I Cant Change My Display Resolution
My Monitor Support Resolution 1440x900 and I Cant Find It please i want quick answer .
My CPU :
Architecture:            x86_64
  CPU op-mode(s):        32-bit, 64-bit
  Address sizes:         36 bits physical, 48 bits virtual
  Byte Order:            Little Endian
CPU(s):                  2
  On-line CPU(s) list:   0,1
Vendor ID:               GenuineIntel
  Model name:            Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
    CPU family:          6
    Model:               23
    Thread(s) per core:  1
    Core(s) per socket:  2
    Socket(s):           1
    Stepping:            10
    CPU(s) scaling MHz:  67%
    CPU max MHz:         3000.0000
    CPU min MHz:         1998.0000
    BogoMIPS:            5986.21
    Flags:               fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mc
                         a cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht
                         tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts
                          rep_good nopl cpuid aperfmperf pni dtes64 monitor ds_c
                         pl vmx smx est tm2 ssse3 cx16 xtpr pdcm sse4_1 xsave la
                         hf_lm pti tpr_shadow vnmi flexpriority vpid dtherm
Virtualization features:
  Virtualization:        VT-x
Caches (sum of all):
  L1d:                   64 KiB (2 instances)
  L1i:                   64 KiB (2 instances)
  L2:                    6 MiB (1 instance)
NUMA:
  NUMA node(s):          1
  NUMA node0 CPU(s):     0,1
  Itlb multihit:         KVM: Mitigation: VMX disabled
  L1tf:                  Mitigation; PTE Inversion; VMX conditional cache flushe
                         s, SMT disabled
  Mds:                   Vulnerable: Clear CPU buffers attempted, no microcode;
                         SMT disabled
  Meltdown:              Mitigation; PTI
  Mmio stale data:       Unknown: No mitigations
  Retbleed:              Not affected
  Spec store bypass:     Vulnerable
  Spectre v1:            Mitigation; usercopy/swapgs barriers and __user pointer
  Spectre v2:            Mitigation; Retpolines, STIBP disabled, RSB filling, PB
                         RSB-eIBRS Not affected
  Srbds:                 Not affected
  Tsx async abort:       Not affected
My GPU :
Intel Corporation 4 Series Chipset Integrated Graphics Controller
The GPU Configuration Are Installed .
Hi @EliteHunter, and welcome!
We all want quick answers. That’s the way things are, whether we like it or not.
Unfortunately, it is also one of the way things are that we can’t always have what we want.
The issue is most likely because you don’t have the correct GPU drivers installed. But we can’t help without more information. To that end, please see:
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
i Did It by cvt and xrandr
