: [kms]
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [plymouth]
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-4.19-x86_64.img'
  -> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'fallback'
  -> -k /boot/vmlinuz-4.19-x86_64 -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-4.19-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
  -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
==> Starting build: '6.12.4-1-MANJARO'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'fallback'
  -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64-fallback.img'
I noticed just now that I still had another kernel
It would seem you didn’t do:
yeah, noticed after, I can’t do git clone anymore because it tells me it already exists, what should I do?
Remove the cloned directory and try again:
rm rtl8821ce-dkms-git
Or simply skip the cloning and go directly to:
makepkg -iscC
still didn’t work :confused:
output:
==> Package creation: rtl8821ce-dkms-git 1.0.5.r172.gf119398-1 (Sat 28 Dec 2024 21:09:17)
==> Checking dependencies during ongoing compilation...
 -> Updating rtl8821ce git repository in progress...
==> Validation of source files with sha256sums...
==> Removing existing $srcdir/ directory in progress...
done.
==> WARNING: Already created package, installation of existing package in progress...
==> Installing rtl8821ce-dkms-git package with pacman -U in progress...
(1/1) verification of the keys in the port...  [######################] 100%
(1/1) verification of package integrity [######################] 100%
(1/1) loading of package files [######################] 100%
(1/1) checking for ongoing conflicts [######################] 100%
(1/1) checking for available disk space [######################] 100%
(1/1) reinstalling rtl8821ce-dkms-git [######################] 100%.
Welp, maybe someone else sees something, if there’s something to see. I, however, don’t see anything and neither do I have much hoped to get it working. (Although I hope to be wrong on that account.)
Technically the driver build and install as expected - but to ensure the system recognize the driver you should restart the system.
You can see which kernels you have installed
mhwd-kernel -li
When you have removed all excess kernels restart the system.
The reason for doing this is to avoid confusion as to which kernel is automagically used at boot time.
Currently running: 6.12.4-1-MANJARO (linux612)
   * linux612
It still tell me no network devices available
:man_shrugging: throwing some ideas - but I have no clue.
Be sure to check the hardware wifi toggle - usually a Fn+F-key combination.
Check that wifi is not softblocked
rfkill
Realtek and MediaTek hardware often have flaky Linux support
